Staro 02.05.2016., 20:41   #2491
T}{OR
DBS
T}{OR's Avatar
Datum registracije: Nov 2010
Postovi: 1,855
EDIT: Promjene mapa u 0.5.5:
Baš. Strpi se dok ne poprave to, ja čak neću ni CA vozit. Navodno traže bug:
Our QA tech priests will try to verify the issue - once they've found it, it will be exorcised.
Carry on
Indianapolis hype:
Zadnje izmijenjeno od: T}{OR. 03.05.2016. u 10:14.
Staro 03.05.2016., 17:30   #2492
Flayer
Why So Serious?
Flayer's Avatar
Datum registracije: May 2005
Postovi: 151
Za Iowa-ljupce
If you're in control, you aren't going fast enough.
Flayer je offline   Reply With Quote
Staro 03.05.2016., 17:49   #2493
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
Cartmanovim riječima, "better!":
https://gfycat.com/ResponsibleCapitalDrake
Must see:
Zadnje izmijenjeno od: T}{OR. 03.05.2016. u 20:04. Razlog: Popravljen link & video.
Staro 04.05.2016., 10:45   #2494
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
WG je testirao SA bug, za sada izgleda da to nije bug već feature:
Autor Tuccy
Gentlemen,
Our technomages checked the reports. Here are few observations:
  1. The 2-3s delay is working as intended and worked like this since CAT. The icon disappears, you are still visible for 3 more seconds.
  2. However anything longer than that IS NOT working as intended. Now of course some cases may be just enemy seeing you begin your turn and then getting lucky in guess what will you do, but if you have any more replays or videos showing the thing described here (ie ship apparently remaining spotted for way longer than 3s), please share. ESPECIALLY if you started maneuvering after the 3s window.
Znači da se ne treba oslanjati na SA iliti uskličnik. 3 sekunde nakon što uskličnik nestane je očigledno prema dizajnu?!
Staro 04.05.2016., 10:58   #2495
Smoki_Gs
Smoki_Gs's Avatar
Datum registracije: Aug 2008
Lokacija: Gospić
Postovi: 452
Hahahahaha WG madness
Staro 04.05.2016., 11:03   #2496
Tvrdi
Sremium
Datum registracije: Oct 2013
Postovi: 2,854
Oni nas prave idiotima. Pa to nije bilo prije 0.5.5 patcha.
Staro 04.05.2016., 12:51   #2497
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
Baš. Ili trolanje na najjače. Igram CV i BB dok se to ne sredi. Sad je lako moguće da sam u onoj partiji sa Fubukijem potopljen radi toga jer me Atago riješio iako sam bio u dimu. Dobro, bio je spoter plane iznad ali svejedno.
DM neću vozit dok se to ne riješi jer sam stalno naprijed s njim, i potopljen u zadnje 3 partije što mi nije napeto uz navedene SA gluposti.
Kako stvari stoje vjerojatno neću imat vremena ni upalit igru do sl. tjedna. Nadam se da će se opametit do tada ili će netko smislit mod koji 3s kasnije miče uskličnik da ne moram sam brojat na glas lol.
Staro 04.05.2016., 13:42   #2498
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
Isprike na duplom postu - update vezano uz bug:
Autor Takru
Did some testing with LilJumpa in the training room just now. It appears that the 3 seconds delay is there, regardless of what you do. Smoke, hide behind an island, whatever.
What catches me totally off guard is that all of a sudden, I'm still visible when SA has extinguished. I'd have sworn it wasn't that way before the latest patch.
Staro 04.05.2016., 15:04   #2499
Lun
Lun's Avatar
Datum registracije: Jan 2010
Postovi: 408
Nezaboravite se joinat u novi event
Lun je online   Reply With Quote
Staro 04.05.2016., 21:20   #2500
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
WG odgovor na ovaj bug:
"Those are not the bugs/changes you are looking for."
Staro 05.05.2016., 09:25   #2501
BladeRy
BladeRy's Avatar
Postovi: 2,000
Ma koja govna, ne, indikator koji ti pokazuje jel te vide il ne radi na dubiozan nacin i nakon sta ti pokaze da te ne vide, oni te jos vide.... to je mehanika. Koja usrana stoka.
I 2-3 sec malo sutra, sad sve poslije toga opisuju kao lucky shot.
Ovo je kao WoT sa ghost shellsima na koje sam izludio...
A glede eventa, koje su nagrade? Italieri radi makete ako se sjecam iz svojih maketarskih dana, Jinx i Razer, hardware i podloge za miseve (valjda)
Evo se uspio logirat i delogirat par puta da im usrani site proradi, nagrade....well.... nikakve. 100k love i dalje kamuflaza zastavice.
