Staro 21.11.2015., 18:11   #18091
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,741
Autor Nybelung Pregled postova
Dizel iz 2005. sa 100+ konja i malo kilometara kod nas i ne postoji.
Imaš tri izbora: gledati novije i skuplje aute, kupiti benzinca ili pravac Njemačka.
Ne mora biti 100+. Ne smije biti manje od 90.
Ali za ovo si u pravu vjerojatno.
Ma čak nije ni stvar u km. Ako je dobro održavan, uzeo bih i sa više, ali svi su izgleda krš.
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
estugarda je offline   Reply With Quote
Staro 21.11.2015., 18:15   #18092
Nybelung
Ja bi na tvom mjestu gledao jednu klasu niže. Za te novce možeš kupiti odličnu Fiestu npr. ili Fabiu.
Staro 21.11.2015., 18:58   #18093
D1viry
D1viry's Avatar
Lokacija: Slavonija
Postovi: 2,066
Malo malo novaca za te zahtjeve za auto u RH.
Pošten trgovac: 1,2,3,4,5,6
Staro 21.11.2015., 19:15   #18094
lowrider
lowrider's Avatar
Lokacija: KR
Postovi: 1,154
Frend je za 6500 ojra uzel Meganea 2011.g 160 000km original i ugradio plin, mislim da je to super kombinacija.
Dizel za tu cijenu i da je dobar definitivno klasu manje, tipa Grande Punto, Corsa, bilo je Brava 2008.g benzinaca po 5000 ojra 1.4 16v pa ugradiš plin itd
Staro 21.11.2015., 19:15   #18095
northeus
northeus's Avatar
Datum registracije: Mar 2008
Postovi: 104
U potpunosti se slaže recimo Ibiza 1.6 tdi 2010g 90konjića, napravim ja 1000km u danu bez problema. Jeftino održavanje, ništa te nepita (auto) pali i vozi već 180 000km
northeus je offline   Reply With Quote
Staro 21.11.2015., 19:17   #18096
tech
Postovi: 1,687
I u njemačkoj dizeli s malo kilometara koštaju. Zapravo tamo ih svi uzimaju za "duge staze" jer imaju nešto veći porez, tako da im se ne isplati dizelaš na malo kilometara(a i ako ga imaju, neće ga dat ispod cijene). Kako god, ako ide u njemačku po auto onda gleda aute do max 5500 eura, a sumnjam da će nekaj pristojno nać za tu lovu. Vrlo vjerojatno isti auto kao i ovdje samo s boljom opremom, a ulazi i u rizik jer moraš napraviti bar 1000km dok se vratiš doma s autom o kojem jako malo znaš.
Ja bi gledao benzinca pa ugradio plin. Naći će auto s manje kilometara jer sigurno nitko nije kupovao skuplji dizel da ide do dućana.
Staro 21.11.2015., 19:22   #18097
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,741
Nisam ih gledao jer se bojim "Twingo efekta" malog auta. Iako, kad bolje razmislim, možda ova novija Fabia sa 1.9 PD TDI motorom i nije toliko loša ideja. Jače 1.6 CR verzije su izgleda skuplje. Fabia je uvijek bila prostranija od ostatka te klase. Ne znam kak je sa ovim zadnjim modelom:
Recimo ovak nešto;
http://www.njuskalo.hr/auti/skoda-fa...oglas-15754735
Prvenstveno mi je bitna prostranost vozačkog mjesta (185cm, 105kg) i bunker (često vozim kompove, monitore, komade namještaja). Sjedala iza mi nisu toliko važna. Dapače, s Golfom se uglavnom vozim za prevaljenom stražnjom klupom.
Problem je što je ovaj moj serviser savjetovao ne gledati Škode, pošto mu ih dosta dolazi. Radi za neko ministarstvo gdje se masovno voze Škode i Octavie i kaže da su sklone čestim sitnijim kvarovima neovisno o godištu. Ništa alarmantno, ali ne bi volio svako malo voziti auto na servis.
A na koju Fiestu si mislio?
Ovaj zadnji model izgleda dobro, ali dosta drži cijenu.
Vozio sam se kao suvozač u starijoj tdci fiesti, i taj auto je preslab i premali za mene. To je više auto za grad, a ja se uopće ne vozim po gradu. Odnosno 5% moje vožnje je gradska a 95% državna i autocesta.
