#4111 |
Uptime 99.99%
Postovi: 2,614
Nije ni malo slican procesor od Intela kosta 2000 dolara i ima TDP od 120W j max turbo boost mu je na 3ghz. Ne sumnjam da nece biti konkurentan samo me eto iznenadio tdp, vise bi pasao taj tdp na 32c procesor
#4112 |
Postovi: 2,138
user7341 sa reddita.... Zen Power Draw, or: Why I'm Not Afraid of 32-Core Skylake We'll start here: http://imagescdn.tweaktown.com/conte...cpu-review.png This shows the 1800X, which handily beats the 6900K in performance at stock values, running 12% lower power at full load and using two-thirds less power at idle. There are two factors not counted in to this. 1) Ryzen is a SoC which has lots of the I/O functionality built in, so that power budget is used on the CPU instead of the chipset. 2) Naples 2p systems will use infinity fabric built into the CPU to communicate between CPUs and attached devices where Intel's systems must communicate through a slower southbridge chipset which consumes more power (and those chipsets are manufactured on older, less power-efficient nodes). Both of these factors mean the gap reported is likely to be even more in AMD's favor for server parts. Here you can see the same comparison with both CPUs locked to 4GHz: http://imagescdn.tweaktown.com/conte...cpu-review.png This is less favorable, on the surface of the thing, but if you actually examine what this means, it's very important and a very good indicator for AMD. Idle power draw is still very, very good compared to Intel HEDT. Again, the onboard I/O is contributing an unknown amount of power to the total draw for Ryzen, but that's not the important part. The important part is that you can see that the fully-loaded draw ramps up between 3.6GHz and 4.0GHz enough to shift the advantage to Intel. That means AMD's Ryzen chips are already binned pretty high on their ideal power curve and reducing the frequency by a few hundred megahertz can save a massive amount of power. (This will be confirmed in some other charts.) This chart gives comparative numbers for a wider variety of CPUs: http://www.techspot.com/articles-inf...h/Power_02.png This is full system load, not just CPU draw, so it's not a perfect data set but it's still very telling. Notice the big drops from the 1800X down to the 1700X. Notice how close the 1700X is to 4c Devil's Canyon and 6c Broadwell-E. Also take note that Intel's Broadwell-E 8c part (6900K) makes an unfavorable showing compared to it's Haswell-E predecessor. This is mostly due to the clock speed differences, but it shows that there's very little power efficiency gained between those generations. These two reviews show that that efficiency gain continues very well from the 1700X down to the 1700: http://www.guru3d.com/articles_pages..._review,7.html http://www.guru3d.com/articles_pages..._review,7.html This chart from PC Perspective provides more confirmation of Ryzen's power advantage over Broadwell-E: https://www.pcper.com/files/review/2017-02-27/power.png Remember, the 1800X trounces the 6900K in Cinebench R15, so even if it were using more power, it would be more efficient. Again, this chart is using full system load, so it's not ideal. However, that's at least partially off-set by the onboard I/O vs. chipset power (which is to say that some of that "full system draw" on Intel's side is counted in the CPU draw on AMD's side). Ryzen total system power compares remarkably well with 4c Kaby Lake: https://www.techpowerup.com/reviews/..._1800X/14.html So what does all of this mean for Naples? Well, first, it means AMD is already crushing Broadwell-E in performance-per-watt. Skylake-E is a new platform and we don't know everything about it, yet, so Intel could surprise us with some amazing power efficiency gains, but comparing the desktop platforms shows us that Skylake did not make significant gains in power efficiency from Broadwell. So given what we know about Haswell to Broadwell to Skylake on the desktop and what we know about Haswell-E to Broadwell-E, it certainly doesn't give us any reason to expect a surprise from Skylake-E. It also means the Samsung/GloFo process is demonstrating a very good power curve. Server parts are not likely to be clocked at 4GHz. The rumored 32 core Skylake part runs at a speed of 2.3 GHz. Extrapolating from the power curve of Ryzen 7, it seems like AMD and GloFo will handily beat Intel's power efficiency at that speed. The MCM design of Naples could also enable them to offer higher clock-speeds (we'll have to wait and see on this). So, Naples probably offers a more competitive price out of the box, better TCO and vastly superior I/O. But it's okay, because Intel still has AVX-512! Right, Brian?