A dijamanti se mogu tradeat za neke sitne stvari, 100 dijamanata za port slot je jos ok, ako se moze vise puta kupit. Kupovanje ticketa za random raffle maketa je besmislen, daju 1:700 model, tako da je Takao (Atago sistership) maketa svih 29cm velika, znaci minijatura teska. Barem u usporedbi sa 60+cm Tirpitz maketom (koju su mi necaci izmasakrirali).
Zadnje izmijenjeno od: BladeRy. 05.05.2016. u 09:44.
Staro 05.05.2016., 12:42   #2502
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
Novi podulji odgovor od Tuccy-a.
Lun - jel ciljaš na chat ban i na službenom forumu!?
Staro 06.05.2016., 21:28   #2503
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
Netko je spominjao troškove u T10?
600k čiste zarade sa Des Moines, 4xCV partija i AFT umjesto DE, i to nakon što sam ispucao dnevni x3 XP bonus:
http://wowreplays.com/Replay/5395-T_...Moines-Hotspot
- Obožavam ovaj brod. S Balmerom sam imao oko 45k avg dmg dok se nije stabiliziralo na +/-40k. Des Moines? 70k avg dmg!!!
Yame i Montane služe za farmanje dmga s vatrom. Range mod FTW.
Zadnje izmijenjeno od: T}{OR. 06.05.2016. u 21:34.
Staro 06.05.2016., 21:45   #2504
Tvrdi
Sremium
Postovi: 2,854
Čuj Thore spominješ jednu super partiju i to s tobom za kormilom. Neko ko je prosjek u većini partija i sa solidnim dmgom jedva će izvući plus.
Staro 06.05.2016., 22:38   #2505
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
Znam. Trolam na najjače.
Sent using Tapatalk.
Zadnje izmijenjeno od: T}{OR. 06.05.2016. u 23:09.
Staro 08.05.2016., 23:08   #2506
Lun
Lun's Avatar
Postovi: 408
Staro 08.05.2016., 23:24   #2507
Tvrdi
Sremium
Postovi: 2,854
Pepsi sa normalnim detectionom i premium cammo....fora...hehe
Staro 09.05.2016., 08:01   #2508
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
Naaaajs! Malo malo HPa ali zato domet od 17km! Samo neka ga stave na T7 i to je Pensa na steroidima.
EDIT: Ali bojim se da bi mogao sjest na T8 što bi bila šteta... No, možda je manje HP-a od Pense i NO kompenzacija radi boljeg oklopa i pokušaj balansiranja da ju stave na T7. U svakom slučaju je moj.
Zadnje izmijenjeno od: T}{OR. 09.05.2016. u 08:26.
Staro 09.05.2016., 12:14   #2509
Tvrdi
Sremium
Postovi: 2,854
Autor T}{OR Pregled postova
Bit će t8 skoro pa sam siguran...
Staro 09.05.2016., 12:33   #2510
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
Netko na redditu tvrdi kako su već davno najavili novi T7 USN CA premium, sličan Pensacoli:
https://www.reddit.com/r/WorldOfWars...apolis_leaked/
Bojim se da ima osjetno premalo HP-a za T8 gdje skoro svaki CA osim NO ima 40k. S druge strane, ima bolji belt armor od NO i za km veći domet.
Biti će interesantno jer je okretnost na razini Pense sa 620m radijusom, dok NO i Cleve imaju 660.
Concealment je ok, ali ništa spekatakularno. Ako mu daju T8 radar onda je za pretpostaviti isti domet kao NO odnosno 9km/30s - s puno gorim concealmentom nema smisla jer ga možeš sa T8 upgradeima spustit na 11km, a ako je T7 max 12km.
Ukratko, trenutni opis Indianapolisa: Bolji oklop od NO, okretnost i topovi od Pense i bolji domet od oboje uz manje HP-a.
EDIT: Yup, T7 - leak je updatean.
Zadnje izmijenjeno od: T}{OR. 09.05.2016. u 13:44.
Staro 09.05.2016., 21:22   #2511
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
Ono kad pobereš 4 reporta nakon što si Lexi kapetanu uporno strafe-ao napad za napadom:
Staro 09.05.2016., 23:59   #2512
BladeRy
BladeRy's Avatar
Postovi: 2,000
To reportanje i karma je apsolutno sranje.
Ne ide te u rundi, tvoji te prijave, ide te u rundi i suprotna strana te prijavi. Prijave te ako dobro gadjas, prijave te jer drugi CV nit nezna za fighter-strafe, prijavi te DD jer si opalio radar a on misli da je hax... stvarno debilana.
Na stranu to, bas kad je ovaj popust u pitanju, svi moduli na Zao i kapetan sa samo T3 skillom, i average 120k dmga po rundi Zao je zakon.
