Staro 21.01.2019., 11:56   #211
Postovi: 34,094
Bilo bi suludo da svaki proizvođač mbo/ssd ima svoje šarafe za M.2 diskove.
Staro 21.01.2019., 21:11   #212
XXX_Man
3X
XXX_Man's Avatar
Datum registracije: Sep 2010
Lokacija: Zagreb, Croatia
Postovi: 216
Prije par dana sam stavljao m.2 SSD u laptop (Acer) i na matičnu (Gigabyte) i nisu isti šarafi. Razlika je u debljini šarafa, laptop je imao tanji.
“The saddest aspect of life right now is that science gathers knowledge faster than society gathers wisdom.” - Isaac Asimov
"With the first link, the chain is forged. The first speech censured...the first thought forbidden...the first freedom denied – chains us all, irrevocably."
XXX_Man je offline   Reply With Quote
Staro 21.01.2019., 21:20   #213
Dottore
Dottore's Avatar
Postovi: 7,711
Autor XXX_Man Pregled postova
Bravo i potpuno točno.
Bilo bi glupo da svaki proizvođać SSD-a šalje šarafe.
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 22.01.2019., 10:06   #214
Postovi: 34,094
Mogu razumjeti razliku u šarafima za desktop i laptop, ali čisto sumnjam da desktop mbo imaju različite šarafe bez obzira na proizvođača.
Staro 03.02.2019., 15:22   #215
spinn
Postovi: 82
Inicijaliziranje novog SSD diska na postojeću konfiguraciju
Sistemski disk mi je Samsung SSD 850 EVO 250GB. Uz njega imama i WD 2 TB hard drive,podijeljen u dvije particije.
Uzeo sam novi Samsung SSD 860 EVO 250GB kojeg mislim koristiti primarno za igre. Na njega ću prenijeti Skyrim (kojeg igram već neko vrijeme, level 55) sa sistemskog diska. I planiram jednu particiju na cijelom disku.
Nisam nikad inicijalizirao novi disk na postojeću konfiguraciju, pa bih molio savjet. Da li odabrati MBR ili GPT..? Informirao sam se, naravno, po netu o prednostima jednog i drugog i ispada da je GPT prikladniji. No, moj je disk 250 GB a GPT se preporuča za diskove veće od 2TB.
Dakle, nisam još odabrao nijednu od ovih opcija jer ne bih želio pogriješiti, pa trebam preporuku.
Drugi upit: kao što se vidi, imam dva diska i tri particije: C, D, and E. U Disk manageru je ovaj novi disk prikazan kao Disk1 (??)
Zar ne bi bilo logično da je on Disk 2...? (Obzirom je sistemski Disk 0)
Kažem, nisam napredovao dalje od ovog koraka i ne znam koje će mi opcije kasnije biti ponuđene, ali volio bih da mi ovaj treći disk bude "nazvan" Local Disk F. Hoću li to moći uraditi?
Naime, znam koje su mi fajlovi na D a koji na E particiji i ako baš ne moram, izbjegao bih privikavanje na nove nazive i zbrku.
spinn je offline   Reply With Quote
Staro 03.02.2019., 15:46   #216
Postovi: 23,636
Pogledaj na koji SATA port na mobo si uštekao koji disk,
pretpostavljam da si 850 EVO 250GB (sistemski, Disk0) uštekao na SATA1, a WD 2 TB (Disk2) na SATA3,
pa potom novi 860 EVO na SATA2 port,
zato je novi po automatskoj numeraciji dobio oznaku / ime Disk1.
Sve skupa sad nije "bitno", a i kasno je za promjene.
Samo ti odradi inicijalizaciju, odaberi MBR + NTFS particiju, prilikom formatiranja možeš mu dati ime (volume) po želji i da mu u winsima dodijeljeno slovo F.
Staro 03.02.2019., 15:54   #217
D/G
D/G's Avatar
Datum registracije: Feb 2010
Lokacija: Ploče
Postovi: 1,210
..brži je Nikky ..pa obrisah napisano ( uglavnom isto) ....uz napomenu da ne mjenjaš sata port od sytemskog diska radi normalnog boota.
Staro 03.02.2019., 16:37   #218
spinn
Postovi: 82
Hvala. Uspješno ga incijalizirah
Sad samo da mi neko kaže kako da prebacim Skyrim i NMM sa sistema na ovaj disk, ne gubeći level. Ali,to ću pitati u drugoj sekciji foruma.
Staro 12.02.2019., 23:44   #219
kvaju
kvaju's Avatar
Lokacija: Cirkus
Postovi: 642
Evo narucio sam i ja crucial mx500
Posto bih probao sam promjeniti ovo ako moze samo savijet.
