Staro 14.12.2017., 10:01   #151
Postovi: 16,712
Meni osobno, nit miriši nit smrdi. Ok je igra, da se ne lažemo, ali to je igra za ubiti vrijeme, ništa drugo.
Staro 14.12.2017., 10:19   #152
Roberto
Roberto's Avatar
Postovi: 2,636
Da se ne lažemo, odigram 2-3 igre godišnje, i služe mi upravo za brainless fun
Staro 15.12.2017., 15:41   #153
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,276
Zadnje izmijenjeno od: mamutarka. 15.12.2017. u 16:26.
Staro 23.01.2018., 07:54   #154
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,580
MINIMUM CONFIGURATION:
OS: Windows 7 SP1, Windows 8.1, Windows 10 (64-bit versions only)
PROCESSOR: Intel Core i5-2400 @ 3.1 GHz or AMD FX-6300 @ 3.5 GHz or equivalent
VIDEO CARD: NVIDIA GeForce GTX 670 or AMD R9 270 (2GB VRAM with Shader Model 5.0 or better)
SYSTEM RAM: 8GB
Resolution: 720p
Video Preset: Low
RECOMMENDED CONFIGURATION (60 FPS):
PROCESSOR: Intel Core i7-4770 @ 3.4 GHz or AMD Ryzen 5 1600 @ 3.2 GHz or equivalent
VIDEO CARD: NVIDIA GeForce GTX 970 or AMD R9 290X (4GB VRAM with Shader Model 5.0 or better)
SYSTEM RAM: 8GB
Resolution: 1080p
Video Preset: High
4K 30 FPS CONFIGURATION:
OS: Windows 10 (64-bit version only)
PROCESSOR: Intel Core i7-6700 @ 3.4 GHz or AMD Ryzen 5 1600X @ 3.6 GHz or equivalent
VIDEO CARD: NVIDIA GeForce GTX 1070 or AMD RX Vega 56 (8GB VRAM with Shader Model 5.0 or better)
SYSTEM RAM: 16GB
Resolution: 2160p
Video Preset: High
4K 60 FPS CONFIGURATION:
PROCESSOR: Intel Core i7-6700K @ 4.0 GHz or AMD Ryzen 7 1700X @ 3.4 GHz or equivalent
VIDEO CARD: NVIDIA GeForce GTX 1080 SLI or AMD RX Vega 56 CFX (8GB VRAM with Shader Model 5.0 or better)
SYSTEM RAM: 16GB
Resolution: 2160p
Video Preset: High/Ultra
Supported NVIDIA cards at time of release:
GeForce GTX 600 series: GeForce GTX 670 or better
GeForce GTX 700 series: GeForce GTX 760 or better
GeForce GTX 900 series: GeForce GTX 950 or better
GeForce GTX 10-Series: GeForce GTX 1050 or better
Supported AMD cards at time of release:
Radeon 200 series: Radeon R9 270 or better
Radeon 300/Fury X series: Radeon R7 370 or better
Radeon 400 series: Radeon RX 460 or better
Radeon Vega series: any Radeon Vega series
Staro 23.01.2018., 08:27   #155
Roberto
Roberto's Avatar
Postovi: 2,636
Dobro je, negdje sam između minimum i recommended
Staro 23.01.2018., 08:32   #156
Odlično, bude bez beda 1080p60
Još 2 mjeseca... taman.
Sent from Mobara
Staro 23.01.2018., 09:23   #157
Postovi: 16,712
Vukla bude to i moja kanta bez brige
Staro 23.01.2018., 13:46   #158
doky
doky's Avatar
Datum registracije: Nov 2010
Postovi: 1,942
Ne znam kak se neko može ložit na ovu igru, pogledo sam više manje sva videa i ovo mi izgleda kao definitivno najgori skin mod Far Crya do sad.. Zapravo setting i atmosfera mi baš i nejdu pod Far Cry. Ne znam kolko će još vremena morati proći od FC4 da mi ovo postane zanimljivo..
doky je offline   Reply With Quote
Staro 23.01.2018., 15:14   #159
Max_Damage
Max_Damage's Avatar
Lokacija: Krapinske Toplice
Postovi: 959
Eto, i ja sam pogledal par videa na YT-u i osim par novih fičura, voziš avion i slično, ne znam baš.. Nije me nešto jako zainteresiralo. A sad igram FC4.. Tak da...
Max_Damage je offline   Reply With Quote
Staro 23.01.2018., 15:20   #160
Postovi: 16,712
Pa jer je prva dobra igra koja će izaći ove godine. Ako bude fail, super, ako bude igriva, ponovo super, ali nemamo što igrati trenutno.
Staro 23.01.2018., 16:35   #161
...ali nemamo što igrati trenutno.
Ja imam
Ma neće biti fail. Fail će biti onima kojima je fail bila i 3 i 4. Meni su bile odlične. I priče i lokacije.
A moram priznat da su mi ova priča i lokacija isto primamljive po tom pitanju, pa makar i reskin bio ali zbog toga kaj je SAD u priči, mislim da ne bude oderavanja kože i skupljanja smilja i bosilja za craftanje injekcija i kožnatih tobolaca
Brda i voda vjerojatno budu copypaste sa drugim texturama, ali možda se malo odmaknu od šprance FC3, FC4 i FCP. Barem malo...
U svakom slučaju veselim se... dok ne izađe Exodus.
