		#391 |
			Datum registracije: Sep 2010
				Lokacija: split
					Postovi: 9
				pomoc pri oc.q9300
			Pozdrav, Imam problem pri o.c-u svog procesora konfa: Cx500m 500w corsair intel quad q9300 + zalamn cnps5x cooling gigabayte GA-EP43-DS3 mem. 8gb OCZ platinum DDR2 1066 OCZ2P10664GK Hdd samsung 500gb Ati VX hd 4770 512 ddr5 ( planiram uzet MSI r7 370 2gb ili novu gtx950 kad izađe) Windows 8.1 (murphy78) Namjestio sam u biosu sljedece postavke po jednoj stranici sto sam nasao , imamo slicnu konfu pa sam probao: http://forums.tweaktown.com/gigabyte...ight=p43+q9300 #post 8 MB Intelligent Tweaker(M.I.T.) Robust Graphics Booster -------------- : [Auto] CPU Clock Ratio ---------------------- : [7] Fine CPU Clock Ratio ----------------- : [+0.5] CPU Frequency ---------------------: 2.8GHz (374x7.5) Clock Chip Control Standard Clock Control CPU Host Clock Control --------------- : [Enabled] CPU Host Frequency (Mhz) --------------: [374] PCI Express Frequency (Mhz) ---------- : [100] C.I.A.2 ------------------------------ : [Disabled] Advanced Clock Control ------- [Press Enter] CPU Clock Drive ---------------------- : [800] ((((bilo je na 700)))) PCI Express Clock Drive -------------- : [800] ((((bilo je na 700)))) CPU Clock Skew (ps) ------------------ : [0ps] MCH Clock Skew (ps) ------------------ : [0ps] DRAM Performance Control Performance Enhance ------------------- : [Standard] (G)MCH Frequency Latch ---------------- : [Auto] System Memory Multiplier -------------- : [2.66D] Memory Frequency (Mhz) ---------------- : 995 DRAM Timing Selectable ---------------- : [Manual] Standard Timing Control CAS Latency Time -------- ?? ---------- : [5] tRCD ------------------- ?? ---------- : [5] tRP --------------------- ?? ---------- : [5] tRAS ------------------- ?? ---------- : [15] (((((( na modulima pise 5-5-5-18 pa neznam dali ovo treba zamjeniti sa 18 )))))) Advanced Timing Control tRRD ------------------- ?? ---------- : [Auto] tWTR ------------------- ?? ---------- : [Auto] tWR --------------------- ?? ---------- : [Auto] tRFC ------------------- ?? ---------- : [Auto] tRTP ------------------- ?? ---------- : [Auto] Command Rate (CMD) -------------------- : [Auto] Driving Strength Profiles Driving Strength --------- : 1066 << both channels Channel A Static tRead Value --------------------- : [9-7] (((((( pise 8 pa sam ostavio ))))))) Channel B Static tRead Value --------------------- : [9-7] (((((( pise 8 pa sam ostavio ))))))) Motherboard Voltage Control CPU Voltage Types------------ Normal -------- Current ----- CPU Vcore --------------- ?.????? ---- : default+ as needed, up to 1.3625 CPU Termination --------- 1.200V ----- : [1.2] CPU Reference ----------- 0.760V ----- : [Auto] MCH/ICH MCH Core ---------------- 1.100V ------- : [1.2] DRAM DRAM Voltage ------------ 1.800V ------- : [2.2] Advanced BIOS Features Limit CPUID Max. to 3 ------------------ : [Disabled] No-Execute Memory Protect -------------- : [Enabled] CPU Enhanced Halt (C1E) ---------------- : [Disabled] C2/C2E State Support ------------------- : [Disabled] x C4/C4E State Support ----------------- : [Disabled] CPU Thermal Monitor 2 (TM2) ------------ : [Enabled] CPU EIST Function --------------------- : [Disabled] Virtualization Technology -------------- : [Disabled] Integrated Peripherals Legacy USB Storage Detect ------------- : [Disabled] -------------------------------------------------------------------------------------------------------------------------------------------------------------- Kad upalim, nakon slike biosa, pojavi se crni ekran