		#8551 |
					Postovi: 430
		 1 x Intel Core i3-4170 Soc1150 CPU 1 x Crucial 4GB DDR3 1600 MT/s (PC3-12800) CL11 1 x GIGABYTE GA-H81M-S2V (S1150,DDR3,VGA/DVI,USB3.0,LAN,SATAIIII) mATX 1 x HDD Toshiba P300 1TB, 64MB, 7200rpm 1 x NaviaTec NVT-603 Mini Tower 1 x Fortron Hexa+ 400W, 80+ 1 x Acer V226HQLAbmd 21.5" VA LED Monitor 1 x Genius KM110X, KB+M set, USB Ukupno: 3432,00 kn  |
		#8553 |
			Datum registracije: Aug 2014
				Lokacija: Kaštel Gomilica
					Postovi: 36
		 Ugl, sad je opet promjena plana, konacno, budzet je 5000kn za konfiguraciju,ekran,miš i tipkovnicu, kao sto rekoh namjena je uredski poslovi, po mogucnosti sto veci hdd. Hvala  |
		#8554 |
			Datum registracije: Feb 2015
					Postovi: 594
		 Sa i5 koji ti je nepotreban ako je isključivo uredsko računalo. 1 x Procesor Intel Core i5-4460 (3.20GHz,1MB,6MB,84 W,1150) Box 1 x Asrock H81M-HDS, s1150, Intel H81, M-ATX, Dual Channel 2xDDR3 1 x DDR3 8GB (1x8GB) Kingston, Value, 1600MHz, CL11, KVR16N11/8 1 x HDD Seagate 1TB, Serial ATA III, 7200 rpm, ST1000DM003 1 x NaviaTec 921G, ATX PC Tower Case • Case Size: 405*180*410mm 1 x Napajanje FORTRON 400W, HEXA Plus 400, 12cm ventilator 1 x Komplet Genius KM110X, tipkovnica + miš, USB 1 x LG E2411PU-BN PIVOT, HAS, USB, 16:9,1920x1080, Svjetlina : 250 4.727,97Kn ili sa i3 i SSD-om od 250GB uz standardni HD 1 x Procesor Intel Core i3-4170 (3.70GHz,512KB,3MB,54 W,1150) Box 1 x Asrock H81M-HDS, s1150, Intel H81, M-ATX, Dual Channel 2xDDR3 1 x DDR3 8GB (1x8GB) Kingston, Value, 1600MHz, CL11, KVR16N11/8 1 x Samsung 250GB 850 Series EVO Basic, Kapacitet 250 GB, 2,5" 1 x HDD Seagate 1TB, Serial ATA III, 7200 rpm, ST1000DM003 1 x NaviaTec 921G, ATX PC Tower Case • Case Size: 405*180*410mm 1 x Napajanje FORTRON 400W, HEXA Plus 400, 12cm ventilator 1 x Komplet Genius KM110X, tipkovnica + miš, USB 1 x LG E2411PU-BN PIVOT, HAS, USB, 16:9,1920x1080, Svjetlina : 250 4.946,94Kn  |
		#8555 |
					Postovi: 36
		 A odvojena grafika?  |
		#8557 |
			Datum registracije: Mar 2015
					Postovi: 1,254
		 Pa za ovo mu jace napajanje netreba, u slucaju nadogradnje, samo uzme jace napajanje i graficku, ostalo je sve na mjestu. Petar 1993 Onaj Samsung od 250GB nije HDD nego SSD koji je visestruko brzi, a posto slazes office konfu, mislim da neces trebati veliki HDD za pohranu, nego ti je bolje imati manje prostora, ali zato da ti sve leti.  |
		#8558 |
			Datum registracije: Nov 2012
					Postovi: 723
		#8559 |
					Postovi: 1,254
		 Je, tamo gdje buđet dozvoljava, međutim situacija je takva da je ovdje buđet ogranicen, pa ako bi se islo na bolje napajanje moglo bi se ubaciti fortron hexa 400w koji opet nije ni vrit ni mimo zato jer je za solo i5 overkill, a za neku bolju grafu(iznad gtx 960) je preslabo ako bi se kasnije nadograđivalo, a u tom slucaju ako bi se islo na hexu 400w bi se moralo uzeti slabo kuciste, pa na kraju svega nebi bio na nicem, i prilikom neke bolje grafe bi bilo pozeljno i bolje kuciste i bolje napajanje, a ovako kako sam ja slozio samo napajanje.  |
