#1231 |
Datum registracije: Nov 2012
Postovi: 724
Ma di se guzit s AMDovim render "uberperformansama"... xD radije bilo koji i7 makar sendi briđ, al ajd. ugl, vako nešt bi ja kad bi bio kenjac s viškom para, no offense, al eto: -FX8370 -Corsair 4x8GB 1600 LP -990FXA-UD3 (šta će mu više, neće ocat) -2x MSI 980 Ti -2x Seagate 4TB HDD -Samsung optika ![]() -Fractal Define R4 -Corsair HX850i -Dell P2715Q -Crucial BX200 480GB -Prolimatech Basic 68 xD ak sam sve dobro prepiso, to ti dođe 29.5k Pa sad računaj. |
#1232 |
Datum registracije: Feb 2015
Postovi: 598
Sa dvije 980Ti se ide malo preko budžeta, ali mislim da bi se isplatilo. 1 x Procesor AMD FX-Series X8 8370 4.0GHz,16MB,125W,AM3+, FD8370FRHK 1 x ASUS SABERTOOTH 990FX R2.0, AM3+, AMD 990FX/SB950, DDR3 1 x Scythe Mugen MAX, SCMGD-1000 2 x Gigabyte GTX980Ti Windforce 3x Gaming, 6GB GDDR5 384-bit, PCI-E 4 x DDR3 8GB (1x8GB) Kingston, HyperX Fury, 1866MHz, CL10 1 x Samsung 1TB 850 EVO Basic, Kapacitet 1000 GB, 2,5" MZ-75E1T0B 2 x HDD WD 4TB, 40EZRX, SATA III, 64MB Cache, WD Caviar Green 1 x Fractal Design ARC XL, crno, bez napajanja, 4x 5.25" okvira 1 x Napajanje Enermax 1000W Revolution 87+ Series,80+ GOLD Modularno 1 x DELL P2715Q 27", Professional , Ultra HD 4K, 3840x2160, IPS AG 30.823,91Kn |
#1234 |
Datum registracije: Mar 2015
Postovi: 1,254
Da sebi slazem za 30k, ovako bi isao: DELL Professional P2715Q Intel® Core™ i7-5960X Corsair Vengeance® LPX 32GB (4x8GB) DDR4 2133MHz C15 Samsung 500GB 850 EVO Toshiba 2TB 3.5" 7.2k SATA 6Gb/s 17229kn 2 x GIGABYTE Video Card GeForce GTX 980Ti GDDR5 6GB/384bit, 1102MHz/7010MHz, PCI-E 3.0 x16, HDMI, 2xDVI, 3xDP, WINDFORCE 3X Cooler(Double Slot), Retail 11560kn 1 x Corsair PSU Enthusiast Series RM1000x Power Supply, Fully Modular 80 Plus Gold 1000 Watt, EU Version 1 x Phanteks kućište Enthoo Pro Black Window Midi-Tower bez napajanja P/N: PH-ES614P_BK 2405kn 1 x Asrock X99 Extreme4, Intel® Socket 2011-v3, Intel® X99, 4-kanaln 1 x Scythe Mugen MAX, SCMGD-1000 2179kn Sve zajedno: 33373kn Je preko al na 30.000kn to nije neki problem kad se vec otvara kesa, a ima se odma najbolje na trzistu! Zadnje izmijenjeno od: coconut. 03.12.2015. u 07:34. Razlog: bez reklamiranja |
#1236 |
Postovi: 1,254
A dobro, ovo je slagano da se sad uzima, i ovisi o tome koliko je hitno uzeti odma konfu, mozda se nema vremena cekati. Ako bi cekao onda se moze pricekati i Pascal, a također bilo bi dobro razmisliti o kupnji svega u Njemačkoj, sve skupa bi ispalo par tisuca kuna jeftinije ![]() |
#1238 |
Postovi: 34,072
Isuse, koliko se tinte prolilo oko te konfe. Spustite loptu na zemlju, smanjite doživljaj i ostavite se komentara koji nemaju veze s temom. EDIT: a sada par osobnih primjedbi (Warning! Sarcasm mode ON) 1. u zadnjih 10-15g. koliko pratim IT scenu, ne sjećam se da je IKAD AMD bio bolji od Intela kod obrade video. Na strani AMD-a nije bilo ama baš ništa: visoka potrošnja, veće zagrijavanje, bučan cooler,... Jedina prednost AMD-a je bila cijena, ali kada si mu dodao pošten cooler, bila je skoro jednaka Intelu. I zato inzistiranje na AMD-u smatram neozbiljnim i bez ikakve praktične podloge u realnom svijetu. 2. nisam se nikada bavio obradom video, ali smatram da je čovjeku koji se misli ozbiljno baviti time daleko bitnije da ima višemonitorski sistem gdje će na jednom monitoru će vidjeti 'before', a na drugom monitoru 'after' rezultate nego imati jedan ogroman monitor sa 100mlrd pixela čije postojanje oko ionako nije u stanju registrirati. 3. zahtjev da konfa mora s jedne strane imati HR trobojnicu sa šahovnicom, a na drugoj fotku Lepog Zoke/Crnog Marka/Vase/you_name_it u omjeru 1:10 i natpis "Di si bijo '91" uglatom glagoljicom, veličina slova 91 je čisto izd**avanje! Oš ti tom konfom barit komade ili će ona obrađivati video? Suma sumarum - cijela tema je polutrolanje.