sa pustim brojkama kao inace i prije dizanja win pise Verifying DMU Pool Data...... Beging to update Bios to....... Bios Auto-Recovering............................................................................... I dignu se windowsi ali u biosu je sve postavljeno na kao prije.. znaci oc nije uspio.... Sad do cega je nezam ... Nije mi jasno dali ovo sto je u channel B timming setting nije kao u A sve na AUTO nego je postavljeno ovako: http://postimg.org/image/cjwj9oqnr/ i ovo nisam mjenajo ostavio sam kako je prije bilo, nisam ni gledao kako je: Advanced BIOS Features Limit CPUID Max. to 3 ------------------ : [Disabled] No-Execute Memory Protect -------------- : [Enabled] CPU Enhanced Halt (C1E) ---------------- : [Disabled] C2/C2E State Support ------------------- : [Disabled] x C4/C4E State Support ----------------- : [Disabled] CPU Thermal Monitor 2 (TM2) ------------ : [Enabled] CPU EIST Function --------------------- : [Disabled] Virtualization Technology -------------- : [Disabled] Integrated Peripherals Legacy USB Storage Detect ------------- : [Disabled] ..... jeli to potrebno mijenjati?  |
		#392 |
			Datum registracije: Jan 2015
				Lokacija: mars
					Postovi: 104
		 e ovako, problems.. Ploča: Gigabyte EP35-DS3R v: 2.0, bios f13 Procesor: Q9300 Rami: 3x corsair TwinX ddr2 1.1 sa micronima 2gb, Kingmax 1gb 800 sa elpidom...prolaze memtest na 4-4-4-12 Napajanje LC power GP6550 2.0 javlja greške u OCCT medium, large database set te u PRIME95 blend testu. bios: 400 fsb vcore 1.18 - 1.35 probao MCH: +1 - +2 probao FSB voltage: ne diram DRAM: +0.3 c1e i eist1 - uključeno isključeno ista stvar javlja grešku prime: rounding was 0.5 expected less than 0.4, OCCT zakrešti grešku nakon 10 ak minuta imam vent koji puše preko northbridga i meme eh...cooler je šugavi artic alpine 11, ali temp ne prelazi 80 u small FTT i namjestio sam da dopušta do 85 prije mi je radilo bez problema na tim postavkama... Ispravite me ako griješim, ali medium i large database više forsiraju memu i NB? pošto je p35 chipset, nemogu se igrat sa ostalim postavkama i voltažama  |
		#393 |
		 FSB voltage +0.1 CPU Voltage neidi preko 1.37V jer nema smisla. DRAM ti je na 2.1V ako se ne varam (1.8V je default). A ako su tu Microni, nebi se čudio da su već lagano u banani. Moj bet je da je memorija počela kenjat pogotovo ako je na samo 800MHz. Probaj neki drugi RAM ili tesitiraj samo sa Kingmaxom na 1.9V. Ako ti na kingmaxu bude OK, znači da je to. A tako probaj isto i drugi RAM ako na kingmaxu baci error. Ploča ne bi trebala bit. Koliko god je Điđibajt mušićav i to što sam spalio hrpu P35 DS3L ploča, nisu se previše glupirale. Samo su crkle   tako da probaj sa mermerijom to. Pa javi. |
		#395 | |
				Lokacija: mars
					Postovi: 104
 a memtest 5x prolaze jbg....probam tnx teška srca priznajem, ali SVI ste bili u pravu. Vrijeme je za novu platformu. Koliko god ja sebe lagao da mi netreba ništa bolje, i imam više nego zadovoljavajuće preformanse od svega ovog...novo je novo. izašao ddr4 a ja se još ebem oko ddr2 lol. Zadnje izmijenjeno od: smak420. 19.08.2015. u 11:50.  |
		#396 |
		 Nije stvar u tome što tebe zadovoljava ili ne. Stvar je u tome što ta starudija odumire i krepava i što nema poštene zamjenske stvari, a da ne košta koliko nova stvar koja je 5x bolja i ima garanciju 3 godine. Samo to  ![]() Ulaganje u s775 mašinu je besmisleno. 8 godina star socket i sad tu ulagati u DDR3 ploče i nekakve quadove je krajnja glupost, osim ako nemaš par somova onako za obrisat cipele   Lijepo neku s1150 ploču sa B ili Z čipsetom, 8GB DDR3 i kakav polovni CPU Pentium ili i3 i bog te veseli. Sadašnji Pentiumi i i3 u svemu prepišaju te Quadove iako ovi imaju te dodatne fizičke dvije jezgre. Pusti mitomaniju njuškalo švercera o tome kako Q9550 na 4GHz skoro pa jede i7 i tako to.  |
