Staro 10.03.2016., 23:48   #4771
alengrosevic
alengrosevic's Avatar
Postovi: 3,775
Autor Kristijan1 Pregled postova
Nisam baš oduševljen sa izmjerenom brzinom , ali nazvati ću ih kroz dan ili dva da to malo poprave .
Teško da će reagirati. Oni u paketu od 20 garantiraju između 14 i 20 ako se ne varam. Meni je padalo ispod 5 mbita (paket 20) pa su reagirali ali im je trebalo 2 mjeseca da to otklone. Eventualno ako te prebace na VDSL (pod pretpostavkom da si na ADSL-u) tad bi mogao dobiti traženih 20.
alengrosevic je online   Reply With Quote
Staro 12.03.2016., 17:23   #4772
Kristijan1
Kristijan1's Avatar
Lokacija: Čepin
Postovi: 1,507
Javim rezultate kada stigne oprema i prebace me na VDSL .
Staro 21.03.2016., 15:06   #4773
Gile
Postovi: 380
Evo mene Optima prebacila na VDSL 30/5 za sada, zvali me 29.2 te danas došao tehničar sa routerom Innbox V51.
Code:
Mode:	VDSL2
Traffic Type:	PTM
Status:	Up
Link Power State:	L0
 	Downstream	Upstream
Line Coding(Trellis):	On	On
SNR Margin (0.1 dB):	121	158
Attenuation (0.1 dB):	0	0
Output Power (0.1 dBm):	145	92
Attainable Rate (Kbps):	56068	20040
 	Path 0	 	Path 1
 	Downstream	Upstream	Downstream	Upstream
Rate (Kbps):	36861	6143	0	0
B (# of bytes in Mux Data Frame):	31	15	0	0
M (# of Mux Data Frames in an RS codeword):	1	1	0	0
T (# of Mux Data Frames in an OH sub-frame):	64	51	0	0
R (# of redundancy bytes in the RS codeword):	10	16	0	0
S (# of data symbols over which the RS code word spans):	0.0276	0.0822	0.0000	0.0000
L (# of bits transmitted in each data symbol):	12184	3114	0	0
D (interleaver depth):	1331	195	0	0
I (interleaver block size in bytes):	42	16	0	0
N (RS codeword size):	42	32	0	0
Delay (msec):	9	2	0	0
INP (DMT symbol):	4.00	2.00	0.00	0.00
OH Frames:	583196	146099	0	0
OH Frame Errors:	0	0	0	0
RS Words:	223804523	2354867	0	0
RS Correctable Errors:	6682	0	0	0
RS Uncorrectable Errors:	0	0	0	0
HEC Errors:	0	0	0	0
OCD Errors:	0	0	0	0
LCD Errors:	0	0	0	0
Total Cells:	109874278	0	0	0
Data Cells:	9389438	0	0	0
Bit Errors:	0	0	0	0
Total ES:	0	0
Total SES:	0	0
Total UAS:	22	22
Zadnje izmijenjeno od: Gile. 21.03.2016. u 20:30.
Gile je offline   Reply With Quote
Staro 22.03.2016., 17:32   #4774
BlackDwarf
BIND SOFT d.o.o.
BlackDwarf's Avatar
Lokacija: Novska
Postovi: 2,411
Digli brzinu na 20Mbit, ali sada je kvaliteta na samoj margini i ima CRC-a (na 10Mbit nije bilo). Za divno cudo nije niti jednom puklo.
Downstream Upstream
SNR Margin
6.0 8.5 db
Line Attenuation
14.7 8.0 db
Data Rate
20111 997 kbps
Max Rate
21388 1076 kbps
CRC
376 3
Znaci oni samo +30Mbit nude VDSL?
Staro 22.03.2016., 22:59   #4775
mislav_os
freak
Postovi: 2,688
Sve sto nude iznad 20MBit je VDSL
Staro 22.03.2016., 23:01   #4776
BlackDwarf
BIND SOFT d.o.o.
BlackDwarf's Avatar
Lokacija: Novska
Postovi: 2,411
Mozda da malo ipak smanje profil, ali dok ne puca nek ostane tako.
Btw. prije 20 dana bili neki momci na pregledu terena. Mjerili udaljenost izvoda i slikali gdje se sto nalazi. Rekose radit ce se nesto, ali nisu rekli sto.
