Staro 02.10.2005., 09:44   #1
Jablan
Jablan's Avatar
Datum registracije: Jul 2004
Lokacija: ZG/Njemacka
Postovi: 756
video zapis MPEG-4
zainteresiran sam za jednu digitalnu videokameru, 3,2 Megapixela, 4X digital zoom, digitalne fotografije itd..
E sad kamera ima 16 MB interne memorije pa me zanima koliko je odprilike vremensko trajanje video zapisa u MPEG-4 formatu, da li je to dovoljno memorije za jednog kučnog usera ili je ipak treba nadograđivati.
Jablan je offline   Reply With Quote
Staro 02.10.2005., 10:39   #2
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Koja je to kamera? Mora snimati na traku, ne samo na internu memoriju...:confused:
Staro 02.10.2005., 12:05   #3
Jablan
Jablan's Avatar
Postovi: 756
Yakumo CamMaster
Staro 02.10.2005., 12:13   #4
Jablan
Jablan's Avatar
Postovi: 756
a ne vidim nigdje nikakvu oznaku za traku, guglao sam ali bezuspješno:confused:
Staro 02.10.2005., 21:49   #5
fanATIk
NITKOV
fanATIk's Avatar
Lokacija: Zagreb / Maksimir
Postovi: 4,003
Yakumo CamMaster SD 432
The Yakumo CamMaster SD 432 is a digital still camera with videoclip capability. This handy camera, which easily fits into the shirt pocket, is equipped with a 3.20 megapixel CCD capture unit. You can use this camera to make video films including sound, as well as to take digital photos.
The Yakumo CamMaster SD 432 features a flash with automatic red-eye reduction and over 13 different settings for controlling lighting. Its fold-out display can be easily turned, allowing you to take photos from every conceivable angle. Your video recordings are stored in MPEG-4 format in the internal memory (16 MB), or can optionally be saved to SD/MM cards. The Yakumo CamMaster SD 432 has a very ergonomic shape, enabling you to comfortably operate most buttons and functions using only one hand.
Its special feature: Using the TV cable supplied, you can easily connect the Yakumo CamMaster SD 432 to your own television and watch the recorded video clips.
Product number: 1035402
daklem, to nije video kamera nego digitalni fotić sa mogućnošću snimanja videa. mada izgleda ko video kamera.
http://www.yakumo.de/produkte/index....=Digitalkamera
Asrock FM2A78M-DG3+
G.SKILL RipjawsX series 8 GB
Palit GTX 460
Corsair VS550
Thermaltake Core V21
22"LCD LG W2242T
MX Revolution
Logitech X-230
Logitech K740
Canon CanoScan 4400F
Win 10
Unique case by fanATIk
Avatar BIG SIZE
fanATIk je online   Reply With Quote
Staro 02.10.2005., 22:56   #6
Jablan
Jablan's Avatar
Postovi: 756
hvala što si mi otvorio oči, nisam si ni mislio da nešto valja kada košta 1300 krznatih