Autor D1viry Pregled postova
A malo. Naravno da je malo. Da imam više, ne bi se mučio, jelte.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 21.11.2015. u 19:32.
Staro 21.11.2015., 19:31   #18098
tech
Postovi: 1,687
Autor estugarda Pregled postova
Vozim na poslu fabiju i pola tu i tamo, neki od tih auta su i došli iz raznih ministarstava. Kršine da nema većih. Voze se na takav način da je uopće čudo da uspiju preć 50k km. Kod nas lizing uvjetuje servise i to se rijetko kad poštuje, šta da ti kažem kad 2 godine star Polo 1.2tdi s 30k km na satu nema lamele a ovjes ispušta metal o metal zvukove.
Čim isti auto vozi više od dvoje ljudi znaš kolko je sati, a nekad je dovoljno da ga vozi i jedan idiot samo(pusa mom šefu). Tako da to baš i ne moraš uzimat u obzir pri kupnji.
Nova Fiesta 2008> daje dojam da se voziš u većem autu nego model prošle generacije. Bar se meni tako čini dok sam ju vozio(inače imam fiestu proše generacije).
Staro 21.11.2015., 19:38   #18099
Speedbreaker
Postovi: 545
@estugarda
Ovaj se čini ok barem iz oglasa
I Focusa tdci ima hrpa na njuški koliko vidim do te cijene, jedino su kilometri na knap malo, ali nađe se opet. Prijatelj je kupio prošle godine jednog iz 2009. za te novce otprilike i po meni je sasvim fin auto za vozit se u njemu, tiho i udobno.
Speedbreaker je offline   Reply With Quote
Staro 21.11.2015., 19:40   #18100
Nybelung
Mislio sam na Fabiu mk2 i Fiestu mk6. U Fiesti se bolje vozi, a Fabija ima najveći gepek u klasi. Oba auta su dovoljno prostrana. Nisu to mali auti tipa Twingo, istih su dimenzija ko tvoj Golf 3.
Staro 21.11.2015., 19:55   #18101
jed2i
jed2i's Avatar
Datum registracije: Jul 2004
Postovi: 1,771
Ja imam auto kojeg cijenim 6500eura, ford focus, uredno servisiran, 115k km, 2009 godina, napravljen kompletan VELIKI servis, benzinac 1.6, pa ga nemrem prodat...
Staro 21.11.2015., 20:05   #18102
MAGARAC
MAGARAC's Avatar
Postovi: 5,984
E to je ono. Trebam auto jučer. Početkom godine sam promijenio posao, i sad se puno više vozim nego prije. Napravim prosječno cca 600-700km tjedno i to moja stara krama viže ne može podnijeti (Golf 3 TDI, 260k km). Stvarno sam ga pazio i održavao, ali otkad sam se počeo voziti ovak puno, svaki tjedan mi nešto rikne. Inače o tom autu imam samo riječi hvale, bez obzira na loš image ovdje. Vrlo je isplativ ispao. I bez ikakvih porblema osim redovnog održavanja dok se ove godine nisam počeo puno voziti. Problem je što je 20g vožnje upravo to; 20 g. vožnje. Bez obzira što ta cifra u km nije nešto jako puno.
Mali mi auto nema smisla. Vozio sam neko vrijeme novog Twinga 1.2. To nije auto za mene. Hrpu toga vučem za sobom zbog posla, a u to ne stane ni jakna iza pošteno. Naporno ga je voziti na više od 100km u komadu po D cestama. Dakle mora biti malo veći od toga i dizel.
Baci pogled i na ovak nesto po mogucnosti sa manje km. Dobro auto sa dobrim motorom. Najveca mana je nest manji gepek.. Za D ceste odlican.. Dosta sx4 benzinjara ima i plin, ko novi su imali opciju za "tvornicku" ugradnju pa ti je mozda i to opcja.
http://www.njuskalo.hr/auti/suzuki-s...oglas-15098708
Zadnje izmijenjeno od: MAGARAC. 21.11.2015. u 20:10.
MAGARAC je online   Reply With Quote
Staro 21.11.2015., 20:08   #18103
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,741
Autor Speedbreaker Pregled postova
@estugarda
Ovaj novi mi je super, ali moram prinzati da mi nije nešto predzadnji Focus. Valjda ih zato nisam baš puno gledao. Ovaj jedan kojeg sam pogledao je defintivno bio izvožen, a 120k km je pisalo.Ja bih rekao barem 220 po sicevima.