Staro 23.03.2016., 00:20   #4777
mislav_os
freak
Postovi: 2,688
Pa da, jedino ako ti bude pucala trebalo bi smanjiti profil malo.
Staro 25.04.2016., 15:55   #4778
Night bird
Lokacija: Varazdin
Postovi: 137
Pozdrav,
Danas sam dobio pismeno da im trebam vratiti ruter. Tj. piše da bi opremu trebao vratiti unutar 30 dana od prestanka korištenja usluga. Pismo je poslano 21.4.2016. a na drugom operateru sam cca. 7mj. Ruter sam planirao bacit jer za drugo i nije, sva sreća pa nisam. Tako da u slučaju da ste prešli na drugog operatera ili to planirate napravit nemojte bacati rutere jer će te ostat kraći za 500-600kn.
Night bird je offline   Reply With Quote
Staro 25.04.2016., 21:49   #4779
microsoft66
microsoft66's Avatar
Datum registracije: Apr 2008
Lokacija: VK
Postovi: 1,257
pa piše ti na računu ili u ugovoru da si u najmu opreme što znači da oprema nije tvoja
Staro 26.04.2016., 18:49   #4780
azure
Datum registracije: Mar 2009
Postovi: 157
Autor Night bird Pregled postova
Pozdrav,
Unazad cca 3-4 godine, svi paketi koji se nude su uz najam opreme a kao što je kolega forumaš iznad komentirao, vidljivo je na svim računima pa si provjeri neki stari. Inače se oprema kupi cca mjesec dana nakon raskida no nekad zaštekaju procesi pa radni nalog izađe kasnije.
azure je offline   Reply With Quote
Staro 27.04.2016., 09:23   #4781
Goranbm
Goranbm's Avatar
Postovi: 1,238
Nije možda full vezano za temu, ali nisam znao gdje da pitam. Uglavnom u firmi na jednoj lokaciji koristimo Optima DSL, i sad imamo telefon preko splitera, i uveli bi drugi telefon ali ne u smislu sa drugim brojem, nego da Telefoni budu kao jedan. Da li je onda dovoljno samo zbrickati tva dva telefona i onda uštekati u splitter. Bude to radilo ? Ili ima za kupit nekih razdjelnika. Hvala.
Goranbm je offline   Reply With Quote
Staro 27.04.2016., 09:41   #4782
tskarda
tskarda's Avatar
Postovi: 1,123
To zvekni u splitter gdje je izlaz za telefon.
Staro 27.04.2016., 09:50   #4783
Goranbm
Goranbm's Avatar
Postovi: 1,238
E hvala. RJ-11 jel to jel ?
Poslano sa mog LG-D855 koristeći Tapatalk
Staro 27.04.2016., 15:00   #4784
Arsenal-fan
Mallosi
Arsenal-fan's Avatar
Postovi: 338
Autor Goranbm Pregled postova
Je to ti je to
Arsenal-fan je offline   Reply With Quote
Staro 03.05.2016., 13:36   #4785
slish480
Yeeepiyaye
slish480's Avatar
Lokacija: Graz, Austria
Postovi: 294
Pozdrav, moram li optimi vratiti router nakon što se prebacim na novu mrežu. Istekla nam je ugovorna obaveza i sad se prebacujemo na Iskon.
slish480 je offline   Reply With Quote
Staro 03.05.2016., 13:52   #4786
Razor
Postovi: 96
Da. Nazvat ce te oko toga za cca mjesec dana i poslati nekoga po ruter (tako su nedavno napravili meni)
Razor je offline   Reply With Quote
Staro 05.05.2016., 15:51   #4787
Feyd
hungry, for a little more
Feyd's Avatar
Postovi: 241
Autor Razor Pregled postova
Meni je jučer došla obavijest da vratim u Buzin od ponedjeljka do petka između 8h i 16h, ili da pošaljem poštom.
Naravno, poslati ću poštom, subotom ne rade, radnim danom do 16:00.
Profesionalno, nema šta.
Feyd je offline   Reply With Quote
Staro 11.05.2016., 17:17   #4788
BlackDwarf
BIND SOFT d.o.o.
