Staro 24.11.2011., 11:20   #61
Perki
Lokacija: VG
Postovi: 774
o Added power user oriented application profile setting allowing MSI On-Screen Display Server to detect runtime function offsets dynamically on each 3D application startup. This provides On-Screen Display functionality support in applications using modified Direct3D runtime libraries (e.g. FXAA injection Direct3D runtimes)
o Updated profiles list
Added new compatibility option allowing using protected kernel mode low-level access to hardware instead of user mode one. This option can also be used to bypass Punkbuster related stability issues
Iako ni kriv ni dužan, čovjek popravlja...
Trust me - I know what I'm doing!
Perki je online   Reply With Quote
Staro 24.11.2011., 12:14   #62
jopis
gadget freak
jopis's Avatar
Lokacija: Jasenovac
Postovi: 2,224
Autor Perki Pregled postova
Koliko sam im samo ja prijava poslao u vezi tog problema sa punkbusterom
Staro 25.11.2011., 00:25   #63
Kreso st
Kreso st's Avatar
Lokacija: Split/Zagreb
Postovi: 148
Autor DeadMan+ Pregled postova
Added core voltage control for reference design NVIDIA GeForce GTX 560 Ti ***
Added core, memory and auxiliary PEXVDD voltage control for custom design MSI N560GTX-*** Twin Frozr III Power Edition series graphics cards with uP6218+uP6262 voltage regulators
Ja i dalje nemogu undervoltati svog msi 560 ti hawk sa ovim beta verzijama 2.2 msi afterburnerom (on uredno pise da je undervoltan,ali u kombustoru, gpu-z ili bilo kojem drugom programu ostaje default napon) jedini s kojim to mogu je 2.1 final
Kreso st je offline   Reply With Quote
Staro 18.09.2012., 21:13   #64
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,533
Afterburner v2.2.4 final
Afterburner v2.2.4 final is available. We added GTX660 and GTX650 Triple Overvoltage support and some other tweaks. Afterburner is a free VGA overclocking tool which works also on non-MSI cards.
Afterburner v2.2.4 final download
Staro 31.10.2012., 11:09   #65
PURSUIT
PURSUIT's Avatar
Datum registracije: Sep 2012
Lokacija: POŽEGA
Postovi: 271
Msi Afterburner 2.2.5
Link
PURSUIT je offline   Reply With Quote
Staro 19.11.2012., 10:56   #66
PURSUIT
PURSUIT's Avatar
Lokacija: POŽEGA
Postovi: 271
Staro 04.01.2013., 08:40   #67
Pizz
Registered Abuser
Pizz's Avatar
Lokacija: Velika Gorica \ ZG
Postovi: 747
ima netko problema sa voltage controlom, jednostavno nece radit mada je ukljucen u opcijama, sad neznam jel to mozda zbog 12.11 beta drivera ili je problem u win8 ... ista stvar je i s drugim alatima (asusov i jos oni neki kajaznam sad napamet)
doduse nisam probao rollback napraviti s driverom, radije cu pricekat neki novi da izadje... konfa je iz siga
edit-forget it, zakljucana voltaza, nist treba maklo flashat, aj bok
Zadnje izmijenjeno od: Pizz. 04.01.2013. u 08:59.
Pizz je offline   Reply With Quote
Staro 04.01.2013., 10:14   #68
Autor Pizz Pregled postova
vrati se na 2.2.3. Ja ga i dalje koristim i mogu dizati i spuštati voltaže. na kasnijim verzijama ne mogu.
Staro 04.01.2013., 14:27   #69
Pizz
Registered Abuser
Pizz's Avatar
Postovi: 747
svejedno nove verzije moje kartice imaju zalokan volt, al vec sam stavio drugi BIOS, mic po mic, skinem i ovu verziju pa javim
EDIT, nije sljakalo, ali s drugim biosima radi gigabyte oc guru 2
Zadnje izmijenjeno od: Pizz. 05.01.2013. u 19:20.
Staro 16.06.2014., 22:57   #70
matxoxo
Postovi: 27
Ako imas msi grafku onda klokaj sa msi afterburnerom jer je prvobitno namjenjen za njih, a onda tek za ostale grafke, ali ja sam svoju proslu grafu gtx 560 clockao sa core 800mhz na 955mhz i memoriju na 2400 uz malo pojacanje voltaze bez problema sa ovim programom
matxoxo je offline   Reply With Quote
Staro 14.12.2014., 12:42   #71
mierdadeltorro
mierdadeltorro's Avatar
Lokacija: zadar
Postovi: 236
ova tema je malo zamrla al nisam našao na guglu niš pa da pitam ovdje.
može li afterburner prikazivati brzinu venta za cpu, ne treba mi za kontoliranje brzine već samo za prikaz trenutne.
mierdadeltorro je offline   Reply With Quote
Staro 03.01.2015., 16:57   #72
zwer54
zwer54's Avatar
Lokacija: Dublin
Postovi: 1,977
Autor mierdadeltorro Pregled postova
Pa jel problem instalirati aplikaciju od 3 mb i vidit?
