Staro 23.01.2016., 14:53   #8701
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Pa ako ne treba da igre rade na ultra, može se fina konfa složiti za tu lovu. Kasnije se lako nadogradi ako bude potrebe
1 x Intel CPU Desktop Core i5-4460 (3.2GHz, 6MB,LGA1150) box
1 x Matična ploča Asus B85M-K (S1150,DDR3,VGA/DVI,USB3.0,LAN,SATAIIII) mATX
1 x KINGSTON ValueRAM DDR3 (8GB,1600MHz(PC3-12800)) CL11, Retail
1 x Seagate ST1000DM003, 1TB, 7200 rpm, 64MB, SATA 6Gbs
1 x Gigabyte NVIDIA GeForce GTX 750Ti, 2GB DDR5, 128 bit, DVI-I*1/DVI-D*1/HDMI
1 x XFX TS 450W, 80+ Bronze - 60mj.
1 x Zalman Z1, USB3.0 black, 2x120mm
Ukupno: 4500,00 kn
Staro 23.01.2016., 17:34   #8702
ibme74
ibme74's Avatar
Datum registracije: Jan 2013
Lokacija: Planet Zemlja
Postovi: 1,587
Uzmi onda ovo i GG
1x Procesor AMD X8 FX-8300 (16MB Cache, 8x3.30 GHz up to 4.20 GHz), sAM3+
1x LC-CC-95 CPU Cooler
1x Gigabyte GA-970A-DS3P, sAM3+
1x Gigabyte GTX950 WF2 Overclocked, 2GB GDDR5
1x DDR3 8GB (1x8GB) Kingston HyperX Fury 1866MHz
1x HDD 1TB Toshiba 3.5" 7200RPM 32MB Cache SATA3
1x Napajanje XFX P1-450S-GREEN TS Series 450W PSU 80+ Bronze
1x MS RANGER midi tower kućište bez napajanja
4.500,00kn
ibme74 je online   Reply With Quote
Staro 23.01.2016., 17:41   #8703
Sphere
Datum registracije: Mar 2015
Postovi: 1,254
Ovo je dobro, ja bi tu samo zamjenio ovo kuciste sa nesto tipa Z1 koje ima dva venta na sebi za protok zraka.
Zadnje izmijenjeno od: coconut. 24.01.2016. u 08:45.
Sphere je offline   Reply With Quote
Staro 23.01.2016., 19:41   #8704
yaya
covjece ova graficka je ko suvo zlato..u kom to ducanu???
Staro 23.01.2016., 22:55   #8705
hajlender
Datum registracije: Dec 2010
Postovi: 28
ASROCK FM2A88M EXTREME4+, AMD A88X, DDR3
AMD X4 860K BOX, Black Edition, s. FM2+, 3.7GHz, 4MB cache
8 GB, G.SKILL RipjawsX series, F3-12800CL10S-8GBXL, DDR3 1600MHz 51.210.359 389
1000.0 GB WESTERN DIGITAL Blue, WD10EZRZ, SATA3, 64MB cache, 5400okr./min
XFX AMD RADEON R7 360 Core Edition, 2GB DDR5
LG GH24NSD1, 24x, SATA, Dual layer, crna, bulk
ANTEC VSK-4000B, MIDI, crno, bez napajanja
ANTEC VP500PC ES, ATX v2.3, 120mm vent.
Ukupno 3782 kn
uzimo bih PC za igranje. Volio bih da bude dugo u igri i da ima novije komponente za do 4000 kn. Sta kazete na ovu konfiguraciju?
Zadnje izmijenjeno od: coconut. 24.01.2016. u 08:47.
hajlender je offline   Reply With Quote
Staro 23.01.2016., 23:13   #8706
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Može se to bolje za par kuna više:
1 x AMD FX X6 6300 (3,5GHz,14MB,95W,AM3+) box
1 x CPU Hladnjak LC-CC-95, Intel/AMD, 90mm 4-pin
1 x GIGABYTE GA-970A-DS3P, AM3+, R2.0, 4+1 Phase, 125W CPU
1 x Optički uređaj LG GH24NSD1 SATA Bulk Black 24x
1 x MS KNIGHT crno kućište, bez napajanja
1 x Fortron Hexa+ 400W, 80+
4040Kn Besplatno slaganje i besplatna dostava
Staro 24.01.2016., 02:27   #8707
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Također pazite sada sa tim WD blue diskovima, green više ne postoji pa imate wd blue od 5400 rpm i 7200 rpm
Staro 24.01.2016., 16:54   #8708
yaya
Dal ova polovna konfa redi 3500 kn??