Laptop je dell inspirion n5110.
Maknuo bih dvd, i stavio onaj docker za disk mjesto njega. Prvo sto me zanima je dali su hdd i ssd istih dimenzija?
Dali moram ssd staviti na isto mjesto gdje je hdd bio, posto bi taj disk bio 'primarni' tj sustav ce na njega ici?
Ili moze ici komotno u taj docker, pa u biosu samo promjenim koji je primarni?
Sent from my Pixel 2 using Tapatalk
kvaju je offline   Reply With Quote
Staro 13.02.2019., 00:05   #220
Dottore
Dottore's Avatar
Postovi: 7,711
Autor kvaju Pregled postova
Teško, pošto ssd na mjesto DVD-a ići će nešto sporije. Neće ići na full brzinu.
Stavi novi ssd na mjestu gdje je bio hard disk. Stari disk prebaci na mjesto dvd-a kao dodatni storage.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 13.02.2019., 00:28   #221
kvaju
kvaju's Avatar
Lokacija: Cirkus
Postovi: 642
Ok hvala ti. Dimezije su predpostavljam isti i hdd i ssd?
Staro 13.02.2019., 00:31   #222
Postovi: 8,245
Da, može bit eventualno tanji a to ne smeta
Staro 13.02.2019., 09:57   #223
zdravko_c
Lokacija: Vinkovci
Postovi: 531
Provjereno iz prve ruke na dotičnom modelu, morat ćeš rastaviti laptop i SSD staviti umjesto postojećeg diska, a hard disk u ladicu koja ide umjesto DVD-a. Ako staviš SSD u ladicu nećeš moći bootat OS sa SSD-a, bios mu je takav i čak i da promjeniš da je DVD primarni, neće raditi jer traži baš DVD.
zdravko_c je offline   Reply With Quote
Staro 13.02.2019., 09:59   #224
kvaju
kvaju's Avatar
Lokacija: Cirkus
Postovi: 642
Hvala, samo mi molim te reci, jesi morao bas za konkretan model laptopa ladicu traziti ili je univerzalna neka?
Staro 13.02.2019., 10:13   #225
zdravko_c
Lokacija: Vinkovci
Postovi: 531
naručena sa ebay-a za par dolara, npr. kao ova. Ako ti se baš ne da čekati da stigne iz Kine onda pogledaš po trgovinama ladicu debljine 12.7mm. U oba slučaja moraš sa postojećeg dvd-a prebaciti prednju plastičnu masku.
Staro 13.02.2019., 10:40   #226
thunder11
thunder11's Avatar
Datum registracije: Dec 2013
Postovi: 1,699
Evo jučer baš ugradio 2x SSD-a u dva različita laptopa (Acer aspre E15 i HP17-F050NG)
SSD stavljen u ladicu umjesto CD/DVD (što god da je bilo) a HDD ostao na prvobitnom mjestu. Sve radi bez greške, barem u ova dva modela. novi winsi instalirani na ssd i pokrenuti, topovi se preporodili
Staro 13.02.2019., 11:21   #227
Postovi: 8,245
Univerzalne su, iako postoji 2 modela, a razlika je u visini. Postoji 12.7mm model za prastare laptope, i noviji, mislim da je 9.5mm.
S tim da nisam siguran dal uopće tko prodaje te stare debele.
Staro 13.02.2019., 11:41   #228
kiki86
Tehničar
Datum registracije: Dec 2011
Postovi: 1,098
Caka je u tome da osim ovih mogućih problema sa bootom, za dvd se u nekim laptopima koristi sata 2 sučelje i dalje, tako da ako stavis ssd u ladicu mu moguće limitiraš performanse. Hdd je i tako spor pogotovo u laptopima obično idu 5400rpm čak i one skuplje i on ne osjeti ako je na sporijem sučelju, ssd već vidi razliku. Naravno da se osjeti pomak sa hdd na ssd, ali bi radio još i bolje da si ga ubacio umjesto hdda a ovog u ladicu (najvjerovatnije)
Staro 22.02.2019., 19:18   #229
Mirkopoter
Mirko, a ne Harry
Mirkopoter's Avatar
Postovi: 5,507
Pitanjce.. uzeo sam polovni hdd ovdje od kolege s foruma i dogovorili smo se da ostavi gore filmove koje je imao. E sad, ja sam što mi treba s tog novog hdd-a prebacio na stari pa bi taj novi formatirao i ne znam ako još nešto treba jer bi htio ono "clean slate". Sad ne znam je li dovoljno samo formatirati hdd i idem li na quick format ili samo format?
