Staro 25.03.2019., 09:30   #1
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,744
(riješeno) Win 7 ne prepoznaje Gigabyte m.2 NVME SSD na Asus Z170-A - missing driver
Pozdrav ekipa,
Stigao mi je Gigabyte m.2 NVME 512GB drive. Instalirao sam ga na Asus Z170-A ploču sa zadnjim BIOS-om. BIOS vidi disk, ali kad bootam postojeću Windows 7 x64 instalaciju sa SATA SSD-a, windowsi prijave missing driver za PCI device - što je vjerojatno NVME driver.
Ova novi M.2 drive nije vidljiv u Disk managementu.
Update ne pronalazi driver. Gigabyte ima samo utility tool za Windows 10. Na Asusu nisam našao driver za skinuti.
Ima tko ideju kako to riješiti?
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
Zadnje izmijenjeno od: estugarda. 25.03.2019. u 09:42.
estugarda je offline   Reply With Quote
Staro 25.03.2019., 09:37   #2
dewil23
dewil23's Avatar
Postovi: 323
Jel uopće Win 7 podržava NVME i m.2?
dewil23 je offline   Reply With Quote
Staro 25.03.2019., 09:37   #3
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Dobro pitanje.
Ja sam mislio da podrzava.
Sent from my SM-N950F using Tapatalk
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 25.03.2019., 10:42   #4
nino
nino's Avatar
Postovi: 12,613
Autor dewil23 Pregled postova
Podrzava.
Sent from my CLT-L29 using Tapatalk
Staro 25.03.2019., 10:46   #5
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Koje pizde.
Ukinuli su podršku za NVME na Windows 7. Još jedan pokušaj prisilnog tjeranja na 10-ku.
Postojao je službeni hotfix za NVME.
I onda, kad se klikne na download link:
This hotfix is no longer available
This hotfix has been discontinued. Instead, you can upgrade to Windows 10 and get the most up-to-date security and other features built right in.
Srećom, može se naći na netu hotfix;
https://www.sevenforums.com/drivers/...me-driver.html
Instalirao sam. Windowsi vide NVME drive.
Javim kad istestiram. Nadam se da će raditi NVME kako treba.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 25.03.2019., 11:04   #6
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,362
a zake ne pređeš na 10, nije viš tak strašna
Staro 25.03.2019., 11:07   #7
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Na poslu je stroj. Poslovna politika firme, a od sad je i pitanje mojeg osobnog principa.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 25.03.2019., 11:30   #8
Postovi: 33,978
Sada više ni nemaju pravo na besplatni upgrade na W10.
OT: Imao sam ovaj vikend situaciju gdje je ženska htjela instalirati Office 2019 na W8.1. Naravno da nije mogla jer oni podržavaju samo najnoviji OS tj. W10. Zašto nije napravila upgrade? Jer joj je njen informatičar rekao da je W10 s**t.
Staro 25.03.2019., 11:33   #9
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Mislim da još ide besplatno;
https://windowsreport.com/windows-10-free-upgrade-2018/
Edit:
Sequential Read (Q= 32,T= 1) : 1571.031 MB/s
Sequential Write (Q= 32,T= 1) : 993.294 MB/s
Brzina štima mislim.
Edit2:
Kloniranje je prošlo dobro (AOEMI) ali ne bootaju windowsi sa NVMe-a. Tu se sad malo priča komplicira, jer na drugom disku imam Linux Mint u dualbootu, sa GNU GRUB loaderom.
Ima tko ideju?
Edit3:
Ne. AOEMI je sranje od software-a. Rasturi MBR/GRUB. Izbjegavati.
Acronis True Image je obavio. Boota. Radi. Jedino sam razočaran što nema nikakvog osjetnog ubrzanja. Djeluje više-manje identično kao Kingston HyperX Fury 240, iako mjeri 1550/650. Dakle 3x više.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 25.03.2019. u 14:19.
Staro 25.03.2019., 14:13   #10
Postovi: 23,534
Fašizam W10 smetja se nastavlja ...
Radi NVMe na W7 x86/x64 samo se treba malo pognjaviti,
nedavno sam to slagao (H100 + W7x86 + Intel 760p).