Staro 10.05.2016., 08:36   #2513
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
U potpunosti se slažem. Služi samo kao ispušni ventil. Partiju ranije u Taihu je meni par naleta prekinuo dobrim strafeom drugi Taiho. Dal sam ga prijavo? Ne, komplementirao u chatu i dao kompliment na kraju partije.
Drago mi je čuti da ti leži Zao, ja sam oduševljen s Des Moinesom. Des je stil života - najzabavniji brod koji sam vozio u igri. U stanju pobrisati svaki drugi CA unutar 20s ako dođe na ispod 10 km. Rastopio full HP Zao jučer u 3 salve i neki dan isto Hindenburg.
Novi leak:
- Hipsteru konačno "atlantski pramac", lol za Koni komentar "at the expense of AA power" - kao da je i imao neki AA u startu
- Roon i Hindi AA nerf potpuno zaslužen
- Buff IJN BB AA... šteta, nadam se da nije previše jer su mi glavni bili za farmanje
- Nerf NC i Iowa AA, buff Moontyu - oukej, nadam se ne preveliki nerf
- Buff USN BB secondary - super
- Indianapolis T7 ... ODLIČNOST!
Nedostaje najavljeni buff preciznosti USN T8-10 BB topova.
Zadnje izmijenjeno od: T}{OR. 10.05.2016. u 08:45.
Staro 10.05.2016., 08:44   #2514
BladeRy
BladeRy's Avatar
Postovi: 2,000
IJN CA line ima svoj nacin igranja, ako igras Zao-a kao Atago na konju si. Imas vise topova, brzi reload i bolju shell putanju, DDovi se tope, tj, sve se topi. Samo treba znat da brod nije bas brawler. Meni lezi taj gameplay sta sam naucio na Atagu
DM je super na svoj nacin igre, ako hoces harrasat, parkiras se iza otoka i sa mortar shellovima bombardirat sve u rangeu, il lovit DDove il cruisere ako nemaju BB podrsku. Brod moze out-dpsat sve zivo i kaznit broadside gadno.
Staro 10.05.2016., 08:51   #2515
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
Što je i logično jer su oba kraj svoje linije pa se i očekuje da iskoristiš sve što si naučio do tada. Prije par dana naletio na dobro vožen Zao. Odličan brod u pravim rukama - uzeo nam je pobjedu na samom kraju i pobrao Krakena potopivši Tirpitza u zadnjim sekundama.
Baš sam isprobavao roštiljanje BB-a sa DM jer nemam DE skill nego AFT. I bez DE skoro svaka salva na Yamu, Montya, Iowu ili neki treći BB je vatra - ako ciljaš visoko u nadgrađe. Onaj replay sa 600k profita koji sam stavio - dok sam se povlačio ispalio sam jednu salvu na Iowu i NC, obje su rezultirale vatrom. Yama je posebno pogodan za roštiljanje "iza otoka".
Čisto za usporedbu kvalitete i jačine AA: U 60 partija sa Balmerom imam oko 300 srušenih aviona. S DM imam toliko u 20 partija i to donosi brdo love i XP-a.
Staro 10.05.2016., 08:56   #2516
BladeRy
BladeRy's Avatar
Postovi: 2,000
Pa DM lako lozi jer ima dobar RoF, ako ne zapalis sad, zapalis sljedecom salvom za par sec. Glavno je pogadjat superstructure, nebitno o brodu.
A dobar brod u dobrim rukama radi cuda.
Staro 10.05.2016., 09:22   #2517
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
Ako ti odgovara način i stil nemamo o čemu pričati.
Dopuna BB AA promjena:
On the NA forums, they said that NC and Iowa's AA was massively buffed, not nerfed, with all the dual 40mm replaced with quads. Karlsruhe also received more torpedo tubes it seems. Nurnberg received a lower C hull that trades 2 tubes for massive AA upgrade. The IJN BBs replaces all the 13.2mm with 25mm (which what should be) and it seems the Nagato turret change adds the rangefinders on the 2nd and 3rd turrets.
Jesu oni normalni? Ionako je NC zona bez letenja za T6 CV koje jako često sreće, ovako bolje da ekipa koja sa T6 CV uleti u T8 partiju stavi na autopilota i pričeka novu...
Meni sve sve čini da je neki rework u planu, u funkciji povijesnih Hullova (Hipper, Koni, 40mm quadovi na USN brodovima).
EDIT: Navodno brutalan AA buff od NC to Montya, kompletna zamjena dual 40mm boforsa quadovima:
http://forum.worldofwarships.com/ind...st__60#topmost
... čemu????
Zadnje izmijenjeno od: T}{OR. 10.05.2016. u 09:56.
Staro 10.05.2016., 09:26   #2518
Tvrdi
Sremium
Postovi: 2,854
Sad ispada da je svaka t10 krstarica zakon hehe. Veli Thor pobrisao je Hindija. Je, ali taj Hindi u dobrim rukama tebe one shota u citadelicu samo tako (to s daljine di ga ti nemreš dohvatiti) I ne samo tebe. Bilo kaj što mu se nađe na putu. Opet, ako ti se približi previše, to je njegov bad. Opet se vraćamo na spiku "know your ship".