"Dvije stvari su beskonačne - svemir i ljudska glupost. Za svemir nisam siguran." A. Einstein Zadnje izmijenjeno od: coconut. 03.12.2015. u 08:42. |
#1241 | |
Datum registracije: Aug 2009
Postovi: 1,492
Šteta što ti se Lewis nije javio kada se on već bavi s tim, zanimalo bi me njegovo mišljenje oko Amd proca u takvoj konfi |
#1242 | |
Datum registracije: Nov 2014
Postovi: 1,972
Sto se tice ovog drugog,trebalo je samo ostat u okvirima koje sam naveo i u skladu s tim davati savjete kao sto dobijam na PM. U svakom slucaju skoro sam vec odlucio o kompletnoj konfi. |
#1244 |
Postovi: 1,972
#1246 | |
#1247 | |
Postovi: 1,972
I prosli put je ekipa mislila da je trolanje konfa od 20k sa AMD dok nije stigla. A sto se trolanja tice Intelce mogu zahvatit na drugim temama. |
#1249 |
Postovi: 1,972
Naravno. Isto sam napravio i prosli put tu na forumu. Lako nadjes,a cijena je bila tu negdje.mozda malo manje. To je bilo specijalno za sumnjicavu Intel ekipu. ![]() Konfa se odabire (hvala darky) na pomoci. Nakon sto prodje approval ide narucivanje. A vecina ekipe reagira u skladu sa ocekivanjem. ![]() |
#1252 |
Datum registracije: Dec 2015
Postovi: 7
Poz, totalni sam noob i imam otprilike 16k keša i slozio bih si konfu za high end gaming iskljucivo s time da bih se volio osigurat za narednih par godina, dakle da pc bude relativno 'future proof' iako je to samo po sebi paradoksalno s obziron koliko brzo tehnologija ide prema napred.. Gledao sam puno konfi po stranim sajtovima, ali na kraju mislim da cu se odluciti za neki nas ducan, cisto zbog sigurnosti i dostave i tako.. Cini mi se da HGSHOP (webshop) ima daleko najbolje cijene!! Uglavnom, vec sam slozio nekakvu konfiguraciju ali zelio bih cuti svacije prijedloge u okviru budgeta u kojeg mora uci i monitor i periferija (mis tipka zvucnici sluske i jedan omanji eksterni hdd)!! Tako da slobodno slozite nesto ko ima viska vremena da usporedim sa svojom zamisljenom konfom, i preporucite neki 24inch monitor, ili vise njih!! Ostalu periferiju netreba.. Imam vise manje samo par nedoumica a to su: 1. Jeli quad core vec pomalo stari? Oce buduce igrice zahtijevat vise jezgri.. Tu neznam dali bi onda isa na 5820k ili da se ipak ne glupiran i da mi izbor bude 6700k?! 2. 16 ili 32gb rama? jeli 32 overkill? da idem na 16 i tu malo ustedim.. stvarno neznam, sta mislite za buduce igrice kroz narednih par godina? neradin nista posebno na kompu, igre skype muzika surfanje, ali mozda bolje da se osiguram?? 3. Sta se tice ssd-a u cemu je kvaka sa ovim m.2 sta li su vec? Jese isplati to uzimat? Tnx i sorry za dug newb post ![]() |
#1253 |
Postovi: 1,254
nerthus Monitor: DELL Professional P2416D Ukupno: 2015kn besplatna dostava Komp + Miš, tipkovnica, zvucnici, slušalice i eksterni hard 1tb: 1 x Tipkovnica i miš COOLERMASTER Octane UI, HR, USB, LED 1 x Genius zvučnici SP-HF800A, 20W, drveni 1 x Kingston HyperX Cloud Gaming Headset - Black 1 x HDD TOSHIBA Stor.E Canvio Basics (2.5", 1TB, USB 3.0) Black 1 x Sapphire R9 FURY X, 4GB HBM, HDMI, DP, DX12 1 x Intel® Xeon® Processor E3-1231 v3 (8M Cache, 3.40 GHz) 1 x Matična ploča ASRock B85 PRO4 1 x Kingston DDR3 HyperX Fury,1866MHz,16GB(2x8GB)White 1 x CPU Hladnjak Raijintek Themis Black, 120mm, PWM 1 x Napajanje Antec TP-550C 550W, 80+ Gold, 120mm 1 x OCZ Arc 100 240GB SSD, 7mm 2.5”, Controller OCZ Barefoot 3 M10, A19nm Toshiba MLC Flash, SATA III 1 x Toshiba 2TB,7200rpm, 64MB HDD 1 x Samsung DVD±RW 24x black, bulk 1 x Fractal Design Define R4, black pearl (dva side panela) Ukupno:13992kn besplatno slaganje i dostava Zadnje izmijenjeno od: coconut. 06.12.2015. u 08:46. |
