Staro 07.09.2017., 11:46   #2521
maja333
Datum registracije: Sep 2017
Lokacija: mostar
Postovi: 4
ltc novcanik
Adresa je dobra u novcaniku vidim da nisu isporuceni znaci zarobljeni negdje jer ih nema ni u nivcaniku ni na poloniexu
maja333 je offline   Reply With Quote
Staro 07.09.2017., 11:52   #2522
O9g1
Bee-do Bee-do Bee-do, TUP
O9g1's Avatar
Datum registracije: Aug 2009
Postovi: 323
Autor Gigi1 Pregled postova
fantje, pokusavam nac u hr/zg shop gdje se moze kupiti pc power/reset switch da ne cekam s ebaya jer mi je tlaka zavlacit se sa srafcigerom.
pokusao sam na nabavi u trazilici pistati na hrv prijevod ali bezuspjesno, rucno trazenje po par shopova pod kablovima i ostalom opremom isto bezuspjesno...
ima netko tip koji shop ili sto da upisem u trazilicu
Nađeš lijepo neku staru kantu (a svi ih imamo bar 2-3, negdje zatrpane u garaži pod hrpom drugog nepotrebnog smeća ), razvališ i voila!
Ja sam sebi tako napravio
CPU: Intel i5 2500k (BX80623I52500K) cooled by Scythe Ninja3 (SCNJ-3000)
MBO: Asus P8Z68-V PRO/GEN3
RAM: 2x4GB Kingston 1600MHz, DDR3, XMP (KHX1600C9D3K2/8G)
GPU: GIGABYTE Radeon R9 290 4GB Windforce 3x (GV-R929OC-4GD)
SSD: Samsung 840 EVO 120GB (MZ-7TE120BW) - System
HDD1: WD Caviar Black 500GB (WD5001AALS) - Storage
HDD2: WD 250GB (WD2500JS-22MHB0 ) - Backup
ODD: Samsung 22/8/8/48/32x (SH-S222AB)
PSU: XFX XXX Edition P1-650X-CAG9 650W
CASE: Fractal Design Arc midi
FAN CONTROL: Scythe KAZE MASTER 5.25″ Bay Fan Controller (KM01-BK)
FAN: 2x Fractal Design Dynamic GP-14, 140 mm intake+2X Scythe S-flex 120mm (SFF21E) exhaust
OS: W10 x64
LCD:MASTER: LG 29UM57-P Ultra širok đubar, jooooj što ga volem... , SLAVE: Dell 17"
KEYBOARD: Logitech UltraX keyboard (Y-BL49)
MOUSE: Logitech G400
SOUND: Creative Sound Blaster X-Fi XtremeMusic
HEADSET: Steelseries Siberia v2
RALLYING GEAR: Logitech G25+homemade cokpit+handbrake (modani Genius MaxFighter F-16U)
IF IN DOUBT, FLAT OUT!!!
Don't touch it! It is mine! It's all miiiiineeee!!!
Lenovo Essential B580
CPU: Intel Celeron Dual Core B820 1.70GHz (2MB cache)
LCD: 15.6" HD LED 1366 x 768
GPU: Intel HD Graphics 3000
RAM: 4GB DDR3 1600MHz
HDD: 320GB SATA
ODD: DVDRW DL
PSU: Up to 4hours (Li-Ion 6 cell)
ETHERNET: Yes (Gb LAN)
COMM: Yes (802.11b/g/n)
BLUETOOTH: Yes
AUDIO IN/OUT: Yes
VGA OUT: Yes
HDMI: Yes
CASE: Lenovo
CARD READER: Yes
FINGERPRINT READER: Yes
CAMERA: Yes
OS: Windows 7 Profesional
Lenovo ThinkPad E560
CPU: Intel Core i7-6500U 2.5 GHz
LCD: 15.6 inch 16:9, 1920x1080, IPS-Panel, LED-Backlight, glossy: no
Extern LCD:Lenovo X24a, 24 inch 16:10, 1920x1200, IPS-Panel, LED-Backlight
GPU: AMD Radeon R7 M370 2 GB GDDR5
RAM: 16GB, 2 x 8 GB DDR3L-1600
HDD: 250GB SSD
ODD: DVD+/-RW
PSU: 48 Wh (6 cell)
ETHERNET: Gigabit Ethernet
COMM: 802.11ac, Bluetooth, Intel Dual Band Wireless-AC 8260 - M.2 Card
CONNECTIONS: 3 x USB 3.0, HDMI, VGA, OneLink connector, LAN, Headphone/microphone combo jack
CARD READER: 4 in 1 ( SD Card, MultiMediaCard, SDHC Card, SDXC Card )
CAMERA: Yes
OS: Windows 10 64x
Poštena, dobra i odgovorna trgovina +još jedna...