Hala Madrid!
Staro 22.02.2019., 19:20   #230
calypso
calypso's Avatar
Datum registracije: Oct 2002
Lokacija: Zagreb/Rijeka
Postovi: 2,050
Desni klik na disk u Windows Exploreru, Format i onda odaberes 'Quick format', pricekas 10-20 sekundi i to je to...
GMKTec K8Plus
2x EIZO EV2336WFS3-BK
23" 1920x1080 IPS
Dell Latitude 7390
32GB DDR4-2666
intel UHD 620
13.3" FullHD IPS Touchscreen
Staro 22.02.2019., 19:31   #231
Mirkopoter
Mirko, a ne Harry
Mirkopoter's Avatar
Postovi: 5,507
Onda ćemo tako.
A za stari disk, ima li neki način da se sigurno sve s njega pobriše ako ću ga prodavat?
Hala Madrid!
Staro 22.02.2019., 19:55   #232
calypso
calypso's Avatar
Postovi: 2,050
Onda ćemo tako.
Nadji neki disk sanitizer tool na googletu pa sa njim.
Sent from my EVA-L09 using Tapatalk
GMKTec K8Plus
23" 1920x1080 IPS
Dell Latitude 7390
32GB DDR4-2666
intel UHD 620
Staro 22.02.2019., 20:09   #233
Postovi: 34,094
Nađi neki Zero Fill program i bar dvostruki pass istoga. Šanse da itko išta iskopa s njega nakon toga su male.
Staro 22.02.2019., 22:27   #234
domy_os
domy_os's Avatar
Postovi: 18,959
Za novi HDD obavezno pokrenuti dijagnostički alat od proizvođača, provjeriti SMART status i onda full format. Kakvi quick formati na neprovjerenim diskovima, to radiš kad si siguran da je HDD Ispravan.
Za prodaju najbolje kombinirati barem jedan zero fill (alat proizvođača diska) i barem dva random fill formata (HD Tune ga ima i razni disk sanitizer alati). Ako radiš samo jedan zero fill, postoji mogućnost recoverya.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 23.02.2019., 11:56   #235
Mirkopoter
Mirko, a ne Harry
Mirkopoter's Avatar
Postovi: 5,507
Health i bad sector sken su oke za novi disk, misliš da je potrebno da ga još s dijagnostičkim alatom od proizvođača provjeravam?
Hala Madrid!
Staro 23.02.2019., 12:49   #236
Postovi: 23,636
Ako si max. nepovjerljiv mislim da je dosta zavrtiti dijagnostički alat proizv. i to onu brzu (quick) varijantu.
Ovisno o izvedbi / slikovnici taj osim specifičnosti isto analizira smart status.
Bitno je da uredu radi, da ako si kupio novi se i vidi iz parametara.
Evo nedavno sam na jedno mjesto ugrađivao novi WD Blue 1TB,
uvalio u makinju, napravio 2 particije i format (u winsima jer je to 2. hdd),
potom testirao transfer, počeo prebacivati / kopirao dio podataka,
pogledao smart patametre,
pošto je sve bilo ok = the end.
Zadnje izmijenjeno od: Nikky. 23.02.2019. u 12:59.
Staro 23.02.2019., 13:09   #237
Mirkopoter
Mirko, a ne Harry
Mirkopoter's Avatar
Postovi: 5,507
Ma nisam neppvjerljiv, vjerujem da je hdd oke jer je skeniran s hd tune-om i crystaldisk-om. Ja sam samo htio ono “clean slate” samo nisam znao kako da ga formatiram, preko windowsa quick ili normalni format ili preko nekog programa.
Hala Madrid!
Staro 01.03.2019., 13:39   #238
m4dm4n
Does youer dewg byte?
m4dm4n's Avatar
Postovi: 1,954
Gdje naručiti set za montažu M.2 diskova na matičnu? Uz matičnu dolazi samo za jedan komad, uz diskove ne dolazi ništa, i šta sad , gdje to nabaviti? U HR, ZG po mogućnosti.
Staro 01.03.2019., 14:16   #239
nino
nino's Avatar
Postovi: 12,613
Mislic na karticu za pcie slot?
Sent from my CLT-L29 using Tapatalk
Staro 01.03.2019., 14:19   #240
m4dm4n
m4dm4n's Avatar
Postovi: 1,954
Autor nino Pregled postova
Ne, one glupe sarafe i nosace za maticnu.
Zadnje izmijenjeno od: m4dm4n. 01.03.2019. u 14:30.
