Staro 30.06.2018., 14:07   #91
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Ono što je 100% sigurno da x80 model nove generacije bude najmanje brz kao x80Ti model iz prošle generacije, uz dosta bolju efikasnost. Ili brži naravno
Staro 01.07.2018., 11:38   #92
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,278
upravo to.. dokazana shema
ja se i dalje fajn igram, i sa starim grafama.. tko voli neka plati skuplje
MojSkuter
Staro 06.07.2018., 01:09   #93
Manuel Calavera
Postovi: 14,584
Nvidia reportedly stockpiling one million next-generation graphics cards
Aside from that, it looks like NVIDIA can expect some sort of relief with the inventory as China’s Sichuan province has been hit by major flooding and the region alone accounts for almost 70% of the mining operations. This led to major drops in the global mining hashrate as several mining setups have been affected and severely damaged. Now, one thing to consider is that currently, all major Taiwanese based graphics card manufacturers were expecting a 40% drop in shipments but this could change things for them. Also, a 20% drop in price was expected since anywhere other than China, the cryptomarket is declining and lots of used graphics cards are now entering the market at really cheap prices.
One of the many mining operations that has been affected by flooding in mainland China. You can see a range of AMD based Radeon cards in the flooded pile.
One of the many affected mining operations by the recent flooding in China. These mining firms may opt to purchase new setups which will spur a rise in graphics card demand and that may ease up some inventory issues for NVIDIA. As soon as inventory returns to safe levels, we can see NVIDIA fast forwarding the launch of their next-gen GeForce gaming cards.
Staro 06.07.2018., 20:21   #94
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,554
Opereš, osušiš i deri miško
Sigurno nisu bile pod naponom kad je voda došla.
Moguće je BESPLATNO produžiti W10 sigurnosne nadogradnje do 2028!
Staro 22.07.2018., 16:40   #95
Manuel Calavera
Postovi: 14,584
NVIDIA GTX 1170 Alleged Benchmark Leaked, Faster Than 1080 Ti
Ovo isto nije bilo linkano, AdoredTV je izračunao da je taj 12nm čip velik između 600-650mm2 te da je vjerojatno jači nekih 25-35% od 1080Ti (ili je rekao titan xp, isti kuki). Usporedbe radi Titan Votla je na istom 12nm nodeu 815mm2, a 1080ti 471mm2 na 16nm. Za Ampere spominje da je to generacija nakon turinga (dakle ne prvotno ime za turing ili mining verzije), dakle 7nm gpu za nagodinu, no to ćemo još vidjeti...
To bi i bilo tako po tradiciji, 1170 egalish ili da prebaci malo 1080Ti, a da 1180 bude brža nekih 30-ak % +/-
Staro 22.07.2018., 17:02   #96
Nek 1170 bude u pricingu kao 1070 kad je izašla i GG
Sent from Usreo Mobara
Staro 22.07.2018., 17:05   #97
Max_Damage
Max_Damage's Avatar
Lokacija: Krapinske Toplice
Postovi: 959
Super. Mislil sam si da bum prešel na Vegu radi Freesync-a ali ovo ak je istina, i dalje bum na zelenom...
Max_Damage je offline   Reply With Quote
Staro 22.07.2018., 17:22   #98
Manuel Calavera
Postovi: 14,584
Cijenom od 3700kn+? E nebudu
Tendencija je i da se dižu cijene svim kategorijama, 970 po dolasku ~ 3000-3200, 1070 ~ 3700kn, ovo bude vjerojatno preko 4 soma. No svakako bi morala biti jeftinija/isplativija te efikasnija od gtx 1080Ti, to nije sporno
Autor Max_Damage Pregled postova
Ma kakvu vegu, em se ne isplati ni pod razno (preskupe), em je praktično non-gaming gpu. Navi (nove mainstreamuše) budu nagodinu (generacija poslije nvidijinog turinga) išle do gtx 1080 odnosno vega 64 performansi maximum (ako te uopće te perfomanse zadovoljavaju). I to ako ti se da čekati, a i pitanje je kakva će situacija biti sa miningom i cijenama tada. Osim toga upgrade ti je samo nvidija
Zadnje izmijenjeno od: Manuel Calavera. 22.07.2018. u 17:30.