Sent from Mobara
Staro 23.01.2018., 16:41   #162
Postovi: 16,712
U potpunosti se slažem s tobom.
FC5 i Exodus se čeka.
Staro 23.01.2018., 16:46   #163
Max_Damage
Max_Damage's Avatar
Postovi: 959
U nedostatku boljih igara koje će izaći, FC5 će biti ok, bolje gubit vrijeme na tak nekaj nego na nekakav Wičer
Staro 23.01.2018., 16:49   #164
Neću komentirat ovo
Ali taman nekako bude izašao FC5 kad planiram zgotovit W3 pa bude to taman
Ali nije mi jasna cijena... 70 eura za šta? Ime?
Sent from Mobara
Staro 23.01.2018., 17:10   #165
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,276
eh da je bar ovo igra poput Far Cry 1, ideš rokaš, diviš se grafici
a ne skupljanju sjemenki i ostalim RPG elementima, naravno netko i to voli dapače
meni je samo žao što su se odmakli od korijena
Staro 23.01.2018., 17:20   #166
joolka
music freak
joolka's Avatar
Lokacija: Sibenik
Postovi: 3,315
Far Cry 1 je bio dobar dok nisu dosli ona cudovista...pre naporno postalo pogotovo pri kraju igre.
tribali su ga nazvati Far Doom
LENOVO LEGION 5 Pro Gaming Laptop (AMD Ryzen 7 7745HX,RTX 4060,32gb DDR5,2tb SSD)
Staro 23.01.2018., 17:20   #167
Max_Damage
Max_Damage's Avatar
Postovi: 959
Neću komentirat ovo
Sent from Mobara
Misliš da budeš gotov sa w3 do tad? Šalim se za W3, i ja ga mislim odigrati uskoro, kad crowd kaže da je super, onda mora biti super, zato smo ovdje da razmjenjujemo mišljenja. Ali idem u OT.
Pa da, "nova" igra, ide se na old glory pa drito na 500 kunića.. I biti će ljudi koji će to kupiti po toj cijeni, dok će neki čekati discount
Staro 06.02.2018., 09:11   #168
Roberto
Roberto's Avatar
Postovi: 2,636
Ubisoft has revealed a brand new story trailer for Far Cry 5 and season pass DLC details alongside it.
We can safely say that this isn't the kind of DLC we would have expected, but it certainly channels the spirit of the Far Cry series. There are three DLC packs confirmed and between them they'll take players back in time to the Vietnam war, pit them against zombies in the ultimate b-movie, and even take them up to Mars (yes, the planet) to go head to head with some Martians.
While purchasing the game's season pass will guarantee access to each of these packs, it'll also give players Far Cry 3: Classic edition. On consoles this'll be the game's single-player content, while on PC it'll be the full game.
http://www.techradar.com/news/far-cr...ews-and-rumors
Staro 07.02.2018., 16:00   #169
Doktor O
I encompass, and I eclips
Doktor O's Avatar
Datum registracije: Jul 2010
Lokacija: Plazikur
Postovi: 1,015
kakva je to igretina bila...dan kad je izašao far cry 2 pa sam vidio kud su kreuli tad sam digao ruke od far crya.
Doktor O je offline   Reply With Quote
Staro 07.02.2018., 16:06   #170
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,276
ja dvojku nisam mogao, al stvarno dulje od 10 minuta igrat, previše sam i rekao
neznam zašto su uopće odlučili ostavit isto ime i ukaljat far cry s time
mislim kužim zašto, na temelju FC1 se sve ovo poslije njega i prodaje
Staro 07.02.2018., 16:09   #171
Postovi: 16,712
Ja sam ju čak i prošao Mada je bila smetje žešće
Staro 07.02.2018., 16:14   #172
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,276
o jebote, ti stvarno imaš toleranciju za svašta
Staro 07.02.2018., 16:15   #173
Postovi: 16,712
Ovisi o trenutku
Staro 07.02.2018., 16:28   #174
Autor Max_Damage Pregled postova
Do izlaska FC5, ja odigram 3x Wičera na moj način, a to je NE rješavanje igre na 100%
No sad trenutno ne igram niš, nemam vremena...
Sent from Mobara
Staro 07.02.2018., 16:48   #175
Max_Damage
Max_Damage's Avatar
Postovi: 959
Sent from Mobara
Ajd da i ti nemaš jednom vremena
Staro 07.02.2018., 21:15   #176
Bome, kako je godina počela sa FC3 i Witcher 3, mislio sam da bude OK sad više nije api za FC5 bumo našli
Sent from Mobara
Staro 28.02.2018., 21:38   #177
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,276
wat
Staro 28.02.2018., 21:43   #178
Kako jedva čekam krenuti u tamanjenje Da je onaj prvi release date bio, danas bi igra i izašla... ako se sjećam od pred pola godine i više, bilo je 28th Feb 2018. Ali dobro, samo što nije
Staro 28.02.2018., 21:46   #179
Postovi: 16,712
Ludilo. Mogo bi biti isti psihopat kao i na trojki Već sada znam da, ako će biti izbora, ovaj je mrtav da ga jebeš
Staro 28.02.2018., 21:49   #180
Ovaj govnar bi mogao biti jači od Pagan Mina, pogotovo ako bude kenjavio u stilu Xerxesa iz filma 300
Eto 60-80 sati gameplaya ko iz čičke na ovom. I fala bogu, nema tornjeva/beacona više...
