#2582 |
Datum registracije: Apr 2008
Lokacija: GER
Postovi: 724
jel ko korisiti WINDOWS 10 REGISTRY TWEAKS FOR MINING Once windows is full installed and booted for the first time i always run the Windows 10 Registry tweaks for mining.bat file https://mega.nz/#!8gZzjQaa!Dt4wE0WEo...6CJgFZTXKq9pnQ (i am not disabling everything, just things that i think wont be needed, windows update, cortana, crash reports etc..) Back Up Your Registry or create a restore point Run in administrator mode Once everything is applied, restart the rig List of Tweaks Replace Utilman with CMD Disable Cortana, Bing Search and Searchbar Disable automatic Windows Updates Disable Hibernation Disable tracking services Disable WAP Push Message Routing Service Disable Windows Search Disable Superfetch Disable Windows Defender Disable OneDrive Disable Quick Access as default view in Explorer show computer shortcut on desktop Show file extensions Disable lockscreen Enable classic control panel view Hide indication for compressed NTFS files Disable Windows Update sharing Remove Pin to start Classic vertical icon spacing Remove versioning tab from properties Disable jump lists Remove telemetry and data collection Change Logon screen background with accent color Disable Windows Error Reporting Removing Windows default apps Blocking Telemetry Servers |
#2583 |
Datum registracije: Sep 2017
Lokacija: mostar
Postovi: 4
[QUOTE=FRipper;3100384]Tamo upišeš transakciju i vidiš di je otišlo,i to onda priloži poloniexu pa neka vide ukucavala ne moze da pronadje transakciju,prije toga je uspjesno 1 ltc prosao tu odmah nadju,kada udjem u svoj novcanik pise mi za tu transakciju da je nepotvrdjena,da li je moguce da je hakovano jer nema ih ni u novcaniju ni na poloniexu |
#2584 |
Postovi: 95
#2585 | |
Postovi: 1,629
dio toga napravim sam... dio toga mi nije pao na pamet... ali mislim da ću napraviti. ako ću imati malo vremena bacim oko... Mene je uvjek frka bilo šta instalirati na rig, s obzirom da postoji opastnost od toga da instaliraš trojanca.. |
#2586 |
Lokacija: GER
Postovi: 724
Pa mozes si sve pogledati sto je postavljeno Na testnom rigu sam stavio... pa cu vidit ocu to i na ostale Elpida Bios RX 570 http://www.mediafire.com/file/u71etk...570+elpida.rom Zadnje izmijenjeno od: croclocker. 10.09.2017. u 19:15. |
#2587 |
Lokacija: Zupanja
Postovi: 12
[QUOTE=FRipper;3100982]Na YT je sigurno Samsung ili Micron memorija, a ti imaš Hynix kojoj je max s ocom tako oko 19. Hvala na odgovoru... Dal ja kako mogu iz nje izvući nešta više od 19 hashrate...? |
#2589 | |
Lokacija: Zupanja
Postovi: 12
hvala na odgovoru... Dal bi ja kako mogo izući iz te kartice šta više o 19 hash
#2590 |
Lokacija: Zupanja
Postovi: 12
#2591 |
Lokacija: Čazma
Postovi: 1,728
Odabir svake će bit pogreška jer grafičkih kartica sa samsungom više nema. |
#2593 |
Lokacija: Čazma
Postovi: 1,728
#2594 |
DIY DILETANT
Lokacija: Čistilište
Postovi: 3,541
Pa zar nisu 1060 6GB grafe još uvijek blagoslovljene Samsungovim čipovima? Prije par tjedana je Fripper nešto na tu temu natuknuo ak se ne varam. Gadna je situacija, sve iznad 1060 je masno precijenjeno, bilo prije, sad još više. A Radeoni nikako opet na 1500kn pasti ![]()
Moguće je BESPLATNO produžiti W10 sigurnosne nadogradnje do 2028! |
#2595 |
Lokacija: Čazma
Postovi: 1,728
Da radeoni padnu na 2000 bilo bi već razumno. |
#2596 |