Staro 23.07.2018., 12:40   #99
tole_
Casual Racist
tole_'s Avatar
Lokacija: Sneed's feed and seed (formerly Chuck's)
Postovi: 422
3Dmark score je fake što se može vidjeti ako se podaci utipkaju u calc http://elmor.se/3dmark . Isto tako je čudno što je 3dmark prepoznao naziv kartice, jer obično piše Generic adapter ili tako nešto za kartice koje još nisu izašle.
Kako sada stvari stoje Ampere bi trebao biti naziv sljedeće HPC uarch bazirane na 7nm procesu koja dolazi u H1 '19 i mijenja Voltu. Gaming verzije će doći kasnije i pitanje je koji će naziv imati jer lako je moguće da nvidia nastavi s različitim uarch za HPC i gamer segment. Ovo je inače početkom godine objavio neki Kinez koji je dao legit info i za Maxwella i za Pascala, tako da je vjerojatno i ovo istina.
https://www.techpowerup.com/246207/n...h-dates-leaked Opet dick tease...
Why did the console peasant cross the road?
To render the buildings on the other side!
tole_ je offline   Reply With Quote
Staro 23.07.2018., 15:05   #100
Joza_Seraf
Joza_Seraf's Avatar
Datum registracije: Jun 2015
Lokacija: Klc
Postovi: 568
Izgleda da cemo svi u zeleni tabor. Po tome 1160 6GB ako bude, ili neki drugi naziv tipa 8 GB, biti jaca od 1070?
Samo čekam dan kada će mi netko pokucati na vrata i zatražiti me bubreg jer sam negdje odscrollao dolje i stavio kvačicu na "Slažem sa svime"!!
Joza_Seraf je offline   Reply With Quote
Staro 23.07.2018., 15:13   #101
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,262
Navodni datumi, ali uzet sa šakom soli jer navodno ovaj Jutjuber voli pričat gluposti:
Slobodno me dodajte na PSN
Disco je online   Reply With Quote
Staro 23.07.2018., 15:41   #102
Manuel Calavera
Postovi: 14,584
Linkao je već Tole
Inače i u wccf članku za onaj "leak" pišu 4 razloga zašto je vjerojatno fake, no neovisno o tome gtx 1170 neće biti slabija od gtx 1080ti. Što se tiče 1160 modela neće to sigurno u prvom valu izaći. Uvijek prvo idu x70 i x80 model, a ostalo po potrebi
Staro 24.07.2018., 06:51   #103
Gigi1
Postovi: 2,138
Volta arch ce biti nove serije, sto je logicno. Turing je izgleda samo bio rezerviran za mining arch od koje se odustalo nakon pada crypta.
Ne bi skodilo promjeniti naziv teme
Zadnje izmijenjeno od: Gigi1. 24.07.2018. u 06:57.
Staro 24.07.2018., 11:00   #104
Manuel Calavera
Postovi: 14,584
Wut? Odakle ti to?
Volta je pro arhitektura i neće doći za gamere. Turing je naziv sljedeće gamerske generacije, priče o mining i non-mining gpu su očito bile netočne, Ampere je generacije poslije turinga (hpc ili gamerska nije sigurno). Očito su tada bila leakala ta dva imena, pa se pokušao naći neki smisao, a mining je tad bio relevantan i otud ta priča.
Staro 24.07.2018., 12:12   #105
Gigi1
Postovi: 2,138
hwinfo64 ce nadodati podršku za GV102 i GV104 u novom updejtu.
sigurno je nvidia skresala tensor jezgre ali volta je ime arch prema ovome
Staro 25.07.2018., 02:21   #106
Manuel Calavera
Postovi: 14,584
Now GV is the prefix for the Volta series but this is something that has an easy explanation. Companies can easily issue inaccurate names against machine ids for the purpose of obfuscation. We have seen this before in the days when shipping manifests were still public (Zauba anyone?) when NVIDIA started hiding the names of their upcoming graphics cards and are probably seeing it again now. If this actually was Volta (or a lighter version thereof), a more accurate naming scheme would have been GV204 and 202.
Staro 31.07.2018., 21:11   #107
subabuse
subabuse's Avatar
Postovi: 107
PROCURILA PRVA GTX1180!!
Evo malo eksluzive i na PCEkspert(da mi i vi budete koji put brzi, bar medju top5), u glavnom procurila prva gtxica 1180 u Vietnamu, kaj nit nije tak cudno jer ih tam i rade...
