#32 |
the luda ribetna
Postovi: 3,952
ak ti se to ne svida sta kazes na: kucište coolermaster centurion 5, silver, cac t05, midi, bez ps links 333kn mbo dfi lan party ut nf4 sli-d, ddr, zvuk, s-ata, fw, 2xg-lan, pci-e, s. 939 links 1436kn cpu amd athlon64 3200+ box, socket 939, venice, 2000mhz, 512kb c., fsb 800mhz links 1436kn ram pc-4000, 1024mb, ddr, ocz, kit, gold vx, ddr 500 mhz, 2 x 512mb links 2217kn 2xhdd 160.0 gb hitachi, serial ata ii 8 mb cache, 7200, deskstar gst t7k250 links 1370kn vga pci-e leadtek px6800gt tdh, geforce pcx 6800gt, 256mb ddr3, dvi, tv links 3105kn dvd±rw nec nd-3540, 16x, black, dual layer ± recording, bulk links 389kn dvd rom toshiba 16x 48x, black, sd-m191t, bulk links 157kn napajanje ocz powerstream 520w, atx2 ver 2.0 links 1407kn 11850 kuciste neko drugo,i jos pokovi vent,mozda vodeno...da se svasta izmjenit ![]() |
#33 |
Postovi: 382
Što kažete na ovu konfu MB GIGABYTE K8N Ultra-9, Socket 939, NVIDIA nForce4 Ultra, 4 x Serial ATA II, 4 x Serial ATA, SATA RAID, UDMA133, 3PCI, 2PCI-E x1, PCI-E x16, 4DDR (Dual Channel, 400/333/266MHz), 8-channel Sound (with Universal Audio Jack, UAJ), SPDIF in/out (coax), 966 kn Ve-Mil CPU AMD Athlon64 3500+ (64-bit, integ. mem. kontr., 512K L2 on-chip cache), Winchester jezgra (90nm), Socket 939 2109 kn Ve-Mil Zalman 7000B-CU Cooler, cijeli od bakra, AMD Athlon64 (Socket754, Socket939, Socket940), 109 (L) x 109 (W) x 62 (H) mm, hladnjak s 92mm ventilatorom, 1350-2600rpm, 2-ball bearing, 298kn Ve-Mil DDR 512 MB 184 pin, 400MHz, SuperRAM, KINGMAX (2 komada) 706 kn Ve-Mil Cooler for case PAPST, 80 mm, 9 dB, N/2GLLE (2 komada) 216 kn Hgspot HDD Seagate ST3200822AS, 200 GB 8MB, S-ATA150, 7200 815 kn Ve-Mil VGA PCI-E SAPPHIRE ATI Radeon X850 XT 256 bit, 256 MB, tv-out, DVI 3500 kn Hgspot DVD+RW/-RW/RAM LG GSA-4163BB, DVD+R DL 4x, Multi-Format Writing, DVD+RW (8x), DVD+R (16x), DVD-RW (6x), DVD-R (16x), DVD-RAM (5x), CD-RW (24x), CD-R (40x), ATAPI, 2MB buffer, Superlink Buffer Underrun Error Protection, bulk 384 kn Ve-Mil SAMSUNG 913N Matisse, 19" TFT, 1280x1024, 300cd/m2, 700:1, 160°/160°, 8ms World fastest response time, Silver/Black, Analog, Narrow, MagicTune, MagicBright, TCO03, MJ19ESKSB Ideal for gaming and multimedia (Prince of Persia DVD Game included) 2974 kn Procesor Računala Ukupno; 11 968 kn |
#34 |
the luda ribetna
Postovi: 3,952
nema kuciste i napajanje kao prvo kao drugo dobra konfa se MORA bazirat na dobroj maticnoj a gigabyte nije bas neka tak predobra tvrtka taj winchester je sporiji od 3200+ venice a uz to se venice moze bar 3x vise klokat nego wini zalman ok..tu se slazem makajr ima boljih rjesenja a i jeftinijih(frizer) extra jaka konfa mora imati (ne mora al je pozeljno) 1024 mb rama...a uz to je kingmax lutrija i nije predobar ram(dobar za midi end i low end konfe) papstove se ne ispalti uzimati ako nisi prevelki noise freak... ako ti vec maticna podrzava sata2 uzmi si onda sata 2 al ni ovaj disk nije promasaj barakuda je jako dobar tih i hladan hdd (pun pogodak)dvd rw nema druge nego pionir 109 ili nec 5-ica i zakaj dat 3 soma kuna ako mos za 2 dobit bolji monitor? samunf nf959o konfama se treba znat jer bacanje novaca nije pozeljno a uz to mora i doc neko iskustvo koje sma ja gradio dobre 3 god...nista osobno al konfa bi radila..mozda cak i dobro al za manje para(ili isto ova moja gore) je uredno za 20% brza a kad se pocne klokat nema joj boga![]() |
#35 |
Postovi: 382
Zašto ploča nije dobra?????Prijatelj mi je ima i prezadovoljan je s njom..... Koji bi ti hladnjak stavio na ovu konfu??? što se tiče dvd-rw pcexpert preporučuje ovu navedenu LG pržilicu što se monitora tiče to nije LCD,možda je bolji ali nikad nećeš pogriješit ako uložiš u monitor |
#36 | |
the luda ribetna
Postovi: 3,952
