Staro 21.11.2005., 16:55   #1
p5ych0p4N
Postovi: 18
kupujem laptop
Treba mi za posao, znači, pisanje, prezentacije, surfanje.
Jedino što mi je bitno da je što lakši, da mu baterija što dulje traje i da voli putovanja
Prijedlozi?
AMD Athlon 64 X2 5000+ Black Edition
MBO DFI, s. AM2, LAN PARTY DK 790FX-M2RS
RAM, 4 GB (2GB + 2GB), DDR 2, PC-6400
VGA PCI-E POINT OF VIEW, 9600 GT Extreme
580 W ATX 2
p5ych0p4N je offline   Reply With Quote
Staro 22.11.2005., 23:46   #2
||Spawn||
||Spawn||'s Avatar
Postovi: 32
moj frend ima končarov laptop i nije los ali ja ti preporucujem ibm-ov jeftin i dobar za stvari koje ti treba
notebook ibm thinkpad r50e
Intel Celeron M Processor 360 1.40GHz,400MHz Front Side Bus, BIOS type: Flash ROM15" TFT Active Matrix display with backlight illuminationMax resolution on built-in screen: XGA 1024 x 768256MB 266MHz PC2700 DDR SDRAM proširivo do 2GBHard disk 40GB ATA-100, EIDE, 5400 rpmIntel Extreme Graphics2, XGA, DVMT, Direct AGP,Maximum resolution 2048 x 1536 at 65536 colorsCD-RW/DVD-ROM Combo:24X/24X/24X/8X Max, EIDEAudio chipset make & model: SoundMAXIntegriran 1 zvučnik, snage 1 WattaFax/modem: 56K V.92 designedFax/modem speeds: 56Kbps data/14.4Kbps faxIntegrated Network Card 10/100 EthernetAC Adapter 72 watt,Pointing device: TrackPoint with Press to SelectFull size Standard Keyboard - HR, Keyboard lightPC Card support: 1 Type I/II or 1 Type IIILithium-Ion Batterijski sklop, do 3.4 sata autonomije radaPortovi: AC adapter, External Display, Headphone/Line out,Microphone/line in, RJ-11, RJ-45, 2 USB 2.0Težina: 2.453KgDimenzije: Visina 38mm, Širina: 332mm, Dubina: 269mmOperativni sistem: Microsoft Windows XP Pro
Cijena za gotovinu:
5.882,54 KN
Cijena za karticu:
6.283,62 KN
imas ga za kupiti u Linksu(www.links.hr)
||Spawn|| je offline   Reply With Quote
Staro 23.11.2005., 00:08   #3
mighty
mighty's Avatar
Postovi: 519
Re: kupujem laptop
Prijedlozi?
mislim da ne bi bilo loše da napišeš s kolko love raspolažeš:clap:
mighty je offline   Reply With Quote
Staro 24.11.2005., 15:12   #4
p5ych0p4N
Postovi: 18
do 10k kuna.
||Spawn||, hvala na prijedlogu
580 W ATX 2
Staro 26.11.2005., 11:49   #5
nicko
Postovi: 4,190
mislim da imaš toshibu portege m100 sa 12" monitorom i težine oko 1.5-2kg...poledaj na nabavi
nicko je offline   Reply With Quote