Trebaš (za tvoju varijantu W7x64 + SSD iz uvodnog posta):
Windows6.1-KB2990941-v3-x86.msu
Windows6.1-KB3087873-v2-x86.msu
Windows6.1-KB2990941-v3-x64.msu
Windows6.1-KB3087873-v2-x64.msu
NVMe drajver
USB 3.0 drajver (ovdje je to ASM1142)
https://dlcdnets.asus.com/pub/ASUS/m...10_V116331.zip
Možda si primijetio da je poviše nije naveden specifični NVMe drajver, na ĐiĐI suportu ga ne spominju,
to znači da ga nisu izdali kao Intel ili Samsung nego se oslanjaju na "univerzalni" od M$.
Sad trebaš "napraviti" install medij kao u stara vremena XP - a sa nekim alatom.
Jedna varijanta je od ĐIĐI - ja mb_utility_windowsimagetool (intel ne AM4):
http://download.gigabyte.cn/FileList/Utility/
https://www.gigabytedriver.com/downl...vers-free.html
Taj alat radi install na USB sticku sa integriranjem navedenog.
Druga varijanta je da to sam odradiš pješke preko NTLite,
uputa > https://www.win-raid.com/t750f25-Gui...Win-image.html
Napomena: Trebaš 2 - 3 koraka za sve odraditi kako treba:
- prvo ide x86 varijanta ova 2 KB + USB u "Boot" dio
- potom to isto ali u odg. "install" prema verziji winsa koje želiš instalirati (npr. W7 Ultimate x64)
Na kraju dobiješ iso za pržit DVD ili preko Rufus - a napraviš USB stick.
Zvuči sve skupa malo komplicirana al kad prožvakaš materiju bit će jednostavno.
That's it
Zadnje izmijenjeno od: Nikky. 25.03.2019. u 14:40.
Staro 25.03.2019., 14:31   #11
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Je. Shvatio sam. Mada je kod mene bilo lakše. Ja sam morao preklonirati već postojeći sistemski disk. Instalirao sam Windows6.1-KB2990941-v3-x64.msu i Windows6.1-KB3087873-v2-x64.msu i to je bilo to. Sve radi.
Ali ovaj tvoj post bi trebao biti sticky.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 25.03.2019., 14:40   #12
Postovi: 23,534
Eto, piši upravi
Staro 01.05.2019., 14:56   #13
medo
#erase startup-config
medo's Avatar
Postovi: 3,714
Thumbs up
Hvala Nikki
I meni se od maloprije uredno boota Windows 7 SP1 64bit sa NVME drivea. Boota se u EFI modu.
Dvije stvari su interesantne. Stara FM2+ ploča nema M.2 slot, pa sam ga upogonio preko pasivnog PCIe adaptera sa eBaya (7-8$USD). Drugo, SSD je SK Hynix BC501 koji uopće nema NVME driver i nije supportan za Win7. Izvađen je iz novog HP laptopa. Evo, sve radi
KB2990941 i KB3087873 patcheve sam skinuo odavde:
http://thehotfixshare.net/board/inde...showfile=20015
http://thehotfixshare.net/board/inde...showfile=20866
Bez tih hotfixa neće raditi. Meni je trebao samo prvi hotfix. Iako mi je bacio onu "0x0000007E" Stop error grešku, Windowsi su uredno vidjeli SSD. Svejedno sam instalirao i drugi patch.
medo je online   Reply With Quote
Staro 01.05.2019., 15:48   #14
Postovi: 23,534
You are welcome, bitno da radi i da si pokazao prst Redmondu
Staro 16.05.2019., 08:52   #15
medo
medo's Avatar
Postovi: 3,714
Primjetio sam da se u Win7 ne vidi SMART info od NVME SSDa recimo temperatura i sl. Na istom kompu se u Linuxu uredno vidi. Isprobano na dva potpuno različita SSDa u HDTune i HWINFO.
Upgrade firmwarea NVME SSDa također ne radi pod Win7.
Staro 16.05.2019., 10:22   #16
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,584
Autor Nikky Pregled postova
Ja mislio da je ta gesta rezervirana za prelazak na Linux.
Ima MSI utility koji u W7 ISO integrira USB3/NVME drivere.
Za nesretnike s matičnim bez USB2 porta ili vlasnike NVME SSD-eja koji neće da bootaju.
Staro 16.05.2019., 10:39   #17
Postovi: 23,534
Da, ali je lošiji od ĐIĐI - jevog jer je loše isprogramiran,
pročitaj txt ispod, valja samo za source sa samo jednom verzijom os - a ...
