#1681 |
Datum registracije: Jun 2016
Postovi: 1,052
Evo dobio sam nove zvucnike , ovaj put ne samo da nisu bili otvoreni nego je cak i kutija bila u zapecacenom celofanu. jedini bed je taj da kad zgasim zvucnike sub pocne zujat i to cujem prek cijele sobe , to nemre bit normalno , dali da nesto pokusavam ili ih opet reklamirat servisu? |
#1682 | |
Lokacija: Čazma
Postovi: 1,728
<mytubeelement data="{"bundle":{"label_delimitor":":","percentage":"%","smart_buffer":"Smart Buffer","start_playing_when_buffered":"Start playing when buffered","sound":"Sound","desktop_notification":"Desktop Notification","continuation_on_next_line":"-","loop":"Loop","only_notify":"Only Notify","estimated_time":"Estimated Time","global_preferences":"Global Preferences","no_notification_supported_on_your_browser":"No notification style supported on your browser version","video_buffered":"Video Buffered","buffered":"Buffered","hyphen":"-","buffered_message":"The video has been buffered as requested and is ready to play.","not_supported":"Not Supported","on":"On","off":"Off","click_to_enable_for_this_site":"Click to enable for this site","desktop_notification_denied":"You have denied permission for desktop notification for this site","notification_status_delimitor":";","error":"Error","adblock_interferance_message":"Adblock (or similar extension) is known to interfere with SmartVideo. Please add this url to adblock whitelist.","calculating":"Calculating","waiting":"Waiting","will_start_buffering_when_initialized":"Will start buffering when initialized","will_start_playing_when_initialized":"Will start playing when initialized","completed":"Completed","buffering_stalled":"Buffering is stalled. Will stop.","stopped":"Stopped","hr":"Hr","min":"Min","sec":"Sec","any_moment":"Any Moment","popup_donate_to":"Donate to","extension_id":null},"prefs":{"desktopNotification":true,"soundNotification":true,"logLevel":0,"enable":true,"loop":false,"hidePopup":false,"autoPlay":false,"autoBuffer":false,"autoPlayOnBuffer":false,"autoPlayOnBufferPercentage":42,"autoPlayOnSmartBuffer":true,"quality":"hd720","fshd":false,"onlyNotification":false,"enableFullScreen":true,"saveBandwidth":false,"hideAnnotations":false,"turnOffPagedBuffering":false}}" event="preferencesUpdated" id="myTubeRelayElementToPage"></mytubeelement><mytubeelement data="{"loadBundle":true}" event="relayPrefs" id="myTubeRelayElementToTab"></mytubeelement> |
#1684 |
Postovi: 1,052
#1686 |
Postovi: 1,052
nije meni problem ic na stolu slagat prekidac od ove redne uticnice struje al mislim da bi ovo mogo bit materijal za reklamirat , nisam nikad cuo da zgaseni tako zuje cuje se kroz rupu za zrak onu unutra ili trafo ili neka druga elektronika a zuje i upaljeni al sateliti , pojma nemam o audio akustici al pretpostavljam da ni upaljene nebi trebo cuti da šume s pol metra? Zadnje izmijenjeno od: Getriba94. 08.09.2016. u 20:23. |
#1687 |
RESPECT MY AUTHORITAH
Postovi: 7,485
Heh, meni 8 godina stari MS zvučnici MS ML-6015 (5.1) od 300kn rade kao urica. Odličan zvuk, dobijem i daljinski gdje mogu svaki zvučnik posebno regulirati glasnoću. Sub dobar, dubok zvuk. Centralni i ostali i dalje rade kao prvi dan. Jedino je pocrkalo par plavih ledica na subu, ali to je normalno nakon toliko godina. Nikakvog zujanja ni dok je upaljen ni dok je ugašeno. I ja sam imao Logitech 2.1 zvučnike koji su lagano zujali (spavam u istoj sobi) ali baš mi se posrećilo što sam ovo kupio.
#1688 | |
Postovi: 1,052
a glava mi udaljena od kompa 4m. |
#1689 |
Postovi: 1,052
Evo samo da javim , odnio sam sam na servis zvucnike gdje su rekli da kvaliteta varira od proizvoda do proizvoda i da je njima normalno kaj zgaseni zuje. Nosim ja direktno zvucnike zapakirane kako je servis predo u Protis i trazim novce nazad jer nisam zadovoljan. Djelatnik Protisa predamnom na moje inzistiranje pregledava detaljno 10 minuta svaki milimetar zvucnika da nisu slucajno osteceni , potom dolazi drugi djelatnik koji s njim gleda i gura kablove u kutiju i zakljucuju kako su mehanicki u savrsenom stanju. Kroz dva sata dobijam na mail slike kako su moji zvucnici osteceni a profesor doktor na slici se slikava s rukavicama kako drzi woofer a dva debila na pultu ih 10 min pregledavali masnim rukama. Uz to ostecenje su mi napisali nasli smo i masni trag od prsta na wooferu i kablovi su zapetljani!!!! a sve su sami predamnom radili. Bjezite sto dalje od tih gnjida lažljivih a od mene su vec zaradili prijavu ministarstva i neovisno vještačenje. Dabog da propali |
#1690 |
Omicron Alpha resident
Lokacija: Bistra
Postovi: 5,073
Preselili su se u Nehajsku 59, išao jučer pokupiti tamo mišonju i kabel A ono, još se nisu do kraja preselili Prostor je nešto veći nego tamo dok su bili u krapinskoj, nedostaje osvjetljenje polica, nisu pofarbali strop, police su prazne... iako mi je bilo smiješno kak imaju modele vlakića i igračaka na jednoj polici ![]() I imaju parking!
