Staro 04.01.2016., 15:19   #391
vedran031
vedran031's Avatar
Postovi: 545
Ima netko da je stavio custom rom na huawei w1 i napravio update na w10?
vedran031 je offline   Reply With Quote
Staro 09.01.2016., 09:34   #392
nathan.fake
Lokacija: n/a
Postovi: 1,258
Iziso je Build 10586.63, zasad samo za Insidere (Fast Ring), navodno slj. tj. public.
... general reliability, battery and perf improvements that come with each of these revisions, there are also a few things that you've reached out to me about that should be improved:
- Typing on Polish keyboard in Outlook Mail
- Turn by turn directions over Bluetooth in car
- Battery usage with Iris Reco
- Reliability of quick actions settings page
- MS Band use with Cortana
Nema sluzbenog Blog posta pa evo sa Win. Central
edit:
Kratki FAQ: Build 10586.63 Info - Read Here!
Zadnje izmijenjeno od: nathan.fake. 09.01.2016. u 09:53.
nathan.fake je offline   Reply With Quote
Staro 09.01.2016., 10:22   #393
xXTheLuka1998xX
xXTheLuka1998xX's Avatar
Datum registracije: Feb 2015
Postovi: 353
izgleda da su ga uklonili
xXTheLuka1998xX je offline   Reply With Quote
Staro 09.01.2016., 11:02   #394
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Kako uklonili, ja maloprije uradio update?
Staro 09.01.2016., 11:23   #395
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,050
Autor xXTheLuka1998xX Pregled postova
Ajde malo čitaj i prati prije nego postaš.
Sinoć je bio haltan na pola sata.
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Mario92 je online   Reply With Quote
Staro 09.01.2016., 16:42   #396
xXTheLuka1998xX
Postovi: 353
Pardon,evo i ja sam ga instalirao na l535 super radi,nema nekih specijalnih poboljsanja
Staro 09.01.2016., 17:05   #397
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,067
Sinoć oko ponoći mi se instalirao. Ne vidim neke razlike, još uvijek sve radi besprijekorno na 830
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
OS: Windows 10 Pro x64
Staro 09.01.2016., 17:09   #398
akoj
lijevo smetalo
akoj's Avatar
Datum registracije: Jan 2014
Postovi: 1,120
Stavio jutros na L520 i radi ok. Jedino što mi je SD kartica wipeana.
Nvisen Y-GX01 // BMAX Y11
akoj je offline   Reply With Quote
Staro 11.01.2016., 23:39   #399
Milentije
Adrenaline junkie
Milentije's Avatar
Lokacija: Doboj - Banja Luka
Postovi: 3,593
Staro 12.01.2016., 10:20   #400
turbojc
turbojc's Avatar
Datum registracije: Sep 2014
Lokacija: Slavonski Brod.
Postovi: 162
Samo jedno kratko pitanje.
Radi li viber video call na Microsoftovom OS-u? Ili to radi samo na nekim modelima Nokie, ili kako?
Susjeda ima neku lumiu, i nemam ogućnosti za video call, pa sam malo guglao i našao sam neku temu staru god dana gdje piše da nije moguće imati tu opciju na ovom OS-u, pa me zanima je li se što promjenilo?
turbojc je offline   Reply With Quote
Staro 18.01.2016., 00:07   #401
Xenon
Postovi: 1,542
10586.63 po meni jos nije za finalnu verziju. Ne radi tako glatko kao 8.1. Ima jos nedostataka i neke stvari rade losije nego na 8.1!
Iako su vec poceli sluzbeno pustat (poljska), vjerovatno je .63 ako nisu mozda medjuvremenu jos sta doradjivali.
Xenon je offline   Reply With Quote
Staro 18.01.2016., 00:31   #402
buljaka
Datum registracije: Aug 2014
Postovi: 2,929
Autor turbojc Pregled postova
Nema
Staro 18.01.2016., 10:56   #403
NeooS
NeooS's Avatar
Datum registracije: Apr 2009
Lokacija: na Zemlji
Postovi: 527
Autor Xenon Pregled postova
Kakva ti je baterija na .63? Imao sam .29, prije cca tjedan dana mi skinuo automatski .36 i u odnosu na prethodni,mob mi ždere bateriju. Na .29 mi bila izvrsna.
Iako,jos nisam od 8.1 radio hard reset,bilo je ok. Stalno čekam službeni pa onda, ali izgleda da neću dočekati.
NeooS je offline   Reply With Quote
Staro 18.01.2016., 10:59   #404
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,067
830 na .63 se jednako ponaša u potrošnji baterije kao i na .29, .36
Ne vidim nikakvih pomaka, ni na bolje ni na lošije.
LCD: BENQ PD3200Q
Zadnje izmijenjeno od: 1v@n. 18.01.2016. u 11:06.
