#1591 |
Datum registracije: Jun 2017
Postovi: 15
Hvala na odgovoru... ovo mi je do sada najjači argument protiv Nicehasha, nemogućnost samostalnog trejdanja valuta. Znači definitivno ne mogu pogriješiti sa njime, barem dok ne dobijem ROI za rig. |
#1592 | |
Sent from my MHA-L29 using Tapatalk |
#1593 | |
Lokacija: Čazma
Postovi: 1,728
1070 je bolja od 1080 jer 1080 ima GDDR5X memoriju. Na ovim rudarskim su modali bios baš za rudarenje i zato rokaju 60. |
#1594 |
Datum registracije: Sep 2011
Postovi: 1,145
#1596 |
Propali Amigaš
Lokacija: Nin
Postovi: 7,005
#1597 | |
Postovi: 1,145
Da ne govorim o potrošnji struje. Poslano sa mog EVA-L09 koristeći Tapatalk |
#1598 |
Jebate, zanimljivo ce bit ![]() Sent from my MHA-L29 using Tapatalk |
#1599 |
Postovi: 15
Evo rezultata. GeForce GTX 1060 9Gbps model and the price should be cheaper than that of the consumer model. The information that we are seeing about the GP106-100 mining GPUs mentions some numbers regarding mining performance, the following numbers are for 8x of these GPUs: 200 MHS for ETH, 2500 Sol/s for ZEC, 4400 H/s for XMR. These numbers translate to about 25 MHs for Ethereum, 312.5 Sol/s for ZCash and 550 H/s for Monero and only the ETH number seems surprisingly high considering what we’ve seen in our recent test of the GTX 1060 9Gbps. So while the GPU might be essentially the same as on the consumer GTX 1060, there could be some differences in the video memory… maybe 256-bit memory bus or optimized memory timings intended for better performance. With a sub $200 USD prices these mining oriented GPUs could be interesting, but the 90-day warranty period could be a bit of a setback. |
#1600 |
Postovi: 1,145
Znači njihova ideja je napraviti jeftinu (ovo 200 usd će kod nas biti 200 eura) karticu koja bi sama sebe trebala isplatiti u roku od 3 mjeseca koliko traje garancija, nema resale mogućnost i nema garanciju, a performanse su bolje 15% od normalne Poslano sa mog EVA-L09 koristeći Tapatalk |
#1603 |
Lokacija: Čazma
Postovi: 1,728
#1604 |
Datum registracije: May 2017
Lokacija: osijek
Postovi: 119
Ne znam, mene te usko specijalizirane verzije komponenata bas i ne privlace sto se tice nekakve financijske sigurnosti. Ove gejmerske barem mozes prodati kasnije, makar to bilo i 30-40% vrijednosti, a o garanciji da i ne pricam. Ne daju bezveze samo 3 mjeseca garancije, posebito te prve iteracije releasova kartica, to necu sigurno kupiti. |
#1605 |
Postovi: 1,145
što se dešava sa dwarfpoolom? Do prije 2 sata prikazivao mi je stanje zaključno sa 17-06-19- 05:59:59 (36 minutes ago) sada sam se spojio na pool i vidim: Date: 17-06-18, 19:59:59 (11 hours ago) Kao da su izvukli stari backup ? Sukladno tome nestalo mi je i 0.07 ETH ![]() Error in stats. Recalculation in progress. Transactions will be rechecked eto ga |
#1606 | |
Datum registracije: Sep 2012
Postovi: 4
#1607 | |
Crypto currency
Datum registracije: Aug 2008
Lokacija: Dubrovnik
Postovi: 525
#1608 |
Lokacija: osijek
Postovi: 119
A istina, to stoji. Za mene i male igrace se to bas i ne isplati... |
#1609 |
Lokacija: osijek
Postovi: 119
Kad vidim cijene za rx 580, prije bi gtx 1070 uzeo. Te rx ce se teze prodati kasnije, nvidija je puno cjenjenija medju gejmerima. |
#1610 |
Propali Amigaš
Lokacija: Nin
Postovi: 7,005
#1611 | |
Bi li ti riskirao dobit izraubanu do jaja grafu, ili radije kupio novu. Naravno, ovdje pricam za gaming iskljucivo. Procitaj malo tu, ljudi namjerno "kure" grafe zadnjih par mjeseci da mogu dobit nove, a kaj mislis ak ih ne uspiju razvaliti, gdje ce zavrsiti? ![]() Sent from my MHA-L29 using Tapatalk |
#1612 |
Lokacija: KC (HR)
Postovi: 917
Pitanje za starije majnere i one koji imaju 10 i više grafi. Dal vam je prdnula koja grafa do sad? Ako je, dal je zbog forsanja/ocanja, i dal ste imali slučaj da prdne grafa koja je undervoltana. Pitam jer sam dobio dojam da će prije prdnut psu nego grafa. |
#1613 |
Lokacija: Petrinja
Postovi: 1,604
Pa kad se pogleda kolika je trenutno nestašica kartica na tržištu, teško će se išta od njih prodat kasnije jer kad ove zalihe kartica koje sad rudare krenu na tržište .... . Ne znam zašto svi kalkuliraju da možeš prodat karticu kasnije - kako ako je jedna ili 10 od recimo 1000 ..... ?Čista logika: desi se da se više nešto ne može rudarit sa verzijom 4GB rama, imaš na tržištu te okljaštene koje mogu i dalje rudarit i imaš već otplaćenu ovu šta ima 4GB - pretpostavljam da će ova od 4gb u oglasnik i kupuje se nova .... Sad to napravi većina ... . |
#1614 | |
Propali Amigaš
Lokacija: Nin
Postovi: 7,005
![]() Koji peh, mogao sam 1000+ kuna zaradit bez truda da je poživila par dana duže Sad majnam sa starom 380 koja troši i grije se ko blesava u odnosu na tu 580-tku, i da kucnem u drvo, nema problema |
#1615 |
Jel ima grafi u USA? Dolazi mi sad hrpa ljudi od tam, pa ono, svako po jednu da donese, to mi je taman. Jedino mi je onda garancija jebada.. Sent from my MHA-L29 using Tapatalk |
#1616 | |
Propali Amigaš
Lokacija: Nin
Postovi: 7,005
![]() To ti je kod ovih što ih zbilja imaju, ako vidiš niže cijene onda je dostupnost obično "isporuka čim ih bude", tj 9. mjesec |
#1617 |
hehe znaci voda ok budem si narucio nekaj korisnije onda ![]() Sent from my MHA-L29 using Tapatalk |
#1618 |
Alija Sirotanović
Lokacija: Banja Luka
Postovi: 33
Drugari imam veliki problem. Kupio sam dvije gtx 1060 kartice i htio sam da stavim na svoju virtuelku (ESXi 5.1 - VMware). Kad sam stavio grafičku nikako nije bila vidljiva. Šta da radim? Zna li iko? |
#1619 |
Alija Sirotanović
Postovi: 33
"Host does not support passthrough configuration". Kako to da rješim i imali u opšte za to rješenje? ![]() |
#1620 | |
Propali Amigaš
Lokacija: Nin
Postovi: 7,005
Ako ništa, napravi upgrade na esxi 6.5, jer 5.1 je tolko star da to nije normalno Zadnje izmijenjeno od: segregator. 19.06.2017. u 16:57. |
