Magister Mundi sum!
Datum registracije: Jun 2003
Lokacija: Zagorje
Postovi: 2,335
Molim vlasnike sljedecih LCD-a...
da se javiju tu i veliju kakvi su je ti monitori .. napokon pred nosom imam 2500 kn i fakat stvarno idem po LCD dosta mi je ovog ekrana koji mi pol stola zeme ... gledal sam ove monitor 17" lcd xerox xa7-17i, 8ms, dvi monitor 17" lcd samsung sm 713bm, 8ms monitor 17" lcd samsung sm 713n, matisse, 8ms monitor 17" lcd samsung sm 730bf, matisse, 4ms, dvi molil bi da mi velite koji je od ovih najbolji ili da preporucite kakvog drugog koji nije tu ..... ( na kompu se igram , programiram , brat dela neke s grafikom itd itd bla bla bla ... ) thnx
the luda ribetna
Postovi: 3,952
730 lg(po mnogim svjedocenjima) al ja osobno preferiram xeroxa ![]() |
Postovi: 9,067
SM730BF Black 17" DVI SXGA LCD Monitor 4MS Response Sleek and minimalist the dynamic lines of the SM730BF brings you adaptable, versatile working, while a market leading 4ms response time makes this monitor perfect for gaming and watching multimedia content. Combine this with both analogue and digital inputs and you have the ideal solution for work or play Specs Product Description SM730BF Black 17" DVI SXGA LCD Monitor 4MS Response Mfr. Code LS17BIDKSV Dimensions (WxDxH) 382 x 386.2 x 175 mm Weight 3.6 kg Interface(s) 15pin D-sub, DVI-D Screen Size 17" Viewable screen Screen Type Flat panel display / TFT active matrix Display Colours Up to 16.2 million colors Resolution 1280 x 1024 / 75 Hz Dot / AG Pitch 0.264 mm Features MagicBright, MagicTune Compliant Standards TCO'99 Included Software Drivers & Utilities, Magic Tune Included Accessories Stand System Requirements Not specified Warranty 3 years manufacturers warranty
___________ Just atha x |
Whatever :)
Datum registracije: Nov 2002
Lokacija: Rijeka,Bulevard
Postovi: 1,751
Ja ti imam ovog Samsunga 713BM,odličan monitor,slika je super,matrica odziva 8ms,imaš ugrađene zvučnike i što je možda inajbitnije ima dvi priključak. Ne mogu ti ništa drugo reći nego samo preporučiti monitor.
#8 | |
Postovi: 18,843
#10 | |
Postovi: 18,843
Postovi: 1,130
valjda je mislio da svi imaju analogni, a "noviji" i DVI...tako da velika većina jeftinih modela i 17 i 19" dijagonale dolaze samo s analognim...
..smartphone... |
the luda ribetna
Postovi: 3,952
sve koji su u natjecanju su sa dvijem mislim da je tu kraj ot prosao ![]() |
#15 | |
Lokacija: Bjelovar/Zagreb
Postovi: 357
Imas na netu dosta reviewova za 930BF pa procitaj njih... dodje ti na isto... |
#17 |
Postovi: 357
I ja sam jucer kupio 930BF... Slika super... u igrama super... sve super... Jedino... ima par sitnica koje me zivciraju... pa ako netko zna rjesenje... Naime, dok monitor radi preko digitalnog prikljucka, onda ne zeli prikazivati rezoluciju manju od 1024x768... Pa imam slijedecih zajebancija: - udjem u igru koja je podesena na 800x600 rezoluciju - monitor izgubi signal - nekako ubijem igru da se vratm u windowse, ili restartam komp - prebacim na analogni prikljucak - udjem u igru i povecam rezoluciju - vratim se u win i prebacim natrag na digitalni - i sada tek idem igrat... I sada igram... I onda primjetim ovo... da se na nekim teksturama u Quakeu 4 i Serous Samu 2 pojavljuju neke titrajuce tockice... i te tockice nestaju tek kada igram u nativnoj rezoluciji (1280x1024)... dok u skoro svim manjim rezolucijama te tockice postoje na odredjenim teksturama... (npr. na Samovoj majici u meniju igre)... I onda se malo zajebavam s postavkama... i skuzim sljedece: Tih tockica ima samo dok koristim digitalni prikljucak... a analogni radi dobro u svim rezolucijama i nisam primjetio ni jednu mutavu tockicu na teksturi... Drivere za monitor sam instalirao, ali mi je onda maksimalni refresh rate bio 60Hz, a monitor podrzava 75... tako da sam vratio Plug and play monitor drivere... jer s njima prepoznaje 75Hz kao maksimalni refresh rate... |
#19 | |
Postovi: 18,843
#20 |
Propali Amigaš
Lokacija: Nin
Postovi: 7,005
Eto i ja ciljao xeroxa, a ubo 930BF...malo mu je loš vidljivi kut i boje, slika malo presvijetla za moj ukus, al za igre i video super, apsolutno nikakav ghosting ne primjećujem |
