		#9061 |
			 MiningMod
					Postovi: 8,715
		 Procesor INTEL Core i5 4460 BOX, s. 1150, 3.2GHz, 6MB cache, GPU, Quad Core Memorija PC-12800, 8 GB, G.SKILL RipjawsX series, F3-12800CL10S-8GBXL, DDR3 1600MHz Matična ploča ASROCK B85M Pro3 Tvrdi disk 1000.0 GB SEAGATE ST1000DM003, SATA3, 64MB cache, 7200 okr/min, 3.5" Grafička kartica PCI-E EVGA GeForce GTX 960 SSC ACX 2.0+, 2GB DDR5 Kućište LC POWER PRO-923B Red Captor, MIDI, crno, bez napajanja-a Napajanje 500W, ANTEC VP500PC ES, ATX v2.3, 120mm vent. = 5000kn  |
		#9062 |
			Datum registracije: Mar 2011
					Postovi: 2,707
		 Memorija CRUCIAL 8 GB DDR4, 2133 MHz, DIMM, CL15, CT8G4DFS8213 Matična ploča MSI H110M PRO-D, socket 1151, DDR4 Procesor INTEL Core i5 6400, 2700/3300 MHz, Socket 1151 Tvrdi disk 1 TB, SEAGATE Barracuda, 3.5", SATA III, 7200 rpm, ST1000DM003 Grafička kartica GIGABYTE AMD Radeon R9 380X G1 GAMING, 4 GB GDDR5, HDMI, DVI Kućište MS Industrial MONSTER RED LED FAN, gaming, bez napajanja Napajanje FORTRON Hyper, 500W =5050kn  |
		#9064 |
			Datum registracije: Jan 2013
				Lokacija: Planet Zemlja
					Postovi: 1,609
		 Zasto nebi mogla  |
		#9066 |
			Datum registracije: Jun 2016
					Postovi: 9
		 Kaj mislite o ovoj konfiguraciji.. ocu moci potegnut novije igre? Matična ploča MSI Z170A Krait Gaming 3X, s1151 Procesor Intel Core i3-6100 (3MB Cache, 3.80 GHz), s1151, box MS CARBON kućište bez napajanja Midi tower, ATX, mATX, vanjski utori: 1x5,25", unutarnji utori: 3x5 Napajanje SPIRE 550W, ATX 2.13, 12cm vent tihi rad, automatska kontrola brzine, 21 dBA max, SP-ATX- DDR4 16GB (2x8GB) PC4-21300 2666MHz CL16 Corsair Vengeance LPX Black, CMK16GX4M2A2666C16 SSD 120GB Kingston UV300, SATA3, SUV300S37A/120G HDD 1TB Toshiba, 3.5", 7200RPM, 32MB Cache, SATA3, DT01ACA100 3,728.00 Kn  |
		#9067 |
					Postovi: 1,609
		 Bez grafe ne  |
		#9068 |
					Postovi: 9
		#9069 |
					Postovi: 1,609
		 Bolje onda idi na i5 i kvalitetnije kuciste, i to napajanje je loše 1x ASRock H110M-DGS, s1151 1x Intel Core i5-6402P (6MB Cache, up to 3.40 GHz), s1151 1x DDR4 8GB (1x8GB) PC3-17000 2133MHz CL15 Crucial 1x SanDisk X400 128GB SSD, 2.5” 7mm, SATA 6 Gbit/s 1x HDD 1TB WD Blue, 3.5", 7200RPM, 64MB Cache, SATA3 1x Fortron Raider 550w 80+ Silver 1x Zalman Z1 mid tower case UKUPNO: 3.680,96kn Besplatno slaganje i dostava  |
		#9070 |
					Postovi: 9
		 evo.. preslozio sam svoju konfiguraciju. upravo oko napajanja i kucista sam se lomio jer stvarno ne znam nista o njima.  ova ASRock ploca, ok? slazem se sa ovim, bolji procesor, a manje rama. lakse kasnije piknem ram, nego novi proc.  |
		#9071 |
			Datum registracije: May 2013
				Lokacija: dubrovnik
					Postovi: 9
		 Bok. možete li mi složeti konfiguraciju bez periferija i monitora. Služila bi za rad u CAD-u plus povremeno igranje SC2 i sličnih igara. Unaprijed zahvaljujem.  |
		#9072 |
			Datum registracije: Sep 2014
				Lokacija: Zagora
					Postovi: 179
		 Pozdrav, nedavno sam pita za konfiguraciju  [QUOTE=scarwin;2928155]Ekipa jel može za kolegu konfiguracija do 5500kn, većinom gaming. Dakle kućište i sve komponente, periferiju ima. Preferira intel/nvidia kombinaciju.[/QUOTE No ako može ikako nova konfiguracija. Ovaj put bez HDD-a, i sa pržilicom. Do 6200kn  |
		#9073 |
			Datum registracije: Feb 2016
					Postovi: 94