Staro 18.01.2016., 11:05   #405
buljaka
Postovi: 2,929
Meni na 535 od .36 baterija traje cca 20% krace
Staro 18.01.2016., 11:46   #406
AtOmIc
AtOmIc's Avatar
Postovi: 324
Meni na L930 sa .63 baterija traje recimo 15-25% dulje nego na .29 i .36
The quieter you are, the more you are able to hear.
Pošten trgovac: 1 , 2
AtOmIc je offline   Reply With Quote
Staro 18.01.2016., 13:52   #407
Xenon
Postovi: 1,542
Autor NeooS Pregled postova
Pa ok. Nisam imao prethodne builde osim 166 al to je bilo davno. U odnosu na 8.1 nisam primijetio neku razliku. Imam 730 DS.
Staro 23.01.2016., 00:40   #408
Xenon
Postovi: 1,542
Ništa ovaj mjesec od WM 10 tek od veljače se može očekivat puštanje ...
Staro 23.01.2016., 09:22   #409
Postovi: 33,949
Mogu se kladiti da ni to neće biti zadnja odgoda
Staro 23.01.2016., 23:04   #410
Xenon
Postovi: 1,542
Uskoro možemo očekivat build 10586.71 na Fast ringu
http://i2.tudocdn.net/img/width381/h...0/id157771.jpg
Staro 24.01.2016., 18:22   #411
viper
super user
viper's Avatar
Lokacija: Houston, TX
Postovi: 1,805
Znaci u utorak valjda.
Build 10586.71 of the OS is already cooling its heels on Microsoft’s update servers waiting to be pushed out on Patch Tuesday next week.
http://wmpoweruser.com/windows-10-mo...pdate-servers/
The update would be for non-insiders and will hopefully address issues such as stability and battery life. The update is part of the TH2 stream and not the Redstone stream which is of course aimed at Insiders.
viper je offline   Reply With Quote
Staro 26.01.2016., 19:52   #412
neno20st
Lokacija: Višnjevac
Postovi: 202
Imam win 10 i windows phone 8.1. Dobio sam jednu video poruku na mobitel na skype ali na kompu mi se ne događa sync poruka pa nemogu sacuvati video. Gdje se na mobitelu nalazi taj video? Kod vibera bih mogao sacuvati video na mob ali kod skypa neznam kako. Hvala svima
neno20st je offline   Reply With Quote
Staro 27.01.2016., 11:49   #413
NeooS
NeooS's Avatar
Lokacija: na Zemlji
Postovi: 527
Ima li jos netko ovakav problem? Nakon sto sam napravio hard reset na W10, zadnji build instalirao, prethodno imao .36. Sada mi ne radi glance. Napravio jos jednom hard reset, mob mi sve updateove za aplikacije poskidao, pa tako i za glance, ne radi i dalje. Na način da ga ne mogu postaviti. Uđem u postavkama u glance i zacrni mi se ekran. Nestanu sve opcije. Ako netko zna rješenje, hvala. Da ne moram čekat idući update, fali mi ova opcija sad. Lumia 640 DS iz edigitala, ako je bitno.
Staro 29.01.2016., 16:50   #414
Neo-ST
Neo-ST's Avatar
Postovi: 8,326
Staro 29.01.2016., 16:57   #415
Tvrdi
Sremium
Datum registracije: Oct 2013
Postovi: 2,854
Šteta. S tim kamerama i fluidnošću OSa....jebiga...eto i mene uskoro na onim mobitelima gdje se čisti cache....i ima puno aplikacija...U bijele hipstere ne idem...a i ne vrijede tolko para...
Staro 29.01.2016., 17:39   #416
zvonac
zvonac's Avatar
Lokacija: Sv.Nedelja
Postovi: 5,819
Cekamo samo sluzbenu potvrdu od MS
Znaci android i iOS dobivaju nove korisnike, uskoro
Staro 29.01.2016., 17:46   #417
gin.tonic
gin.tonic's Avatar
Postovi: 2,434
Autor zvonac Pregled postova
Više iOS
gin.tonic je offline   Reply With Quote
Staro 29.01.2016., 17:54   #418
Xenon
Postovi: 1,542
Ma moš si mislit ...
Staro 29.01.2016., 17:55   #419
zvonac
zvonac's Avatar
Postovi: 5,819
Autor gin.tonic Pregled postova
Više iOS
Bus se ti predomislil android je svakom novom nadogradnjom blizi iOSu, a WP je nazalost sve dalji od ovog dvojca..
Dok wp "propadne" bit ce puno njuskalo nokia i wp uredjaja po kikiriki cijeni
Staro 29.01.2016., 18:14   #420
Xenon
Postovi: 1,542
Autor Neo-ST Pregled postova
Istina ... dolazi Windows Mobile
