Staro 02.05.2018., 16:08   #961
Frung
Frung's Avatar
Lokacija: zg westside
Postovi: 625
Ovakvo nešto?
https://www.asus.com/Motherboards/Z270-WS/
Samo to je kaby ploča jel, ali ima na nabavi uglavnom, a i na tržnici sam vidio.
Frung je offline   Reply With Quote
Staro 11.05.2018., 20:35   #962
Postovi: 8,546
Gigabyte Z370 Aorus Ultra Gaming 2.0 ... Review?
There has been a lot of behind the scenes things going on with the Z370 Aorus Ultra Gaming. Having spotted so many problems with the original model we have been constantly liaising with our local Gigabyte contact to ensure that this revised model allowed the top of the line Gigabyte Z370 to flourish to the heights it should reach. We were assured that the issues noticed had been solved, the whole power phase element redesigned, that, in short, this was a new beast and worthy of an entire "two point oh" version. We had barely scratched the surface of the AUG 2.0 before it became crystal clear that the flaws of the original hadn't been fixed. Not remotely. Perhaps worst of all is the fact that even the safety procedures where the motherboard will automatically either throttle everything or shut down entirely to save your hardware seem to still not be in place.
Gigabyte had set that to 105c on the original which once we had tested and informed them of the issues their answer was to just increase the limit to 125c. Sadly that limit is still in place on the V2.0. Now the Mosfets are rated for 125c but the issue is that the actual mosfets will be running 10-15c hotter than the probe will be reporting (the probe is on the motherboard not the actualy mosfet) It would be bad enough if it shut off all the time, but to merrily melt everything in a ten mile radius is a bit ridiculous. The only possible scenario in which we could even cautiously recommend the Z370 Aorus Ultra Gaming 2.0 is one in which you solely browse the internet, or perhaps use a single core or two at stock speeds.
Izvor: OC3D
Staro 11.05.2018., 23:11   #963
BladeRy
BladeRy's Avatar
Datum registracije: Aug 2008
Postovi: 2,000
O majke ti, sta su oni napravili od ploce. Vrm se pece do tocke taljenja.
A ja mislio da je moja sa 42c u idleu i 75c nakon 2 ure kodiranja u adobeu po proslogodisnjem toplinskom valu u sobi bez klime puno.
Staro 25.07.2018., 19:32   #964
Redline
Redline's Avatar
Lokacija: Vž-Mb
Postovi: 385
Pozdrav, ima ko jednu od Asus maximus x ili Gigabyte ploča da provjeri dal se na GUI od zvučne može poštimati da na dva analogna izlaza ide isti signal. Znači da se može tipa na plavi izlaz koji je inače rear speakers postaviti da bude front speakers isto ko zeleni izlaz, pa su u tom slučaju dva front speakers izlaza iz ploče. Obično su na zelenom i plavom izlazu, zeleni je inace front speakers, a plavi rear speakers koji sad radi isto ko front. Nekad se to dalo postaviti na pločama, ali sad kolko vidim nema na Z370 pločama srednjeg ranga, moja Asrock K6 nema te opcije niti Asus strix.
Zadnje izmijenjeno od: Redline. 04.08.2018. u 01:43.
Redline je offline   Reply With Quote
Staro 04.08.2018., 01:39   #965
Redline
Redline's Avatar
Lokacija: Vž-Mb
Postovi: 385
Autor Redline Pregled postova
Nema nikog da čekira? na nekoj od jačih Z370 ploča... Pošto je ovu informaciju nemoguće naći na netu...
Konkretno me zanima trenutno za AORUS Gaming 7 / ASUS Maximus X Hero / ASRock Z370 Taichi -> ekipa s tim pločama?
Staro 04.08.2018., 09:23   #966
RainZG
Postovi: 727
Mogu ti ja provjeriti ali tek sutra navecer kada se vratim s mora. Imma gaming 7 z370
RainZG je offline   Reply With Quote
Staro 05.08.2018., 23:11   #967
RainZG
Postovi: 727
Dakle, na Gigabyte Gaming 7 Z370 na dva izlaza imam analog front speaker out. Kada sam ustekao slusalice u taj drugi audio out pitao me sto sam ukljucio, odabrao sam front speaker out i to je to. Upravo imam isti zvuk na zvucnicima i slusalicama istovremeno
Staro 06.08.2018., 17:32   #968
Redline
Redline's Avatar
Lokacija: Vž-Mb
Postovi: 385
Puno hvala! Ostali sa ASUS Maximus X Hero / ASRock Z370 Taichi? ako ima ko da je voljan provjeriti? Jednu od tih 3 ploca planiram uzet ovaj tjedan za svoj 8600K
Staro 06.08.2018., 17:49   #969
Frung
Frung's Avatar
Postovi: 625
Evo ja na Gigabyte Z370N imam front speakere na plavom a sluške na zelenom i zvuk ide van na oba stalno, pa ako ti info znači što.
Staro 05.09.2018., 07:12   #970
Mogy
Hala Madrid!