Korisito sam to prije dok sam bio na nvidia karticama, ne mogu reci sa sigurnoscu, ali mislim da moze.
Staro 03.01.2015., 17:28   #73
spaceman
spaceman's Avatar
Datum registracije: Feb 2010
Lokacija: Našice
Postovi: 327
Koliko vidim, zadnja verzija ne može. Što se tiče procesora, prikazuje zauzeće i temperaturu.
spaceman je offline   Reply With Quote
Staro 03.01.2015., 17:40   #74
lampa
Datum registracije: Jun 2014
Postovi: 4
Ja sam instalirao verziju koju sam dobio sa GTX 650 i prikazuje sve parametre temperature od grafičke pa to matične i za svaku jezgru i njezino ponašanje.
lampa je offline   Reply With Quote
Staro 03.01.2015., 18:02   #75
iNoob
Game Collector
iNoob's Avatar
Datum registracije: Jun 2010
Lokacija: Viškovo (Rijeka)
Postovi: 366
Instaliraj uz Afterburner i HWiNFO pa ćeš moći vidjeti sve podatke iz svakog senzora u kompu.
iNoob je offline   Reply With Quote
Staro 18.06.2015., 23:27   #76
slavonac90
slavonac90's Avatar
Postovi: 1,499
Kako uključiti kontrolu voltaže? Pod settings stavim kvačicu, resetira se afterburner ali i dalje voltaža zaključana.
slavonac90 je offline   Reply With Quote
Staro 21.06.2015., 23:31   #77
Mislim da su verzije nakon 2.2.3 to ukinuli. Ja imam tu verziju i mogu se igrat sa voltažama.
Staro 21.11.2016., 02:11   #78
ibme74
ibme74's Avatar
Datum registracije: Jan 2013
Lokacija: Planet Zemlja
Postovi: 1,568
Jedno pitanje. Imam instaliran MSI Afterburner i RivaTuner za praćenje temperaturea, cpu/gpu/ram usage i ostalo. E sada, u opcijama MSI Afterburner mogu stavljati razne boje, recimo za CPU usage zutu za GPu usage zelenu za RAM usage crvenu itd ali boje sveg toga budu iste in-game, odnosno bude ona koju odaberes u Riva Tuneru. Dali je nekako moguće naštimati da pokazuje boje koje odredis u afterburneru?
ibme74 je offline   Reply With Quote
Staro 21.11.2016., 11:43   #79
dean225
DD9512
dean225's Avatar
Postovi: 1,869
Jel se moze tu sta dobiti igranjem sa voltazom? Mislim na bolji OC?
dean225 je offline   Reply With Quote
Staro 21.11.2016., 12:47   #80
alen.s
alen.s's Avatar
Postovi: 1,441
Autor ibme74 Pregled postova
mislim da ne...moguce ih je poštelat po volji za taskbar ali ne za in-game
Staro 21.11.2016., 13:02   #81
Autor dean225 Pregled postova
Na GTX560Ti, 660Ti i 970 se dobilo dosta. Na 1070 nisam probao.
Staro 22.03.2018., 12:04   #82
Postovi: 16,636
Ekipa, pitanje.
Imam feeling od kada sam instalirao MSI Afterburner da mi je glasnija grafa. Znam da je moguće zbog one custom krivulje u afterburneru, ali sam jučer napravio testiranje, MSI afterburner sam ugasio (desni klik i quit) i grafa je došla do 70% fanovi u PUBG-u svejedno. Da li je process MSI Afterburner negdje u pozadini upaljen bez obzira što je sama aplikacija ugašena?
Ako obrišem afterburner s kompa, padne fan speed u igri..
MSI Afterburner nemam cijelo vrijeme upaljen (osim kada me zanima zauzeće u igrama).
Moje pitanje je, da li je desni klik i quit afterburnera dovoljno da on uopće ne radi ili moram obrisati kompletno i tek onda testirati?
Staro 22.03.2018., 14:47   #83
frezer
frezer's Avatar
Datum registracije: Jan 2018
Postovi: 490
Ako je na "quit" nema efekta na grafičku. Koristim ga za underclock grafičke, i ako je isključen, grafička se vraća na tvorničke postavke.
frezer je offline   Reply With Quote
Staro 22.03.2018., 15:21   #84
Postovi: 16,636
Hmm.. Nemam pojma zašto mi onda divljaju ventovi na grafi.
Možda je jednostavno do igre, iako prije to nije bio problem. Možda kako je igra bila patchirana tako je i opterećenje poraslo.
