Staro 09.01.2019., 07:26   #11041
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,138
jel gledo ko project blue book?
nadam se da ce bit dobra
pogledali godless. odlicna serija.
geronimo_2 je online   Reply With Quote
Staro 09.01.2019., 16:43   #11042
WraGG
WraGG's Avatar
Lokacija: Stuttgart
Postovi: 1,594
Gleda li tko Manifest? Nelosa serija, vuce mi dosta na neku sf seriju koju sam relativno nedavno gledao, ali se ne mogu sjetiti imena. Mislim da je bilo Ressurection.
Staro 09.01.2019., 22:16   #11043
vranjba
vranjba's Avatar
Datum registracije: Aug 2009
Postovi: 613
Domaća serija u produkciji HBO-a - Uspjeh
Bila jučer E01 na HBO. Ima u videoteci cijela sezona. Pogledao prvu i izgleda jako jako dobro.
Sent from Usreo Mobara
koja?
CPU: AMD Phenom II X2 545 @X4 B45 + AC Freezer 64 Pro PWM
MBO: Asrock a780GXH @ bios 1.70
RAM: Kingmax 2x2GB PC2-8500
VGA: Sapphire HD5570 1GB
Zvučna: Asus xonar d1
HDD: WD6401AALS + WD2000JB + WD3200AAJS
PSU: Corsair cx400W
Case: Gigabyte GZ-X6
Keyboard: Logitech mk520 + Microsoft Natural Wireless Mouse 6000
Daljnski: Mce ir
Zvučnici: Swans d1080mkii 08
Monitori: Philips 220SW + HP L1950g
TV: Panasonic TX-P50C3E
AIO: HP Deskjet F4280
OS: Windows 7 x64
HP Compaq nx7010
CPU: Pentium centrino 2.0 GHz
RAM: 1gb + 512mb PC2700
VGA: ATI Mobility Radeon 9200 32mb
HDD: wd 40 GB
OS: Win XP SP3 x32
CPU: Pentium 3 1.0 GHz + Glacialtech igloo 2520
MBO: Intel D815EFV
RAM: 2x 256mb PC133
HDD: Maxtor 80gb + Seagate Barracuda 7200.7 160gb
PSU: Codegen 400W
OS: Win XP SP3 x32
PCI Lan: Linksys cisco gigabit EG1032 v3
Routher: Thomson ST780i WL
Net: T-com Flat
Acernote lite 350pc
CPU: Pentium 100 MHz
RAM: 8 mb edo onboard
VGA: chips&tech f65545
HDD: ibm 540 mb
OS: win 95
CPU: pentium 166 MHz
MBO: ga 586vx rev 3.37
RAM: 4x16 mb edo ram
VGA: Ati 3D rage II +dvd 4 mb
HDD: quantum fireball se2.1a 2.1 gb
PSU: seasonic ssa-200g
Monitor: Acer 13"
OS: dos 6.22
vranjba je offline   Reply With Quote
Staro 09.01.2019., 22:19   #11044
Postovi: 8,201
Staro 09.01.2019., 22:41   #11045
buljaka
Datum registracije: Aug 2014
Postovi: 2,928
Autor vranjba Pregled postova
koja?
Zove se "uspjeh"
Staro 10.01.2019., 21:06   #11046
Postovi: 8,201
Za seriju koja (nažalost) vrlo vjerojatno ne bude obnovljena, The Punisher ima obećavajuću drugu sezonu.
The 13-episode season is expected to be released on January 18, 2019.
Staro 10.01.2019., 22:03   #11047
Mr.Ex.President
Torrent freek
Mr.Ex.President's Avatar
Postovi: 3,943
Pogleda 3 sezone The Man in the High Castle i nije me domojio pretjerano.
Prva sezona je zanimljiva, napeta, kasnije to postaje sve monotonije i dosadnije te na kraju i previše naporno. Pogtovo je naporna igra spasim ja tebe-spasim ti mene koja se odvija između glavnih protagonista serije. Inače kad smo kod glavnih već, cijeli taj "pokret otpora" je smiješan i neuvjerljiv totalno...
Nije serija tolko loša, ali nije me baš kupilo ni pričom ni radnjom da sa nestrpljenjem čekam 4. sezonu...
MBO: MSI B450 Gaming Plus
PSU: Corsair RM550X 550W
Periferija
LCD: HP ZR24w
Mouse: Logitech G400
Sound: Genius SP-HF1201A
Printer: HP LaserJet 1020
Scanner: HP ScanJet 4300
Headphones: Philips SHC 2000
MBO: Gigabyte GA-F2A85XM-HD3
HDD: WD Green 2TB [WD20EZRX]
PSU: Antec SU380
TV: Samsung 43E450 @HDMI
LINK
Staro 10.01.2019., 22:10   #11048
buljaka
Postovi: 2,928
Meni jedna od boljih Marvel serija. Jedva čekam 💪💪💪
Staro 11.01.2019., 15:23   #11049
Igorr
Flajing super šiiiip
Igorr's Avatar
Lokacija: Zd -- Zg
Postovi: 1,676
Uuuuu, može može
Pa jedino on i Daredevil vrijede.