Mogy's Avatar
Postovi: 1,323
Jutro ekipa
Razmišljam uskoro nadograditi računalo i uzeti i7 8700k procesor. Ne želim dati previše novaca za matičnu, a opet bi htio da bude kvaliteta ploča s obzirom na spomenuti procesor.
Sveo sam izbor na 3 matične ploče koje bih kupio:
1. ASRock Z370 EXTREME4
2. MSI Z370 GAMING M5
3. ASUS ROG Strix Z370-H
Da napomenem da mi RGB nije baš bitan. Bitna mi je lakoća korištenja biosa, dobar OC potencijal itd.
Na CPU planiram staviti NOCTUA NH-D15 cooler.
Ukoliko mislite da postoji bolji izbor od ove 3 navedene ploče molim Vas da slobodno date preporuku
Hvala na savjetima
Mogy je offline   Reply With Quote
Staro 05.09.2018., 08:24   #971
Smartic
Smartic's Avatar
Datum registracije: Mar 2011
Postovi: 2,707
Hmm, za to sve što si naveo, Asus Z370-F
Eventualno Z370 Extreme K6(ista cijena ko i Extreme 4 kolko vidim). Malo mesnatija od -F, ali Asusica ima bolji/jednostavniji BIOS.
Staro 05.09.2018., 12:04   #972
zgmmax
zgmmax's Avatar
Postovi: 1,678
Imam problem..
U firmi su naručili Asus TUF Z370-Plus Gaming i Intel Core i7-7700.
MBO podrzava 8th gen procesore, a ovaj proc je 7th gen.
Dal postoji BIOS upgrade da podrzava gen7 procesore da se rijesim muke oko povrata?
Nazalost smo to primijetili prilikom sastavljanja
zgmmax je online   Reply With Quote
Staro 05.09.2018., 12:39   #973
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,589
Noup, ništa od toga
Staro 05.09.2018., 13:08   #974
tiki66
tiki
tiki66's Avatar
Postovi: 2,763
Naravno zamijeniti ćeš procesor a ne matičnu, jer novi i7 su jači od te stare generacije
Staro 06.09.2018., 16:38   #975
zgmmax
zgmmax's Avatar
Postovi: 1,678
Tnx na odgovorima.
Lakse mi mijenjat maticne jer manje gubim sa njihovim povratom nego povratom procesora.
Mada mi je malo cudno da nas nisu upozorili iz ducana kada su vidli sto se je sve narucilo.
Staro 06.09.2018., 17:09   #976
Manuel Calavera
Postovi: 14,589
IMO bolje promjeni cpu, nema logike ići nazad na 4 jezgre i EOL socket gdje je 4c8t maximum
Staro 06.09.2018., 17:19   #977
Smartic
Smartic's Avatar
Postovi: 2,707
Staro 15.11.2018., 17:05   #978
lateralus_eye
lateralus_eye's Avatar
Postovi: 603
Pozdrav!
Uzimam Intel i5 8600K procesor. Uzeo bi matičnu do 1500kn. Dajte par opcija! I da, OC-at ću procesor. Hvala!
lateralus_eye je offline   Reply With Quote
Staro 15.11.2018., 18:42   #979
Smartic
Smartic's Avatar
Postovi: 2,707
Samo je jedna
https://www.nabava.net/search.php?q=Z390+Aorus+Elite
Btw. za što koristiš PC i koji je ostatak konfe?
Staro 15.11.2018., 18:47   #980
lateralus_eye
Postovi: 603
Najviše za gejmanje, filmovi, muzika... ostatak konfe u opisu!
Staro 05.02.2019., 16:30   #981
zwer54
zwer54's Avatar
Lokacija: Dublin
Postovi: 1,977
Bok,
koja bi bila najbolja ploca za oc 8086K i ram? Trenutno sam na Z370 Taichi ali ne mogu postici ram na vise od 4100, a 4266kit je...
Znaci zanima me ploca koja moze oc do neba, cijena nebitna... Al cisto provjeren info... Nemojte ponudu na Godlike ili giga xtreme jer su najskuplje... Ako je koja od njih stvarno najbolja, nije problem, ali zanima me doslovno najbolji izbor, ne najbolji marketing...
hvala
Staro 05.02.2019., 22:09   #982
23-D
23-D's Avatar
Datum registracije: Apr 2008
Postovi: 272
Ekipa, može jedno BLAST FROM THE PAST pitanje?
Crknula mi stara s775 điđabajt EP45-UD3LR na kompu od kćerke, pa gledam malo polovnjače po oglasima.
Proc je E8500 i 4x2GB OCZ Reaper 1066 ramovi.
Konfa nije za nikakve ekstreme, na korištenje 12 godišnje klinke.
Imam par kandidata i tražim mišljenje:
(primarna stavka je dugovječnost, khm, koliko je moguće pričati o dugovječnosti sa 10 godina starim pločama)
EP45-UD3R
P5Q Deluxe
P5Q Pro
P5Q-E
23-D je offline   Reply With Quote
Staro 06.02.2019., 09:26   #983
Od ove 4 koju god oćeš. P5Q Deluxe je DDR2 flagship i najjača ploča ovdje.