		#8561 |
					Postovi: 1,254
		 Imas vec moja misljenja o hexi za ovu konfu i nadogradnju na jacu grafu, također i malo iznad misljenje zasto prije SSD nego HDD za ovu vrstu konfe. A posto je covjek rekao da ga ne zanimaju nadogradnje, nije mu ni potrebno jace napajanje, i neda mi se vise vodit raspravu o ovoj temi kad je vec sigurno kupio ono sta mu je najvise odgovaralo, a ovo nase raspravljanje je mlacenje prazne slame. Pozz  |
		#8562 |
			 Axl Rose
					Postovi: 395
		 Pozdrav! Može jedna konfa do 3700 isključivo za gaming, bez cd čitaća, znači da što duljem ogu vrtit igre na dobrim detaljima.. Iz osijeka sam, ali bi naručio online iz bilo koje trgovine u Hrvatskoj.. hvalaa Zadnje izmijenjeno od: drz_nedaj. 24.12.2015. u 02:03.  |
		#8563 |
			 Terror Absolut!
			Datum registracije: May 2014
				Lokacija: Earth
					Postovi: 802
		 Matična ploča BIOSTAR TA970 Plus AMD CPU Desktop FX-Series X4 4300 (3.8GHz, 8MB, 95W, AM3+) Cooler LC POWER LC-CC-95 HDD SATA III 500 GB TOSHIBA, 3.5", 7200 rpm Memorija Kingston DDR3 1600MHz 8GB Gigabyte GF GTX750 Ti OC, 2GB GDDR5 Napajanje Fortron Hexa Plus 400W, 80+ Kućište COOLERMASTER Force 500 = 3751kn Za parsto kuna više bi se tu mogli ugurati bolji proc a i grafa, ali za ove novce mislim da je ovo najbolje što možeš dobiti. Za ime dućana mi se javi na pm.  |
		#8564 | |
			 MiningMod
					Postovi: 8,715
 1 x Gigabyte GA-78LMT-S2 (AM3+,DDR3,VGA,SATA II,LAN,USB 2.0) mATX, 95W CPU 1 x KINGSTON ValueRAM DDR3 (8GB,1600MHz(PC3-12800)) CL11, Retail 1 x Gigabyte NVIDIA GeForce GTX 950, 2GB GDDR5, 128bit 1 x MS VOYAGER crno kućište, bez napajanja 1 x HDD TOSHIBA DT01ACA100 (3.5", 1TB, 32MB, SATA III) 1 x XFX TS 450W, 80+ Bronze Ukupno: 3757,00 kn Besplatno slaganje i besplatna dostava *Zamoli ih da ti daju gratis original hladnjak za procesor te da u biosu isključe turbo da ne bude komp bučan ![]()  |
		#8566 |
			Datum registracije: Mar 2011
					Postovi: 2,707
		 Crucial Module 8GB, 240-pin DIMM, DDR3 PC3-12800, CL11 XFX TS Series 450W PSU, XFX-P1-450S-GREN Procesor AMD X4 FX-4300 XFX R9-380X 4GB DD, XFX-R9-380X-4DF5 GIGABYTE Main Board Desktop AMD 970A (970A-DS3P) LC Power CPU Hladnjak LC-CC-95 - 90mm MS KNIGHT kućište bez napajanja Hladnjak za kućište Thermaltake Pure 12 ~4050kn Crucial Module 8GB, 240-pin DIMM, DDR3 PC3-12800, CL11 XFX TS Series 450W PSU, XFX-P1-450S-GREN GIGABYTE Main Board Desktop AMD 970A (970A-DS3P) LC Power CPU Hladnjak LC-CC-95 - 90mm MS KNIGHT kućište bez napajanja Hladnjak za kućište Thermaltake Pure 12 Procesor AMD X8 FX-8300 Gigabyte GV-N950WF2OC-2GD, NVIDIA GeForce GTX 950, PCI-E 3.0, 2GB GDDR5, 128bit, Dual-link DVI-I*1/D ~4020kn U prvoj je overclockanje obavezno zbog grafičke(4.3GHz barem).  |