Intel i5 3570 3.4 Ghz - turbo 3.8 Ghz
Asus p8h67-m evo
Corsair 6 gb ddr3 1600 mhz (3x2 gb)
Obično kućište (120 mm led plavi)
Msi hd 7850 2 GB GDDR5 Twin frozr (imam kutiju i račun, garancija istekla)
Xfx 650w 80+ bronze (daje 636w na 12v - sposoban držati 2 grafičke bez problema)
Dvd čitač
Wd black 1500 GB (bez bad sectora, health na 100%)...ja mislim da ne jer je lik vec kupio polovnu a i grafu je kupio polovnu
Staro 24.01.2016., 17:07   #8709
Smartic
Smartic's Avatar
Datum registracije: Mar 2011
Postovi: 2,707
Da.
Staro 24.01.2016., 19:17   #8710
Željac
sto da napisem ?!
Željac's Avatar
Postovi: 880
Autor ibme74 Pregled postova
Uzmi onda ovo i GG
4.500,00kn
u kojem je ducanu ovo slagano ??
moze i na pm ako je neka tajna itd.
djeluje mi maksimalno dobro za tu cijenu...
iii ova
Autor FRipper Pregled postova
Ukupno: 4500,00 kn
momci
Staro 24.01.2016., 20:57   #8711
yaya
Autor Željac Pregled postova
iii ova
momci
nije u jednom ducanu bas i mene zanima
Staro 24.01.2016., 21:42   #8712
Manuel Calavera
Postovi: 14,584
nitko (skoro nitko) ne slaže prijedloge iz više dućana.
Staro 25.01.2016., 15:39   #8713
goce11
Datum registracije: Jan 2016
Lokacija: sinj
Postovi: 8
ekipa moze neka konf za jedno 3500 kn da moze vrtit novije igre..što se da izvuc za ove pare..hvala
goce11 je offline   Reply With Quote
Staro 25.01.2016., 16:16   #8714
ibme74
ibme74's Avatar
Postovi: 1,587
Ako ne planiras u buducnosti nadogradivati:
1x AMD Athlon X4 840 (4MB Cache, up to 3.80 GHz), sFM2+
1x Gigabyte GA-F2A68HM-S1, sFM2+
1x Gigabyte GTX950 OC 2GB GDDR5
1x HDD 1TB Toshiba, 3.5", 7200RPM, 32MB Cache, SATA3
1x Napajanje XFX P1-450S-GREEN TS Series 450W 80+ Bronze
1x MS VOYAGER midi tower
UKUPNO: 3.569,97kn
Ako planiras (i5/r9 380 i sl.) onda ovo:
1x Procesor Intel Pentium G3260
1x Matična ploča MSI H81M-P33 iH81
1x KINGSTON 8GB 1600MHz DDR3 CL10 DIMM HyperX FURY Black Series
1x MSI GF GTX950 2GD5 2GB GDDR5
1x Toshiba DT01ACA050 500GB 3.5''
1x Fortron napajanje Hyper 500W
1x MS VOYAGER kućište bez napajanja
Ukupno: 3.525,17kn
Zadnje izmijenjeno od: coconut. 25.01.2016. u 17:50. Razlog: nema potrebe quotati post iznad svoga
Staro 26.01.2016., 15:54   #8715
goce11
Lokacija: sinj
Postovi: 8
konfiguracija do 3500 kn
Moze gaming konfiguracija do 3500 šta se da izvuc za te pare..hvala
Staro 26.01.2016., 16:09   #8716
ibme74
ibme74's Avatar
Postovi: 1,587
vec si napravio tu temu iako ti je odmah na vrhu glavna tema za to "Konfiguracije u rangu od 3.000 do 5.000 kn" i admin ti je premjestio pitanje tamo i ti opet pravis. Odi tu, tamo ti je prvi post i imas odg. http://forum.pcekspert.com/showthrea...10528&page=291
Staro 26.01.2016., 20:20   #8717
goce11
Lokacija: sinj
Postovi: 8
kakvi si ka strucnjak brajo?