Ajde još eventualno i Cage, ali brate onaj kmečavac (kme kme či mi je prazan, kme kme hoćeš da te fistam...) i ona Jonesica su mi žali bože.
5.1.4 setup:
Zvučnici - 2x Arendal 1723 S monitors, 1x 1723 S center, 4x 1961 height, 2x 1961 surround, XTZ 12.17 EDGE
Amps - Marantz Cinema 40 + ROTEL RMB-1585
Igorr je offline   Reply With Quote
Staro 11.01.2019., 18:37   #11050
Mirkopoter
Mirko, a ne Harry
Mirkopoter's Avatar
Postovi: 5,400
Jessica Jones prva sezona je u rangu Daredevila i Punishera, sve ostalo je loše.
Hala Madrid!
Staro 12.01.2019., 10:12   #11051
chief_wolfinjo
Staro 12.01.2019., 10:19   #11052
buljaka
Postovi: 2,928
Autor Igorr Pregled postova
Uuuuu, može može
Iron fist je teško smeće ,slažem se. Jesica se razvodnila, čak i Cage nije ispunio svoj potencijal do kraja. Daredevil je ok ali punisher je zakon 😁😁
Staro 12.01.2019., 15:02   #11053
ITATABISINE
ITATABISINE's Avatar
Datum registracije: Jun 2018
Postovi: 29
Pozdrav svima
Ako Vam nije mrsko slušati njemački jezik (osobno perferiram Danski i Svedski hahaah),
svakako pogledajte seriju DAS BOOT (2018).
Serija nema nikakve veze s istoimenim vrhunskim filmom iz 1981
Po žanru možemo ju staviti pod špijunski triler radnja smještena i na moru i kopnu
Vrhunski prijevod možete naći na
https://www.prijevodi-online.org/ser.../das-boot-2018
Što se tiče downloada, nemojte se mučiti preko torrenta, jer prijevod ne odgovara videu.
Ima je za skinuti veoma lako na Hrvatskom forumu, ako neznate koji obratite mi se na pm
ITATABISINE je offline   Reply With Quote
Staro 12.01.2019., 22:43   #11054
Mr.Ex.President
Torrent freek
Postovi: 3,943
Pogledan Narcos: Mexico
Odlična serija, odlična gluma, odlična atmosfera uz konstatni deja vu osjećaj s obzirom na pogledanog Narcosa ranije. Ona epizoda u kojoj putuje u Kolumbiju je sve ikad, toliko poznatih faca i likova, ajme
Ono što je po meni potpuno nepotrebno, a možda me vrijeme demantira je 2. sezona. Kažem možda me vrijeme demantira pa ispadne jebeni hit, ali po povijesnim činjenicama koje serija više-manje prati druga sezona će biti kao i 2. sezona Narcosa, jebena potjera pri kojoj će ovaj ić iz kuće u kuću, ugl. booooooring. A nepotrebno, u 10 epizoda su prikazali sve, ako su baš htjeli 20, mogli su razvuć ovih 4-5 godina na 20 epizoda i zdravo...
Autor ITATABISINE Pregled postova
Ako jedini smisao posta nije reklama, onda triba znat šta skidat jebiga Paše prijevod savršeno na HDTV.x264-ACED
Nisam pogledao još do kraja pa ću se suzdržat ocjene, ali zasad mi je film, odnosno radnja koju prati film nekako draža... Inačpe ne bi se složio da nema nikakve veze sa filmom, ako se ne varam baš su je autori prikazali kao nekakav "nastavak" na film gdje se radnja nastavlja na novoj serii podmornici par mjeseci nakon uplovljavanja U96 u luku...
Periferija
LCD: HP ZR24w
PSU: Antec SU380
LINK
Staro 13.01.2019., 00:08   #11055
Ziiky
Ziiky's Avatar
Postovi: 2,880
koja?
Autor buljaka Pregled postova
Zove se "uspjeh"
Ne znam ... mozda sam previse subjektivan, ali na kakve sam sve odrone nailazio i gutao, ova nasa je vrh i isplati ju se pogledati.
Dostupna je cijela sezona
https://www.imdb.com/title/tt8453458/
... a veceras cemo naceti "BESA"
https://www.imdb.com/title/tt9170318/?ref_=tt_rec_tt
Edit: Besa je goli odron 😵
MBO: MSI Mortal
RAM: Crucial DDR4 8gb
GPU: Gigabyte GF GTX 1050 ti
HDD: SSD 128gb + WD blue 1TB
RW: LG
MON: Acer 24"
CASE: Antec Fusion Remote Max
PS: Fortron 550w modular
NAS: Synology 210j WDred4TB
HEADPHONES:Bluedio t3 plus BT
TV: Philips 55pus7805
REC: DENON x1600H
SUB: SVS PB1000
Trenutno ništa ...
