Staro 12.08.2016., 17:33   #331
nino
nino's Avatar
Postovi: 12,613
Ovo napravi.
1) Run the Registry Editor (regedit.exe)
2) Navigate to Registry Key: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Msahci
3) Set the "Start" value to 0 (zero)
4) Navigate to Registry Key: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Pciide
5) Set the "Start" value to 0 (zero)
6) Shut down
7) Start up again, but before Windows boots go into the BIOS configuration screens and change the disk mode to "AHCI". Save the new BIOS configuration and restart so that Windows boots.
When Windows starts, it will detect the change, load new disk drivers, and do one more reboot to start up with them.
Staro 12.08.2016., 17:36   #332
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,387
napravio ovo maloprije i proradilo, to je kao za win 10
Start REGEDIT and look for this line :
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\storahci\StartOverride
Change the 0 DWORD value from 3 to 0.
Reboot, and change your SATA controller to AHCI in BIOS. Now let it boot into safe mode, WIN 10 will install required drivers for AHCI.
Now with a normal boot you will boot into Windows with AHCI drivers.
nino nema više msahci foldera u regeditu u win 10, sad je ''storahci''
Staro 12.08.2016., 18:13   #333
nino
nino's Avatar
Postovi: 12,613
Isti k...., drugo pakiranje.
Staro 14.09.2016., 15:11   #334
lobo64
lobo64's Avatar
Postovi: 1,346
Pošto je domy zatvorio thread sa raspravama o SSDu, evo da skrenem pažnju budućim (a i sadašnjim korisnicima SSD diskova) koji još uvijek imaju dubioze odnosno nedoumice u razlikama između MLC i TLC čipova, naravno, izuzevši SAMSUNG koji je kralj po pitanju performansi:
http://www.anandtech.com/show/10674/...-ssd-review/10
Ukratko; fu.. the TLC or 3D TLC !!!
Ponosni sam vlasnik TRANSCEND SSD 370S (2x 128 GB, 1x 256 GB, plaćeni 128 GB 336 Kn, 256 GB 633 Kn), koji brišu pod sa svim TLC pogonima za sada (usprkos tome kaj su spojeni na SATA2 konekciju, a pogotovo kada ih se optereti tj. kada su zapunjeni sa podacima ), a da ne pričam o trajnosti odnosno o TBWu.
Ovo pogotovo vrijedi za za INTEL (540, 540s, 5400, 5400s) te TOSHIBA i SANDISK odrone za koje ni Bog Otac ne može predvidjeti njihovo trajanje bez obzira na 5 god gare.
Dakle, ukratko, uštekajte +60 Kn za MLC čipove (po disku), -50 MB/S je gubitak u brzini koji ni jedan prosječni korisnik neće osjetiti, te mirno spavajte.
Svjestan sam da ovaj post može zvučati kao plaćeni oglas, ali nije tako, ne plaća me nijedan proizvođač diskova, govorim isključivo iz vlastitog iskustva.
Staro 14.09.2016., 15:26   #335
nick praskaton
Asshole
nick praskaton's Avatar
Lokacija: RH
Postovi: 2,359
Autor lobo64 Pregled postova
ne kuzim intel, on je svoju 535 seriju koja je bila super pouzdana, odlucio zamjenit sa tim TLC sranjima, sa serijom 540 wtf
Staro 14.09.2016., 20:02   #336
lobo64
lobo64's Avatar
Postovi: 1,346
Intel 535 ima zastario kontroler (SANDFORCE, koji se više vjerojatno ne proizvodi), koji nije nužno loš (koristi ga KINGSTON V300, te još neki modeli drugih proizvođača).
No, u svijetu gdje svaka kompanija želi "maksimizirati profit" (čitaj zaraditi čim više para, pa makar potencijalnim kupcima uvalili proizvod niže vrijednosti po čim većoj cijeni), tako stoje stvari.
