Staro 30.08.2016., 08:59   #91
Postovi: 10,119
Autor android-split Pregled postova
Anker se oglasio, pohvalno:
https://plus.google.com/+BensonLeung/posts/AxHVKXrdCD7
It has come to our attention that some units of the Anker PowerLine USB-C A8185011 may present technical issues, which could prevent the cable from performing at its full capacity or even cause damage to devices when used. Therefore, to ensure that all of our customers are getting only the best quality products from Anker, we are recalling all units of our Anker PowerLine USB-C A8185011 immediately.
We'll be issuing a full refund and customers will be provided with a free cable once the problem has been resolved. In total, less than 150 customers have purchased this product and our support team have reached out to each of them individually via email.
Staro 30.08.2016., 12:33   #92
Dottore
Dottore's Avatar
Postovi: 7,664
Pohvalno
@edit
Da li preko Amazona uključen shipping za Hrvatsku ( mislim direktno preko Aukey i Anker)
Naime, mislio sam naručiti punjač Aukey 3-portni, a ono štanga "not shipping"
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Dottore je online   Reply With Quote
Staro 30.08.2016., 14:56   #93
Postovi: 10,119
Gledaj amazon.de gdje ces dobiti i obicni eu plug (sada postoji i sa sluzbenim engleskim jezikom) ili co.uk i .fr.
Shipping inace nije u cijeni, a ako se logiras na amazon pisat ce ti pored itema dostavljaju li kod nas.
Staro 30.08.2016., 17:40   #94
Dottore
Dottore's Avatar
Postovi: 7,664
Hvala za hint. Snašao upravo.
Poslano s kompjutera iz kreveta preko interneta
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 20.12.2016., 21:00   #95
c-shadow
c-shadow's Avatar
Postovi: 3,491
Choetech?
Ima netko iskustava s kabelima marke Choetech?
Na neku foru na aliexpressu mi search za USB-C s 56k otporom daje samo njihove kablove
Naručen ovaj, uskoro treba doći, valjda se nisam zeznuo?
https://www.aliexpress.com/item/USB-...738677522.html
Kako stoji stvar s kablovima duljim od 1m, npr 1.5m, kakva su im svojstva?
Treba mi prvenstveno za data sync na PC, a kad povučem odostraga na stol malo mi na knap.
Staro 20.12.2016., 21:06   #96
gin.tonic
gin.tonic's Avatar
Postovi: 2,436
Ok su, ako se ne varam provjereni su ti
Nisu na onoj zloglasnoj listi loših kablova...
Kakva svojstva? Radit će...
gin.tonic je offline   Reply With Quote
Staro 20.12.2016., 21:21   #97
Postovi: 10,119
Koristim iste od 1 do 3m modele (pisao u temi). Rade kako treba, koristim ih za punjenje, isporucuju urednih 2,8-3 ampera. Oni su ti na safe listi tako da...
Staro 20.12.2016., 21:32   #98
Dottore
Dottore's Avatar
Postovi: 7,664
Choetech nisam imao prilike naručiti ali uletjelo mi je super ponuda za Anker i Aukey. Od trojice nema šanse fulati i pouzdani su.
Sent from my Nexus 6P
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 20.12.2016., 22:22   #99
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,103
Uzeo sam nedavno Aukey, paket od 3 komada:
https://www.amazon.de/gp/product/B01...?ie=UTF8&psc=1
Vrhunsko metalno kućište konektora, kabel je čvrst i fino umotan u bužir. Preporuka.
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
OS: Windows 10 Pro x64
Staro 20.12.2016., 22:27   #100
mislav_os
freak
Postovi: 2,688
Uzeo preko Ebaya ovaj:
http://www.ebay.com/itm/3m-Braided-U...item2375f8f1d9
1.5m, za LG G5. Već 6 mj s njim punim mob i prebacujem podatke. Sve u redu, puni kao i original kabal te prebacuje podatke istom brzinom. Također je kvalitetne izrade.