		#8567 |
			Datum registracije: Dec 2012
				Lokacija: Rijeka-Zagreb
					Postovi: 1,207
		 Mislim da ti je ovo bolja varijanta.. ujedno ovo je iz linksa složeno tako da ti negdje drugdje i jeftinije intel i3 6100 antec vp450p 450w antec vsk 4000b gigabyte h110m-ds2 ddr3 8gb gskill sniper 1.35v gigabyte r7 370 4098kn  |
		#8569 |
			Datum registracije: Dec 2015
				Lokacija: Kl.Ivanić
					Postovi: 9
		 Dobar dan svima! Nakon 11 godina došlo je vrijeme za uzimanjem nove konfiguracije! Treba mi konfiguracija za sve pomalo znači za crtanje večinom sketch up, surfanje, gledanje multimedije i trenutno ponekad igranje. E sad klinci rastu i uskoro će se krenut igrati pa bi bio zahvalan da se složi konfa za igranje u doglednoj budućnoati tj da se konfa bez nekih velikih ulaganja u sljedeće 3-5 godina može nadograditi i terat poneke igrice! Nadam se da nisam prezahtjevan i da ste me shvatili što sam htjeo reći. Ako niste ne zamjerite ipak je obilje hrane i pića pa..... Cijena tu u ovim okvirima. Monitor imam, periferiju imam. Hdd nije presudan može i bez njega tj možda ssd ubaciti. Zaboravih nalisati zagreb i okolica ili online svejedno mi. Plačanje hmm možda gotivinom ako bude dobar i isplativ popust na antu ![]() Zadnje izmijenjeno od: Ihrki13. 25.12.2015. u 17:14.  |
		#8570 |
					Postovi: 1,207
		 prijatelju dragi jel pratiš malo trenutno kakva je situacija ? pa taj i3 pojede fx-a a za grafu sve moze birat 950 ili r7 370.. 380x je skuplja skoro za duplo a da uzme fx 4300 i r9 380x rađe se propucat ![]()  |
		#8571 |
				Lokacija: スラボニア
					Postovi: 3,061
		 Pojede,da,ali u kojoj kombinaciji ? Sa ddr4 memorijom na 2666 MHz i overclockom na koliko ? Trošak ploče koja podrži taj blck ili kako već overclock,trošak dobre ddr4 memorije na 266 MHz i naravno dobar air kuler. Isplativiji je FX. Zadnje izmijenjeno od: coconut. 25.12.2015. u 19:54.  |
		#8572 |
					Postovi: 723
		 Freak, skontaj da FC4, TW3 i još par igrica jednostavno ne rade dobro na dvojezgrenim procesorima... a davat 1k+ kuna za dualca je ekvivalent skakanju sa eiffelovog tornja glavom dolje. Radije bolju grafu. Pogotovo za gejming. Po meni, uzmeš ovu prvu konfu što je smartic napravio, zamjeniš 380x sa najjeftinijom 380 i staviš FX6300. i sve 5+.  |
		#8573 |
					Postovi: 1,207