Kontroler sam po sebi je važan, ali za trajnost i performanse SSDa puno važniji je NAND, tj. dali je SLC(koji btw. običan smrtnik nemre platit), MLC ili TLC(sa svim njegovim varijacijama).
Moje osobno mišljenje je da razlika od 50(pa čak i 100) MB/s čitanja ili pisanja kao i broj IOPSa prosječnom korisniku igraju manje važnu ulogu u odnosu na trajnost (koja je sa MLC čipovima definitivno veća nego sa TLC), bez obzira na garu koju daju proizvođači.
Na kraju, neki od danas najbržih(consumer) diskova su bazirani na MLC čipovima(osim prije spomenutog SAMSUNGa koji je po tom pitanju klasa za sebe, ali je isto tako povezan sa "premium" cijenom).
Staro 15.09.2016., 08:50   #337
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,592
Problem s TLC-om je bio problem u ranim danima kad su garancije bile mizerih godinu dvije, s dobrim razlogom.
Čar petgodišnje gare je u tome da ti disk crkne nakon tri/četri godine i fino ti ga zamijene za novi i bolji i možda čak veći.
Jedini problem je gubitak podataka eventualni :-)
To definitivno jedino MLC može riješiti. Zato MLC i samo MLC ide u enterprise riješenja.
Staro 15.09.2016., 09:18   #338
virty
Ronon Dex
virty's Avatar
Lokacija: DS9
Postovi: 1,625
Dok su garancije tipa 3+ godine, uopce se ne zamaram jel TLC ili MLC.
Cisto jer na SSD-u drzim "manje bitne" stvari tipa OS, programe i igre.
Ionako radim redovito image "C" diska pa nema panike.
A kao sta kolega kopija kaze, ako crkne u garantnom roku, vjerojatno cu dobit bolji/veci model
virty je offline   Reply With Quote
Staro 15.09.2016., 18:31   #339
Kinez
Kinez's Avatar
Postovi: 112
Evo samo da se nadovežem u vezi crkavanja neki dan mi crkao Intel 520 serija od 120 GB, garanciju ima 5 g., a on je odapeo nakon 2. Stvarno iznenada, nije davao nikakve znakove da ce krepat.
Bio mirnijeg sna nego da je garancija bila 2 godine, kao sto je bila u mnogih ostalih modela koji su se tada nudili.
[Opteron 165 + TT 120]***[TwinMos 4x512 MB CL2]***[DFI NF4 LanParty]***[ATI HD4850]
[Hitachi 1TB HDD]***[Seasonic S12G-650G Gold 650W]***[Razer Lycosa]***[NZXT Beta Black Metal Edition, SCYTHE Kaze Master II KM05-BK]***[Samsung 22" B2230]
Kinez je offline   Reply With Quote
Staro 15.09.2016., 20:31   #340
lobo64
lobo64's Avatar
Postovi: 1,346
kopija
Da, kolega, djelomično ste u pravu, naime: u enterprise riješenja ide eMLC (enterprise) koji za razliku od običnog ima garantirani povećani broj ciklusa pisanja/brisanja u NAND (MLC između 3000 i 10000 ciklusa, eMLC do 30000 ciklusa, KINGSTON E100, Toshiba eMLC NAND (30,000 P/E cycles),Total Bytes Written (TBW): 100GB – 1241TB=11 DWPD, MTBF 10 000 000 hrs.) što naravno provocira visoku cijenu proizvodnje koja je širokoj masi korisnika (consumer) neprihvatljiva.
Evo još nekih enterprise SSD diskova:
Hitachi SSD400M (400GB, Intel EW29AA31AA1 controller, Intel 25nm eMLC NAND, 6.0Gb/s SAS)
PureSi Kage S1 (200GB, SandForce SF-2500 controller, Toshiba 24nm eMLC NAND, 6.0Gb/s SATA)
Tu su još i SLC diskovi (100 000 ili više P/E cycles, najpoznatiji predstavnik INTEL X25-E) koji su danas postali endemska vrsta, odnosno postoje kao OEM što će reći širokim masama su gotovo pa nedostupni i to ne samo zbog cijene koja je najblaže rečeno astronomska.