		#397 |
				Lokacija: Bjelovar
					Postovi: 739
		 775 se zadržao neprirodno dugo kod nas. Da, bio je zakon, da mogao je napraviti čuda, ali nova je tehnologija toliko otišla naprijed.  Kada usporedim kako je jednostavno OC-ati Sandy i Ivy bridgeve u odnosu na 775 quadove, stvarno ne vidim smisla maltretirati se sa toliko starom tehnologijom.  |
		#398 | |
					Postovi: 4,403
 ![]() Da postoji nešto novije, a da se može poštimavati kao legendarni 775 - uzimam odmah ![]()
		#399 |
		 Zadržao se dugo jer ga je i Intel gajio dugo. AMD odgovor nije imao, a prodaja je išla kao mutava. Daleko od toga, bio je odličan socket, pogotovo kad je došao P45 i 45nm procesori. Moj ćaća gazi P5Q-E i Xeona E3110 sa 6GB RAMa. Kaj njemu treba (Autocad, Office, multimedia, net) i više nego super. Ali da mu rikne ploča... momentalno sve novo ide. Nema teorije da tražim s775 ploču i okidam 400+ kuna za nju. Tako i svi koji imaju Quadove s775. Jasno da im se ne isplati prelazak nekamo ako nisu HC gameri ili neki uracpalac. No ako tako rikne ploča ili počne zebavat, lagano se okrećeš novim igračkama.  |
		#400 |
				Lokacija: mars
					Postovi: 104
		 Da...eto ja sam ipak imao dosta srece sa time...necu da spammam temu, al ajde..moja kratka PC životna prica hehe jos do prije 2 godine, imao sam dual core e2160 i neku asus p5b-vd...clock sa 1,8 na 2.0 ![]() Malo googlao sto bi meni trebalo za zaigrat neke stare igre, pogledam po njuškalu i opa... DFI x38 t2rb, 4 x 1gb ddr2 i q9300 za 400 kn. Naravno da sam uzeo. Onda pljunuo još toliko za corsair TX650 i još toliko za GTX 260. SSD od 40 giga dobio, a 2 harda od 160 gb imao    Pa dobim Xeona iz servera raspalog u frendovoj firmi...za 1200 kn ja sam odjednom složio kantu koja je na mojoj plazmi 720p ganjala svaki k.. od igrice na ulta bez frke. Nenadjebiv osječaj ![]() ...dok ne počnu krepavat stvari....hehe eto posralo me da dobijem i 4 x 2gb očito neispravnih precjenjenih twinX rama, pa frend kupuje novu kantu pa udjeli đabe još Gigabyte ploču.. ne radim, živim od invalidnine i sjeb mi je davati 3-4k koje nemam btw na novo i bolje.. al jbg, bumo morali   edit: a istina...nekako imam osjecaj ispod i5 4460 da mi i nije neki upgarade...jer kad i ako dajem tu lovu za novo, želim da ipak imam drastičan porast preformansi. i da brko druže, imaš pivu jedna 2gb pločica zaebavala....sad prolazi large data set u OCCT i blend test hvala Zadnje izmijenjeno od: smak420. 19.08.2015. u 23:46.  |
		#401 |
				Lokacija: mars
					Postovi: 104
		 nikad điđa više u moj pc! ASUS p5q pro-fenomenalna ploča koju sam našao za lol..50 kn Q9300 radi na 427 FSB za sada 2x2 gb ddr2 twinX 800 cl4 CPU Multiplier - 7.5x FSB - 427MHz PCIE 100MHz FSB Strap to North Bridge AUTO Dram Frequency - DDR2-854 DRAM Timing Control- 4-4-4-12 (ostalo auto) Dram Static Read Control AUTO Dram Read Training DISABLED MEM OC Charger - AUTO AI Clock Twister - AUTO AI Transcation Booster AUTO CPU Voltage(vCore) - 1.19375 CPU GTL reference AUTO CPU PLL Voltage 1.52V FSB Termination Voltage AUTO Dram Voltage - 2.1 North Bridge Voltage - AUTO South Bridge Voltage - AUTO PCIE SATA Voltage - AUTO Load-Line Calibration ENABLED CPU Spread Spectrum - DISABLED PCIE Spread Spectrum DISABLED CPU Clock Skew AUTO North Bridge Clock Skew AUTO CPU Margin Enhancement - Optimized C1E Support ENABLED Intel Virtualization