Zadnje izmijenjeno od: coconut. 01.02.2016. u 06:38.
Staro 26.01.2016., 20:57   #8718
goce11
Lokacija: sinj
Postovi: 8
UKUPNO: 3.569,97kn
Ukupno: 3.525,17kn
u kojem bi ovo ducanu moga narucit? kakva su iskustva
Staro 26.01.2016., 23:30   #8719
whoracle
Lokacija: Lepoglava
Postovi: 4
Ukupno: 4500,00 kn
Jel ovo solidna konfiguracija za odigrat pokoju igru? Ispričavam se, al nisam baš u tome, ovo mi djeluje solidan iznos, pogledao sam komponente na nabava.net i sve se može na jednom mjestu nać, jedino bih izbacio hdd i stavi neki ssd, te može neka grafička koja podržava 2 monitora i tv na hdmi? hvala unaprijed
whoracle je offline   Reply With Quote
Staro 31.01.2016., 20:08   #8720
Nova_Konfig
Postovi: 7
Pozdrav ekipa. Gledam da si uzmem nešto za gaming s čime bi mogao igrati nove stvari barem na high postavkama. Uzeo bi samo ssd jer imam stari hard. Išao bi oko 5000kn ukupno, ali može i nešto više ako je baš potrebno. Trenutno gledam nešto ovakvoga što je već preko 5000 pa bi bilo super da sam negdje fulao s komponentama ili fulao dućan pa da se nešto uštedi. Navedene cijene su za gotovinu (kakti neki popust)
Matična Asrock s1150 H81M-HDS R2.0 436.45 Kn
Procesor Intel Core i5-4460 3.20GHz, 1150 Box 1,752.79 Kn
Grafička MSI Radeon R9 380 GAMING GDDR5 2GB 1,779.11 Kn
Kingston 8GB 1600MHz DDR3 CL10 DIMM HyperX FURY Black Series 336.38 Kn
Patriot SSD Blaze R545/W430, 120GB 392.59 Kn
Zalman Z1 NEO mid tower case 329.66 Kn
Napajanje Real Power RP500 ECO Silent Retail bronze 500W 369.00 Kn
Nova_Konfig je offline   Reply With Quote
Staro 31.01.2016., 21:13   #8721
Manuel Calavera
Postovi: 14,584
Sve je Ok samo nebi bilo loše kvalitetnije napajanje
Staro 31.01.2016., 21:19   #8722
ibme74
ibme74's Avatar
Postovi: 1,587
Autor Nova_Konfig Pregled postova
INTEL:
1x Procesor Intel Core i5 4460
1x GIGABYTE GA-H81M-S
1x Gigabyte R9 380 WF2 OC GDDR5 2GB/256bit, 970MHz/5500MHz
1x Kingston 8GB 1866MHz DDR3 CL10 HyperX Fury
1x Patriot SSD Blast R560/W425, 120GB, 7mm, 2.5"
1x Zalman Z1 mid tower
Sveukupno: 5.049,66kn
AMD:
1x AMD FX-8300 (8x 3.3GHz, Turbo Mode 4.2GHz, 16MB,95W,AM3+) box
1x LC Power CPU Hladnjak LC-CC-95 - 90mm Intel/AMD
1x GIGABYTE R9 380 GAMING GDDR5 4GB/512bit, 990MHz/5700MHz
1x Kingston 8GB 1866MHz DDR3 CL10 DIMM HyperX FURY Black
1x Fortron napajanje Hyper 600W
Sveukupno: 5.175,70kn
Staro 01.02.2016., 18:02   #8723
Nova_Konfig
Postovi: 7
Možda ja tu nešto griješim, ali u ovoj prvoj kombinaciji za matičnu kaže da je 1333MHz i 1600MhZ memorija a vidim da je kombinirano s 8GB 1866MHz rama.