Straight roads are for fast cars, turns are for fast drivers!
O9g1 je offline   Reply With Quote
Staro 07.09.2017., 12:30   #2523
bez_komentara
Datum registracije: Jul 2017
Postovi: 238
Servis za računala nazovi i pitaj imaju li toga. To ti je najjednostavnije.
bez_komentara je offline   Reply With Quote
Staro 07.09.2017., 12:54   #2524
maja333
Lokacija: mostar
Postovi: 4
ltc novcanik
Autor FRipper Pregled postova
da li mislis da mi oni mogu pomoci i ako nema veze sa njihovim sajtom ili su oni generalno za transakcije
Staro 07.09.2017., 17:39   #2525
Ag008
RESPECT MY AUTHORITAH
Ag008's Avatar
Postovi: 7,487
Je li prvi post i dalje aktualan, ažuran?
Staro 08.09.2017., 09:53   #2526
Marko Gaće
Postovi: 5
Pozdrav,
htio bih složiti rig za rudarenje ETH i ZEC. Stavio bih ga na tavan, ali je problem što tamo nemam mogućnost spajanja na internet žicom nego bih morao ići preko WIFI-a. Zanima me kolika brzina interneta bi trebala biti ako bih išao na brzinu od recimo 150 MHs?
Unaprijed hvala na odgovorima.
Marko Gaće je offline   Reply With Quote
Staro 08.09.2017., 09:56   #2527
BlackDwarf
BIND SOFT d.o.o.
BlackDwarf's Avatar
Lokacija: Novska
Postovi: 2,422
Nije preporucljivo koristit wifi
Sent from my Lenovo A7020a40 using Tapatalk
Staro 08.09.2017., 10:05   #2528
Marko Gaće
Postovi: 5
Pretpostavljam da nije, ali našao sam tutorial na youtube gdje čovjek rudari preko WIFI-a, samo me zanima koliko troši prometa kad rudariš na brzini 150MHs.
Mogu staviti i repeater gore, pa iz njega kabelom povuć na mrežnu... Kažem, bitno mi je samo koliko mi treba Mb/s za rudarenje...
Staro 08.09.2017., 10:13   #2529
Sam Fischer
Džabe si krečio!
Sam Fischer's Avatar
Postovi: 5,190
Nije preporučljivo, ali radi najnormalnije (barem u mom slučaju).
Osim toga, bitno ti je da je veza stabilna - brzina toliko i nije bitna. Ako se ne varam, netko je tu imao 1MB/s mobilnog interneta za par rigova i sve je radilo ok...
Sam Fischer je online   Reply With Quote
Staro 08.09.2017., 10:15   #2530
Marko Gaće
Postovi: 5
Imam optiku doma na 50Mb/s. Radi stabilno... Hvala na info!
Staro 08.09.2017., 10:29   #2531
snhelix
Datum registracije: May 2017
Lokacija: rijeka
Postovi: 76
Autor O9g1 Pregled postova
dobri su t svi kablovi koji imaju one fine male jackove(zvučnik,usb proširenja etc,) glavno da fino sjeda na pinove na matičnoj,oguli suprotne krajeve i dok nađeš fensi prekidač dovoljan je i goli kontakt sa žicama....kratko power,reset itd.. krajeve izoliraš razdvojeno i ajmo dalje po neki šminkerski svitch
nadam se da će nekom koristiti navedeni primjer
snhelix je offline   Reply With Quote
Staro 08.09.2017., 10:32   #2532
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Autor maja333 Pregled postova
Tamo upišeš transakciju i vidiš di je otišlo,i to onda priloži poloniexu pa neka vide
Autor Ag008 Pregled postova
Što te točno mući?