Tech DISABLED CPU TM Function ENABLED Memory Hole - DISABLED CPU Core Temps at IDLE- C0 - 47C C1 - 40C C2 - 40C C3 - 41C CPU Core Temp na OCCT small data set C0 - 69C C1 - 64C C2 - 63C C3 - 63C i to sa šugavim coolerom ARTIC Alpine 11 plus. Sad na redu kasapljenje ploče te stavljanje x5460 e0 i scythe mugen 2 Nazalost krepali mi rami tako da imam 2x2 gb corsair twinX 800 cl4, al našao sam za 120 kn adata 2x2 400 cl5. nadam se 4.00ghz te 4-4-4-12 latencijama Živio 775 socket! P.S. prije nego me napadnete da kupujem starudiju, ovo je free stuff upgarade ![]() te ako netko ima bios p5q pro za xeona isproban... Zadnje izmijenjeno od: smak420. 25.09.2015. u 15:38.  |
		#403 | |
				Lokacija: mars
					Postovi: 104
 ![]() ruke su mirne, ne tresu se pa idem odrezat socket. Navecer javim rezultate testiranja i OC X5460 e0 dodane jos 2x1 gb...vec je testirana sa memtestom i occt large setom, pa nebi trebalo bit problema na 425 fsb Edit: konacno mi rade svi keksi skupih corsairovih twinX 8gb rama \o/, skoro sam ih bacio fora je bila u asusovom ai tweakeru stavit zadnju postavku dolje umjesto OPTIMIZED u PREFORMANCE MOD. Memtest 10 pass prolaze i blend test 5h. Zadnje izmijenjeno od: smak420. 22.10.2015. u 10:37. Razlog: otkrio toplu vodu  |
		#404 |
			Datum registracije: Jul 2014
				Lokacija: Serbija
					Postovi: 108
		 E ja sam imao taj procesor. Držao sam ga na 3.3Ghz da bi mi memorija radila na oko 800Mhz ako se ne varam. Ovo dole možeš da zadržiš a ostalo ploča mi je bila DFI a na gigabajt ne bih umeo da se snađem.  |
		#405 |
					Postovi: 2,523
				pomoc sa q9450
			Bok, konfa pod moj komp. Cilj je 3.6ghz za sad. Po dosadasnjim indikacijama trebalo bi ici sa 1.32v cca. No zeza me malo ploca. Sad testiram nju prvo da stabiliziram 450mhz fsb. Izgleda da bude ok sa ovim postavkama: vtt 1.26v Nb 1.22v Gtlref auto cpu pll 1.56v (tek tolko, ne znam jel icem pomaze) sb auto pcie auto Dakle pitanje je da li za stabilizaciju ploce dovoljno dizat vtt i nb voltazu i kad je to stabilno onda dignem proc. Da li je jos koja voltaza bitna za stabilizaciju ploce? Kolko sam skuzio ako stabiliziram plocu i onda procesor sa odredenom voltazom, pomogu gtlref mogu probat dobit vecu stabilnost procesora sa manjom voltazom. Ali ako sam zadovoljan sa voltazom (npr da nije preko 1.35v) onda ne trebam dirat gtlref uopce? Pokusavam ga izbjec jer nisam bas upoznat sa tom opcijom. Jel mi pristup ok ili da mijenjam nesto? Temp su ok. Ispod 70c pod full load. Prime95  |
		#406 |
				Lokacija: Vukovar-Osijek
					Postovi: 491
		 Pozz!  Imam i ja par pitanja, proljetos sam uzeo X5460 E0, MSI P45 Neo3 plocu i 4x2gb kingston 800 rama. problem mi se javlja da nakon nekog vremena sto je cpu radio bez problema na 4.2ghz, sa malim podizanjem napona, s vremenom vise nije htio raditi na tom taktu i sad na jedvite jade ga odrzavam na 3.8ghz, fsb400, i to kad sam skontao overclock preko jumpera na ploci. nikad nisam morao podizati napone ramova niti nb-a, a sada i kad probam bilo sta od navedenoga, ne zeli raditi vislje od tih 400mhz na fsb-u. mogu reci da sam i zadovoljan sada kakvo je stanje, 3.8 je dosta dobar takt s obzirom da sve radi na stock naponima i ne grije se... al dok je radio na nesto visljem taktu osjetilo se da je jos malo "aktivniji" edit: i da, ploca malo buca u biosu, tipa C1 i EIST su mi iskljuceni i mnozitelj je stavljen na 9.5x ali bez obzira na to u windowsima mi frekvencija ipak seta po mnozitelju od 6 do 9.5... isto tako i napon.. Zadnje izmijenjeno od: animATrIx. 29.10.2015. u 01:04.  |
		#407 | |
				Lokacija: mars