#4113 |
Postovi: 14,584
#4114 |
Postovi: 2,138
fino, zahuktava se i u hedt segmentu http://wccftech.com/amd-ryzen-16-12-...n-cpus-leaked/ ako se ne varam skylake-x od intela ide na max 12c/24t(bar po najavama) i mislim da je intel svjestan da u ovoj generaciji ne moze parirati amd-u po potrošnji/zagrijavanju pa vjerojatno iz istog razloga ne idu na veci br.jezgri. jos da je vidjeti kako ce oba tabora formirati cijene..
#4115 | |
Aiden Fierce
Datum registracije: Jan 2016
Postovi: 1,171
![]() the Bariarnil
#4116 | |
Postovi: 2,138
malo sam pretjerao ali kuzis poantu, to je prakticki free marketing nekako sumljam da bi intel to samo tako prepustionisam ovo bas skuzio, ili mozda jesam, ugl. mislim da je puno relanije gledati r7 1700 ili 1700x power draw, a ne od 1800x(tvornicki jako nafrljen), taktovi za 16jezgri su tu negdje za 1700-tkom pa kad se uzme njen power draw razlika od 5w se dosta poveca
#4117 | |
Aiden Fierce
Postovi: 1,171
Kasnije sam samo natuknuo da 1800X troši točno 4w do 5w manje od 6900K stock vs stock. Slažem se da je 1700 daleko bolja kupnja od 1800X i da troši još oko 25w do 30w manje(mozda, nisam vidio testove).
![]() the Bariarnil
#4118 |
Postovi: 14,584
Cijena tu igra veliku ulogu. Intel je za 10c20t tražio 1700$, pretpostavljam da 12c24t neće biti puno jeftiniji, ako uopće bude jeftiniji. S druge strane AMD će nešto više od 1000$ (treba vidjeti koliko cijene pci-e lanese i quad channel) tražiti za 16c32t, te još ako per core budu iole sličnih performansi... |
#4119 | |
Postovi: 14,584
AMD Zen Based Enterprise CPU / APU Roadmap Leaked: 14nm Naples With 32 Cores in 2017, 7nm Starship With 48 Cores in 2018 – Zen 1 and Zen 2 Based Horned Own, Grey Hawk, Banded Kestrel and River Hawk CPUs Detailed Zatim iz drugog članka: Citiraj:
Zadnje izmijenjeno od: Manuel Calavera. 12.05.2017. u 01:18. |
#4120 | |
Aiden Fierce
Postovi: 1,171
Oštra borba na cpu frontu. Odlično. Još kad bi se X399 ploče mogle naći bar za 200€+ bilo bi optimalno. @Manuel, zar stvarno misliš da bi Intel to učinio? Dopustio da izgube negdje i to za tolku razliku u cijeni? Pa pogledaj što im NVidia radi. 1080 se prodavo $700+ sve dok nisu iz sprdnje izbacili artiljeriju da kontriraju Vegi.
![]() the Bariarnil
#4121 |
Datum registracije: Feb 2004
Postovi: 1,030
Nitko ništa u ovom biznisu ne izbacuje iz sprdnje. Ti proizvodi i njihovi kupci, s druge strane, mogu biti sprdnja. CPU se ne slaže kao lego kockice pa kada konkurencija izbaci CPU sa 16 jezgri, mi dodamo još 4 da konkuriramo. To je dugotrajan proces. Intel trenutno zaostaje u broju jezgri po socketu (po cijeni) i to se neće tako brzo promijeniti. Naravno broj jezgri nije sva priča. Tu govorim o HEDT tržištu ako su x299 i x399 gotova priča, a čini se da i u serverskom svijetu pobjeđuju, međutim tu je broj jezgri bitan samo za određene segmente. EDIT: Meni je ipak najzanimljiviji Banded Kestrel SoC i hoće li izbaciti nasljednika AM1 platforme s njim. ![]() Zadnje izmijenjeno od: cccp. 12.05.2017. u 10:05. |
#4122 |
Postovi: 2,138
Naravno, pa to je sve planski, ako zakuha - konkurencijija eventualno ide na raniji launch od originalno najavljenog, ali generalno neke bitijnije/vece preinake nisu moguce. situacija prema najavama je takva da amd u svim segemntima ima veci core count, nije to bas sad bezveze. po Kresinom testu 37W manje trosi 1700 od 1800x, sto je osjetno pogotovo kada se core count dodatno poveca
#4123 | ||
Aiden Fierce
Postovi: 1,171