Staro 02.06.2018., 12:54   #341
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,066
Autor killuminati Pregled postova
Da, optimize/defragment. Znam da sam sigurno podesio c: na off, nakon updatea 1803 je sve bilo on, bitno da svugdje laju kak W10 zna upravljat SSD-ovima.
Optimize na Win7 pa nadalje znači pokretanje TRIM-a na SSD-ovima.
Iliti, preporučljivo je ostaviti uključeno osim ako ne koristite tool od proizvođača SSD-a da ručno pokrenete TRIM bar jednom mjesečno.
Meni se ne da paziti na to pa ostavim automatski.
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Staro 02.06.2018., 13:44   #342
killuminati
killuminati's Avatar
Datum registracije: Mar 2017
Postovi: 403
Autor Mario92 Pregled postova
Nije tako jednostavno, MS je potvrdio defragmentiranje SSD-ova u određenim situacijama by design, dakle ne trimanje i ta tema se provlači već dugo.
Osobno uvijek odznačim SSD s automatic maintenance, recimo na 1709 sam odznačio, nakon updatea na 1803 je opet bio označen, a kad sam pokrenuo naredbu u PowerShellu, vidi se jasno da je bio triman i zatim defragmentiran, krasno. Ima štiva po netu koja se tiču upravo te problematike.
Vidi se storage optimizer successfully completed re-trim on (C pa zatim storage optimizer successfully completed defragmentation on (C
Eventualno se može dodati scheduled task TRIM-SSD u Task Scheduleru uz micanje SSD-a iz automatic maintenance ili koristit magician ili kaj već, tako je najsigurnije.
Sent from my LG-H870 using Tapatalk
Staro 02.06.2018., 14:02   #343
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,066
Nemrem vjerovati da su sjebali I to...
EDIT: Scott Hanselman je napisao nekaj o tome:
https://www.hanselman.com/blog/TheRe...ntYourSSD.aspx
Actually Scott and Vadim are both wrong. Storage Optimizer will defrag an SSD once a month if volume snapshots are enabled. This is by design and necessary due to slow volsnap copy on write performance on fragmented SSD volumes. It’s also somewhat of a misconception that fragmentation is not a problem on SSDs. If an SSD gets too fragmented you can hit maximum file fragmentation (when the metadata can’t represent any more file fragments) which will result in errors when you try to write/extend a file. Furthermore, more file fragments means more metadata to process while reading/writing a file, which can lead to slower performance.
As far as Retrim is concerned, this command should run on the schedule specified in the dfrgui UI. Retrim is necessary because of the way TRIM is processed in the file systems. Due to the varying performance of hardware responding to TRIM, TRIM is processed asynchronously by the file system. When a file is deleted or space is otherwise freed, the file system queues the trim request to be processed. To limit the peek resource usage this queue may only grow to a maximum number of trim requests. If the queue is of max size, incoming TRIM requests may be dropped. This is okay because we will periodically come through and do a Retrim with Storage Optimizer. The Retrim is done at a granularity that should avoid hitting the maximum TRIM request queue size where TRIMs are dropped.
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
Zadnje izmijenjeno od: Mario92. 02.06.2018. u 14:08.
Staro 02.06.2018., 14:17   #344
killuminati
Postovi: 403
Koga zanima, u Windows PowerShellu može pokrenuti naredbu.
Code:
Get-EventLog -LogName Application -Source "microsoft-windows-defrag" | sort timegenerated -desc | fl timegenerated, message
Ovako izgleda kod mene, nakon 1803 updatea na ryzenu, drugo računalo na intelu nema takav zapis, moram provjerit s čime točno ima veze, možda sa system restore.