Što je to točno bolje u vožnji Fieste?
Znam da nisu ko Twingo, ali nije n sve u tome. Uzmi recimo Volvo C30. Taj nema mjesta više od Twinga nigdje.
Teško je to reći. Trebalo bi probati. Recimo, stara Fabia je imala dosta mjesta.
Autor MAGARAC Pregled postova
E za to sam već dobio preporuku, ali nisam ovdje mogao naći nijednog dizela. Samo benzinci...
Inače, vozio sam se u benzincu, i stvarno je fora auto. I da. Ima mali bunker. ALi recimo da bi pregrmio to.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 21.11.2015., 20:13   #18104
MAGARAC
MAGARAC's Avatar
Postovi: 5,984
Malo ih je jer su ko novi bili 40 tisuca skuplji od benzinca..
Modeli prije 09 su imali dosta problema sa ovjesom, ostalo je na japanskom nivou kaj se pouzdanosti tice. Benzinjare nakon 09 trose puno manje od starih, 1.6 cak 1.5l. Mozes racunat sa manje od 8l svugdje, osim po zimi u gradu i rezervoar je mali. Moj je radio slicnu kilometrazu ko ti sad i svaki 3ci dan na pumpi, sa Meganom sa prosli mjesec napravio 1090km na rezervoaru, inace obicno tankam na oko 900 ili manje. Malo da se pohvalim. Odrzavanje benzinca je minimalno...
Btw. i Suzuki je konacno pustio male turbake u prodaju, 1.2 i 1.4. 1.4 u Vitari i Crossu ima 140ks u Balenu 1.2 ima 110ks i citam da je odlican za vozit. Swift sa tim motorom bi bio bonboncek za grad sa 1.4 bi bio novi Sport.
http://www.nacionalnaklasa.com/domac...1-4-boosterjet
Ova kombinacija boja mi najbolje izgleda na tom autu. Turbak bi mogla bit dobra alternativa dizlu. Ja bi samo zamjenio boje na nosu, metal sivi, plastika crna.. Obruc je metalni na skupljim modelima i plasticka moze bit crna i siva-
Zadnje izmijenjeno od: MAGARAC. 21.11.2015. u 20:49.
Staro 21.11.2015., 20:29   #18105
Nybelung
Meni se na Fiesti sve svidilo. Mjenjač, volan, položaj vozača. Svidio mi se i motor, ali ja sam vozio benzinca.
Ako ti je prostor presudan onda definitivno gledaj Fabiu. Ima više mjesta i na zadnjoj klupi i u gepeku.
Ja ne bi unaprijed otpisao benzinske motore, pogotovo ako većinu kilometara radiš na državnoj cesti.
Staro 21.11.2015., 20:38   #18106
MAGARAC
MAGARAC's Avatar
Postovi: 5,984
Moj trosi oko 6 litri na drzavnim i lokalnim cestama sa najnormalnijom voznjom i bas ta voznja mu najvise pase generalno, vozi se ko dizlo bez problema cak i bolje ispod 1500 rpm..
Zadnje izmijenjeno od: MAGARAC. 21.11.2015. u 20:46.
Staro 21.11.2015., 20:43   #18107
Flood
Into my head it goes
Flood's Avatar
Datum registracije: Feb 2004
Lokacija: space de luxe
Postovi: 778
To je Fiatov dizel unutra
Čije benzince stavljaju ili imaju svoje,kako to ide sa njima?
Staro 21.11.2015., 21:02   #18108
MAGARAC
MAGARAC's Avatar
Postovi: 5,984
Benzinci njihovi, dizlo Fiatovi. Sad je 1.6 dizlo. 1.6 benzinac je najstedljiviji sa najmnje C02 u klasi. Talijanski motori su nuta od 2006 i pouzdani su i jaki iako su traktori..
