Staro 24.12.2017., 19:07   #1
pilgrim_23
pilgrim_23's Avatar
Datum registracije: Nov 2011
Postovi: 104
(riješeno) Gigabyte GA-AB350M-Gaming 3 krepala?
Evo ukratko: flashao sam bios sa f6 na f10 njihovim APP centerom, vjerojatno je nešt pošlo krivo jer je jedna verzija biosa između F7a, a ovaj vrag je skinuo odmah f10 verziju.
Uglavnom nakon flashanja i restarta sve vrti, svjetli, ali nema signala na monitoru i rgb tipkovnica ne svjetli..
Probao sam clear cmos vađenjem baterije, probao sam reset preko jumpera, vadio keks memorije, probao samo s jednim i ništa..
Ploča i proc su kupljeni u Linksu i sad mi je frka to nositi kod njih jer sam garant mjesec dana bez kompa.
Proc je r5 1400, memorija je uredno radila na 2.666Mhz, znači prije flashanja nikakvih problema nije bilo od prvog dana, bios sam redovito nadograđivao i sve je bilo o.k.
Ima još kakvih trikova ili nosim na reklamaciju, i ako nosim uzimam i memoriju ili samo ploču i proc koji su kupljeni kod njih?
Zahvaljujem unaprijed!
All my life I fought this fight
The fight that no man can never win
Every day it just gets harder to live
This dream I'm believing in
Thunder Road..
pilgrim_23 je offline   Reply With Quote
Staro 24.12.2017., 19:36   #2
Dzavke
Datum registracije: Oct 2013
Lokacija: Vukovar
Postovi: 22
Posto ploca ima dual bios, probaj :
Method #1:
1. Shut your PC down (if you're reading this guide, than your PC isn't working anyways)
2. Hold the power button until the PC starts and shuts down again
3. Press the power button again, your backup BIOS should kick in now and should re-flash the main BIOS if there's anything wrong with it.
Method #2:
2. Hold the power AND the reset button for about 10 sec, than release.
3. Backup BIOS should kick in anytime soon now.
Method #3:
Had to use this one in order to get my 990FXA-D3 working again. Backup BIOS kicked in using method #2, but I was back to the good ol' no signal state once the procedure finished..
1. Short out pins 1 and 6 on the main BIOS chip (pin #1 should be marked with a red dot or whatever)
2. Tell a friend (or a relative) of yours to press the power on button
3. Remove the ghetto-like jumper you're holding between pins 1 and 6 as soon as you hear a beep.
4. Backup BIOS should kick in again and everything will (hopefully) be fine.
Preuzeto :
http://forum.gigabyte.us/thread/1356...gaming-useless
http://www.overclockers.com/forums/s...byte+dual+bios
Lik kaze da mu je sa metodom 2 proradilo.
Dzavke je offline   Reply With Quote
Staro 25.12.2017., 10:24   #3
Srdan
Srdan's Avatar
Postovi: 1,212
Nema veze što je preskočio F7, meni je isto skočio s F6 na F10 i sve normalno radi.
Jel' ima šta ženskih starih
što vole strance da
nas vozaju u autu
i kupuju skupe lance
Srdan je offline   Reply With Quote
Staro 25.12.2017., 10:52   #4
pilgrim_23
pilgrim_23's Avatar
Postovi: 104
Autor Dzavke Pregled postova
Method #1:
Method #2:
Method #3:
Preuzeto :
Isprobana metoda 1 i 2 i ništa..
Fakat ne kužim, ako imam dual bios koji jarac ne mogu loadati backup bios..
Jedino kaj mi kod metode 2 pada na pamet je da mi možda reset switch ne radi, kolko čitam svima je ta metoda dala rezultat.
Sve je spojeno uredno, provjereno x puta..
Se može kako ručno uključiti reset i stisnuti power button a da sve ne ode u k...?
Thunder Road..
Staro 25.12.2017., 10:53   #5
nino
nino's Avatar
Postovi: 12,597
Ja na svojoj imam jumper za drugi bios, pa provjeri.
Edit: da li beepa ako upalis bez ram-a?
mob
Staro 25.12.2017., 15:30   #6
alengrosevic
alengrosevic's Avatar
Postovi: 3,775
Meni se b85 gigabyteica tako zbrikala. Metoda 3 mi je pomogla. Taj dual bios nekad ne uskoci jer mu primarni ne javi da je zbrikani. Tako sam negdje procitao objasnjenje. Ugl metoda 3 ce ti 99,9% pomoci. Samo potrazi pomoc nekoga da upali komp dok ti drzis kratko spojene pinove.
Edit: onda moras opet flashati primarni bios sa novijim. Jer backup pregazi primarni sa svojim koji je tvornicki napucan, kod mene je bio ver 1.0.
Staro 26.12.2017., 08:39   #7
pilgrim_23
pilgrim_23's Avatar
Postovi: 104
Autor nino Pregled postova
mob
Ma ne beepa uopće, ali nije ni prije, nikad nisam čuo nikakav zvuk kod paljenja kompa, možda je u biosu tako podešeno.
Evo isprobana i metoda br. 3 i ništa.
Bum danas sve povadil iz kištre pa na stolu probam uz precizniji pristup.
Ako ništa nosim sutra u Links pa sam kroz GO od dva tjedna bez kompa..divotica.
Thunder Road..
Staro 26.12.2017., 10:11   #8
Nemoj se dalje zejebavat. Odnesi u Links na RMA i bok.
Ako ti je problem čekat novu ploču, odma kupi neku drugu ili istu takvu, a onda prodaj novu zapakiranu sa novim jamstvom kad dobiješ povrat.