		 Pozdrav forumašima. Zanima me što mislite o specifikaciji na slici.  Ono što me posebno zanima su procesor i grafička kartica. Da li ići na  i3 (i koji model) i da li ići na jaču grafičku (GTX 950). Osnovna  namjena je gaming, po mogućnosti da vrti najnovije naslove na bar nekim  srednjim postavkama. Pozdrav i hvala.  |
		#9074 |
					Postovi: 430
		 Za taj procesor bi trebalo uzeti i neki hladnjak, radije si ovako složi: 1 x AMD FX X6 6300 (3,5GHz,14MB,95W,AM3+) box 1 x Kingston DDR3 1600MHz,C11, 8GB 1 x Gigabyte GA-78LMT-S2 (AM3+,DDR3,VGA,SATA II,LAN,USB 2.0) mATX, 95W CPU 1 x CPU Hladnjak LC-CC-95, Intel/AMD, 90mm 4-pin 1 x VGA Palit GTX 750Ti 2GB StormX OC 1 x HDD SEAGATE Barracuda (3.5",1TB,64MB,SATA III) 1 x Kućište MS Mercury 2 1 x Fortron Hexa+ 400W, 80+ Ukupno: 3400,00 kn slaganje i dostava u cijeni ili intel opcija: 1 x Procesor Intel Core i3 6098P, 3.6GHz, 1151 1 x Crucial 8GB DDR4 2133MHz (PC4-17000) CL15 1 x Asrock H110M-DGS (s1151,DDR4,USB 3.0,SATA III,LAN,DVI) mATX 1 x VGA Palit GTX 750Ti 2GB StormX OC 1 x HDD SEAGATE Barracuda (3.5",1TB,64MB,SATA III) 1 x Kućište MS Mercury 2 1 x Fortron Hexa+ 400W, 80+ Ukupno: 3340,00 kn  |
		#9075 |
					Postovi: 94
		 Po tvom mišljenju, je li bolje AMD ili Intel (CPU) za gaming? Bi li bilo bolje stavit GTX 950 (nije puno više love, a znači)? Koliko bi ubacivanje SSD-a umisto HDD poboljšalo gaming (mislio sam nimalo, osim učitavanja mapa itd., ali mi kolega kaže da je on neke igre koje nisu baš išle na low postavkama, nakon ubacivanja SSD-a igrao na mid postavkama)? U kojem shopu si izračunao ove cijene? Hvala puno, svaki savjet je dobrodošao ![]() Zadnje izmijenjeno od: coconut. 05.07.2016. u 18:30.  |
		#9076 |
					Postovi: 430
		 Slični procesori, nema neke razlike. Intel možda radi novije arhitekture, manje potrošnje i manjeg zagrijavanja bi bio moj pick. SSD za gaming ne igra nikakvu ulogu, radije GTX950 ako se već možeš protegnuti. Shop je isti kao i tvoj.  |
		#9077 |
			 Varilnik
					Postovi: 1,648
		 Bok ekipa, slažem si neku konfu za frenda do 5500 kn max (samo kutija). Imam neke ideje ali bi volio također ako netko ima kakav prijedlog da mi olakša odluku ![]() Gaming je u pitanju. Uopće nije bitno da li AMD ili nvidia, AMD ili intel. Hvala unaprijed! ![]()  |
		#9078 |
					Postovi: 430
		 1 x Intel CPU Desktop Core i5-4460 (3.2GHz, 6MB,LGA1150) box 1 x Kingston DDR3 1600MHz,C11, 8GB 1 x ASRock H81M-HDS R2.0 (s1150,DDR3,USB 3.0,SATA III,DVI/VGA/HDMI) mATX,Usb 3.0 header 1 x HDD SEAGATE Barracuda (3.5",1TB,64MB,SATA III) 1 x Zalman Z1, USB3.0 black, 2x120mm 1 x XFX XT 500W XT, 80+ Bronze 1 x Inno3D Geforce GTX970 OC HerculeZ X2 4GB GDDR5 Ukupno: 5493,00 kn slaganje i dostava u cijeni  |
		#9079 |
					Postovi: 94
		 Evo složio sam nešto, ovaj put u Protisu jer po nabava.net je jeftini pa me zanima šta misliš o ovome.  |
		#9080 | |
					Postovi: 1,609
 1x MSI H110M PRO-D, LGA 1151, DDR4-2133, Military Class 4 1x Procesor Intel Core i5 6400 1x Kingston 1x8GB DDR4 2133MHz C15 1x Inno3D Geforce GTX970 OC HerculeZ X2 4GB DDR5 1x Toshiba P300 1TB, 64MB, 7200rpm 1x Fortron napajanje Hyper 500W 80+ 1x Raijintek Arcadia Black Midi Tower UKUPNO: 5.547,65kn  |
		#9081 | |
					Postovi: 1,609
 FX 8300 + GTX950 i5 4460 + GTX950  |
		#9082 | |
					Postovi: 1,052
 ja sam uzo i3 6100 , nisam se nado da se tako malo proc moze grijat na loadu ![]() pozeljno je da kanta ima dobar protok zraka , kad sam na papir stavio jeftino kuciste + ventilatori koje moras kupit sam doso na cijenu 100kn manju od dobrog kucista sa ugradenim ventovima , pa razmisli. ovo mi se cinilo ko best buy sa prozirnom stranicom https://www.protis.hr/products/detai...wer-case/77771  |