Message : The storage optimizer successfully completed retrim on (C: )
Message : The storage optimizer successfully completed defragmentation on (C: )
Kako god, ima dosta oprečnih mišljenja, od nepotrebnog trošenja ćelija do toga da bi filesystem metadata bez defragmentiranja mogao dosegnuti maksimalnu fragmentaciju, što opet donosi nove probleme. No kako god, dok bi došlo do toga, isteklo je jamstvo na SSD-u ili je ispucan TBW, a cijene SSD-ova su u padu, pa nije neki big deal.
EDIT: to na što se referira Hanselman je iz ovog članka - http://www.outsidethebox.ms/why-wind...#_Toc352763197
EDIT #2: kako tim konglomeratima, da ne kažem monopolistima, nije za vjerovati, bolje se držat ručnog trimanja bez defragmentiranja, IMHO naravno.
Zadnje izmijenjeno od: killuminati. 02.06.2018. u 14:24.
Staro 02.06.2018., 17:00   #345
Max_Damage
Max_Damage's Avatar
Lokacija: Krapinske Toplice
Postovi: 959
Sad sam zbunjen Imam u Magicianu auto optimize, sad dal da to isključim pa kad se sjetim stisnem optimize ili kaj? Di provjeriti dal mi je ssd defragmentiran ikad?
Max_Damage je offline   Reply With Quote
Staro 02.06.2018., 17:01   #346
Keyser Söze
Rent-a-maniac
Keyser Söze's Avatar
Postovi: 756
moglo bi se sastaviti neki tutorial ili nesto tako za nove i postojece korisnike, sve vise ljudi prelazi na ssdove a ne znaju se njima sluziti ispravno (myself included)
Staro 02.06.2018., 17:38   #347
killuminati
Postovi: 403
Autor Max_Damage Pregled postova
Možda samo pušem na hladno, ako je uključen SSD optimization, možda Win samo šalje TRIM naredbu, možda ne. Vidi se u mom prethodnom postu da je na mom SSD-u odrađen i TRIM i defragment. Pa sam ga odznačio u Defragment and optimize drives.
Magician optimization je vezan za Win optimization, pa bih ga osobno isključio, odnosno odznačio samo SSD. Vidi u Magicianu je li TRIM uključen, alternativa je sljedeća:
CMD (run as admin)
Code:
fsutil behavior query DisableDeleteNotify
Ako su nule kao dolje, sve ok.
NTFS DisableDeleteNotify = 0 (Disabled)
ReFS DisableDeleteNotify = 0 (Disabled)
Ako nisu, nego su jedinice (1) opet u CMD (run as admin) ukucaj ovo.
Code:
fsutil behavior set DisableDeleteNotify 0
Povijest defragmentiranja svih diskova možeš vidjeti u Windows PowerShellu, kako sam gore napisao, sljedećom naredbom, vidiš sve po datumu;
Code:
Ostalo nemaš kaj, TRIM naredbu šalje Win svaki put kad obrišeš neki file.
Staro 02.06.2018., 17:43   #348
nickross
Budget gamer
Datum registracije: Nov 2017
Postovi: 908
Meni je trim u Samsung Magicianu uključen a zadnji put windows kaže da je prije mjesec dana napravljen trim...postavljeno automatski tjedno
nickross je offline   Reply With Quote
Staro 02.06.2018., 20:40   #349
Max_Damage
Max_Damage's Avatar
Postovi: 959
Hvala!
Staro 03.06.2018., 11:37   #350
Max_Damage
Max_Damage's Avatar
Postovi: 959
Ukucal u powershell ovu gore naredbu i vidim da mi na C: napravi retrim i onda "The storage optimizer successfully completed shrink estimation on (C Jel to normalno da napravi shrink? guglam uzalud
Zadnje izmijenjeno od: Max_Damage. 03.06.2018. u 11:53.
Staro 07.02.2019., 17:01   #351
domy_os
domy_os's Avatar
Postovi: 18,862
Evo kako je kolega imao problem sa sporošću SSD-a odnosno visokim random access timeom, stavit ćemo rješenje i ovdje.
Autor Babaloo Pregled postova
Našao rješenje!
jučer sam s frendom u sitne sate raspravljao o ovome problemu i poslao mi je jedan registy file da ubacim u sustav koji se odnosi na stare SATA kontrolere.
