Staro 25.10.2018., 15:56   #1
DiVojich
Datum registracije: Nov 2017
Postovi: 69
Server 2008 DCenter problem
Problem s spajanjem - RDP
Spajam se na server i dobijem error
"to log on to this computer, you must be granted the allow log on through terminal services right. by default, members of the remote desktop users group have this right. if you are not a member of this group, or if the remote desktop user group does not have right, you must be granted this right manually".
s obzirom da mi imam admin podatke s kojim se mogu spojiti na server - već sam dodao Usera u navedenu grupu.(Remote Desktop Users group).
"Allow log on through terminal services" mi ne dopušta da dodam usera jer imam error "this setting is not compatible with computers running windows 2000 service pack1 or earlier. apply group policy objects containing only to computers running a later version of the operatins system."
ima li itko ikakve ideje?
DiVojich je offline   Reply With Quote
Staro 25.10.2018., 20:12   #2
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Pod remote postavke na DC-u skini kvačicu s "only remote desktop with network level authentication" pa probaj...nisam 100% ali mislim da bi ti to trebalo pomoći.
Staro 25.10.2018., 20:36   #3
Alister
Alister's Avatar
Datum registracije: Aug 2009
Postovi: 1,492
Nije to, to je kada se pokušava spojiti sa starijih Windowsa pa ga odbije i prije logiranja.
Da li ti je u tom policy-u dodan remote desktop groups?
Da li ti admin ima prava putem remote-a ili s njim ideš lokalno?
Imaš dignutu domenu ili ?
Koji su ti user ili grupe pod allow Log on locally
Alister je online   Reply With Quote
Staro 25.10.2018., 21:47   #4
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
jok bebe, mene je *ebalo upravo to, s 10-ke Neki "fix" od MS je zeznuo stvar, od prije par mjeseci.
Staro 25.10.2018., 22:06   #5
Postovi: 8,226
Poupdejtaj si masinu s koje se rdp-as
Staro 25.10.2018., 22:55   #6
Alister
Alister's Avatar
Postovi: 1,492
Pitanje je da li se s tog računala spaja s admin podacima, jer ako da onda nije to tih postavki već je vezano za usera
Staro 26.10.2018., 12:51   #7
DiVojich
Postovi: 69
Autor tor Pregled postova
Hvala na info, već je bilo to odabrano.
Staro 26.10.2018., 12:54   #8
DiVojich
Postovi: 69
Autor Alister Pregled postova
Error se pojavi kada korisnik upiše username/password.
Dodan je Remote Desktop Groups i sami korisnika je dodan u tu grupu i nije dalo rezultata.
Admin prava idu putem remotly.
Imam dignutu .local domenu.
Pod log on locally imam samo Administratore, drugo ne mogu ništa dodati.
Staro 26.10.2018., 12:55   #9
DiVojich
Postovi: 69
Autor Pupo Pregled postova
Korisnik ne želi da se išta update-a tj. vlasnici ne daju.
Staro 26.10.2018., 13:23   #10
Alister
Alister's Avatar
Postovi: 1,492
jel taj server i DC ujedno, dodao si usera u lokalnu grupu Remote ili u domensku grupu?
Staro 26.10.2018., 14:04   #11
DiVojich
Postovi: 69
Server nije DC. Kad sam usera dodao u grupe remote/domain, nisam se mogao prijaviti. kada sam ga izvadio iz tih grupa, nisam se mogao prijaviti.
Staro 26.10.2018., 14:26   #12
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Autor DiVojich Pregled postova
Možda se nismo dobro razumjeli, NE treba biti odabrano, skini kvačicu jel...po defaultu je zakačeno.
Staro 26.10.2018., 14:39   #13
Old Iggy
Old Iggy's Avatar
Postovi: 4,888
Bježi od tamo.
Igor Batinic
Staro 26.10.2018., 14:42   #14
syss
syss's Avatar
Postovi: 10,805
pa ukratko... da
Staro 26.10.2018., 14:54   #15
DiVojich
Postovi: 69
Autor Old Iggy Pregled postova
Bježi od tamo.
Rado bih pobjego od tamo ali što ćeš....ne isplati mi se uopće komentirat il živcirat oko toga
Staro 26.10.2018., 14:56   #16
Alister
Alister's Avatar
Postovi: 1,492
daj ti tog usera privremeno stari u grupu admin i vidi da li ti onda radi pristup. Da se riješi dilema user prava ili problemi s RDP-om i te spike
Staro 26.10.2018., 15:20   #17
DiVojich
Postovi: 69
kada ga se stavi u admin grupu, sve radi bez problema
Staro 26.10.2018., 15:34   #18
Alister
Alister's Avatar
Postovi: 1,492
On ne smije imati admin ovlasti?
Koliko vidim jedino da napraviš push kroz GPO da taj user ima log on locally prava na tom serveru