Spušit ćeš 100 kuna. Ili tako ili čekaj. Ploča je rikavela.
Meni je tako P5Q-E prdnula 31.12.2008 prilikom postavljanja playliste za novogodišnji party. Poslao sam ju u Links dan dva nakon nove godine i dobio drugu 31.01.2009. Mjesec dana je na statusu pisalo "testiranje robe / utrvrđivanje kvara". Ne znam koliko su se ubrzali po tom pitanju od onda.
Sent from Mobara
Staro 10.01.2018., 06:28   #9
pilgrim_23
pilgrim_23's Avatar
Postovi: 104
Evo jučer vraćena ploča sa servisa, piše da je izvršen update biosa i da je test o.k.
Sve ja to fino opet složim i rezultat je isti kao i prije.
Svi ventilatori rade, ledice na matičnoj svjetle, grafa vrti, ali nema signala na monitoru i na tipkovnici.
Probao sam po jedan keks memorije šaltati po svim utorima ali ništa.
E sad, ploča bi trebala biti o.k. prema Asbisu.
Moguće da je proc u pitanju?
Nažalost nemam komponente za provjeru i sad sam u banani..
Ima netko kakvu ideju?
Znaći sve to se dogodilo nakon flashanja biosa, do onda je sve radilo perfektno..
Thunder Road..
Zadnje izmijenjeno od: pilgrim_23. 10.01.2018. u 08:00.
Staro 10.01.2018., 07:51   #10
tiki66
tiki
tiki66's Avatar
Postovi: 2,721
A ne preostaje ti drugo nego isprobati s drugim komponentama, izvaditi M2 disk i "ogoliti" ploču pa tako probati itd. Za početak ja bih isprobao s nekom drugom grafičkom
Staro 10.01.2018., 08:28   #11
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,578
Da, probaj odspojit hdd, miš, tipkovnicu pa onda idi bootat
Staro 10.01.2018., 10:36   #12
pilgrim_23
pilgrim_23's Avatar
Postovi: 104
Budem probal gore navedeno, a i uspio sam nabaviti drugu grafičku pa popodne sprobam..šteta kaj proc nema integriranu grafičku, sad bi mi puno pomoglo..
Zahvaljujem!
Thunder Road..
Staro 10.01.2018., 11:16   #13
Manuel Calavera
Postovi: 14,578
Meni tako prije par godina jednom nije htjelo bootat neš vjerovat - zbog krepane tipkovnice (crn ekran, svi ventovi se vrte)
Staro 10.01.2018., 17:37   #14
pilgrim_23
pilgrim_23's Avatar
Postovi: 104
Evo isprobana nova grafa, u oba utora sa i bez memorije, izvadjeni disk, bez misa i tipkovnice i opet nista..
Je moguce da je proc?
Sent from my SM-G903F using Tapatalk
Thunder Road..
Staro 10.01.2018., 17:42   #15
Manuel Calavera
Postovi: 14,578
Iznimno je mala mogućnost, no ako si sve ostalo eliminirao moguće je...
Staro 11.01.2018., 06:40   #16
pilgrim_23
pilgrim_23's Avatar
Postovi: 104
Pošto ostajem bez ideja na pamet mi je palo da prva verzija biosa podržava samo ryzene 7, sa drugom verzijom F4 je dodana podrška za ryzene 5.
E sad kaj su ovi u servisu apdejtali iz njihovog radnog naloga se ne vidi, samo piše izvršen update biosa, test o.k.
Budem ih probal nazvati ili im poslati mail..
Thunder Road..
Staro 11.01.2018., 07:51   #17
tiki66
tiki
tiki66's Avatar
Postovi: 2,721
Pa piše upgrade biosa, nisu radili downgrade
Nazovi ih i pitaj jesu li uopće vidjeli grešku. Moguće da su vidjeli, flashali, da je radilo neko vrijeme i da je opet crklo. Možda najbolje da odeš tamo osobno sa procesorom i mbo i napomeneš da je ovo reklamacija reklamacije i ako je serviser tamo da pokuša to odmah upaliti pred tobom
Staro 11.01.2018., 07:55   #18
pilgrim_23
pilgrim_23's Avatar
Postovi: 104
Autor tiki66 Pregled postova
To mi je i namjera, uzeti kištru i direkt na servis..
Poslal sam im mail, poslije ih budem zval i ako treba odmah popodne pičim do njih..
Thunder Road..
Staro 11.01.2018., 18:36   #19
tiki66
tiki
tiki66's Avatar
Postovi: 2,721
Ajd pa javi kako je prošlo
(da ja mogu svoju flashati bez bojazni )
Staro 11.01.2018., 18:58   #20
pilgrim_23
pilgrim_23's Avatar
Postovi: 104
Evo ovg trena sam ga upalio napokon..
Uglavnom, bio sam na servisu, ploča radi, bios F10 gore, proc radi, memorija ne radi..ni jedan keks..
Sad sam otišao u dućan i kupio 8 giga memorije 2400MHz i konačno ga bootao.
Stara memorija nema šanse da je samo tak krepala i to oba keksa, vjerojatno se u biosu nekaj pošemerilo pa ju ne prepozna..
Sutra bum se poigral s tim..
Eto, nakon 3 tjedna konačno sam za svojim kompom..kakvo olakšanje
Edit:
Nije mi vrag dal mira, otišal sam u bios i uključioXMP profil kak je bilo i prije, ubacim svoju memoriju i radi..
U 6 p.m.
I sad ovu memoriju kupljenu danas moram na njuškalo staviti ili probati vratiti u web shop..
Thunder Road..
Zadnje izmijenjeno od: pilgrim_23. 11.01.2018. u 19:21.
