Staro 09.07.2018., 11:24   #37231
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Hm, zanimljivo, temperatura rashladne tecnosti 90C, temperatura ulja tek preko 60C. Pokazuje koliko zapravo puno treba da se i ulje ugrije.
Staro 09.07.2018., 11:42   #37232
ThePornstar
ThePornstar's Avatar
Postovi: 4,403
Ma dobro to, ali da nema šahovnicu na haubi i retrovizorima te proper zastavice, to ne razumijem
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
Battery: 57 Wh internal
ROM: Android 9
Staro 09.07.2018., 11:53   #37233
Wolverine
Wolverine's Avatar
Postovi: 12,431
Autor SRV Pregled postova
Prema tom pokazivaču temperatura ulja mi je uvijek na oko 70-80.
Ode do 90-100 samo ako sam u gužvi i onda odma ugasim auto pa ulje ode gore vjerojatno jer hladi turbine.
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 09.07.2018., 11:56   #37234
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Kazes "turbine", to imaju dvije?
Staro 09.07.2018., 12:13   #37235
Wolverine
Wolverine's Avatar
Postovi: 12,431
Upravo tako
PSX_20180709_020950
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 09.07.2018., 12:27   #37236
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Jao jao.
Je li to napravljeno da simultano rade, ili se sta smanjuje turbo rupa?
Staro 09.07.2018., 19:09   #37237
Facelessone
Facelessone's Avatar
Postovi: 4,205
Valjda 3 cilindra na jednu 3 na drugu
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 09.07.2018., 19:11   #37238
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Slaba vajda onda, dobijes samo jos veci feeling turbo rupe.
Staro 09.07.2018., 19:32   #37239
Facelessone
Postovi: 4,205
Mislim da si u krivu, ali ajd. Lag bi trebao biti manji. Ak se varam, jbg.
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 09.07.2018., 19:37   #37240
Wolverine
Wolverine's Avatar
Postovi: 12,431
Jao jao.
Ne kuzim, nikad nisi cuo za biturbo motore?
Da, svaka strana ima svoju malu turbinu. Po jedna na svakoj ispusnoj grani.
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 09.07.2018., 19:42   #37241
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
velim ti, kad se odlucis na prodaju, javi mi. Ovdje ga ne mogu nac u dobro stanju.
Staro 09.07.2018., 19:53   #37242
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Naravno da sam cuo, nego mislio sam da nije verzija gdje je jedna manja i jedna veca turbina, gdje je manja non stop on. I tako samo smanjuje turbo rupu - odnosno ne nudi nista na 2000rpm+.
Staro 09.07.2018., 22:15   #37243
Gabre
Lika u mom srcu
Gabre's Avatar
Postovi: 9,887
nije to 1.4 turbo od 300ks pa da ima turbo rupu, vec 2.7 V6 koji sam po sebi vec ima ohoho momenta u niskim okretajima.
Staro 10.07.2018., 01:50   #37244
X-Plosiv
X-Plosiv's Avatar
Postovi: 1,811
Po zimi zna proći i 15 do 20 minuta prije nego se ulje ugrije, baš gledam kazaljku ulja i preko zime zna proći vremena..
Staro 10.07.2018., 04:38   #37245
Wolverine
Wolverine's Avatar
Postovi: 12,431
Lag je primjetan kao i kod svakog turbaka tog godišta, no ništa strašno jer već praktički u leru taj motor daje preko 200 Nm momenta. Baš zato da se smanji lag ima dvije manje K03 turbine.
image image
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 11.07.2018., 10:02   #37246
zkljaja
Brat od Đon Vejna
zkljaja's Avatar
Lokacija: zg-vg
Postovi: 1,204
Udarit mu remap, ali lagani neki, kad je bal
Staro 13.07.2018., 02:58   #37247
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Ahhhh moras voljet (stockholmski sindrom) Renaulte. Danas sam vozio Talismana dCi 130 EDC s 110km na satu (ne tisuca, nego 110km) i nosaci motora kao da su vec odradili 110 tisuca kilometara. U manual modu kod dodavanja i oduzimanja gasa fino trese kabinu, negdje ima fajn praznog hoda.
Za Lagunu vec imam na lageru doma nosace, izgleda da ce ih se namijenjat i na Talismanu.
Staro 13.07.2018., 12:10   #37248
ThePornstar
Postovi: 4,403
Pa moraju se razradit
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
ROM: Android 9
Staro 13.07.2018., 16:02   #37249
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Autor IcyTexx Pregled postova
Mozda je vracan.
Staro 13.07.2018., 21:03   #37250
murina
murina's Avatar
Postovi: 495
Mocan je Tesla za vidit
Staro 13.07.2018., 21:10   #37251
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Ne znam bas. Meni je ogavan.
Staro 13.07.2018., 23:15   #37252
partwish
Creeper
Datum registracije: May 2013
Postovi: 2,216
I meni je katastrofa.
Staro 13.07.2018., 23:38   #37253
bertone
bertone's Avatar
Datum registracije: Mar 2010
Postovi: 2,063
I meni... danas sam na Zgb obilaznici vozio iza jednog par sto metara 90 km/h jer je ispred nas bio šleper koji je preticao drugi šleper... i onda kad se šleper napokon maknuo u desnu traku vidio sam Teslu još nekih 7-8 sekundi... baš fuj kako ubrzava, ogavno i katastrofa
Staro 14.07.2018., 11:23   #37254
Wolverine
Wolverine's Avatar
Postovi: 12,431
Tu ih gledam 24/7
Ovih Modela 3 ima ko blata. Fakat moram otić jedan dan i odradit neki test drive.
Iskreno, što ih dulje gledaš to ti se više počinju sviđat
KREK
https://www.news1130.com/video/2018/...ught-on-video/
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Zadnje izmijenjeno od: Wolverine. 14.07.2018. u 11:29.
Staro 14.07.2018., 12:28   #37255
murina
murina's Avatar
Postovi: 495
fituristički dizajn mu je primjeren. Vjerujem da je i interijer dosta prostran. Nisam nikad sjeo u Teslu, ne znam ni koji je ovo model ali bih rado napravio đir od Norveške i nazad (ili jos bolje obratno &#128578
Staro 14.07.2018., 17:07   #37256
Gabre
Lika u mom srcu
Gabre's Avatar
Postovi: 9,887
Auto je ružan u pm, pogotovo u bijeloj boji.
Lijepo su spustili kajlu ovdje u Ontariju, ukinuli 14,000 dolara subvencije za kupnju el. vozila.
Vidit ćeš sad kolko će ih se prodavati...
Staro 15.07.2018., 13:22   #37257
murina
murina's Avatar
Postovi: 495
Koji auto tih gabarita ti je lijep?
Staro 16.07.2018., 17:38   #37258
Gabre
Lika u mom srcu
Gabre's Avatar
Postovi: 9,887
Bilo koji u toj klasi je ljepši od tog, pogotovo unutrašnjost.
Staro 17.07.2018., 02:17   #37259
webstartm
Sandy!!!
webstartm's Avatar
Postovi: 1,692
Jel iko ima iskustva sa Chevrolet Spark 2010 pa nadalje, m300 serija.
Gledam uzet jednog polovnog za po gradu, pa eto ako neko zna.
1.0 50kw , abs, klima, 6x airbags
webstartm je online   Reply With Quote
Staro 17.07.2018., 15:19   #37260
Postovi: 10,253
Je li Vulkal ok firma za kupiti gume online, jesu ok sto se tice webshopa, isporuke i sve sto ide u tom procesu?