BlackDwarf's Avatar
Lokacija: Novska
Postovi: 2,411
Ima netko problema s brzinom. Meni umjesto 20Mbit varira 0,1-0,56Mbit
Staro 17.05.2016., 16:56   #4789
c-shadow
c-shadow's Avatar
Postovi: 3,472
A ima likova stvarno na Optima helpdesku... Danas mi baš trebao VPN do firme i kad ono ne ide.... CGN
Skinem obrazac, vidim nema nigdje za slanje mailom, zovem podršku i javi se neka kvočka i 3 puta sam pokušavao postaviti pitanje kako i na koji mail da to pošaljem, svaki puta me prekinula: "Piše sve na webu" Ono, niti rečenicu nisam završio do kraja, ova neće niti pričati dalje, čim zaustim evo nje opet da sve piše na webu. Sad popunjavam obrazac, printam, potpisujem, skeniram i šaljem na sve emailove koje nađem od Optime. Baš da vidim jel prolazi ili će baš trebati pismeno poštom slati.
U 2016.g. smo, dobro da ne moram javnom bilježniku na ovjeru
Staro 17.05.2016., 17:10   #4790
mislav_os
freak
Postovi: 2,688
podrska[at]optinet.hr
Samo pošalji na taj mail.
G3 via Tapatalk
Staro 17.05.2016., 19:59   #4791
opala
Datum registracije: Jul 2009
Lokacija: Koliba
Postovi: 1
Pozdrav svima,
Imam problem sa otvaranjem portova na ovom zadnjem modem od optime,
u pitanju je Innbox V51,iako postoji opcija pod NAT-Virtual servers,ali nemoguće je otvoriti portove,.
Isto tako imam više svojih routera,ali nemožže ni jedan drugi,jer kad sam ih zvao u SZK-optima rekli su da je modem vezan MAC-adresom za centralu,radi se o paketu TO2-40 Mibps,inače modem nije loš,ali nemože se portat niti bacit u bridge mode,pa da mogu probat spojit neki drugi modem za taj Inbox i tako dobiti portove na van,.
ovo je moja linija inače,..jel dobra,jer nikad nisam kužio te brojke,..
Code:
Mode:	VDSL2
Traffic Type:	PTM
Status:	Up
 	Downstream	Upstream
SNR Margin (0.1 dB):	177	272
Output Power (0.1 dBm):	139	93
Attainable Rate (Kbps):	89738	29586
 	Path 0	 	Path 1
Rate (Kbps):	45055	8192	0	0
B (# of bytes in Mux Data Frame):	31	34	0	0
T (# of Mux Data Frames in an OH sub-frame):	61	1	0	0
S (# of data symbols over which the RS code word spans):	0.0226	0.1323	0.0000	0.0000
L (# of bits transmitted in each data symbol):	14872	3084	0	0
D (interleaver depth):	1625	61	0	0
I (interleaver block size in bytes):	42	51	0	0
N (RS codeword size):	42	51	0	0
INP (DMT symbol):	4.00	1.00	0.00	0.00
OH Frames:	481	90	0	0
RS Words:	176339	0	0	0
RS Correctable Errors:	0	0	0	0
HEC Errors:	0	0	0	0
OCD Errors:	0	0	0	0
LCD Errors:	0	0	0	0
Total Cells:	86635	0	0	0
Data Cells:	95	0	0	0
Bit Errors:	0	0	0	0
Total ES:	0	0
Total SES:	0	0
Total UAS:	0	0
xDSL BER Test  Reset Statistics
Hvala na pomoći,.
opala je offline   Reply With Quote
Staro 18.05.2016., 10:41   #4792
Kapica
Lokacija: Varazdin
Postovi: 108
Pozdrav svima,
Zamolio bi za pomoc, ako je netko imao iskustva s ranijim prekidom ugovora i slicno.
Naime, podstanar sam, i vlasnik stana ima 2 ugovora, jedan kod sebe doma, i drugi u stanu gdje sam trenutno..
I stuck sam sa "O3TVSURFPLUS paketa imate ugovornu obavezu do 24.10.2016"
Jebeni 4Mbit i kad upatim TV padne na 3Mbit....
Ne mogu vise tako, poludit cu, a placam jebenih 307 kn, da ne pricam da nis pametnog nema na televiziji jel...
Upite njima na helpdesk dobivao info da nemogu ni promijeniti brzinu bez da se potpise novi ugovor na 24mj...
Ima ko neki savjet, ili broj stranice, malo mi teze pretraziti cijeli thread za tocnu tematiku?
Hvala ekipa
Kapica je offline   Reply With Quote
Staro 18.05.2016., 23:11   #4793
alengrosevic
Postovi: 3,775
http://www.optima.hr/hr/korisnicka-podrska/internet/
Prvo pitanje:
Koliko puta mjesečno mogu promijeniti paket prometa/brzine, i koliko se to naplaćuje?