Ne znam jel to prototip il gotov proizvod, al kosta ko svetog Petra kruna..
Najvjerojatnije ce je kupit neki casopis il AMD..
ne znam jel ih ima puno ill samo ova jedna..
Name:	procurila GTX 1180.jpg‎
subabuse je offline   Reply With Quote
Staro 31.07.2018., 21:27   #108
bambi56x
bambi56x's Avatar
Postovi: 357
Super, ali su zaboravili na gornjoj strani kutije prepravit 1080 u 1180...
bambi56x je offline   Reply With Quote
Staro 31.07.2018., 21:34   #109
maXonja
bu
maXonja's Avatar
Datum registracije: Jan 2017
Lokacija: VŽ
Postovi: 2,595
A bogme se i bočno skuži na kilometre ove jedinice da su prepravljane
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 31.07.2018., 21:34   #110
Smirite strasti. To je staro već mjesec dana.
Zadnje izmijenjeno od: Brko. 01.08.2018. u 19:40.
Staro 01.08.2018., 00:06   #111
Manuel Calavera
Postovi: 14,584
Staro 01.08.2018., 10:20   #112
Wolfman89
Postovi: 9
Kakva je generalno situacija u HR po pitanju novih generacija grafičkih kartica, tj. koliko je do sada u prosjeku trebalo da se nove kartice pojave u domaćim trgovinama nakon službenog predstavljanja?
Wolfman89 je offline   Reply With Quote
Staro 01.08.2018., 10:24   #113
A nije svaki puta bilo isto. Kad su predstavljali recimo davno tamo 2012 GTX600 seriju, grafe su maltene isti dan bile u HR trgovinama.
A recimo 2016 kad su predstavljali Pascala tj GTX 1000 seriju, bilo ih je ali jako jako malo. Htio sam kupiti u srpnju a na lagerima u HR u nekim većim količinama su se počele nakupljati krajem kolovoza/početkom rujna, tako da sam ju uzeo u rujnu. A zanimljivo je i to da kad sam uzo svoju 1070, bila je među zadnjima jer isto bio grabež samo takav.
Računaj da je kroz mjesec dana od launcha možeš imati.
Staro 02.08.2018., 10:46   #114
subabuse
subabuse's Avatar
Postovi: 107
Hmm...( sad sam i ja bolje pogledo onaj vietnamski .jpgi bogme je shoop da whoop, vidi se i sa strane)
Sad kad bolje razmislim, prvo ce isplivat Founders Edition za blesavo bogate,majnere i jutubere, ak je serija 11 , onda je vjerovat da ce je zvat 11#0(il ak je po MX150 ,
moguce da ce promjenit u GT1#0 I GTX1#0?!).
GTX20#0 mislim da nece bit jel je Rajzn preblizu...
RX580>VEGA64> konacno su se uspjeli riješit RadiOnPomalo
nVidia mora nekaj smislit da se sprda s AMDom, bar malo... RX1180
Staro 02.08.2018., 15:52   #115
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,552
Staro 02.08.2018., 17:54   #116
scarzz
scarzz's Avatar
Lokacija: Stuttgart/Rijeka
Postovi: 414
scarzz je offline   Reply With Quote
Staro 02.08.2018., 22:59   #117
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,850
mislim da nisam nigdje vidio/čitao kolko će bit brže od predhodnika??
1180 vs 1080
1170 vs 1070
1160 vs 1060
Staro 02.08.2018., 23:12   #118
Smartic
Smartic's Avatar
Datum registracije: Mar 2011
Postovi: 2,707
Koliko sam vidio po glasinama... otprilike isti broj CUDA jezgri će stavljati za onaj niži model u odnosu na trenutnu generaciju, uz povišene clockove i GDDR6.
Na papiru 40-50% na svaki model koji mijenja isti u ovoj seriji.
Staro 03.08.2018., 07:12   #119
Znači 20% max.
Staro 03.08.2018., 08:52   #120
maXonja
bu
maXonja's Avatar
Lokacija: VŽ
Postovi: 2,595
Ako će biti samo 20% onda su komotno mogli napraviti
1050 u 1130
1060 u 1150
1070 u 1160
I za 1180/Ti roknuti GDDR6 na 1080/Ti i još malo podebljati clockove
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
