Staro 08.12.2018., 07:57   #2311
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Ma moze se to bolje...
1 * Procesor AMD Ryzen 7 1700X AM4, 3.4Ghz
Sifra: AMD-YD170XBCAEWOF - 1.599,00 Kn
1 * Hladnjak MSI GAMING Core Frozr L, Intel/AMD + AM4
Sifra: CORE_FROZR_L - 399,00 Kn
1 * MSI B450 Tomahawk, AM4, DDR4, U3, m.2, ATX
Sifra: msi-b450-thawk - 850,00 Kn
1 * Memorija PC-24000, 16 GB, GEIL EVO Spear GSB416GB3000C16ADC, DDR4 3000MHz, kit 2x8GB
Sifra: 051.200.225- - 1.150,00 Kn
1 * NZXT H500 crno bez napajanja, ATX
Sifra: nzx-h500-black - 769,00 Kn
1 * Fortron napajanje Hydro GE 650W,80+ GOLD modularno
Sifra: fsp-hydro-ge-650w - 749,00 Kn
1 * SSD 500.0 GB SAMSUNG 970 Evo NVMe M.2, MZ-V7E500BW
Sifra: 051.400.570- - 1.139,00 Kn
1 * Toshiba 3.5 2TB, SATA6Gb, 7200rpm, 64MB
Sifra: DT01ACA200 - 489,00 Kn
Ukupno: 7.144,00 Kn -2% popust za clanove = 7000 kn
Staro 08.12.2018., 12:23   #2312
ibme74
ibme74's Avatar
Datum registracije: Jan 2013
Lokacija: Planet Zemlja
Postovi: 1,572
Autor S1r1uS Pregled postova
1.) Hvala na preporukama iznad. Evo moje trenutne revizije.
2. Jeidno nisam siguran oko procesora. Gledao sam po yt i razlike između 1600x i 2600x su stvarno malene.
Nisam siguran kako će to raditi sa rtx karticama, malo sam gledao benchmarke sa 1600x i Gtx 1080 cisto za neke reference i nije to loše na 2k pa čak i na 4k.
1.)
1x Procesor AMD Ryzen 7 2700, 3.20GHz, 16MB Cache, s.AM4, YD2700BBAFBOX
1x Arctic Freezer 33 eSports ONE red, Socket: 1150, 1151, 1155, 1156, 2011, 2011-3, 2066, AM4, ACFRE00042A
1x Matična ploča MSI X470 Gaming Plus, s.AM4, 7B79-002R
1x DDR4 16GB (2x8GB) PC4-24000U 3000MHz CL16 G.Skill Aegis, F4-3000C16D-16GISB
1x SSD 500GB Crucial MX500, SATA3, Read: 560MB/s, Write: 510MB/s, CT500MX500SSD1
1x HDD 2TB Seagate BarraCuda, 3.5", 7200RPM, 64MB Cache, SATA3, ST2000DM006
1x Napajanje 650W Corsair RMx Series RM650x 2018, ATX 2.4, CP-9020178-EU
1x Zalman R1 mid tower case. 192(W) x 465(H) x 450(D)mm. MB standard: Standard ATX / Micro ATX. PSU: S
Ukupno: 6.998kn
2.) normalno da nije lose na 2k i 4k jer sto je rezolucija veca to je CPU rasterećeniji
ibme74 je offline   Reply With Quote
Staro 08.12.2018., 13:04   #2313
nino
nino's Avatar
Postovi: 12,607
AMD Ryzen 7 1700X BOX = 1.507,38 kn
Cryorig H7 = 255,11 kn
XFX 650W PSU easyRail Gold = 681,12 kn
ASRock Fatal1ty Gaming B450 K4 = 823,53 kn
Team T-Force Vulcan 16GB (2 x 8GB) 3000MHz C16 = 937,02 kn
Samsung 860 EVO 500 GB 500GB = 715,86 kn
Toshiba 2TB 3.5" 7.2k SATA 6Gb/s = 507,31 kn
Ukupno: 5.427,33kn cijena za forumase. Kuciste uzmes gdje ga ima.
nino je online   Reply With Quote
Staro 08.12.2018., 22:48   #2314
S1r1uS
Datum registracije: Feb 2016
Lokacija: Mars
Postovi: 77
Ajme meni sad nemam pojma sto je najbolja opcija da sve radi kak treba na 2k.