#1691 |
Slobodan leni seronja
Postovi: 852
Ima tko iskustva sa slanjem komponentni na reklamaciju kod njih? Nisam iz ZG pa bi trebao slati postom. Pitao sam na koju adresu da posaljem, ali su taj dio maila izignorirali ![]() Takoder, rekli su mi da prilikom slanja posaljem i opis kvara. Znaci, trebao bi napisat sve u Wordu i onda to isprintat i poslat im postom? Na koju adresu? U opisu tvrtke stoji Nehajska, liku u potpisu na mailu stoji Krapinska. Nisu mi ostavili bas dobar dojam prilikom tih par razmjenjenih mailova... |
#1693 |
Postovi: 1,052
#1698 |
Postovi: 34,002
Jesi li siguran da je serviser slikao baš tvoju grafu? Ono tipa, tvoja grafa ima crveni PCB, a na slici je zeleni. Nažalost, sada si naučio jednu novu lekciju - sve što šalješ na reklamaciju, dobro poslikati sa svih strana u čim većoj rezoluciji. Po mogućnosti, sa jasno vidljivim datumom slikanja.
#1699 |
Lokacija: Bec
Postovi: 1,194
Nažalost mislim da tu nema pomoći....Stvarno si vrhunski zajebo stvar. Tako skupu stvar slati poštom, tim više da ju nisi slikao...ali nema veze to ti je dobra škola. A za inače, takva stvar se ne šalje u servis, nego se šalje tamo di je kupljena. Iz više razloga. Prvo zbog garancije. Pričali smo vec milijun puta da servis ne daje nove garancije (pravne/fizičke osobe) i kao drugo najcesce kad se u dućane predaje roba na reklamaciju, oni jako dobro poslikaju karticu i dokumentiraju njeno stanje i tu onda tvoja odgovornost prestaje....ovako ga sad mozes fuckat.. |
#1701 |
@Master_Hrc: Ovako ga sada Protis može "fućkati" ako su tako odlučili igrati. Samo odjebom od strane PCE-ovaca zažaliti će brzo za ti pišljivih 100 ili koliko već kuna. Evo, ja osobno ciljam sada preko ljeta kupiti 4k monitor, Protis definitivno križam sa liste. Moju lovu neće vidjeti, ostane li sa Alenom ovako kako je sada. Pa to niiti debil ne bi slao bez vijka na reklamaciju, a ne netko sa PCE foruma, i to još Alen. Jbt. |
#1702 |
Lokacija: Bec
Postovi: 1,194
@Alen cek cek malo...u prvom postu si napisao da je poslana na servis a sad velis da je poslana u protis. Sto je tocno od tog dvoje? Ako je poslana u protis a oni su je proslijedili na servis, sto su oni napisali u svoj nalog za tu karticu, da li ima ostecenja ili nema? Slažem se s tobom da je nezgodno ici u Zagreb iz Čakovca zbog kartice ali ono brate mili, 200 kuna benzina i 3-4 sata zbog kartice od 9500 soma kuna...ono jok pa ne bih isao.. Isto tako, kakav jebeni poligraf, ono lol...znas u kojoj drzavi zivis....i jos reklamacija u protisu...koja je ravna reklamaciji u edigitalu...jebote pa ti ko da si s Marsa pao...ili to ili si se bunike najeo ![]() edit: da se razumijemo zao mi je kaj te klosari pokusavaju preveslati ali mi nije jasno da netko tko ima toliko staza na forumi i kako ti velis iskustva sa nasim servisima ovako falsuje ![]() |
#1706 |
MiningMod
Postovi: 8,715
Koga onda boli vrag sto je skidan hladnjak? Ako nema naljepnice trgovina ti nemre odbiti garanciju pa i da si skidao hladnjak...Odi po grafu...posalji ih u kujac, stavi novi saraf i odnesi uvozniku... Btw imas jamstveni? Tko je uvoznik? |
#1708 |
MiningMod
Postovi: 8,715
Mogu jedino ako su oni uvoznik i to treba biti navedeno na jamstvenom. Ako je npr asbis ili microline, onda ti oni moraju odbiti garanciju a ne trgovina. Šaraf nađeš na nekoj drugoj grafi da je isti. |
#1709 |
Postovi: 34,002
Ako je grafa prvo završila u Protisu, nameće se zaključak da su oni skinuli šaraf i takvu grafu poslali u servis. E, sad bi trebalo vidjeti što piše u Protisovoj primki za tu grafu. Ako tamo piše da je s grafom sve ok i da nema vidljivih oštećenja, ti si siguran. Zbog toga masa ljudi inzistira da se u primki napiše da komponenta nije oštećena jer time skida odgovornost sa sebe i prebacuje je na onoga koji tu komponentu šalje u servis.
#1710 |
Postovi: 1,052
Dali si odbijen bas iz servisa ili su to uslikali "strucnjaci" u protisu? Nisi nikakvu gresku napravio slanjem postom, ja osobno odnio i pregledano predamnom sve, i za koji sat na mail stizu slike ostecenja... Prijavljuj to odmah i budi uporan: https://prijava.mingo.hr/CD/prijava.jsp Ne znam kakve koristi imaju ovi iz protisa u kompi sa servisom ali se besramno mulja i podvaljuje ekipi, jos te u oci gledaju i uvjeravaju u neistinu. Valjalo bi napravit forumski "Black list" ducana. Sent from my D6603 using Tapatalk |
