Zaključane teme
Staro 14.10.2016., 21:40   #3031
9800pro
aka Edo, aka Syncros
9800pro's Avatar
Postovi: 1,775
Izašao novi Libreelec za 905/905x.
http://forum.libreelec.tv/showthread.php?tid=1924
Molim ekipu sa a95x da probaju i jave kako radi, prvenstveno 24p switching i hd audio.
sent from my LG G2
9800pro je offline
Staro 15.10.2016., 10:48   #3032
cyrus
cyrus's Avatar
Datum registracije: Feb 2016
Postovi: 94
Autor Rookie01 Pregled postova
Problem zatamnjivanja videa kod prikazivanja na Nexboxu A95X.
Ovo sam našao na Nexbox forumu vezano za zatamnjenje videa ako netko želi ovo prevesti možda bi bilo još bolje:
One owner of this box has found a nonpractical but efficiently solution:
"Apparently this is a firmware issue and i have figured out a solution. The solution is not persistent and might be unique to my tv box and monitor setup only, so i don't know if it will work for anyone else
There is a video test file on the box which is part of the deviceTest diagnostics. Either run the device test and then do a video test or just find the video test file in the movies folder and run it using the built-in android video player.
Playing it through the installed Movie player or kodi or mx player does not correct the video color issue. Its not some special video file but playing it for even 1 second corrects the hdmi color mode.
Suspend resume doesnt affect the fix but upon reboot or shutdown the video has to be played again to correct the color mode."
If still curious, the test video is inside the movies folder in the root directory. The file which is also labeled as ' test' doent have any file extension, so it wont show up as a playable format. Therefore use a file explorer (which this box already have two of) and play as a video file and then select the 'video player' as the app to run it.
Alternatively, you could also just locate and run the devicetest app on the box which is also already installed. This app also has a shortcut programmed on the remote which is the options key (the key right above the keypad's 3 digit). Hold it for 3 seconds and the app will execute. Use the video test option to play the video.
Ovo sam i ja primjetio da je malo tamnija slika kod ovog playera. Malo pojacas svjetlost na tvu i problem rjesen.
Sent from my K6000 Pro using Tapatalk
cyrus je offline
Staro 15.10.2016., 10:54   #3033
vorda22
jel koristi tko apple tv 1 sa crystalHD karticom?
Sent from my MI MAX using Tapatalk
Staro 15.10.2016., 12:36   #3034
tintin
tintin's Avatar
Lokacija: negdje
Postovi: 1,793
Trebao bih danas upogoniti Beelink mini mxIII i malo sam skeptičan prema napajanju koje je došlo s njim. Neki no name eu plug sa dvije tanke žice. Imam jednog uboxa i njegovo napajanje je robusnije i ima debelu okruglu žicu.
Koristite ovo napajanje koje dolazi uz mxIII bez problema?
Mislim, nebi htio da mi nešto izgori...
tintin je online
Staro 15.10.2016., 14:26   #3035
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
Po specifikacijama ovo mi izgleda jedan od jačih amlogic baziranih playera
http://www.geekbuying.com/item/YOKAT...liday_20161015
a i cijena nije pretjerana
segregator je offline
Staro 15.10.2016., 14:53   #3036
9800pro
9800pro's Avatar
Postovi: 1,775
Treba pričekati sa uzimanjem novih i neprovjerenih čipova. Kodi je u verziji 17 izbacio podršku za hardversko dekodiranje putem amlogic dekodera koji je u svim amlogic čipovima. Šta će biti kad puna verzija 17 izađe nitko nezna. Po meni je bolje uzet s905 ili 905x koji imaju podršku za Libreelec pa ako ovi zajebu sa Kodijem 17 imaš druge opcije.