"Možete jednom mjesečno. Promjena se ne naplaćuje."
Staro 19.05.2016., 15:47   #4794
Kapica
Lokacija: Varazdin
Postovi: 108
Prvo pitanje:
Bok, kao prvo, hvala na odgovoru...
Prvo sam mislio da me trollas, onda sam popizdio i isao zvat opet SZK.
I opet mi pricali, da promjena paketa brzine povlaci i ugovornu obavezu jer te tarife vise nema u ponudi bla....
Pa sam bio malo uporan, i nakon 10 minuta, se sjetila
A gle, mozemo vam ponuditi tarifu bez ugovorne obaveze koja je 30kn skuplja od one s ugovornom obavezom....
Znaci, sad cu dobit, mislim da O3, 10Mbit, za 275kn bez ugovora, i time pregaziti trenutni paket koji ima ugovornu obavezu do 10.2016..
I teoretski mogu prekinuti uslugu, recimo s 01.07.2016 bez penala...
Ko je tu lud.. Ja se ne bunim... Ali.. Nema veze s mozgom...
Samo u Hrvatistanu..
P.s.: nadam se da ce ovo nekome pomoci
Staro 20.05.2016., 00:06   #4795
alengrosevic
Postovi: 3,775
super da si si sredio. Ma nisam te trollao niti nista lose mislio nego sam cisto htio da imas argument kad kaze da ne moze, da fino kazes, "procitajte si na Vasem WEB-u..."
Jer nemali broj puta mi se javio s druge strane operater koji nije bas najbolje upoznat s uslugama i mogucnostima koje mi mogu ponuditi/pruziti. Zasad mi je net ok, i samo neka tako ostane. Jer ako krenu problemi, jao si ga meni... Ne ponovilo se...
Staro 20.05.2016., 09:08   #4796
Kapica
Lokacija: Varazdin
Postovi: 108
Ma.. ispada da argumentat o informaciji na internetu je i nije pomogao..
Naime stara je bila tarifa, i naravno oni u sustavu nemaju vise "srodnih" tarifa vec samo nove.. koje nisu "kompatibilne" s mehanikom promjena paketa brzine...
Naime u jednom trenutku mi je ponudila na postojeci tarifu koju vec placao preko 300kn, da dodaju veci paket brzine, do 10Mbit sa 65kn doplate...
Skoro sam pitao da li su normalni.. Malo se zgrazao, pa vidi vraga pocele se otvarati opcije...
Da bi na kraju dobio nesto "normalnije"..
Staro 08.06.2016., 15:11   #4797
alengrosevic
Postovi: 3,775
koji su to kraljevi u Optimi. Naime pod ugovornom obvezom sam još cca godinu dana (VDSL 20 mbita). Prilikom potpisivanja tog ugovora bilo mi je rečeno da ću brzinu moći promjeniti na veću, jer brzina više nije problem pošto je unutar iste usluge (VDSL).
Jučer sam htio uzeti veću brzinu (40 mbit) i kaže mi Lucio (operater) s druge strane, da ne mogu samo tako promjeniti brzinu na veću, nego ako povećavam, onda moram potpisati novo produženje na 2 godine. Lijepo sam se zahvalio, i rekao da ću pričekati tu nekog lokalnog providera koji vuče optiku jer je ovo svinjarija. Za promjenu profila na centrali traže nove 2 godine ugovora. Koje gluposti...
Staro 08.06.2016., 15:31   #4798
BlackDwarf
BIND SOFT d.o.o.
BlackDwarf's Avatar
Lokacija: Novska
Postovi: 2,411
Svaki mjesec besplatno mozes dizati i spustati brzinu. Znaci svaki mjesec novi ugovor.
Sent from my SM-J500FN
Staro 08.06.2016., 15:38   #4799
brodjo
Playmaker
brodjo's Avatar
Lokacija: Osijek/Wien
Postovi: 1,660
Pa nisu ti ništa naplatili da ti produže ugovor
brodjo je offline   Reply With Quote
Staro 12.06.2016., 00:35   #4800
dario1122
Datum registracije: Jun 2016
Lokacija: rijeka
Postovi: 2
Ima li neke razlike u v45 iv51 innbox modema, meni uvalili ovaj v45 i cini mi se jako los wlan
dario1122 je offline   Reply With Quote