Staro 08.09.2017., 11:24   #2533
O9g1
O9g1's Avatar
Postovi: 323
Autor Ag008
Što te točno mući?
On bi 'vrpu paruštine, al' niko od nas đubretara neće da mu upre prstom di ih ima za uzest...
OS: W10 x64
HDD: 320GB SATA
ODD: DVDRW DL
BLUETOOTH: Yes
AUDIO IN/OUT: Yes
VGA OUT: Yes
HDMI: Yes
CASE: Lenovo
CARD READER: Yes
CAMERA: Yes
HDD: 250GB SSD
ODD: DVD+/-RW
PSU: 48 Wh (6 cell)
CAMERA: Yes
OS: Windows 10 64x
Staro 08.09.2017., 15:28   #2534
Uzi84
Lokacija: Vinkovci
Postovi: 170
AMD - Claymore ZCash miner
Code:
ZecMiner64.exe -zpool ssl://eu.zenmine.pro:9999 -zwal ADRESA.IMERIGA -zpsw x -allpools 1
NVidia - EWBF's Zcash
Code:
miner --server eu.zenmine.pro --user ADRESA.IMERIGA --pass x --port 9009
Skinio sam EWBF 0.3.4b
Kad ga ekstraktam ima u folderu 6 naredbenih datoteka (svaka ima ime nekog poola, al nijedna od zen pro. Pretpostavljam da bi trebao napraviti novi .bat file iako vjerojatno isto postignem ako editiram bilo koji od navedenih.
Drugi problem mi nastaje ako pokrenem bat jer mi malwarebytes miner oznaci kao trojan i posalje u karantenu. Skinio sam sa prvog posta na bitcointalk.
Uzi84 je offline   Reply With Quote
Staro 08.09.2017., 16:46   #2535
mraka
Datum registracije: Apr 2017
Postovi: 23
Pozdrav ekipi
Znam da je kasno za rudarenje, i sve to, ali zanima me jedna stvar.
Znaci moja stara 960gtx eko majna 1usd dnevno sa nice hashem 2. (zanimalo me koliko ce majnat).
Ugl pitanje je. zelim promjenit graficku (sudeci da ova je pomalo zastarjela za gejming, pogotovo na 50"tvu-1080p), zanima me koju biste preporucili, u ovo sadasnje (mracno doba grafickih kartica), naravno graficka bi sluzila za gejming, ali bome i za majning, jbg bolje ista nego nista..(a i struja mi nije skupa tako da).
Ugl da su dostupne, i po pristojnoj cjeni, Ili neznam ako je bolja prepuruka nekih jeftinijih ali uzet ih u paru tipa 2 komada. (Ugl cca do max 3500 kn), ugl svaka preporuka je dobrodosla cak i preko budgeta). ali kako to ide na balkanu, bolje sto jeftinije.
Sto se tice konfe
I5-6600 3.5 (clock na 4.2)
8gb ram
gtx 960 (zamjena)
HDD/SSD
Hvala
mraka je offline   Reply With Quote
Staro 08.09.2017., 16:54   #2536
lit
Lokacija: hr
Postovi: 976
Autor mraka Pregled postova
Nije kasno, samo ako planiraš samo 1 grafulju... a iskreno to ti je premala zarada a imaš veći trošak cijelog riga. Rig treba iskoristiti do maksimuma da ti se lijepo sve isplati.
ako misliš s jednom samo malo probavat to OK, ali zaradu ne očekuj prije 12 mjeseci da ti otplati grafičku i rig.
Svi drugi odgovori su ti u prvom postu. Čitati molim.
lit je offline   Reply With Quote
Staro 08.09.2017., 17:00   #2537
mraka
Postovi: 23
Pročitao sam, samo sam mislio da su se mozda sad pomalo stvari promjenile. Sto se tice zarade, i koliko mjueseci, pa nije mi toliko bitno, 12/24/36mj. neka stoji. strpljen spašen.