sent from my LG G2
9800pro je offline
Staro 15.10.2016., 15:02   #3037
hrki
Lokacija: ZG - VŽ - KR
Postovi: 279
Koji windows box uzeti
Sent from my ONEPLUS 3
hrki je offline
Staro 15.10.2016., 16:17   #3038
vorda22
evo slozio pi3 b i radi bolje od bilo kojeg droida...samo za kodi, naravno
Staro 15.10.2016., 16:24   #3039
rendula
Lokacija: Zagreb, Trešnjevka
Postovi: 5,774
Autor vorda22 Pregled postova
Odlicni su raspberryji sa libreleceom, jedino steta sto h265 ne gutaju
rendula je online
Staro 15.10.2016., 16:46   #3040
vorda22
Autor rendula Pregled postova
ma ja sam na 1080p, ovo drugo je sve overkill a sve torrente kaj nadjem su h.264
a ovo kaj sam nasao na netu:
Right now if you use x265 and x264 with roughly equivalent settings the x264 will look better at the same bitrate. That is, x265 seems smaller and better at the moment because the settings used are much inferior in comparison to x264 forquality*encodes of high bitrate HD movies and tv. All the x265 releases out there on public trackers are brilliant if you don't care for the overall quality. HEVC/x265 still has a long while to go and once the encoders are happy that it is surpassing x264 at the same settings with considerable benefits then yes, they will switch to x265.
koja je poanta 265ice?
Zadnje izmijenjeno od: vorda22. 15.10.2016. u 16:54.
Staro 15.10.2016., 17:07   #3041
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
nemam pojma, ovi koje sam ja skidao izgledaju ljepše iako su fajlovi manji...npr prva sezona House of Cards
Staro 15.10.2016., 17:21   #3042
Ag008
RESPECT MY AUTHORITAH
Ag008's Avatar
Postovi: 7,485
Ma, nema neke razlike između starog i novog procesora koji podržava taj 265.
Dobri su i najjeftiniji playeri od 30-ak dolara. A95x 2Gb i dalje radi super
Ag008 je offline
Staro 15.10.2016., 18:42   #3043
9800pro
9800pro's Avatar
Postovi: 1,775
X265 su smislili da naguraju 4K filmove na bluray diskove. Po meni je x265 idealan za streaming recimo u Exodusu sa RealDebrid-om, slika super, mala fajla, ima ac3, za svakodnevno gledanje super.
sent from my LG G2
9800pro je offline
Staro 15.10.2016., 18:55   #3044
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
Autor Ag008 Pregled postova
Što podrazumijevaš pod stare, a što pod nove procesore?
Staro 15.10.2016., 19:21   #3045
Ag008
Ag008's Avatar
Postovi: 7,485
S905 i S905x
Ag008 je offline
Staro 15.10.2016., 19:58   #3046
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
S905 i S905x
Ma to je praktički ista stvar
Staro 16.10.2016., 20:31   #3047
redscro
redscro's Avatar
Lokacija: Kupres
Postovi: 4,085
Može preporuka za Android box, uz uvjet da nije rootan? Ne trebaju neke posebne karakteristike, na njemu će se vrtiti samo jedna aplikacija (D3GO), koja pak zahtjeva da uređaj nije rootan. Bilo bi dobro da je cijena ispod vrijednosti koja se carini (nekih 30ak $ u BiH).
redscro je offline
Staro 17.10.2016., 10:59   #3048
Mate_zg
Mate_zg's Avatar
Postovi: 92
http://www.gearbest.com/tv-box-c_112...gh&odr_value=1
Ne kuzim se koliko su velike razlike izmedu ovih uredaja al valjda se isplati dati koji 20-30 dolara da od telke koja je u boravku napravim smart TV pa ako tko moze preporuciti sa ove stranice koji je najbolji.
Uzimam za roditelje kojima bi intalirao kodi i mozda neki light surfing,youtube...nista posebno znaci.Ne razumijem se puno u te smart boxove al predpostavljam da za tu namjenu mogu posluziti ovi od 25 dolara.
Ako tko ima neku preporuku best buy ili tako nesto bio bi mu vrlo zahvalan.