Ajmo to postaviti ovako, Intel može staviti 18 core E5 2699 (v3/4? ) pod i7cu na LGA2066, kao što je Nvidia izbacila Titan XP sa 35xx jezgrica pod flagship za 1200 baksi, a kada se trebala pripremiti za Vegu je izbacila puni GP102 čip sa 38xx jezgrica(Titan Xp). Jasno sad? Citiraj:
![]() the Bariarnil
Zadnje izmijenjeno od: Bariarnil. 12.05.2017. u 11:26. |
#4124 |
PREMIUM
Datum registracije: Dec 2014
Postovi: 2,158
Al amdu fakat treba skinut kapu za imena procova i platformi. X399 vs X299, dakle osim što su u istom segmentu i sličnog imena, intel ostaje bez imena za iduću generaciju nakon x299 ![]() Nadam se da će i finalno ime ostat takvo |
#4126 | |
Postovi: 311
#4128 |
Postovi: 14,584
Nadam se da se šali kad priča o igrama u kontekstu X399 i X299 platforme. Mislim ono igraju se igre i na takvim konfama, ali nisu glavni razlog uzimanja takvih platformi Inače ima igara koje koriste i 16 threadova, što naravno ne znači i da ih trebaju ako ih koriste |
#4129 | |
Postovi: 1,030
i7 7700k je najbolji proc svih vremena. Citiraj:
#4130 | |
Aiden Fierce
Postovi: 1,171
Sada imamo dvosjekli mač. Intel u HEDT procesorima koji konkuriraju R7cama i R5 6core ne može spuštat cijene iz razloga što su im 2011 veliki čipovi. AMD s druge strane, ne može R3 pozicionirat prenisko jer je to sve cutdown R7 kojeg prodaju i za $500. Intel si može priuštit otić tako nisko. Opet u ovom, 12 i 16 core high endu je pitanje samo želi li intel ostati on top i izbaciti i 22core Xeon(primjer) jer na njemu bi mogao ubosti $2000 tek tako čak i kada ima konkurencije(a to nije mala lova). Pricas o dionicama, a dionicari nisu bili zadovoljni sa nekim planom zarade kod AMD-a i odma vrijednost dionice otišla 25% niže. Misim da nije samo intel (ili nvidia je pravi primjer) da mora držat određenu cijenu i/ili zaradu. X399 će nam točno pokazat kolko šta treba vrijedit i kako će konkurencija odgovorit, a vjeruj mi, bit će konkurentna jer su kraljevi segmentacije ![]()
![]() the Bariarnil
#4132 |
Datum registracije: Nov 2012
Postovi: 723
https://www.overclock3d.net/news/cpu..._series_cpus/1 Ha? 7 nanometara, 48c/96t procesori. 38 kW TDP, al štaš. Ugl, ako je ovo išta ko ryzen, ima da intelu podere novu rupu iz koje izlaze "procesori". Hype aside, šta mislite? 7nm zvuči jako dobro. |
#4133 |
Postovi: 14,584
Pričalo se o tih "7nm" ranije, to je bliže intelovom 10nm procesu. U svakom slučaju fenomenalno ako dođe i na AM4 proizvode Bariarnil Kužiš da je intel navikao na određenu lovu sa tog tržišta, te ima veće troškove (svoje tvornice, masu zaloslenika, masu uloženog itd.), njima je u interesu održati taj "cash flow", a ne biti kraljevi core/thread counta, prepolovit cijene xeonima i sl. S druge strane amd-u je to win win u svakom slučaju, i širenje marketsharea i zarada (kakava god da bude) jer te prihode prije nisu imali i sve će im biti dobro. Intel s druge strane tu može samo izgubiti. Njima je samo pitanje sto im je bolji damage control - ostaviti visoke cijene, pa prodati manje ili sniziti cijene i prodati više. U oba slučaja će im biti manji prihodi nego do sada. Zadnje izmijenjeno od: Manuel Calavera. 12.05.2017. u 18:31. |
#4135 | |
Postovi: 14,584
Zaključit će se kad dođu rezultati prodaje i marketsharea ![]() Ovdje malo spominju za Q1 Citiraj:
#4137 | |
Postovi: 2,138
jos malo o x399 Citiraj:
#4138 | |
Postovi: 14,584
#4139 |
Aiden Fierce
Postovi: 1,171
![]() the Bariarnil
#4140 | |
Postovi: 14,584
To će se kasnije povećavat (ako se može). Sad amd očito ide na 16 jezgri, intel na 12 Inače iz jednog od prethodnih linkova: Citiraj:
![]() Zadnje izmijenjeno od: Manuel Calavera. 13.05.2017. u 17:36. |