Lokacija: Zupanja
Postovi: 12
Pošto je takva situacija šta kažete o ovome...? https://www.protis.hr/products/detai...m_medium=click ili za 1500 kn da uzmem još jednu MSI GTX 1050 TI GAMING X 4G 15 hashrate na eth...? Poslano sa mog F5321 koristeći Tapatalk |
#2597 | |
Lokacija: Čazma
Postovi: 1,728
Uzmi 1060 i rokaj zec ili zen. |
#2598 |
Datum registracije: Nov 2011
Lokacija: Daruvar
Postovi: 308
Ja sam kupio antiminer s7,za 600 ojera,sad planiram ili kupiti gotov rig ili sam složiti,6x 1060,ili slićne.Brine me isto hinix,a 1070 su bezobrazno skupe.Ako mi naleti, neki gotov rig, sa 1060,što moram paziti,osim da ima garanciju.Lp |
#2599 | |
DIY DILETANT
Postovi: 3,541
Gigabyte Windforce, Zotac AMP, MSI 1060 3GT OC su dobri primjeri dobrih hladnjaka. Uzi/Alza imaju Windforce po 1750kn. Hynix, ofkors ![]()
#2600 |
Datum registracije: Oct 2013
Postovi: 132
Zanima me koje su razlike za određene modele gtx1060? Gledam postoje Gigabyte, Gainward GeForce, MSI, Zotac, Asus GeForce... Hvala unaprijed. |
#2601 |
Lokacija: Zupanja
Postovi: 12
Zašto mi se ovo dešava...? Do danas je radilo sve kako treba... ![]() Poslano sa mog F5321 koristeći Tapatalk |
#2602 |
Lokacija: Zupanja
Postovi: 12
I ovo ni je na eth... Majner vrti al se ništa ne vidi i worker mi je crven..? Dal tko zna o čemu se radi u ova dva slučaja..? Sve radilo u redu do danas... ![]() Poslano sa mog F5321 koristeći Tapatalk |
#2604 |
Lokacija: Zupanja
Postovi: 12
Da prva je eth, a druga zcash... Majno sam eth i vidio sam da jučer cijeli dan mi se nije ništa nakupili a majner pokazuje da se vrti i vidio sam da mi je worker crven... Onda sam stavio zec jer sam njega Majno dok sam imo jednu grafičku i radilo je prije i radilo je i sad sve do et jutros... Poslano sa mog F5321 koristeći Tapatalk |
#2605 |
Lokacija: Zupanja
Postovi: 12
Ugl jel imo itko ovakav slučaj i jel itko zna riješenje...? Poslano sa mog F5321 koristeći Tapatalk |
#2606 |
Datum registracije: Apr 2017
Postovi: 23
Pozdrav, jedno pitanje Kakva je gainward gtx 1080 (cijena oko 4500kn?) kao sto sam rekao, sluzila bi za gejming i majning. (inace igram na 1080 50" tvu) tako da mi nereba ta jacina graficke, vec bi se zadovoljio i sad nekom drugom. Ugl pruza mi se prilika uzed i msi gtx 1060 6gb (cijena 2600kn) e sad, preporuka za neki eventualni buduci majning. (recimo da me vise zanima majning, al eto moram od nekud pocet sudeci da se nemogu isprsit za par komada grafickih. osim do 5000kn max. nadam se da ste razumili pitanje. (da mozda ciljam 2x 1060? 1080? 1070 ne spominjem jel ih nemaaaaaaaa) |
#2607 | |
Postovi: 95
Bar ces znati da nije napajanje/žice/konektori problem. |
#2608 |
Lokacija: Zupanja
Postovi: 12
Nemam s čime izmjeriti al ću probat stavit u pcie od ove grafičke koja radi.... Al ovo se meni dešava na zec majneru, a na eth ona radi... Poslano sa mog F5321 koristeći Tapatalk |
#2609 |
Datum registracije: Aug 2017
Postovi: 111
Imam RIG 5 X 570 4 GB Elpida, Pošto mi je napajanje 1000 w i ima još jedno mjesto kupio bih proširenje raisera za ploču i stavio SAPPHIRE NITRO+ RX 570 8GB GDDR5 GPU dali je to dobro riješenje? Mislim u smislu dalui bi mi to bilo dostatno napajanje i dali imate neku "pametniju" karticu koja više rudai MH/s za kupiti. Cijena nije važna Hvala (početnik). ![]() |
#2610 |
Lokacija: GER
Postovi: 724
Dali je ko imo iskustva sa power color rx 570/580 ? lp |