Staro 20.12.2016., 23:33   #101
gin.tonic
gin.tonic's Avatar
Postovi: 2,436
Autor Dottore Pregled postova
Čisto da znaš nisu baš mjerilo kvalitete ni Anker ni Aukey ako gledam testove od Nathan K:
https://plus.google.com/102612254593917101378
+AUKEY Official​ (non-eMarked/3A) USB2.0 2m Type-C Charging Cable [Model CB-C19].
tl;dr: BAD cable. Shield intermittent/missing due to questionable manufacturing. Poor performance.
+Anker PowerPort Speed PD 30w wall charger [Model A2014111].
tl;dr: Noncompliant charger. Printed and advertised levels do not match actual capabilities. Inconsistent overload protection. It may not work on certain laptops and high-power devices.
+Anker PowerLine+ USB 2.0 C-to-C cord. [Model A8187091]
tl;dr: Safe but middling quality at best. Packaging has nice fit and finish. But IR drop (.31v) is absolutely excessive.
+AUKEY "24W" USB-PD Dual Port 12v car charger [Model CC-Y7].
tl;dr: Bad -- provable on two points, "spidey sense" on another (due to lack of test equipment). Mismatch in safety markings (24w) vs claimed capacity (36w), goes outside USB-PD voltage thresholds. CC line errors, dubious overload behavior.
Ali, ne govorim o svim proizvodima
Zadnje izmijenjeno od: gin.tonic. 20.12.2016. u 23:44.
Staro 21.12.2016., 00:30   #102
Dottore
Dottore's Avatar
Postovi: 7,664
Autor 1v@n Pregled postova
Taj imam i vrijedi spomena
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 21.12.2016., 01:23   #103
kvaju
kvaju's Avatar
Lokacija: Cirkus
Postovi: 642
Uzet cu i ja ovaj Choetech, ali prvi put narucujem sa Aliexpress, i vidim nema opcije paypal za plaćanje, sto mi je jako čudno.
Pa sam naručio kabal i platio Visa karticom, medjutim u medjuvremenu sam malo gledao po profilu prodavača i ugledao jos nesto od istog prodavača i da ne kupujem ponovo taj drugi predmet i placam na njega postarinu posebno trebao sam to fino sve u chart staviti i naručiti.
U medjuvremenu sam 15min nakon plaćanja isao na cancel order.
Vidim s kartice mi je vec skinilo taj iznos koji sam platio, koliko cu čekati refund da legne novac na kraticu, i dali treba ista osim samo cancel order uraditi, valjda se refound podrazumijeva.
Navikao sam na ebay i paypal pa mi je ovo novo sve, ali mislim da cu ubuduce cesce kupovati preko Aliexpress, izbor je puno bolji, i aplikacija je miljama ispred ebay i sama stranica takodjer.
Sent from my ONEPLUS A3003 using Tapatalk
kvaju je offline   Reply With Quote
Staro 21.12.2016., 16:25   #104
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
gdje je ta lista o dobrim kablovima?
ja trebam naruciti par dugackih, ovi od 90cm su smijeh, pa ne mogu nista s tim, trebam 2 metra duzine, nesto USB C, a nesto obicnih Micro USB za tablete, te mi treba i lightning za iphone za punjenje u krevet, isto bar 2 metra. (10feet)
Staro 21.12.2016., 16:45   #105
kvaju
kvaju's Avatar
Lokacija: Cirkus
Postovi: 642
https://m.reddit.com/r/Nexus6P/comme...s_with_benson/
Staro 21.12.2016., 18:42   #106
c-shadow
c-shadow's Avatar
Postovi: 3,491
Dobro da sam spomenuo choetech, jutros ga poštar donio, 14 dana je putovao.
Kabel izgleda ok, nije naročito dobeo, dosta je čvrst, krut, fino opleten izvana, ne petlja se.
Djeluje kvalitetno, konektori su čvrsti, nisu glomazni, USB-C seamless.
Nije mi spalio komp kod data transfera niti mob kod uštekavanja na punjač, za dalje ćemo vidjeti
Staro 21.12.2016., 18:44   #107
Postovi: 10,119
A sta poceli su raditi seamless metalni dio konektora? Ajde pohvalno, mene je jedino to brinulo po pitanju dugotrajnosti iako zasad izgledaju kao prvog dana. Volio bih da nisu tako zilavi
Staro 21.12.2016., 18:53   #108
c-shadow
c-shadow's Avatar
Postovi: 3,491
Da.