		 gle neću se prepirat al očito je i gledaj stvari kako idu iz dana u dan skylake i sa ddr3 mem će ga skinut ili će imat performanse istog ranga ddr4 hvala bogu se overclocka ko blesav ako oćeš dodatne performanse.. ja sam imao kitova od 2133, 2400, 2666.. svi su išli 400mhz ko od šale gore trošak ploče koja podržava bclk ? najeftinija h110 ploča danas može overclockat.. zato govorim samo gledaj kako idu na tjedan mi prođe hw-a i hw-a i vjeruj mi znam šta pričam http://www.asrock.com/news/index.us.asp?id=  |
		#8574 |
			 MiningMod
					Postovi: 8,715
		 slažem se da je i3 bolji od fx4300 ali r7 370 tu nema šta tražiti... fx4300 + jača gtx950 je bolje za igre nego skylake i3 + 370 A i ddr4 što se oc-a ko blesav ne vidim baš nekog smisla za igre, tutnio ti njega sa r7 370 na 5000mhz opet će to biti lošije od fx4300+gtx950 Smarticeva druga konfa fx8300+gtx950 je najbolje  |
		#8576 |
					Postovi: 1,254
		 Stvar je u tome i sta se taj i3 treba posteno OC-at da bi radio neke rezultate, za to opet trebas ulupat u hladnjak cca 250-300kn, i maticnu nekih 900kn, a cisto sumnjam i da se ovom covjeku da jebavat i imat vremena za to. Ja bi isao na onu sa fx 8300 i gtx 950, ta konfa je ovako everall najbolje slozena, em gtx 950 nije previse iza r9 380x, a opet mu ostaje fx 8300 na kojega kasnije opet moze birati koju ce grafu staviti, a na fx 4300 je vec i gtx 960 li-la, samim time bi morao mijenjati i platformu(posto ce mu tada biti sigurno bolje otici na nesto skroz novo) i graficku.  |
		#8577 | |
			 MiningMod
					Postovi: 8,715
 1 x CPU Hladnjak LC-CC-95, Intel/AMD, 90mm 4-pin 1 x GIGABYTE GA-970A-DS3P, AM3+, R2.0, 4+1 Phase, 125W CPU 1 x KINGSTON ValueRAM DDR3 (8GB,1600MHz(PC3-12800)) CL11, Retail 1 x Crucial SSD 240GB Crucial® BX200 SATA 2.5” 7mm 1 x GIGABYTE Video Card GeForce GTX 750Ti GDDR5 2GB 1 x Kućište Cougar MX200, crno, USB3.0 1 x XFX TS 450W, 80+ Bronze Ukupno: 4434,02 kn Besplatno slaganje i besplatna dostava (cijena za keš) *Ako još imaš love uzmeš jaču GTX950 *Ako ti je previše uzmeš 120gb SSD  |
		#8578 |
				Lokacija: Unknown
					Postovi: 247
		 Hvala na prijedlozima, bitno da ima opcija.  ![]() Inače, konfa je za frenda koji nije baš sklon prčkanju po komponentama, tako da mu je najbolje uzeti drugu Smartićevu konfu i ovo što je Sphere rekao, da nakon dvije godine može zamijeniti 950-ku za bolju grafu i ubaciti novo napajanje, a proc mu ostaje. Zadnje izmijenjeno od: Rocky Rocastle. 26.12.2015. u 16:16.  |
		#8580 | |
				Lokacija: Kl.Ivanić
					Postovi: 9
 Ako smijem pitati tj traziti jos jedan savjet Isplati li se uzet fx x8 8300 za razliku od 130kn? Uzeo bi GTX 950. U ovom trenu mozda ne bih uzeo ssd nego bi bez njega sa starim diskovima koje imam dok ne bi dosla prilika uzet ssd da se to sve iskompletira. Kao sto rekoh nadam se da bi ova kombinacija bila dostatna za neke 3-5 godina uz mozda izmjenu graficke mada mozda ni to nece trebati!? Primam savjete da li da nesto drugo izostavim za sada ?  |
