Staro 21.12.2005., 20:57   #1
Brain32
Brain32's Avatar
Postovi: 498
Forceware v81.98
Je izasel je
ftp://download.nvidia.com/Windows/81.98/
Iz release notes-a:
Single GPU Issues Resolved
• Low Viewperf 8.01 scores occur with Dual Core and dual processor systems.
• Dual Core Processors: Corel Paint Shop Pro X does not work.
• Rendering problems occur in Need for Speed: Most Wanted.
• GeForce 7 Series: Ground textures in Flight Simulator 2004 do not render correctly when using “Ultra High” settings.
• GeForce 7800 GTX 512: The system cannot resume from Standby.
• GeForce 7800 GTX/GT: Running F.E.A.R. hangs the system on the Apple 30ʺ Cinema display when Monitor Scaling is used.
• GeForce 7800 GTX/GT, GeForce 6800/6600: Ground and water textures are corrupted when zooming out in Civilization 4.
• GeForce 7800 GTX/GT, GeForce 6800: Shadows fail to render in Splinter Cell 1.
• Dual GeForce 7800 GTX/GT: Everquest 2 launches to a black screen when antialiasing is set to 2xQ at 1920 x 1200 resolution.
• GeForce 7800 GTX 512: Chronicles of Riddick does not run at resolutions higher than 800x600.
• GeForce 7800, GeForce 6800: Corruption is seen in Flight Simulator 2004.
• GeForce 7800 GTX, GeForce 6800, Quadro FX 4500: The system slows down with the Liquid Edition SD time line.
• GeForce 6800: Wrong colors appear when playing QuickTime trailers using the non-native video resolution.
• GeForce 6800 Ultra / GeForce FX 5950 Ultra: Battlefield 2 has corruption or crashes when a player switches from zoomed commander view to zoomed sniper view.
• GeForce 6800: Shimmering or cropping of the full-screen video mirror occurs when covering the video window with another window.
• GeForce 6150/6100, Windows XP Media Center Edition: The driver does not recognize display connection changes that occur during a
system shutdown.
• GeForce 6100/6150, Windows Media Center Edition 2005 Update Rollup 2: HD modes are listed as available when a TV is connected
using S-Video.
• GeForce 6150/6100, Windows XP Media Center Edition 2005: The display remains inactive when resuming from Suspend mode.
• GeForce FX 5200: Textures disappear in CrimeLife v105.
• GeForce4 Ti 4200, Windows 98: Java applications crash when calling OpenGL.
SLI-Related Issues Resolved
• GeForce 7800 GTX 512, SLI: In Battlefield 2 and other applications, screen corruption occurs with SLI AA enabled.
• GeForce 7800 GTX, SLI: Everquest 2 launches to a black screen when antialiasing s set to 2xQ.
• GeForce 6800, SLI: There is pausing in Colin McRae Rally 5 when SLI is enabled.
• GeForce 6800, SLI: Corruption occurs on the golf course in Tiger Woods 2006 with 2x antialiasing enabled.
• GeForce 6800, SLI: The desktop doesn't refresh after exiting Black and White 2.
• GeForce 6800, SLI: Nothing appears below the SLI load balancing line in 3DMark06 when SLI AA is enabled.
• GeForce 6600 VE, SLI: “Lack of video bridge” error message appears when enabling SLI without the SLI connector.
• GeForce 6600, Windows XP, SLI: The system occasionally hangs when playing Everquest 2.
• GeForce 6600, Windows XP, SLI: When the quality level is set to Extreme Quality, EverQuest 2 does not render correctly with 4x
antialiasing enabled at 1600x1200.
Brain32 je offline   Reply With Quote
Staro 21.12.2005., 22:00   #2
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Jel se isplati to skidat?
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 21.12.2005., 22:19   #3
Brain32
Brain32's Avatar
Postovi: 498
Hm, ne znam kaj da ti velim ali ak te nista s liste fix-eva osobito ne privlaci ne vidim razloga... Kol'ko sam skuzio NFS MW i dalje ima svoje musice, no uskoro bi trebala izach beta 82.12 pa cemo vidit...
Staro 22.12.2005., 13:10   #4
LorD ClockaN
od LemilicE
LorD ClockaN's Avatar
Lokacija: Veli Lošinj
Postovi: 4,712
Ne znam o kakvim uvijek greškama spominjete za Most Wanted i CoD2.
Meni sve šljaka bez problema. Nisam ni prismrdio te greške i zastajkivanja
Nemam više lema!!!
Staro 22.12.2005., 13:35   #5
Brain32
Brain32's Avatar
Postovi: 498
Pa cuj ne znam kaj da ti velim osim da mi je drago kaj nemas tih problema tim vise kaj si ovo(sig) ziher fino platio, ali meni recimo NFSMW ide na full do jaja u 30-40fps, ali tu i tamo padne na 20-25 sto je prilicno iritantno, a sa CoD2 performansama uopce nisam zadovoljan jer "ide" u 20-22fps i 40 kad gledam u zid ali neovisno o postavkama:confused:
No mislim da to tak i onak nije do drivera nego do debilnih game-developera.
Staro 22.12.2005., 13:44   #6
Hrubi
Hrubi's Avatar
Datum registracije: Sep 2004
Postovi: 817
istina.Meni je recimo prvi stage u COD2 isao jako lose,a sad sam u nekoj pustinji i igra leti.Prodjem par misija kad ono opet steka.Ista stvar je i u NFSMW.
Hrubi je offline   Reply With Quote
Staro 22.12.2005., 16:49   #7
jed2i
jed2i's Avatar
Datum registracije: Jul 2004
Postovi: 1,771
dobri su ovi novi driveri
dobijem par fps-a vise u igrama
3d mark dobijem oko 100 bodova vise
