Staro 25.02.2016., 21:11   #1
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,744
Eksterni sistemski SATA 3 SSD: USB 3.0 vs eSATA?
Ovako, pošto se na poslu vrlo često selim s jednog na drugo računalo, razmišljam u eksterno 2.5" kućište šiknuti sistemski Sata3 SSD sa OS-om i potrebnim softverom. Koje je robustnije i/ili brže sučelje? eSata ili USB 3.0/3.1?
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
Zadnje izmijenjeno od: estugarda. 26.02.2016. u 12:39.
estugarda je offline   Reply With Quote
Staro 25.02.2016., 23:19   #2
Postovi: 23,579
Jel to ozbiljno pitaš ?!?
Drugo i važnije pitanje je koliko je različit hw među tim kompovima ?
Postoji mogućnost da bi se os na tom prenosnom disku "rasuo" nakon x različitih.
Mada ima alternativa za takav scenarij.
Staro 26.02.2016., 00:18   #3
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Najozbiljnije. Nije sve u brojkama. Ostavimo kompatibilnost drivera/os-ava/hardvera po strani za sad. To je druga komplicirana priča. Mene zanimaju vaša mišljenja i iskustva u razlici eSATA/USB3.0/3.1 baš za SSD sistem, odnosno stabilnost i robustnost sistema. Brojke su jasne. 5Gbps za USB3.0, 6Gbps za eSATA i 10Gbps za USB3.1. U idealnim uvjetima, naravno, a koji su pak rijetko mogući.
USB prolazi kroz hub. eSATA ide direktno koliko ja znam i samo je produžni za SATA, i trebao bi biti optimiziran baš za diskove, dok je USB katica za sve, što mu i ime govori.
Nisam nikad koristio USB za sistemski SSD, ali eSATA jesam. I nije se pokazalo kao sasvim robustno rjesenje. Za početak, eSATA portovi i kablovi po mojem iskustvu nisu baš robustni i zgodni za višestruka preštekavanja (pričamo o barem 3 uštekavanja/ištekavanja dnevno). Nije da je USB puno robustniji. I tak, ima tu meni dosta nepoznanica i zanimljivih stvari.
EDIT:
Evo solidne usporedbe USB 3.0 vs eSata za eksterne HDD i SSD. Jasno je bilo da će tu eSATA biti puno bolji u brojkama iz navedenih razloga, ali ipak nisam očekivao toliko. Bilo bi zanimljivo vidjeti i usporedbu sa USB 3.1.
Bitna stvar je da USB 3.0 danas manje više imaju sva računala. eSATA je teže naći na laptopu, a i sve rijeđe se nalazi na jačim pločama (primjer Z170). USB3.1 se nađe vrlo rijetko za sada generalno. eSATA kućišta često podržavaju i USB3.0, pa je to osigurač.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 26.02.2016., 16:34   #4
rodney
only fool, not a horse
rodney's Avatar
Datum registracije: Apr 2008
Lokacija: near zgb
Postovi: 1,281
Pa logično da je esata puno brži od usba. Prvo, esata nema nikakav "chip", kontroler etc. između diska i ploče, samo kabel. S druge strane usb protokol stvara dosta veći overhead, i to ovisi o veličini paketa koji se šalje, sto manje paket, to veći overhead. Sata protokol ima overhead oko 20%, a usb ima minimalno 20% (to je kad se pogodi bulk transfer i najveći payload ). Kod usba samo "bit stuffing" (umetanje 0 na svaki šesti bit u payloadu) može pojesti 16.67% podataka.
eh da, malo i teorije:
http://www.usb.org/developers/docs/w...s/bwpaper2.pdf
http://wiki.osdev.org/Universal_Seri...a_Payload_Size
"I intend to live forever. So far, so good."
job security - example
rodney je offline   Reply With Quote
Staro 26.02.2016., 16:41   #5
Postovi: 34,033
Meni je za eSATA trebao kabel za napajanje jer mu struja koju dobiva preko eSATA nije bila dovoljna za rad. Isti disk i kućište je na usb-u radilo bez dodatnog kabela.
Staro 26.02.2016., 18:44   #6
rodney
rodney's Avatar
Lokacija: near zgb
Postovi: 1,281
Dakako, eSATA protokol po defaultu ne nudi napajanje (a niti SATA).
To je kakti rješeno sa "eSATAp", ali to još nisam sreo uživo
Staro 27.02.2016., 14:29   #7
Old Iggy
Old Iggy's Avatar
Postovi: 4,888
Autor estugarda Pregled postova
Ne kužim baš ovo "ostavimo kompatibilnost sa strane". Ekstremno bitno. Počevši od samog SATA kontrolera.
S druge strane, usporediti eSATA i USB je, onak, u usporedbu si mogao staviti i vrećicu iz Konzuma.
eSATA je block, USB file protokol. Jedno s drugim nemaju veze. USB nije za OS ni bilo kakvu ozbiljnu data priču.
Igor Batinic
Staro 27.02.2016., 19:26   #8
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Je, bitno je. Na žalost sam se i sam uvjerio u to, ali je to skroz druga diskusija. Mene je zanimalo ovo drugo - brzina i stabilnost pod uvjetom da nema problema sa kompatibilnošću.
Imam iskustvo s jednim (eSATA) koje nije savršeno, pa me zanimalo drugo, jer sam pred odlukom što uzeti, s tim da je zapravo odluka USB3.1 vs eSATA. To poteže još dosta drugih stvari. Recimo, high end novije ploče (primjer Asus Z170) uopće nemaju eSATA, a adapter smanji priču na 3Gbps. Pa sam se pitao nije li USB3.1 bolje rješenje.
Slažem se da nisam dovoljno proučio materiju, jebiga. Zato ste vi tu da od vas naučim, ne!?
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 28.02.2016. u 12:53.
Staro 28.02.2016., 11:23   #9
max111
max111's Avatar
Postovi: 543
Autor coconut Pregled postova
SATA ne može dati napajanje ako nema standard power over SATA a treba i poseban kabel za spojiti disk. Znači ne može raditi niti 2.5 ni veći disk direktno samo spajanjem na običan SATA port. Ako komp nema ugrađenu podršku za napajanje preko SATA ima adapter ili pcie kartica.
CPU Intel i7 6700K
MBO ASRock Z270 Extreme4
RAM Kingston HyperX (2x8GB)
VGA MSI GTX970 4G TF5
HDD (1TB Samsung F3, Samsung 960 EVO, WD Caviar Green 3TB)
PSU Corsair AX750W
Windows 10 x64
max111 je offline   Reply With Quote
Staro 28.02.2016., 12:54   #10
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Autor Old Iggy Pregled postova
...Počevši od samog SATA kontrolera...
PS Sad kad sam još jendom pročitao, vidim da mi je ovo promaklo. Rado bih pročitao pojašnjenje ove gore izjave o kompatibilnosti "samog SATA kontrolera".
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 28.02.2016., 22:27   #11
Old Iggy
Old Iggy's Avatar
Postovi: 4,888
Svaki SATA kontroler ima svoje drivere za optimalan rad, kod diskovnih sustava to je ključna stvar.
Tehnički bi računalo možda moglo raditi ne generičkim driverima (sa spuštanjem u BIOS-u na stare legacy modove rada), no to baš i nema smisla.
Igor Batinic
Staro 29.02.2016., 20:26   #12
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Hm. Nisam do sada naletio koristeći eSata SSD na problem drivera ni potrebu legacy mode-a. Ili možda samo mislim da nisam, jer problema je bilo. File permission i slične gluposti uglavnom. Više su me mučili portovi i hardware.
Hvala na info u svakom slučaju.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