		#9084 |
					Postovi: 1,052
		 u ovom kucistu sto sam linko dobije se ugrađeno 2x 120mm na vrhu , 1x120mm straga , 1x120mm napred , ja sam dodo jos jedan 120mm napred jer je za njega predvideno mjesto. (ima kanta gumb za regulaciju ventova da tise radi kad nije u loadu nekom) takoder prednost je sto je napajanje dole pa se hladi sa friskim zrakom. i3 bi radio super na serijskom hladnjaku , meni je ova temp na katani 3 , neznam koliko su temperature vece u loadu sa serijskim , nisam probo.  |
		#9085 |
			 Varilnik
					Postovi: 1,648
		 @Doc @ibme74 Hvala obojici na savjetu. Tu negdje sam i ja bio sa razmišljanjem. No da li je opravdana razlika u toj cijeni između 970-ke i r9 380 4GB pošto će se igrati na starijem ekranu ispod 1080p rezolucije? Mislio sam tu razliku u cijeni utopiti u 120GB SSD, malo bolje napajanje i aftermaket hladnjak za cpu. Kasnija nadogradnja gpu-a mu ne predstavlja problem kao i nadogradnja monitora kroz cca 2 god. A do tada će več biti 100 drugih čuda ![]()  |
		#9086 |
					Postovi: 1,609
		 Ako ne planiraš ići na 1080p monitor onda uzmi R9 380, iako je i ona OP za rezolucije ispod 1920x1080  ![]()  |
		#9087 |
			Datum registracije: Jul 2016
				Lokacija: Đakovo
					Postovi: 9
		 Pozdrav. Trebao bih kofiguraciju bez periferije kojoj je osnovna namjena rad sa programima tipa FL Studio i Cubase zajedno sa gomilom VST pluginova.Naravno da igranje nije isključeno,raspoloživa sredstva su do 5ooo kuna. P.S. Da li u ovakvom slučaju više odgovara SSD + manji hard (500 mb) ili je dovoljan hard disk. DVD je svakako u igri. Hvala!  |
		#9088 |
					Postovi: 94
		 Evo na kraju se odlučio za ovo:
 Imam nekoliko pitanja: - matičnu sam se mislio između ove i GIGABYTE GA-H110M-DS2. Netko pljuje AsRock, ali većina ima pozitivna mišljenja o njihovim matičnim pločama. - da li je dobro na ovu konfiguraciju uzet mATX kućište ili da idem na neki midi tower? - kućište ima otvore za ventove pa me zanima da li ventilatori dolaze s kućištem ili ih treba kupiti zasebno? Da li mi uopće trebaju dodatni ventilatori za ovu konfiguraciju? - napajanje 400W je dovoljno (po power calculatoru dosta je oko 300 W)? - btw SSD je samo 240 GB, ubacit ću u postojeću konfiguraciju još HDD od 500 GB (kojeg imam).  |
		#9089 | |
					Postovi: 430
		 @cyrus Ok je ploča, ne moraš brinuti, ako ti se više sviđa giga odi na nju, razlika zanemariva. S obzirom da se konfa ne zagrijava kućište je ok, Zalman Z1 bi bio bolji izbor ako već želiš nešto kvalitetnije. U ovom kućištu imaš 1 vent, Z1 ima 2 venta. Napajanje je kvalitetno i dovoljno. SSD radije zamjeni za Sandisk Z400 koji ima 60mj jamstvo. Citiraj:
 1 x Kingston DDR3 1600MHz,C11, 8GB 1 x ASRock H81M-HDS R2.0 (s1150,DDR3,USB 3.0,SATA III,DVI/VGA/HDMI) mATX,Usb 3.0 header 1 x HDD SEAGATE Barracuda (3.5",1TB,64MB,SATA III) 1 x Patriot SSD Blast R560/W425, 120GB, 7mm, 2.5" 1 x LITE ON DVDRW 24x SATA, black, bulk 1 x Gigabyte GeForce GTX 960, 2GB 128 bit DDR5 1 x Zalman T3 Mini-Tower ATX kućište, bez napajanja, crno 1 x Fortron Hexa+ 400W, 80+ Ukupno: 5047,63 kn slaganje i dostava u cijeni  |
		#9090 |
					Postovi: 94
		 Na njihovi preporuku uzeo sam i3 6098P umjesto i3 6100 (neznatna razlika) i SSD koji ima 60 mj garancije:
 Mislim da je sad u redu. Hvala svima na pomoći.  |