Staro 10.05.2016., 09:36   #2519
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
Poanta priče je da ih moraš igrat na kartu gdje su jači. DM nema balistiku za gađat mete preko 12km izuzev BB-a i ekipe koja ne zna za WASD hack. Isto sam odgovorio na službenom forumu jednom liku koji je rekao da je USN CA linija najslabija CA linija. Nije istina - biraš mete i uvjete pod kojima ulaziš u borbu, kako tebi odgovara. Sa svakim brodom. Samo je pitanje dal ti njegov gameplay leži ili ne.
Hindi traži metu sa otkrivenim bokom i tu kažnjava, više je kao artiljerija. Zao je sličan sa puno boljim HE shellovima pa je malo više fleksibilan dok i Roon i Hindi postanu "sterilni" kad im nos okreneš jer ovise o AP granatama. Onda im je jedina šansa uništavanje kupola (dogodilo mi se nekoliko puta na nos protiv navedenih brodova, jednom ostao bez obje prednje u NO).
I Des i Balmer su najjači kad se kreću blizu svoje flote. Zato i imam 70% WR sa Balmerom. Odličan oklop i super za brawl. Ne želiš im doć blizu. Najbolja stvar koju sam jučer skužio - Khabarovskove AP granate su se samo odbijale od mog Des Moinesa, pod svim kutevima. U NO mi je on strah i trepet jer me rastopi s APom, u Des se samo smijem dok me škaklja.
Gušt igranja T10 linije je što si uvijek top tier. To nam je svima bilo jasno i prije.
Staro 10.05.2016., 11:19   #2520
BladeRy
BladeRy's Avatar
Postovi: 2,000
Bas to sta Thor kaze, balistika DMa ti diktira nacin borbe. Prilagodi se tome i deri. DM je nesto kao Cleveland, zato ekipa sa Clevelanda prelaskom na Pepsi popizdi radi totalno drukcijeg gameplaya. Nakon Pepsi-No-Baltija, DM ima drugi stil igre.
Ima RoF, ima dmg, balistika ti diktira situaciju i iskoristivost, jedini minus je bas radi tog RoFa da bi radio dmg moras non stop pucat i bit otkriven, il stat iza otoka.
Nisu brodovi OP koliko ljudi neznaju igrat sa njima. Eto je po njima DM najlosiji T10 cruiser, a ne uzimaju u obzir da je razlika u stilu igranja ono sta radi dmg. Atago (il Tirpitz ako hocete) je kao najgori T8 cruiser (BB), barem po statsima, jer su ga noobovi nakupovali, odu u T8-10 gdje ih netko izbrise sa 1-2 salve i onda kmece na forumu.
DMa me uvijek strah kad pridje, jer ima bolji RoF i ako ne napravi cisti dmg, moze ti poubijat turete i onda se jebi. Ako naidje na DDa, radar i ode DD. U pravim rukama je DM vrlo opasan brod, al na svu srecu, malo je bas dobrih igraca sa njim. Ekipa rusha na njega jer je T10 i RoF brod a kad sjednu u njega vidis da pojma nemaju.
Jebote, na t10 ispod 10km on otvara broadside... umjesto da se igra na prednosti broda.
Vidio sam dosta ekipe prve dane sa Moskvama, platili free exp cca 150€ da ih odma igraju, iako je brod prokleto nebalansiran sa njom mozes radit cuda. Odlicni topovi, balistika, domet i sve, al ljudi igraju na krivi nacin pa sa velikim brodom idu u prvu crtu borbe i onda ih pobiju. Igrao sam sve t10 krstarice na PTRu, Zao mi je najdrazi, al Moskva je radi topova najucinkovitija. Citadel pen u belt sa 15-18km na BB. To sam pokusavao sa Zao u trening sobi na ispod 10km na BBove, Montane i Yamata, nista. Ako pogadjas belt nema citadela, jedino ispod tureta, Moskva ne jebe 2% belt, busi sve. Daj je u ruke dobrom igracu koji zna prednosti i mane broda pa da vidis masakra (doduse, vrijedi za sve t10, jer im je stil igranja svima razlicit)
Glede BB AA buffa, pa ako hocemo povjesno gledano, BBi su bili AA oslonac flote. Jer su imali stotine AA topova, ako ih stavis ingame tako, CV im nemoze nista. Pa su doveli ovu situaciju sadasnju, gdje neki BB nemoze pogodit nebo a drugi imaju AA da ih se jednostavno ne isplati napadat.
Zadnje izmijenjeno od: BladeRy. 10.05.2016. u 11:30.