Naime, radi se o patchu koji gasi power management tako da ''link'' ostane aktivan cijelo vrijeme umjesto da se isključuje svakih par milisekundi. nekad to nije bilo problem sa mehaničkim diskovima jer im je access time bio manji od vremena koje je trebalo da se sata link ponovo uspostavi. sad kod ssd-a je to veliki problem i mora se ugasiti.
Evo pa tko želi neka isproba, meni je ne samo riješilo problem nego i značajno povećalo preformanse na oba SSD-a, a danas ću ga isprobati na još nekim SSD-ovima sa starijim kontrolerima i Windowsima 10
Nadam se da sam još kome pomogao, javite vaše rezultate
File Type: zip Add_AHCI_Link_Power_Management_HIPM-DIPM.zip‎ (635 byte, 399 views)
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 07.02.2019., 17:46   #352
kasko
kasko's Avatar
Lokacija: Ivanić_Grad
Postovi: 2,009
Autor domy_os Pregled postova
Za koji OS, 86/64bit?
kasko je online   Reply With Quote
Staro 07.02.2019., 19:13   #353
domy_os
domy_os's Avatar
Postovi: 18,862
Isti key postoji i na Win 7 i na Win 10, vjerojatno i na Win 8.
Staro 07.02.2019., 19:29   #354
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,206
prvi put cujem za ovo. kako to ako je toliki perf impact ?
geronimo_2 je online   Reply With Quote
Staro 07.02.2019., 20:23   #355
domy_os
domy_os's Avatar
Postovi: 18,862
I ja isto, tko zna, možda je vezano i za SATA driver, trebalo bi usporediti verzije.
Staro 07.02.2019., 21:56   #356
Flegma
Flegma's Avatar
Datum registracije: Jul 2004
Lokacija: Zagreb/Šibenik
Postovi: 832
I ima li ovo veze i na novim (recimo Z390) plocama, ili samo starije?
Bila je toliko lijepa da sam poželio da nikad ne otvori usta. A onda mi je nekako objasnila da je nijema. Oženio sam ju Las Vegasu, tjedan dana kasnije. I sad napokon živim sa ženom koju razumijem.
Moj PC - https://www.twitch.tv/flegmoar
Flegma je offline   Reply With Quote
Staro 20.02.2019., 08:58   #357
geronimo_2
geronimo_2's Avatar
Postovi: 4,206
nista ne javljte jeste probali? jel ima utjecaja? koja je definicija "stari SATA kontroler"? jel recimo moj Z68 spada u to ili pricamo u puno starijim?
Staro 20.02.2019., 11:11   #358
2XO
Lokacija: Osijek-Zagreb
Postovi: 325
Ako može malo više info, koliki random access time se smatra visokim za ssd?
2XO je offline   Reply With Quote
Staro 20.02.2019., 15:11   #359
domy_os
domy_os's Avatar
Postovi: 18,862
Probao sam i nema skoro nikakve razlike, nijanse su u pitanju. Dobio sam 0.01 ms na RAT-u, nešto malo u sequential read/write i neke silne opcije za SSD u power managementu. Prije bih rekao da je to zbog toga što sam prvi test radio s dosta otvorenih aplikacija, a drugi nakon reboota. Nakon upgradea Win 10 na novi build, sve se vratilo na default i ne diram više jer nema potrebe.
Kod mene Samsung 840 Pro super radi na Z68, nema potrebe ništa dirati.
Autor 2XO Pregled postova
Relativan pojam, nekome je i 0.1 ms sporo, ali recimo da se većina SSD-ova vrti oko te vrijednosti ili niže. RAT od 0.2 ms već daje duplo manje IOPS-a.
Staro 20.02.2019., 15:13   #360
geronimo_2
geronimo_2's Avatar
Postovi: 4,206
daklem da ne gubim vrijeme...
hvala ti na reportu i info-u.