Staro 22.03.2018., 19:00   #85
Prki
Prki's Avatar
Postovi: 1,315
E sad ovo što ću napisati neće biti stručno ali možda shvatiš.Imao sam isti problem.Navodno Afterburner u suradnji s prepametnim softwareom od grafičke(u mom slučaju AMD settings) radi neki file koji grafa koristi čak i preko svojih Bios postavki.Znači ako si ga upalio taj file je napravljen i grafa će se pokretati preko tog filea.Problem je što afterburner ili ne očita tvorničke Bios postavke kako treba ili nešto i onda ti Default settings nije kako je bio prije Afterburnera i ako ti ugasiš AB grafa i dalje radi preko postavki koje su je pokrenule.Taj file nikada nisam uspio naći i grafu nisam mogao dobiti više na default postavke nikako iako gledam u Bios postavke očitanja s grafe su potpuno drugačija.Našao sam na nekom forumu da se za sigurno korištenje AB-a preporuča disejblanje tvorničkog softwera da ne bi vuklo postavke s dva mjesta i onda dolazi do sranja.Nakon par dana mučenja novi Windowsi i nikad više AB i takvi SW,grafu sam clocknuo preko Biosa i mir nikada više.E to se ne događa svaki put ali ako se dogodi da se taj file sjebe prevelika je zajebancija da se to ispravi.Brisao sam AB,AMD settings,po registriu,ma nema što nisam probao ali ju dobiti da radi,samo s novim windowsima.U početku mi se događalo samo poslije paljenja AB-a a kasnije je počelo i kod samog paljenja kompa.I navodno nije do AB-a nego do default softwera grafe koji radi taj file usporedo s original Bios postavkama da bi se izbjeglo baš ovo što se događa.Ako možeš ući u Bios grafe pa tamo pogledaj kako su krivulja venta i clockovi podešeni pa usporedi s stvarnom situacijom,ako se stvari ne poklapaju znači da ti grafa ne radi preko Bios postavki nego preko nečeg drugog ili trećeg.Sorry na ovakvom postu znam da je nabacano svega i svačega i da nije stručno ali nije moje područje i bilo je to prije 7-8mj.Nadam se da će te usmjeriti u pravom smjeru.
Staro 22.03.2018., 19:25   #86
Postovi: 16,636
Hvala ti na objašnjenju, pomoglo mi je. Iako nakon brisanja AB-a se u PUBGu ništa nije promjenilo, i dalje je grafa na 70% što se tiče ventova, tako da mislim ipak da je do same igre.
Staro 22.03.2018., 19:31   #87
Prki
Prki's Avatar
Postovi: 1,315
Da neće pomoći brisanje AB-a jer nije njegov file(ili je ali ga ne obriše deinstalacijom iako sam ja radio i sa RevoUninstalerom).Najlakše je doći do istine tako da u Biosu vidiš postavke i usporediš s GPU-z om ili bilo čime-Meni je osim ventova pobrkalo da grafa nije išla u onu prvu brzinu nego je konstantno radila u drugoj od tri.
Staro 23.03.2018., 09:17   #88
frezer
frezer's Avatar
Postovi: 490
Nisam se nikad bavio overclockom grafičke pa imam pitanje za one koji znaju.
Imam KFA2 GTX 970 koja je tvornički overclockirana. Defaultno, takt joj ide do 1405mhz. Na defaultnim postavkama mi se ponekad u igrama dogodi crni ekran na sekundu ili dvije. Igra se ne ruši, sve normalno samo taj crni ekran. Nije se događalo u svim igrama.
Spustio sam takt na 1200mhz i sad je ok.
Jeli crni ekran standarna nuspojava ako se previše overclockira?
Dali bi podizanje napona možda riješilo problem?
Staro 23.03.2018., 10:29   #89
Postovi: 16,636
Ako je tvornički OC-ana, trebala bi raditi kako treba, bez obzira na sve. Afterburner isto tako, osim dizanja temperature same grafe, trebao bi raditi bez ikakvih problema.
Ne može se tvornički previše OC-ati. Tako da napravi neke testove, optereti ju, ako imaš problema reklamiraj.
Downclock bi trebao samo smanjiti potrošnju i temperature (zato se i radi), ali ako ti samo tako grafa radi kako treba, reklamiraj.
Vezano za moj upit:
Mislim da sam našao problem. Čitam po netu, većini je grafa zakucana do ibera (pričam o 1070). Gledam ekipu po netu, bez obzira na ram i CPU, grafa je svima između 85 i 99% u PUBG-u.
Tako da je do igre, 99% sam siguran.
Staro 03.05.2018., 16:02   #90
Postovi: 16,636
A zašto to trebaš? Clockaš? Ako ne, default ti je ok.
Preglasno ti je? Pretoplo?