					Postovi: 104
 Ja imam slicnu konfu, doduse p5q pro sa ddr2 i q9300 te X5460. stabilizirao sam na 440 FSB sa cpu PLL na 1.60V , mislim da se za 450 fsb trebaš igrat sa GLT x0.63 ili x0.65, moj savjet da pričekaš ili pitaš druga Brku (član foruma), znat ce ti konkterno pomoci i nekako mi je velik taj 1.32V vcore za tu frekfrenciju, meni q9300 radi 3300 na cca 1.27  |
		#408 |
					Postovi: 2,523
		 Tnx na odgovoru pa evo i update. Zasad 1.32v, da, cini se malo puno s obzirom da je 1.26v dovoljno za 3.4ghz, ali tako to ide... Mislim da bi mogo spustit voltazu kad bi znao odigrat dobro sa gtlref i cpu pll. Uglavnom stabiliziro sam plocu na 450mhz, ali trebo sam: VTT: 1.32v vNB: 1.32v Stabilan je i proc na 3.6ghz sa spomenutih 1.32v i 1.56v PLL. Dal je to puno volti za plocu? Meni se cini da je s obzirom da je za 437mhz (4.5ghz) dvoljno 1.22v (vtt i nb), ali nejde sa manje. No ipak mislim da je u granicama za 24/7 koristenje. Kako dalje? Brko pomagaj ![]()  |
		#410 |
					Postovi: 2,523
		 Asus P5Q3 (obicna, nije deluxe). Kad stignes ako mozes malo pojasnit gtlref, trenutno mi je na auto. I da li bi trebo povecat PLL? Mozda sa vecim PLL i sa pogodjenim gtlref mogu smanjit voltazu za procesor? Uglavno, htio bi to jos malo fine tunat.  |
		#411 |
		 Ko će se sad toga sjetit ... Ja P5Q-E nemam od 08/2010, dakle preko 5 godina. Ako nađem notepad sa tim postavkama, javim.  Nemrem se napamet sjetit tih svih parametara. Ali vidi malo po forumu u starim temama, sve je tu. Siguran sam da piše o tome...  |
		#413 |
				Lokacija: mars
					Postovi: 104
		 evo Q9550 e0  na 3.7  sa 1.306V,  kasnije smanjio na 1.275V u biosu i odvrtio jos 1 sat small data set http://valid.x86.fr/hlci70 ![]() BIOS postavke ![]() ![]() ![]() ![]() uff glomazne slike ![]() Zadnje izmijenjeno od: smak420. 08.11.2015. u 17:53.  |
		#415 |
				Lokacija: mars
					Postovi: 104
		 Da memorija me koči, trenutno su 2x2gb corsair TwinX i 2gb kingston cl6, i jedan kingmax od 1gb, sve skupa 7gb Corsair mi šalje nove dominatore jer ovi imaju life time warranty, pa sad cekam 4 x 2gb dominatore 10000 CL5, tek onda cu moci cmmon preformance level stavit na 10 cca i probat gurat 471 fsb za 4.0, proc očito može  |
		#416 |
		 Ako me pamćenje služi, gtlref je za neki jači OC sa vodenim ili LN2 hlađenjem. Na ovim taktovima do i oko 4 GHz je potpuno nebitno. 0.63 je bila neka brojka ako se ne varam. Ali 3.7 na 1.3V... nije to baš neki dobar čip. To da je 4.0 na <1.3V onda da. Ovako je to osrednje dobar čip. Evo u mog čaće E5450 (Q9650) ide 1.15V 3.6 GHz a C0 je.  |
		#417 |
				Lokacija: mars
					Postovi: 104
		 nisam ni probavao niže jer me memorija koči, al posta normalno na 4.0 i vrti prime, u biosu je na 1.275...tako posto znam sto mi greske baca, vcore nije kad stigne onda cu fine tuning neki bacat, a jos si razmišljam jel mi se isplati kasapit plocu radi ovog slanp x5460, jer plan je mrknut ovo za dobru lovu iza nove ![]()  |
		#419 |
					Postovi: 2,523
		 Moj je na 3.6ghz sa 1.35v, sto je u odnosu na njegov chip, zesci uzas    Nikad nemam srece sa tim stvarima. Promjenio 5 CPUa i ni jedan nije bio nest extra. jbgMislim da se vracam na 3.4ghz i 1.26v. Eventualno 3.5ghz sa 1.3v. Kupio sam novi cooler bezveze. 3.4/3.5 sam mogo i sa freezerom. Doduse ovaj LC drzi bar 10c u prosjeku manje temp.  |
		#420 |
				Lokacija: mars
					Postovi: 104
		 A vidjet cemo sta ce se dobit sa ovim Xeonom osim veceg multija. Ipak je tdp 120w naprema 95w, tako da sam skeptičan prema nekim manjim voltažama.  Kako sada stvari stoje, ja zadovoljan. Ipak se osjeti tih parsto mhz  |