nego jednostavno iz razloga da za jeftinije pare dobis bolje...dfi dagf...a posto je ovo ipak konfa "teske klase" treba imat i dobru maticnu ne? s toga nista ispod fitalitija ili ultra/sli dja osobno unutra imam hyper 48 i tisi je od zalmana a hladi isto ako ne i mrvicu bolje...sad si misli kak bi hladio na malo vecem broju okretaja ![]() znam da pce preporucava lg-a i ne kazem da je losa...al ima kao sto rekoh boljih i ovo je ipak konfa teske klase pa u nju treba ic sve najbolje ili? za monitor: osobno nisam vidio boljeg monitora od 959 nf ili iiyame mozda je bolji ovaj tvoj al nebi rekao te za 959nf je sigurno ![]() konfa kaj si slozio i nije tako losa..uz par sitnih izmjena i sve 5 inace kako ce uopce radit taj stroj bez napajanja? |
#38 | |
Postovi: 541
#39 | |
the luda ribetna
Postovi: 3,952
ps za detaljnu pretragu svih shopova(ne 100% al ajde) doi na www.nabava.net ![]() |
#41 |
the luda ribetna
Postovi: 3,952
ako ne kanis klokat dobro |
#42 |
Postovi: 382
Baš zato bih uzeo taj hladnjak,za overclock Specifications Socket Type 478 / 603 / 604 Intel CPU Clock Speed (max.) P4 Prescott 3.4 GHz (478-pin socket) Xeon 3.2 GHz (603-pin & 604-pin socket) Cooler Dimension (mm) 100 x 98 x 108 Cooler Weight (gram) 800 Fan Type 12 Volts / Ball Bearing Dimension (mm) 80 x 80 x 18 Speed (RPM) 1,900 (± 10 %) Airflow (CFM) 29.20 (± 10 %) Noise (dBA) 20.0 Interface Material High Efficiency Thermal |
#43 |
the luda ribetna
Postovi: 3,952
na stok frekvama i slabom ocu je jako dobar al kad poche extremno ko ja...gubi dah(recimo da mu vent nema konde )ako kanis ono klokat za 200-300 mhz...uz min dizanje napona i da nije preskot...moze...ak ne...zalim |
#45 |
the luda ribetna
Postovi: 3,952
ok i to se da sredit...(napisao sam ti vec kako) |
#47 |
Postovi: 8
Evo ova konfa nije bas do 12k kn,al nema veze....: MBO DFI, s. 939, Lan Party UT, nForce 4 Ultra-D, BUS 2000 MHz, serial ATA, RAID, 7.1 zvuk, DDR 400, 2x 1Gbps, FireWire, ATX 2------- 1.229,00 kn AMD Athlon 64 3700+, 2200 MHz, 1 Mb c., socket 939, BUS 2000 MHz, BOX (San Diego)-------- 2.207,00 kn RAM, 1 GB, DDR 2, PC-4300, 533 MHz, KINGMAX----------- 821,00 kn Cooler ZALMAN, CNPS 7700 AlCu, (socket 478, socket 775, socket 754, socket 939, socket 940)---------232,00 kn Napajanje 580 W ATX 2, HIPER HPU-4K580-MU------- 748,00 kn kućište raidmax bzerk 868s, midi, srebrno, bez napajanja----------314,02 KN vga pci-e sapphire ati radeon x800gt, 256mb ddr3, dvi, tv-------------1.450,60 KN hdd 160.0 gb maxtor, diamondmax plus 10, serial ata, 8mb cache, 7200--------681,01 KN DVD pisač, DVD±RW & DVD±R, NEC ND-3540, 16x, 8x dual layer 8.5 GB, bulk, crni-----------373,00 kn DVD ROM Drive, 16x 48x, LITE ON, bulk, crni----------- 137,00 kn Tipkovnica HR, LOGITECH HR Internet, PS/2, crna-------- 89,00 kn Miš CREATIVE LABS, Creative Mouse 5500----------- 137,00 kn Podloška za miša THERMALTAKE Damier, plava (A2192)-------- 17,00 kn Ukupno:8441 kn + monitor Mon. LCD 17" Acer AL1751A, crystal bright panel-------- 2.554,00 kn Ukupno:10995 kn Periferije sam stavio zato kaj mi je bilo dosadno...:clap: ![]() |
#48 |
Postovi: 8
Uups, stavio sam DDR2 memoriju.....umjesto toga x2 ram pc-3500, 512mb, ddr, kingmax, ddr 433 mhz---810 kn |
#49 |
fanATIčni AMDovac
Lokacija: KC-ZG
Postovi: 1,312
1.213,04kn -->