Mate_zg je offline
Staro 17.10.2016., 11:13   #3049
freddie
freddie's Avatar
Postovi: 351
Autor Mate_zg Pregled postova
Već par stranica hvalimo A95X, 2GB
30-tak dolara ,odličan box
imam ga ja par dana i zadovoljan. Izbrisal nepotrebne stvari tipa skype,face i njihov predinstalirani kodi.Skinuo kodi sa playa ,poštelal ga i radi odlično.Youtube isto bez greške. To sve putem Wi-Fi,žičano još nisam stigal spojit.Uglavnom gledaj da box ima unutra Amlogic čip jer priča se da je bolji od ovih drugih.
freddie je offline
Staro 17.10.2016., 13:15   #3050
Mate_zg
Mate_zg's Avatar
Postovi: 92
Hvala kolega mislim da cu danas naruciti.Cijena mu je 38 dolara i koliko sam vidio najeftinije.amazon i ebuy su nesto skuplji.Mozes li mi preporuciti neku malu tipkovnicu usput
Mate_zg je offline
Staro 17.10.2016., 13:42   #3051
vorda22
par zapazanja za raspberry pi 3 b:
konacno mi radi DTS i AC3 kako spada na mojem setupu.
hardverski acceleration OMX ne switcha IPTV sliku na pravi framerate, dok MMAL to radi.
to je za sad to
Staro 17.10.2016., 13:50   #3052
Hrconja
Hrconja's Avatar
Postovi: 1,623
Na koji način ste izbrisali kompletni Kodi ?
Kada odem na Google play mi nudi samo upgrade ovog kaj je došao sa boxom. Nekako sam se nadao da će mi dati da budu paralelno instalirani :/
Predinstalirani radi ok osim kaj se ne da normalno izaći iz njega bez da se smrzne...
Hrconja je offline
Staro 17.10.2016., 13:51   #3053
alengrosevic
alengrosevic's Avatar
Postovi: 3,775
odeš u settings od boxa i u applications. tamo nađi kodi i klikni na njega. nakon toga uninstall...
alengrosevic je offline
Staro 17.10.2016., 18:17   #3054
Hrconja
Hrconja's Avatar
Postovi: 1,623
I instaliram kodi sa Play storea i opet se vrati sa svim addonovima i sranjima
Hrconja je offline
Staro 17.10.2016., 18:30   #3055
rendula
Postovi: 5,774
Autor Hrconja Pregled postova
Zvuci kao da bi trebao izbrisati kodi folder sa settingsima nakon feinstalacije. Zaboravio sam di se on u androidu tocno nalazi.
rendula je online
Staro 17.10.2016., 18:41   #3056
rak21
COD2 expert
rak21's Avatar
Postovi: 1,918
ili preko fusion repoa skines freshstart addon koji bi trebao resetirati KODI..
rak21 je offline
Staro 17.10.2016., 18:49   #3057
Hrconja
Hrconja's Avatar
Postovi: 1,623
Ovo je jaaako čudno. Izbrišem xbmc kodi folder u android/data i PONOVO se stvori sam od sebe. Nevjerojatno. Kao da postoji neki proces koji to stalno resetira.
Joj nikako se riješiti tog nametnika
Hrconja je offline
Staro 17.10.2016., 21:21   #3058
Hrconja
Hrconja's Avatar
Postovi: 1,623
Autor rak21 Pregled postova
Probao sam skriptu. Odradi svoje. Restartam box. Opet su svi addonovi nazad. Aaargh.
Hrconja je offline
Staro 17.10.2016., 22:08   #3059
9800pro
9800pro's Avatar
Postovi: 1,775
Koji je to box?
Skini Spmc sa store-a. On ima odvojeni folder tako da može biti instaliran usporedo sa Kodijem.
Poslano sa mog LG-D802 koristeći Tapatalk
9800pro je offline
Staro 17.10.2016., 22:34   #3060
alengrosevic
Postovi: 3,775
jesi li deinstalirao i onaj Kodi Center ili kako se zove? Ono s čime updateaš kodi? ja sam i njegamaknuo i nemam nikakvih repova. Dobijem čisti Kodi
Zaključane teme