#1254 |
MiningMod
Postovi: 8,715
R9 Fury i 550w gold ne bi baš... Ja bi ovako: 1 x Intel Core i5-6600K, 3.5GHz, Skylake, S1151, bulk 1 x CPU Hladnjak LC POWER LC-CC-120, Intel/AMD, 120mm, PWM 1 x Gigabyte GA-Z170-D3H, DDR4, Skylake, Sck. 1151 1 x Memorija DDR4 8GB, 2400 MHz, Performance series, AMD Radeon bulk 1 x Sapphire R9 FURY TRI-X, 4GB HBM, HDMI, DP, DX12 1 x OCZ Arc 100 240GB SSD, 7mm 2.5”, Controller OCZ Barefoot 3 M10 1 x HDD TOSHIBA DT01ACA100 (3.5", 1TB, 32MB, SATA III) 1 x Kućište Aerocool Aero-500, crno, plexy, USB3.0 1 x Fortron napajanje Aurum S PSU 700W, 80+ GOLD 1 x AOC LED 28" U2868PQU, DVI, HDMI, DP, zvu. piv., 4K 1 x Tipkovnica i miš ROCCAT Gaming Lua/Arvo 1 x Gaming slušalice ROCCAT Kave XTD Stereo Camo Charge 1 x Toshiba CANVIO Basics 500GB,USB3,crni |
#1255 |
Postovi: 1,254
Gura 550w napajanje to bez problema, ovaj 4K monitor sta si stavio je ipak overkill za r9 fury i morat ce se rezat na detaljima dosta da se izvuce pozeljan fps, da ne pricam o screen tearingu, također fale ti zvucnici... |
#1256 |
Postovi: 10,805
otvorim ovu temu tu i tamo i onda vidim šta se stavlja u skupe kompove: pržilice, tn monitori, napajanja od 500w, spikeri od 300kn u kartonskim kutijama, lc power komponente, ssd-ovi fizički umjesto m2 kartuša... fino, fino ![]() |
#1257 |
MiningMod
Postovi: 8,715
Pa gle, meni je bolje ako već ide na jaču grafu od 390/970 da ide i na 4k monitor... jer ako ne ide na 4K neka onda ide na 390/970 jer fury nema smisla ![]() 550W se nikako neču složiti, jer takva napajanja su idealna za 280x/390 a ne za jednu grafu od 4k kn nema smisla dati 15k za komp i uzeti 550w napajanje |
#1258 |
Postovi: 1,254
Ja nisam stavio obican Fury model, vec onaj od 5300kn sa X na kraju, i napajanje je cist dosta, ta konfa u gejmingu trosi oko 400w Sta se tice monitora, za 2k je ta grafa rođena, za igranje na max postavkama bez ikakvog tvikanja na 50-60fpsa, 4k je mucenje Syss, ajd ti slozi prijedlog pa objavi da vidimo tvoje umjece |
#1259 |
MiningMod
Postovi: 8,715
da, tek sada skužio... onda još gore btw kako može ta grafa trošiti isto kao tvoja? :SA sisu pusti, nema ti on pojma slagati kompove, ona samo zna trgati Iako znam da ima dobru namjeru sa svojim pisanjem na naše prijedloge I ok, treba jer istina loše smo mi to zapravo složili Ali teško je, tolike pare pa sada da slažem kvalitetno sa tu nekom 970 samo kako bi ugurao sve ostalo bolje ![]() Evo kvaliteta ![]() 1 x Monitor LCD DELL UltraSharp U2412M (24", 1920x1200, IPS) 1 x Gaming tipkovnica ROCCAT Ryos MK, MX Black, Mehanička, HR 1 x MIŠ ROCCAT Tyon, 8200 dpi, USB, crni 1 x Slušalice ROCCAT Kave XTD Stereo, premium gaming, crne 1 x Genius SW-HF2.1 1700, 45W, drveni 1 x INTEL Core i5-4690K (3.50GHz,1MB,6MB,88 W,1150) 1 x Lepa LV12, 1x120, black 1 x GIGABYTE Main Board Desktop Z97 2 x MEM DDR3 8GB 1600MHz, HyperX Fury KIN 1 x Toshiba 2TB,7200rpm, 64MB HDD 1 x SSD Samsung 250GB 850 EVO 1 x Sapphire R9 FURY TRI-X, 4GB HBM, HDMI, DP, DX12 1 x Kućište Fractal Define S, crno, bez napajanja 1 x Fortron napajanje Aurum S PSU 700W, 80+ GOLD Metnuo bi M2 ssd al nema toga ovdje ![]() |
#1260 |
Lokacija: Vratlo
Postovi: 303
Nema smisla čovjeku trpati 4k monitor ako želi nešto "future proof". Sphere ako ikako možeš izabaci iz vokabulara taj 2k izraz jer ga tu nitko ne koristi osim tebe a samo zbunjuješ ljude s njim. |