Staro 21.11.2015., 21:03   #18109
bertone
bertone's Avatar
Datum registracije: Mar 2010
Postovi: 2,057
Grešiš, postoji... evo prije tjedan-dva obavio redovni servis
Staro 21.11.2015., 21:04   #18110
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,741
Kakvi problemi sa ovjesom? Što točno? To se pretpostavljam odnosi i na diesel!? Vjerojatno onda i više, kad je teži.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 21.11.2015., 21:10   #18111
MAGARAC
MAGARAC's Avatar
Postovi: 5,984
Nesto se trosilo vise nego je trabalo, ne znam tocno kaj al naci ces po forumima. Glasan ovjes i neudoban je simptom. Nije nis fatalno.. SX ima robusnije podvozje i mozes bez straha ic po rupama da ne strgas nes.. Moj je po zagroskim Z cestama bio ko doma i nis se nije razmrdalo. Na meganeu sam vec dve felge malo shebo pa su morale na popravak, kad naletim na rupu molim boga. Rupe su skrivene ispod sodra koji sluzi za prosirenje ceste jer je na knap za dva auti pa su jos i zavoji ko na sljemenu..
Zadnje izmijenjeno od: MAGARAC. 21.11.2015. u 21:18.
Staro 21.11.2015., 22:04   #18112
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,741
Hvala. Budem pogledao ovaj SX4 ako uleti koji dizel. Vidim da je na dizelima problem 2-maseni zamašnjak. 100 000 km mu je domet, piše po forumima.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 21.11.2015., 22:13   #18113
listerstorm
listerstorm's Avatar
Datum registracije: Apr 2011
Postovi: 1,428
Mogao bi i limuzinu + ostane ti za plin.
http://www.njuskalo.hr/auti/renault-...oglas-14996376
Ili noviji model, diesel. 113000 na satu.
http://www.njuskalo.hr/auti/renault-...oglas-17252081
Staro 21.11.2015., 22:51   #18114
tech
Postovi: 1,687
Autor jed2i Pregled postova
To ti je tak. I meni dođe da se riješim svoje fieste ali onda skužim da ju cijenim više nego što su druge na njuškalu i zato ju nitko ne bi ni pogledao. Bez obzira kaj sam ja na svojoj promijenio sve živo i riješio svaku manu tog modela. A sve one kaj su jeftinije se i prodaju iz tog razloga jer im se sprema velik servis i tek će sad sve te mane isplivat na vidjelo. Takvi su ljudi, prije će kupit isti auto u lošijem stanju za 500 eura manje pa ić ulagat još 1000 u njega nego uzet skuplji u boljem stanju.
Staro 21.11.2015., 23:11   #18115
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Lagunu 2 ne bi ni neprijatelju preporucio.
S druge strane, Laguna Coupe je kod nas okrenula nekih 250k km zasad, bez vecih kvarova. Cuje se vec polako turbina, al bude to još...
Staro 21.11.2015., 23:13   #18116
MAGARAC
MAGARAC's Avatar
Postovi: 5,984
Ja cu morat prodavat servisiran (veliki servis), frisko registriran, sa novim kocnicama i zimskim gumama, novim. Kompletno sreden auto mehanicki, limarija kaj je ogrebotine i sve, nis krpano ili sl.. Ostavit cu nekom i 4 ljetne gume ali pri kraju..
Nisam nikad tak dobar auto prodaval da sve dela i u tak dobrom stanju.
Staro 21.11.2015., 23:15   #18117
listerstorm
Postovi: 1,428
Autor IcyTexx Pregled postova
To je phase 2 i benzinac. Problem su dizeli prije phase 2.
A za tu lovu ide i laguna 3.
Staro 21.11.2015., 23:29   #18118
X-Plosiv
X-Plosiv's Avatar
Postovi: 1,811
Ima premali bunker. Inače, izvrsno podnose plin, ja znam cca 6 vlasnika koji imaju na plin i nitko mi se nikada nije požalio da imaju problema.
Ali jako jako jako mal bunker.
Staro 22.11.2015., 04:01   #18119
MAGARAC
MAGARAC's Avatar
Postovi: 5,984
Nije bas jako, jako mali. U rangu novih mali gradskih auti tipa Polo i sl., 270 litri. Nije on ni bitno veci od njih. Da se i on fino natrpat i skoro svi imaju nosace, osim najjeftinjih..
Staro 22.11.2015., 09:27   #18120
jed2i
jed2i's Avatar
Postovi: 1,771
Autor tech Pregled postova
Točno to, na mom je promijenjena korpa, focus ima tu serijsku grešku
Promijenjeno je crijevo serva, isto tako serijska greška + pumpa, remenje, natezači, diskovi, pločice, 4 zimske 4 ljetne gume.... i onda mi dođe tip, vidi malo zagrebanu boju i traži me da mu skinem 500-1000 eura...