S1r1uS je offline   Reply With Quote
Staro 09.12.2018., 09:57   #2315
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Realno sve ove tri konfe su bolje od one što si ti napisao.
Moja se jedino razlikuje naspram ostalih jer imaš kućište koje i želiš, nasljednik od S340. Te imaš puno bolji i brži SSD (koji ako ne želiš, uzmeš običan Samsung i cijena padne za cca 400kn) . A i mislim da je hladnjak najjači od ovih svih.
Kod ibme-a imaš novi i jači proc, ali da se mene pita ja bi išao bolje na NVME SSD neko na 2700 jer ipak kod tebe više utjecaja ima grafika a ne proc.
A kod nine imaš dobru cijenu (Samo ja osobno ne volim te asrock ploče za AM4 jer rade probleme sa ramom, al ne znam kako se točno ova kombinacija ponaša....)
Zadnje izmijenjeno od: FRipper. 09.12.2018. u 10:03.
Staro 09.12.2018., 13:46   #2316
S1r1uS
Lokacija: Mars
Postovi: 77
Hvala decki.
Nova revizija:
Proc: AMD Ryzen 7 1700X BOX = 1.507,38 kn
Cooler: Cryorig H7 = 255,11 kn
Napajanje: Corsair PSU, 650W, CX-M Series = 732kn
Maticna: MSI GAMING B450 PRO CARBON AC
Memorija: Team T-Force Vulcan 16GB (2 x 8GB) 3000MHz C16 = 937,02 kn
SSD: Samsung 970 EVO 500GB M.2
HDD: Toshiba 2TB 3.5" 7.2k SATA 6Gb/s = 507,31 kn
Kuciste: NZXT S340 elite
Vecina od Nine jedino sto bih dodao nvme ssd i ostao bih pri msi maticnoj te bih isao na vise manje modularno napajanje.
Staro 09.12.2018., 13:49   #2317
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,581
Ja bi samo zamjenio cooler za freezer 33 (obični ili plus), a napajanje za seasonic focus 550w. 100 eura je IMO previše za CX seriju
Staro 09.12.2018., 17:14   #2318
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
I zašto S340 koji je skuplji od H500?
Napajanje svakako bolje
Seasonic FOCUS Plus 550W Gold
Corsair PSU, 550W, TX-M Series
Staro 10.12.2018., 03:00   #2319
S1r1uS
Lokacija: Mars
Postovi: 77
S340elite mi je vec odavno zapelo za oko po dizajnu ali sam malo istrazio i H500 je također odlično.
Nova revizija nadam se finalna.
Napajanje: Corsair PSU, 550W, TX-M Series = 734.70kn
Maticna: MSI GAMING B450 PRO CARBON AC = 1305kn
Memorija: Corsair Vengeance LPX 16GB Kit (2 x 8GB) DDR4 3000MHz CL16 = 1193kn
SSD: Samsung 970 EVO 500GB M.2 = 1146kn
HDD: Toshiba 2TB 3.5" 7.2k SATA 6Gb/s = 523kn
Kuciste: NZXT H500, MIDI, MIDI, window, crno, bez napajanja = 784kn
Memorija sam stavio ovu posto je predlozena od Nine raprodana.
I grafa ce doc poslije vjerovatno Rtx 2070 a mozda i Rtx 2080.