Ugl mislio sam da ima neko preporuku. tipa uzmi radze dvije 1050 umjessto 1060 (ovo je cisto primjer)
Staro 08.09.2017., 17:07   #2538
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
vega 56 ili 1080ti...na taj način će ti omjer utrošene struje i hashing powera biti bolji nego sa nekim jeftinjačama
Staro 08.09.2017., 17:09   #2539
Gilbert5
Agent 0
Gilbert5's Avatar
Lokacija: Kutina - ZG
Postovi: 4,312
Mislim da je bolje 3x gtx1060 nego jednu 1080ti.
Staro 08.09.2017., 17:13   #2540
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
Autor Gilbert5 Pregled postova
Pa uglavnom jest, al ne stanu mu vjerojatno 3 u PC
Staro 08.09.2017., 17:14   #2541
RaneZ
Vršni visioc
RaneZ's Avatar
Postovi: 2,209
A ono, tu su negdje
Zcash:
3x1060 = 3x1700kn = 5100kn= 3x250sols = 750sols
1x1080ti = 1x 5500kn = 5000kn = 1x700sols=700sols
S time da su ovo njuskalo cijene
(na forumu je neki dan otišla 1080ti za 4800kn.. a sa druge strane i 1060 za 1500kn)
Bez potpisa.
RaneZ je online   Reply With Quote
Staro 08.09.2017., 17:15   #2542
Gilbert5
Agent 0
Gilbert5's Avatar
Postovi: 4,312
Da, nisam bas citao. Sori.
Ni ja nisam mogao nagurati 3 karice na svoju x99 deluxe, danas rade neke deblje kartice nego prije.
Staro 08.09.2017., 17:32   #2543
mraka
Postovi: 23
nope, moze stat dvije..
sad gledam malo na web stranici rijeckog xxx ducana (da ne reklamiramo), ugl 1060 se krećuo oko 2500 kn od 3/4gb i 2700 od 6gb, to je sto se tice nvdia / a sto se tica amda
560 cca 1600kn, 570 2500 kn cca. (Naravno planiram novu).
Naravno nisam gledao nista dalje jel cjene nakon ovih skacu toliko da bi morao prodat bubreg.
Staro 08.09.2017., 20:45   #2544
lit
Lokacija: hr
Postovi: 976
Autor RaneZ Pregled postova
A ono, tu su negdje
Zcash:
U to treba računati i potrošnju struje 1060 x 120W = 360W
1080ti = 250W
Iskreno, najbolje je uvijek da si svatko sam napravi računicu prema onome što želi majnati.
Staro 08.09.2017., 20:52   #2545
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Samo info, računajte da cijene grafi opet uskoro idu gore. Jer je nestašica, opet, pogotovo nvidia, trenutno nema šanse da kupiš dobre 1060, pod dobre mislim Micron/Samsung memorija, jer ih nema...
Pa eto ako netko planira ulagati u rigove, savjet je da što prije to obavi
http://forum.pcekspert.com/showpost....&postcount=166
Staro 08.09.2017., 21:20   #2546
Blue_Fatal1ty
Blue_Fatal1ty's Avatar
Lokacija: Čazma
Postovi: 1,728
Znači opet sranje...
Uz to je nestašica rama i nema šanse da više vidimo samsung/micron grafe.
Staro 08.09.2017., 21:52   #2547
mraka
Postovi: 23
uu, zakon...znaci cijene skacu.
Cekaj sad da vlada i anemicni uvedu porez na majning
Staro 08.09.2017., 22:04   #2548
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
Prodam ti ja moju rx560 100kn jeftinije i sa već sređenim BIOSom za majnanje
Staro 08.09.2017., 22:28   #2549
Shamanix
Shamanix's Avatar
Postovi: 870
Pa tko kupuje te silne grafe po ovim cijenama i trenutnoj profitabilnosti!?
Taj mora biti svjestan da nece uspit ni pola ulozenog otplatit i onda ce mu izaci volta...
Shamanix je offline   Reply With Quote
Staro 08.09.2017., 22:39   #2550
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Hm...pa ja nisam prestao kupovati
Ak ja kupujem, brijem da i ostali... jer eto mi gledamo dugoročno, važno mi je da ne idem u minus...sada da li je 10k zarada ili 1k, svejedno, + je + kako bi rekli
Od kada majnam, uvijek sam se isplatio, tako da nema šanse da se ne isplatim. A to i je ono najbitnije, ne?