Sorry, ova druga slika malo ispala van fokusa
Nego jel netko uzimao nešto od ove marke Ugreen na aliju?
Imaju mi par zanimljivih stvari, a ne znam kakvi su.
Usput, kod pretraživanja na Aliju dobra fora da nakon searcha posloži na vrh linkove po brandovima.
Staro 21.12.2016., 18:58   #109
Postovi: 10,119
A to su estetski malo drukciji kablovi. Kod mene obicni crni sa logom, a taj konektor je nesto kraci
Staro 21.12.2016., 19:19   #110
c-shadow
c-shadow's Avatar
Postovi: 3,491
Ovaj je opleten izvana nekom sintetikom, pitam se koliko će to trajati.
Samo pazi ako gledaš na slici na linku sa alija, bešavni je samo USB C strana. Slika im je kriva, druga strana ima šav, ali to ne me smeta, i drugi kablovi to imaju pa se nikad ništa nije potrgalo.
Staro 21.12.2016., 19:40   #111
android-split
android-split's Avatar
Datum registracije: Dec 2015
Postovi: 1,041
Autor Gabre Pregled postova
http://m.geekbuying.com/item/Tronsma...re-366500.html
Ja ga imam vec par miseci
Kupio zajedno sa ovim punjacem
http://m.geekbuying.com/item/Tronsma...ug-363290.html
android-split je offline   Reply With Quote
Staro 21.12.2016., 19:56   #112
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,250
Ja kupio ovaj, komada 2
Look at this on eBay http://www.ebay.com/itm/282231430191
Jebat cu mu kevu ne bude li radio kako treba.
Staro 21.12.2016., 21:38   #113
gin.tonic
gin.tonic's Avatar
Postovi: 2,436
Autor Cuky Pregled postova
Postoje ti Anker fejkove inače, samo da znaš...
A ne znam čemu toliko novaca dati za taj kabel i na testovima nije baš bio bajan
Staro 21.12.2016., 22:09   #114
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,250
Najbitnije je da ne moze nista skurit, lako za sve ostalo.
Staro 22.12.2016., 09:44   #115
hakija
hakija's Avatar
Postovi: 348
Naso netko mozda neki ok 3u1 kabel USB C, micro i lightning? Znam da je to glupo i 99.9% smece ali za auto kad je hica....jos da je kratak i samo za punjenje to bi bilo sjajno
hakija je offline   Reply With Quote
Staro 22.12.2016., 10:33   #116
Dottore
Dottore's Avatar
Postovi: 7,664
Ovaj nije fejk. Teško da fula premium braided i dobiva se pernica za spremanje kablova (pohvalno)
@cuky
Lupit češ sebi i osati živ
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 22.12.2016., 10:39   #117
Postovi: 10,119
A gle, objavim oglas, prodajem fejk anker kablove, stavim 10 anker slika ali nijednu live, stavim cijenu malo vecu ali taman nizu da se ekipa zakaci, profit dok netko ne skuzi i pocbe pisati kako su fejk
Ako mu je netko preporucio tog sellera i item, ili seller ima super feedback za taj item, nema dvojbe da je kabel ok!
Staro 22.12.2016., 12:15   #118
gin.tonic
gin.tonic's Avatar
Postovi: 2,436
Autor xlr Pregled postova
Na aliexpressu je baš taj kabel fake, ima i drugih fejkova brenda a seller ima dobar feedback
Staro 22.12.2016., 13:21   #119
Postovi: 10,119
Aliexpress je smetje, tamo svaka fejk sd kartica ima odlican rejting Na ebayu feedback barem ima vise smisla (on je postao link sa ebaya gore).
Staro 22.12.2016., 13:35   #120
c-shadow
c-shadow's Avatar
Postovi: 3,491
Na aliju takve stvari kupujem obično od branda koji imaju svoj vlastiti store pa mislim da je sigurnije.