Zadnje izmijenjeno od: coconut. 10.12.2018. u 07:44. Razlog: nema potrebe citiranja posta iznad svoga
Staro 10.12.2018., 03:28   #2320
Smartic
Smartic's Avatar
Datum registracije: Mar 2011
Postovi: 2,707
Ako mijenjaš dućan u Uzi, ploča je tamo neisplativa za 1300kn, i radije bolji RAM za takvu cijenu:
https://www.uzishop.hr/ddr4-memorije...0mhz-cl15.html
https://www.uzishop.hr/amd-maticne-p...-x370-atx.html
Staro 10.12.2018., 08:45   #2321
Wiz3m4n
Wiz3m4n's Avatar
Datum registracije: Apr 2009
Lokacija: Bjelovar
Postovi: 244
Ako nije nužna kupovina sada ja bih na Vašem mjestu pričekao 3mj. da nebi tukli glavom o zid....dolazi ryzen 3xxx serija i njihove Navi VGA koje će sudeći po svemu napraviti dar mar kako Intelu tako i sadašnjoj generaciji Ryzena/Rx....
Jasna mi je i ona da se uvijek može tako čekati jer stalno nešto dolazi, no performanse i cijena ovaj put kod AMD-a bi trebala biti drastična a ne kao kod Intela 5% za Cpu i 20% za gpu a skok cijena 50%
Živjeli!
Wiz3m4n je offline   Reply With Quote
Staro 10.12.2018., 09:42   #2322
Manuel Calavera
Postovi: 14,581
Neće ti ni Navi niti ryzen 3xxx prije 6 mjeseca, a ja vjerujem i kasnije (9 mj.). Čisto da netko ne bi ispizdio od čekanja
Staro 10.12.2018., 13:48   #2323
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Bas to...nacekati ce se
Staro 10.12.2018., 14:23   #2324
Wiz3m4n
Wiz3m4n's Avatar
Lokacija: Bjelovar
Postovi: 244
ma kolege drage, informacija iz prve ruke....halo Bing, kako brat...kraj 3mj. a kod nas do mjesec kasnije
Staro 10.12.2018., 14:47   #2325
Autor Wiz3m4n Pregled postova
Iz tvojih usta u Lisine uši
Sent from Usreo Mobara
Staro 10.12.2018., 16:31   #2326
Manuel Calavera
Postovi: 14,581
Nek vam 2 benčmarka budu da je službeno rečeno da prvo izlazi epyc milan, pa kasnije ryzen. Prema zadnjim info epyc bi trebao do 6 mjeseca...
Drugi benčmark je vega, predstavljena je u radnom stanju u 1. mjesecu, a izašla sredinom 8 mjeseca... A veoma je upitno da li će Navi biti predstavljen sada na CES-u u radnom stanju. Glasine za Navi sugeriraju od 6 mjeseca pa sve do kraja godine. Nitko nije ni spomenio mogućnost da bude Q1 2019. Poznavajuć glasine i službene najave nikad ništa nije izašlo ranije, dok je obrnuto čest slučaj.
Staro 10.12.2018., 16:42   #2327
prileee
laser
prileee's Avatar
Postovi: 2,340
A uostalom to cekanje nove generacije je glupost, kupujes tada kad mislis i imas novaca. Cekanjem mos kupit komp na sv. nikad, jer "svako malo" izlazi nova-"brza"-"bolja" generacija. A to iz prve ruke je valjda od same lise su...
Staro 10.12.2018., 17:17   #2328
trpi
dakle sto ono ocekujemo od ryzena 2, 9900k za 1800kn, sa jos jacom integriranom grafickom ? NICE.
Staro 10.12.2018., 17:34   #2329
Manuel Calavera
Postovi: 14,581
Autor prileee Pregled postova
Ja jesam za čekanje, ali pod dva uvjeta - da dolazi u skorije vrijeme (tipa mjesec dana) i/ili da se ima neki upotrebiv pc u međuvremenu tj. ako nov pc nije hitan tj. ne kuburi se pola godine ili više da bi se kupilo 10% bolje za iste novce
Staro 11.12.2018., 10:04   #2330
antebr
antebr's Avatar
Postovi: 418
Molio bi preporuku za konfiguraciju koja bi se koristila za izradu geodetskih elaborata, izradu profila, rasteri i slično. Znaci AutoCad, Geoplus...
