Staro 10.07.2017., 20:14   #4051
Dottore
Dottore's Avatar
Postovi: 7,674
Autor nick praskaton Pregled postova
ako ovaj kriterij pri kupnji tipkovnice nije znak da si ostario, onda ne znam sto je
Haha, ma pobjegao mi je Š pokraj ć
Nego, jesi li pogodio koji je to model?
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 10.07.2017., 20:22   #4052
nick praskaton
Asshole
nick praskaton's Avatar
Lokacija: RH
Postovi: 2,361
Autor Dottore Pregled postova
Logitech Comfort Keyboard K290
Staro 13.07.2017., 09:40   #4053
riceburner
SCSI Freak, deda :P
riceburner's Avatar
Lokacija: ZEGEIZABREGE
Postovi: 871
ja imam K280e i zgleda isto?
use SCSI/SAS and live longer!
Staro 13.07.2017., 09:56   #4054
calypso
calypso's Avatar
Datum registracije: Oct 2002
Lokacija: Zagreb/Rijeka
Postovi: 2,002
Autor riceburner Pregled postova
Zas imate sliku mog radnog mjesta? :-)
Tipkovnica je Lenovo eksterna USB 7-redna. Mis je G602 koji mi nikako ne pase, mislim da cu se vratit na MX518.
Sent from my D5503 using Tapatalk
GMKTec K8Plus
2x EIZO EV2336WFS3-BK
23" 1920x1080 IPS
Dell Latitude 7390
32GB DDR4-2666
intel UHD 620
13.3" FullHD IPS Touchscreen
Staro 22.07.2017., 23:01   #4055
Postovi: 17,020
Napokon namjestion novi stan, malo manje mjesta mi ostalo nego sam očekivao ali sam sve uredio.
Kejbling je gotov napokon
Image and video hosting by TinyPic
Staro 22.07.2017., 23:13   #4056
Drvoje
Split resist itself!
Drvoje's Avatar
Postovi: 4,037
Sve fino, divno, krasno ali text/titlovi na telki su epski: "Znači, sad bi se i ti htio malo osladiti debelim dupetima?"
Mmmmmmmm, dobro da nisi neki porn kanal okrenija
Pomelo mi sig -.-
Staro 22.07.2017., 23:34   #4057
Postovi: 17,020
Straight Outta Compton, hbo 2
Staro 23.07.2017., 02:04   #4058
X-Plosiv
X-Plosiv's Avatar
Postovi: 1,811
Ne izbacuje te iz takta to što imaš te dvije police odmah 1cm ispod monitora?
btw, i like it!
Staro 23.07.2017., 02:05   #4059
Oooo, komp sa AMD ovim komponentama onako lijepo zatvoren sa 3 strane će ti jako biti zahvalan na svježem zraku. U znak zahvale, zapalit će ti pisaći astal
@mob
Staro 23.07.2017., 11:37   #4060
Postovi: 17,020
Druže, dobro znaš da ja nisam fan AMD-a
Intel sine, intel.
Staro 23.07.2017., 13:28   #4061
Hmmmm... kaj nisi ti imao R9 390 nedavno? Ili sam te zamjenio za nekoga
@mob
Staro 23.07.2017., 13:34   #4062
Postovi: 17,020
Imao, već sam nekih 6 mjeseci na GTX-u
Staro 23.07.2017., 13:47   #4063
A onda se posipavam pepelom
Inače, kad sam imao stroj pod stolom, puno više prašine je bilo na filterima nego sad kad je na stolu. Iako se usisava najrijeđe svaki drugi dan... poprati pa javi stanje.
@mob
Staro 23.07.2017., 13:51   #4064
Postovi: 8,219
Ta lampa ti nije baš pozicionirana po standardima prakse Ja bi razmislio o nekom zidnom nosaču za monitor, pošto ti stol nije baš zahvalan.
Titlovi su vrh.
Staro 23.07.2017., 18:16   #4065
Sam Fischer
Džabe si krečio!
Sam Fischer's Avatar
Postovi: 5,190
I komp preživi ove vrućine u tom tunelu?