O kojem se dućanu radi u ovom pitanju? može i pm ako se ne smije javno.
U svakom slučaju hvala za prijedlog
Zadnje izmijenjeno od: coconut. 02.02.2016. u 11:05.
Staro 01.02.2016., 21:13   #8724
ibme74
ibme74's Avatar
Postovi: 1,587
Nema veze sebi ploca spusti na 1600mhz a cijena je ista... Ne znam jel smoje pisat trg, ako je problem molim admina da obrise post... ***
Zadnje izmijenjeno od: coconut. 02.02.2016. u 11:06. Razlog: ne može se pisati trgovina
Staro 02.02.2016., 16:55   #8725
warlock25
warlock25's Avatar
Postovi: 2,327
pozdrav ljudi
bratu bi trebao slozit gamersku konfu da moze igrat sve nove igre na max detaljima u fullhd-u
Raspolaze sa 5000 kn.Ssd,hard,mon ima
znaci grafa,proc,ploca,cooler,ram,psu,kuciste treba
Zadnje izmijenjeno od: warlock25. 02.02.2016. u 17:56.
Staro 02.02.2016., 19:47   #8726
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
1 x AMD FX X8 8300 (3.3GHz,16MB,95W,AM3+) box
1 x CPU Hladnjak Alpenföhn Ben Nevis, 120mm, PWM
1 x Gigabyte GA-970A-UD3P (AM3+,DDR3,SATA III,LAN,USB 3.0, S/PDIF) 8+2 Phase, 125W CPU
1 x Grafička PowerColor PCS+ R9 380, 4GB 256bit GDDR5
1 x Fortron Hyper 600W, 80+ - 60mj.
1 x Kućište Cougar MX200, crno, USB3.0
Ukupno: 4995,00 kn
*Sa slabijom pločom GA-970A-DS3P ispada 4885,00kn
Zadnje izmijenjeno od: FRipper. 02.02.2016. u 22:34.
Staro 02.02.2016., 21:33   #8727
warlock25
warlock25's Avatar
Postovi: 2,327
u kojem je to ducanu?
Staro 02.02.2016., 22:10   #8728
ODO
Datum registracije: Feb 2015
Postovi: 593
GIGABYTE Main Board Desktop AMD 970A (SAM3,DDR3,SATA III,LAN,USB 2.0/3.0) ATX
LC Power CPU Hladnjak LC-CC-120 - 120mm Intel/AMD
XFX R9 380 4GB, XFX-R9-380P-4DF5
Kingston HyperX 8GB DDR3-1866 CL10SDRAM
Zalman kućište Z3 PLUS mid tower case
Sveukupno: 4.881,11
Matična ploča ASRock H81M-HDS R2.0
KINGSTON 8GB 1600MHz DDR3 CL10 DIMM HyperX FURY Black Series HX316C10FB/8
Zalman kućište Z3 PLUS mid tower case black Z3+, USB 3.0, bez napajanja, ZAL-Z3 PLUS
5.039,78 kn
ODO je offline   Reply With Quote
Staro 02.02.2016., 22:30   #8729
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Autor warlock25 Pregled postova
http://www.nabava.net/search.php?tp=...C+120mm%2C+PWM
jednostavno samo copy-past u nabavu
A konfa od kolege ODO
http://www.nabava.net/search.php?tp=...%2F3.0%29+ATX+
Staro 03.02.2016., 10:31   #8730
ibme74
ibme74's Avatar
Postovi: 1,587
1x AMD FX X8 8300 (3.3GHz,16MB,95W,AM3+) box
1x LC Power CPU Hladnjak LC-CC-120 - 120mm Intel/AMD
1x Gigabyte GA-970A-DS3P,AM3,A970,D3,S3,U3,A
1x GIGABYTE Radeon R9 380X GAMING GDDR5 4GB/256it, 980MHz/5700MHz
1x Kingston 8GB 1866MHz DDR3 CL10 DIMM HyperX FURY Black Series
1x Zalman Z1 mid tower case
UKUPNO: 4.999,93kn