Znaci nesto tipa:
i7 8700
16gb ddr 4 min
500gb SSD (970 evo)
2TB HDD
1050 ili 1050ti
Kućište mATX (fractal ili sl.), neka provjerena matična bez bugova. Ne trebaju nikakve ledice, bitno da je što tiše.
LP
Sent from my BLA-L29 using Tapatalk
antebr je offline   Reply With Quote
Staro 11.12.2018., 13:03   #2331
Smartic
Smartic's Avatar
Postovi: 2,707
Koliko threadova se tipično koristi? Nešto bitnija je jedna jezgra pretpostavljam.
2x Corsair 1X8GB DDR4 3000 C16 LP, COR-CMK8GX4M1D300C16
Intel CPU Desktop Core i7-9700K (3.6GHz, 12MB, LGA1151) box (ima iGPU)
SSD ADATA 512GB SX8200 Pro PCIe M.2 2280
Napajanje SilentiumPC Supremo M2 Gold 550W 80+ Gold P/N: SPC140
SEAGATE HDD Desktop Barracuda Guardian (3.5"/2TB/SATA 6Gb/s/7200rpm)
Kućište Thermaltake Core V21
GIGABYTE Main Board Desktop Z390 M GAMING
Hladnjak za procesor Thermaltake Riing Silent 12 RGB Sync Edition
Sveukupno: 8.236,86kn + grafička(polovna GTX 1070 s garancijom?)
Zadnje izmijenjeno od: Smartic. 11.12.2018. u 13:12.
Staro 11.12.2018., 13:42   #2332
antebr
antebr's Avatar
Postovi: 418
Da, nazalost AutoCad koristi 1 thread.
Konfiguracija se kupuje za firmu, tako da bez računa ne dolazi u obzir.
Zadnje izmijenjeno od: coconut. 12.12.2018. u 08:49.
Staro 11.12.2018., 16:35   #2333
Smartic
Smartic's Avatar
Postovi: 2,707
Ok, onda dodati još 1050 Ti ili 1060 6GB. Uzeti AMD karticu je inače dosta isplativije trenutno, ali ne znam točno kakva je podrška u tim alatima za njihove mogućnosti. RX 580 8GB ima za cca. 1900kn.
Staro 13.12.2018., 19:28   #2334
ampeg
ampeg's Avatar
Postovi: 184
Bok ljudi
bavim se produkcijom glazbe i naravno treba mi jako računalo jer radim s Kontakt library instrumentima koji gutaju ram ko ludi.
Kupio bih i9 proc 9 generacije. Matična ploča mora imati usb type c s thunderbolt supportom jer kupujem zvučnu karticu s tom konekcijom. Da može primiti minimalno 64gb rama i da ima na sebi onboard grafičku :-)
Koji ostale komponenete osim procesora preporučate? Limit je 15tis kuna, ako može za manje tim bolje
Jedan od mojih uradaka možete poslušati ovdje: https://soundcloud.com/mareproductio...fury-1/s-Fjls1
grrr
ampeg je offline   Reply With Quote
Staro 13.12.2018., 19:39   #2335
Smartic
Smartic's Avatar
Postovi: 2,707
Procesor Intel Core i9-9900K (16MB Cache, 3.60GHz), LGA1151 V2, boxed without cooler, BX80684I99900KSRELS
Matična ploča Gigabyte Z390 Aorus pro, s1151 V2
4x DDR4 16GB (1x16GB) PC4-24000U 3000MHz CL16 G.Skill Aegis, F4-3000C16S-16GISB
Phanteks Eclipse P400 Tempered glass Edition white, glass window, PH-EC416PTG_WT
Napajanje 550W Fortron Hydro GE, ATX 2.4, PPA5504501
SSD 250GB Samsung 970 EVO, M.2 2280, MZ-V7E250BW
MSI Core Frozr L, s. 775/1150/1151/1155/1156/1366/2011/2011-3/AM2/AM2+/AM3/AM3+/FM1/FM2/AM4, 140mm x 155mm x 84mm, 500 - 1800 ±15% RPM
Ukupno: ~12.886Kn
Možeš povećati storage ako trebaš. Koliko CPU threadova obično koristi taj softver?