northbridge hladnjak zalman zm-47j, pasivni --------------->24,62kn hladnjak za procesor: thermaltake sonictower, pasivni, alum-bakreni ----------->236,96kn ventilator papst 80mm, 9db, n/2glle ------------------------>104,54kn memorija: corsair c25, kit, twinx, ddr 550 mhz, 2x512mb ---------->1.870,26kn graficke kartice: xfx, geforce pcx 6800, 128mb ddr ------------------------->1.580,66kn xfx, geforce pcx 6800, 128mb ddr ------------------------->1.580,66kn hard diskovi: hdd 160.0 gb seagate, ncq, 8mb cache -------------------->728,31kn hdd 160.0 gb seagate, ncq, 8mb cache -------------------->728,31kn optika: dvd±rw pioneer dvr-110, 16x, black ------------------------>409,04kn dvd rom toshiba 16x 52x, black ------------------------------>147,32kn kuciste: chieftec lcx-01bbsl-w, midi, produljeno --------------------->556,43kn napajanje: tagan 480w, super silent, tg480-u01 ----------------------->736,20kn monitor: 19" hyundai q995,96khz, 0.25mm,dynaflatx ------------>1.389,93kn ------------------------------------------------ukupno -------->12037,82kn tips'n tricks: hardove spojiti u raid graficke normalno u sli plocu moddate da radi sli ugodno clockanje.... ![]() procesor:
amd athlon64 3500+ tray, socket 939, venice --------- >1.615,06kn maticna ploca: dfi lan party ut nf4 ultra-d ,socket 939 ------------------->1.213,04kn northbridge hladnjak zalman zm-47j, pasivni --------------->24,62kn hladnjak za procesor: thermaltake sonictower, pasivni, alum-bakreni ----------->236,96kn ventilator papst 80mm, 9db, n/2glle ------------------------>104,54kn memorija: corsair c25, kit, twinx, ddr 550 mhz, 2x512mb ---------->1.870,26kn graficke kartice: xfx, geforce pcx 6800, 128mb ddr ------------------------->1.580,66kn xfx, geforce pcx 6800, 128mb ddr ------------------------->1.580,66kn hard diskovi: hdd 160.0 gb seagate, ncq, 8mb cache -------------------->728,31kn hdd 160.0 gb seagate, ncq, 8mb cache -------------------->728,31kn optika: dvd±rw pioneer dvr-110, 16x, black ------------------------>409,04kn dvd rom toshiba 16x 52x, black ------------------------------>147,32kn kuciste: chieftec lcx-01bbsl-w, midi, produljeno --------------------->556,43kn napajanje: tagan 480w, super silent, tg480-u01 ----------------------->736,20kn monitor: 19" hyundai q995,96khz, 0.25mm,dynaflatx ------------>1.389,93kn ------------------------------------------------ukupno -------->12037,82kn tips'n tricks: hardove spojiti u raid graficke normalno u sli plocu moddate da radi sli ugodno clockanje.... ![]()
#50 |
Lokacija: KC
Postovi: 4
MBO DFI LAN PARTY UT nF4 SLI-D, DDR, zvuk, S-ATA, FW, 2xG-LAN, PCI-E, s. 939 -------- 1.553,44 CPU AMD Athlon64 3700+ BOX, socket 939, San Diego, 2200MHz, 1MB c., HTT 1000MHz ----- 2.103,12 Cooler ZALMAN CNPS7700-Cu, socket 478/775/754/939/940 --------------------------------- 323,02 2x512MB, RAM PC-3200, DDR, Corsair, Value Select C2.5, DDR 400 MHz -------------------- 861,62 HDD 36.0 GB WESTERN DIGITAL Raptor, Serial ATA, 8MB cache, 10000 okr/min (system) ----- 910,31 HDD 200.0 GB SEAGATE, 8MB cache, 7200.8 Plus (storage) -------------------------------- 766,30 VGA PCI-E SAPPHIRE ATI RADEON X800GTO Ultimate Edition, 256MB DDR3, DVI, TV --------- 1.804,08 DVD±RW PIONEER DVR-110D, 16x, black, Dual layer ± recording, bulk --------------------- 393,21 DVD ROM LITE ON 16x 48x, SOHD-16P9S, bulk --------------------------------------------- 144,68 Kućište CHIEFTEC DG-01BD-UW, MIDI Dragon, bez PS, Office series ----------------------- 382,14 Napajanje CHIEFTEC 400W, GPS-400AA-101A, 12cm fan, ATX2 ver 2.0 ----------------------- 374,33 Mon. LCD 17" HYUNDAI B70A, 8ms ------------------------------------------------------ 2.048,00 Miš LOGITECH, Ultrax B85, Optical PS/2 + USB ------------------------------------------ 127,00 Tipkovnica HR, LOGITECH Media Keyboard Special Edition, PS/2 -------------------------- 168,00 ____________________________________________________________________ Ukupno ------------------------------------------------------------------------------ 11959,25
DFI LAN PARTY UT nF4-D AMD Athlon64 3700+ San Diego@2200MHz (200x11) PCI-E SAPPHIRE ATI RADEON X550 200.0 GB SEAGATE, 8MB cache Kingmax 2x256 DDR433@400 2.0-4-4-8 Zadnje izmijenjeno od: Bota. 17.11.2005. u 18:48. |