Tjeebote, meni se čak i Pentium I 133Mhz pregrijavao u takoj konfiguraciji (sličan stol sam davno imao)...
Staro 23.07.2017., 18:24   #4066
Postovi: 8,219
Ak ima a izgleda da ima naprijed i nazad po jednu 12icu, bez problema se rjesava komp toplog zraka. A i dođe čovijek u period kad mu nije butan baš svaki stupanj
Staro 23.07.2017., 20:20   #4067
Postovi: 10,150
Negdje je stavljao slike iza stola.. Iza mu je sve otvoreno, ne vidim problem ako mu je komp ventiliran (a vjerujem da je)
Staro 23.07.2017., 22:20   #4068
Postovi: 17,020
Što se stola tiče, stol je privemen. Kupujem novi kada odem u svoj stan (kroz nekih 6 mjeseci), trenutno sam podstanar.
Zraka ima, cijeli komp je pun ventova, sve je složeno onako kako treba biti.
Lampica je tu, jer ju nisam imao gdje staviti
Ovako izgleda iza.
Druže, želio bi ga i ja vani imati, trenutno nemam mjesta.. Ali bude.
Staro 24.07.2017., 00:17   #4069
bertone
bertone's Avatar
Datum registracije: Mar 2010
Postovi: 2,063
... Ovako izgleda iza...
Ma improvizacija je OK, ali ne razumijem sliku onog autobusa ... ili ti je to soba izvana
Staro 24.07.2017., 00:30   #4070
Dottore
Dottore's Avatar
Postovi: 7,674
Možda bi moglo ispilati da oslobodi prostor za monitor. Recimo pod kutem da može stati ti zvučnici. Ali, opet zvučnici stvaraju vibracije o stol??
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 24.07.2017., 07:30   #4071
Postovi: 10,150
Za vibracije se inace stavlja spuzva
http://blog.dubspot.com/files/2012/04/MG.jpg
Staro 24.07.2017., 10:12   #4072
Postovi: 17,020
Autor bertone Pregled postova
Hmm.. Čitam više puta i ne kužim
Kakav autobus?
Staro 24.07.2017., 11:11   #4073
bertone
bertone's Avatar
Postovi: 2,063
Kakav autobus?
Hmmm... sinoć kad sam kliknuo na link koji vodi na pozadinu stola, prva i treća slika su bile kakve su i sada, a druga (srednja - kablovi u boci) je bio crveni autobus ... jbg, trebao sam uhvatiti screenshot.
Staro 24.07.2017., 11:31   #4074
syss
syss's Avatar
Postovi: 10,805
si ti vidio crveni autobus prije ili poslije veselog duhana?
Staro 24.07.2017., 11:59   #4075
bertone
bertone's Avatar
Postovi: 2,063
Autor syss Pregled postova
Staro 24.07.2017., 20:01   #4076
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
Autor Pupo Pregled postova
bas htio napisati, takav setup radi bez problema, protok zraka od naprijed prema nazad i ciao. Imao tako godinama komp u centurion5 kucistu. Nikad problema sa temperaturama, a buka na minimumu jer i stol malo dampira zvuk.
Staro 25.07.2017., 13:01   #4077
Postovi: 17,020
Imam 120-tku naprijed, 140-tka iza, 140-tka je na vrhu kućišta i na stranici je 140-tka.
Nikad problema imao s temperaturama.
Staro 25.07.2017., 13:17   #4078
Sam Fischer
Džabe si krečio!
Postovi: 5,190
U obranu kolege, bio je autobus, matere mi! Gledao i ja wtf, bit ce da je covjek greskom uploadao, a inace mozda brije na autobuse, tramvaje, etc...
Staro 25.07.2017., 13:37   #4079
Postovi: 17,020
Isti diler, a?
Staro 25.07.2017., 13:47   #4080
Postovi: 10,150
Tapatalk se napusio lose gare, u nekoj drugoj temi je isto izbacivao random slike u postovima, valjda vam povuce nesto iz cachea