P5Q-E, eno je kod mene 11-tu godinu radi i ne pokazuje znakove umora. P5Q Pro je malo slabija od P5Q-E ali nije loša.
Gigabyteovu sam imao EP45-UD3P, ova joj je slična, isto dobra ploča.
Pošto je gore E8400 (ako je E0, digni to na 4GHz ko od šale), doslovno možeš uzeti ploču koju hoćeš, najjeftiniju iz te ponude. Uglavnom nemreš fulat. Asuske ti imaju nešto bolji BIOS (AMI) i lakše ih je moddat za s771 Xeone jednog dana. Gigabyte ima onaj star gadni Phoenix award BIOS, žuta slova plava podloga
I za kraju, razmisli, samo razmisli o quad procesoru Core2Duo procovi lagano gube dah, pogotovo sa novim browserima.
Sent from Usreo Mobara
Staro 06.02.2019., 11:17   #984
23-D
23-D's Avatar
Postovi: 272
Hvala Brko.
Otprilike sam i ja shatio da vjerojatno ne mogu pogriješiti sa niti jednom od ovih.
Našao sam neke combo oglase upravo sa quadovima (q6600, q8400, q9550) koje sam mislio možda prodavat da pokrijem dio troška, ali dobro kažeš, duali su ipak već malo zastarjeli.
Poslano sa mog SM-G920F koristeći Tapatalk
Staro 06.02.2019., 11:34   #985
Np
Imaš po 100 kn moddane Xeone koji su ekvivalenti Q9550/Q9650 punokrvnih quadova. Samo flešaš moddani BIOS na socket 775 procu, ubaciš Xeona i vozi miško.
Q8000 nemoj. Nisu baš bogzna što. Q6600 je OK, ali to je 65nm pa nije baš da može daleko taktom. No ako misliš da ti je 3GHz dosta, Q6600 za sitne pare može biti dostatan.
No ako uzmeš neku od Asusica i odlučiš se na Xeona, bios moddani ti pošaljem jer imam sve biose od kompletne P5Q serije
Čak imam i Xeona X5450 E0 (Q9650) viška ako će ti trebati, ali kod mene se blesirao na P5Q-E ploči, no ako si voljan probati, javi se. Pošaljem ti ga pa se igraj sa njime, meni ionako stoji bezveze. Kolega s foruma ga je isprobavao, ali njemu nije ni radio na G43 DDR3 ploči. Kod mene na G31 i P35 čipsetima je išao na 4.3GHz, a na P5Q-E se blesio.
Po meni, ako nije neka lova, najbolje uzeti onda kombo P45 ploču sa Quadom, bilo Xeon bilo Q6600 ili Q9550/Q9650. Osjetno su bolji od Q8000 quadova.
Staro 06.02.2019., 19:42   #986
maXonja
bu
maXonja's Avatar
Datum registracije: Jan 2017
Lokacija: VŽ
Postovi: 2,622
Slažem se sa Brkom oko svega, i procesora i ploče, naravno sve ovisi kolika je razlika u cijeni
Neki Xeon ili Q9550 i P5Q Deluxe bi bila dobitna kombinacija, ali niti sa bilo kojom pločom od ostalih nabrojanih nećeš pogriješiti
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 06.02.2019., 21:05   #987
23-D
23-D's Avatar
Postovi: 272
Eto, nabacio par bidova za P5Q-E i P5Q deluxe bundlove. Nadam se da ću upecati štogod zanimljivo
Staro 06.02.2019., 21:07   #988
Sretno. S tim pločama neš fulat. A ako ti treba Xeon, javi
Staro 01.03.2019., 22:55   #989
Nixis
Casual gamer
Nixis's Avatar
Postovi: 802
Ne znam jel spada u temu, ali ostao sam neugodno iznenađen B250 čipsetom.
Naime, spojih 3x LED trake od phanteksa direktno na RGB 12V header na matičnu nadajući se da ću putem Mystic Lighta koji je reklamiran na MSI webu kao RGB lightning.
Spojih tako na matičnu i krenuh skinut Mystic Light App i iznenadio sam se errorom da mi sistem nije podržan.
Naime, Mystic Light ne radi na budget čipsetima MSI-a već samo high end.
No dobro, skinuo sam MSI Gaming App jer je to alternativa. Još jedno iznenađenje - opcije za osvjetljenje su krnje i jadne. Ne postoji mogućnost rainbow effecta ili mjenjanja boja automatski, a i izbor boja je doslovno 7 komada (bijela, plava, zelena, žuta itd...).
Tako da ako mislite kupiti neku "budget" matičnu, iako doduše 700-1000kn baš i nije nekakva budget matična za većinu Hrvata, nemojte se nadati lightshowu sa led trakama
Nixis je offline   Reply With Quote
Staro 01.03.2019., 23:54   #990
Manuel Calavera
Postovi: 14,589
Zašto upće B250? Stari socket, samo quadovi...