Moje njuškalo
Zadnje izmijenjeno od: Ziiky. 13.01.2019. u 13:41.
Staro 13.01.2019., 11:29   #11056
virty
Ronon Dex
virty's Avatar
Lokacija: DS9
Postovi: 1,621
Serije koje pratim sa zenom sve pogleda, mozda je vrijeme za Uspjeh posto ima dobre kritike. Ne gledam nista sa ovih prostora pa eto red je bacit oko na bar ovu.
Poslano sa Sony XZ3
virty je offline   Reply With Quote
Staro 13.01.2019., 12:55   #11057
pogi
aka Mali Mirko
pogi's Avatar
Postovi: 3,089
Autor virty Pregled postova
Poslano sa Sony XZ3
Jel uopće ima S01E03 u videotekama? Kod mene kao da je netko E03 zaboravio vratiti u videoteku...
pogi je online   Reply With Quote
Staro 13.01.2019., 14:00   #11058
GT3
Lokacija: Kr. toplice
Postovi: 142
Autor Ziiky Pregled postova
gdje se moze nabaviti cijela sezona?
GT3 je offline   Reply With Quote
Staro 13.01.2019., 14:02   #11059
Postovi: 8,209
Autor pogi Pregled postova
Sve je vani i dostupno.
Autor GT3 Pregled postova
HBO
Staro 13.01.2019., 14:03   #11060
U svakoj boljoj videoteci sa domaćim sadržajem. I to je najviše što možemo reći
Staro 13.01.2019., 14:35   #11061
pogi
aka Mali Mirko
pogi's Avatar
Postovi: 3,089
Našao sam, videotekarka ju je zametnula na jednoj polici...
Staro 13.01.2019., 18:31   #11062
Bodisson
Bodisson's Avatar
Datum registracije: Dec 2014
Postovi: 246
Tko je pratio...
Brooklyn Nine-Nine
...ide dalje sa šestom sezonom!
Bodisson je offline   Reply With Quote
Staro 13.01.2019., 19:39   #11063
gin.tonic
gin.tonic's Avatar
Postovi: 2,434
Luther S05 i nije nešto
Čeka se True Detective S03...
gin.tonic je offline   Reply With Quote
Staro 13.01.2019., 19:50   #11064
Spikeman
Lokacija: bi volio znat?
Postovi: 1,220
ima netko informaciju di se moze posudit srpska serija Besa i Jutro će promeniti sve u HD rezoluciji, moze u PM
btw Uspjeh je meni osobno najbolja HR serija koju sam gledao, nisam nigdje pronasao informaciju hoce li bit snimanje nove sezone il epizode 7, ima netko kakav info?
Staro 14.01.2019., 16:56   #11065
acer
Whatever :)
acer's Avatar
Datum registracije: Nov 2002
Lokacija: Rijeka,Bulevard
Postovi: 1,751
Krenula treca sezona True Detectiva, ima u videotekama.
GIGABYTE B450 AORUS PRO
Fractal Design Define XL R2
Chieftec A-80, CTG-750C, 750W
AMD Ryzen 5 3600
Be Quiet Dark Rock Pro 4
Asus Nvidia GTX 1060 OC Edition, 3GB
Avermedia Live Gamer HD Lite
GEIL Evo Spear AMD GASB416GB3200C16ADC, DDR4 3200MHz, kit 2x8GB
Kingston NVMe M.2, 1TB
LG BH16NS55 Bluray writer
LG GGW-H20L Bluray writer
27" Philips
Brother HL-2240
Das Keyboard 4 Professional, MX brown
Logitech mouse G402
Scanner HP Photosmart G3010
Cambridge Audio DacMagic 100
Scythe SDAR-2100 + Scythe Kro Craft Speaker SCBKS-1000
Windows 10 PRO x64
Staro 14.01.2019., 20:11   #11066
tizhu
Datum registracije: Sep 2014
Postovi: 771
ideš!
Staro 14.01.2019., 22:10   #11067
virty
Ronon Dex
virty's Avatar
Lokacija: DS9
Postovi: 1,621
U mojoj videoteci ima
Staro 14.01.2019., 23:01   #11068
Venomgamer
Venomgamer's Avatar
Datum registracije: Sep 2010
Lokacija: Peljesac
Postovi: 293
Vrhunska serija,plus srpski film Juzni vetar.Sto se to dogadja na ovim prostorima...
Venomgamer je offline   Reply With Quote
Staro 15.01.2019., 00:57   #11069
warlock25
warlock25's Avatar
Postovi: 2,327
Nakon odgledane 2 epke trece sezone True Detectivea jedva cekam jos.Serija se vraca starim korijenima tj. prvoj sezoni.Napetost,misterija itd.Jako dobar pocetak.
Staro 15.01.2019., 06:48   #11070
nick praskaton
Asshole
nick praskaton's Avatar
Lokacija: RH
Postovi: 2,358
vidim da je na netflixu izasla ona nasa serija Novine, jel gledao tko ? preporuka ?