Staro 13.12.2018., 20:00   #2336
ampeg
ampeg's Avatar
Postovi: 184
Autor Smartic Pregled postova
Ukupno: ~12.886Kn
Hvala na preporuci kolega :-)
Ne znam točan odgovor na tvoje pitanje. Ovo sam našao na službenoj stranici softvera koji koristim. Ableton je glavni soft a kontakt je podprogram koji s u njega učitava: vst.
How many threads are used per Live track?
Live uses one thread to process a signal path. A signal path is a single chain of audio flow. In tracks where instrument or effect racks are used, with multiple chains in parallel, Live may use one thread per chain depending on how CPU-intensive each chain may be. If two tracks are "chained" by routings, for instance by a side-chain routing, a track being fed to a return track or any tracks being fed into each-other, they are considered dependent tracks and count as one signal path. Any dependant set of tracks will use one thread each.
grrr
Staro 08.01.2019., 22:55   #2337
nenadv99
Lokacija: zadar
Postovi: 129
Pozdrav svima,
zanima me sto mislite o ovoj konfiguraciji, sto bi se dalo izmjeniti po vama. pc je prvenstveno za igre.
adm mi se cini prilicno ok sa cijenama pa bi pc uzeo kod njih. ne zelim OC, samo da je tih i da se ne grije previse.
max 18-19k kuna bez monitora.
koja je uopce razlika izmedju 8700 i 9700 procesora i jeli mozda 9900k bolji za igre ili je to overkill u ovom slucaju.
hvala na svim prijedlozima.
Procesor Intel Core i7-9700K (12MB Cache, 3.60GHz)
DDR4 16GB (2x8GB) PC4-25600U 3200MHz CL16 G.Skill Trident Z silver/red
Samsung 500GB SSD 970 EVO M.2, MZ-V7E500BW
HDD SEAGATE SSHD Desktop FireCuda Guardian (3.5"/2TB/SATA
Grafička kartica MSI RTX2080 Duke 8G OC, 8GB GDDR6
Kuciste Fractal Define R6, Blackout, bez napajanja
Napajanje ?
Nostua NH-D15
Monitor Acer XB271HU 27''
nenadv99 je offline   Reply With Quote
Staro 08.01.2019., 23:00   #2338
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,276
9700 ima 8 jezgara, 8700 6, ali ima HT, za igre je bolje 8 jezgara nego 6 + HT, tak da 9700K uzmi
Staro 09.01.2019., 15:47   #2339
nenadv99
Lokacija: zadar
Postovi: 129
hvala na odgovoru, nisam siguran jos za napajanje, treba li mi 650w ili 750w?
Staro 09.01.2019., 16:42   #2340
Broken Arrow
The Man
Broken Arrow's Avatar
Lokacija: Novi Zagreb
Postovi: 1,252
Ljudovi, molio bih savjet.
Trebao bih radnu stanicu koja bi prvenstveno sužila kao poslovna mašina koja bi vrtila neke LCA based optimizacije... znači, pošto se radi o velikim bazama podataka... što brži procesor puno rama i brz pristup hardu...
Razmišljam o nekoj kombinaciji i7 8700 ili 9700, nvme pcie hard od 512 gb te 32bg rama?
Cifra je oko 10k s monitorom, te pošto je narudžba preko firme da je sastavljeno u jednoj trgovini.
"Everybody's at war with different things...I'm at war with my own heart sometimes"
Broken Arrow je offline   Reply With Quote
