Staro 05.07.2015., 10:05   #211
morbid_angel
Lokacija: Tokyo
Postovi: 196
Meni Bumblebee radi dobro na OpenSuSE. Graficka je gtx 970m.
CPU: i7 4710HQ
MBO: NEXTGEAR-NOTE i5700
RAM: 4*8 GB DDR3 1600 MHz
GPU: nvidia GTX970M
SSD1: Crucial MX100 512 GB
SSD2: Samsung 850 EVO 1TB
OS: Windows 8.1
MBO: HP NW9440
CPU: C2D T7600
RAM: 2*2 GB DDR2 667 MHz
GPU: nvidia Quadro FX 1500M 512MB
SSD: SanDisk 32GB
HDD: Toshiba 100GB 7200 rpm
Dock: HP Advance Docking Station 180W
OS: Windows 8.1 Professional x64 / OpenSUSE 13
CPU: Intel Core i5 3570K & Scythe Mugen 4
MBO: ASRock Z77 Extreme 4
RAM: 4*8 GB DDRIII 1600 MHz
GPU: VTX3D 7970 & XFX 280X-TDFD
SSD: 2*Vertex 4 128GB (RAID 0)
HDD: Seagate 2TB
PSU: Coolermaster Silent Pro M2 1500W
Case: Coolermaster CM 690 III
LCD: 2*Dell U2412M
Periferija: Logitech G510 & G500, Denon AH-D400
CPU: AMD FX-6200 & Scythe Ninja 3
MBO: Asus M5A97 Evo R2 AMD3+
RAM: 2*8 GB DDRIII ECC
HDD: 2*WD Red 2TB
PSU: XFX 550W
Case: Fractal Design Define XL R2
OS: ESXi 5.5
CPU: AMD Athlon II X4 & Scythe Big Shuriken 2
MBO: ASRock 880G Extreme 3
RAM: 4*4 GB DDRIII 1333 MHz
HDD1: WD Red 2TB
HDD2,3,4: 3*WD Green 2TB
HDD5: Samsung 1 TB
HDD6: Seagate 1500GB
PSU: Corsair VX 450W
Case: Chieftec BA-02B-B-B
OS: Windows Server 2012 R2
CPU: AMD Athlon x2
MBO: Gigabyte GA-M55plus-S3G
RAM: 4*2 GB DDRII 800 MHz
HDD1,2,3: Seagate PATA 320GB
PSU: Corsair CX 400W
Case: White ;D
OS: ESXi 5.5
MBO&CPU&GPU: ASRock E350
RAM: 1*4 GB DDRIII 1333 MHz
SSD: SanDisk 32GB
Case&PSU: Inter-Tech e-i7
OS: Windows 7 Pro x64 + XBMC
SSD: SanDisk 32GB
CPU: C2D 2.4 GHz
MBO: MacBook Pro 13" mid-2010
RAM: 2*4 GB DDR3 1066 MHz
GPU: nvidia 320M
SSD: Kingston HyperX 3K 120GB
HDD: Toshiba 250GB 5400 rpm
OS: OS X 10.9
morbid_angel je offline   Reply With Quote
Staro 05.07.2015., 10:07   #212
0siris
Datum registracije: May 2015
Lokacija: Stan
Postovi: 122
sad ću probati sa bumblebee,..
koliko vidim ubuntu uopće ne vidi nvidiu:
~$ lspci -vnn | grep -i VGA -A 12
00:02.0 VGA compatible controller [0300]: Intel Corporation Core Processor Integrated Graphics Controller [8086:0046] (rev 02) (prog-if 00 [VGA controller])
Subsystem: Micro-Star International Co., Ltd. [MSI] Device [1462:1063]
Flags: bus master, fast devsel, latency 0, IRQ 27
Memory at f0000000 (64-bit, non-prefetchable) [size=4M]
Memory at e0000000 (64-bit, prefetchable) [size=256M]
I/O ports at e080 [size=8]
Expansion ROM at <unassigned> [disabled]
Capabilities: <access denied>
Kernel driver in use: i915
edit:
stvar ista nakon instalacije Bumblebee.Uopće nije našao nvidia grafičku u računalu -_-
Zadnje izmijenjeno od: 0siris. 05.07.2015. u 10:21.
0siris je offline   Reply With Quote
Staro 06.07.2015., 13:06   #213
0siris
Lokacija: Stan
Postovi: 122
NItko nema ideju kako riješiti ovaj problem? stvara mi dosta problema,ne mogu koristiti svoju Nvidia u ubunti 15.04 uopće je ni neprepoznaje....
Staro 06.07.2015., 14:19   #214
cccp
cccp's Avatar
Datum registracije: Feb 2004
Postovi: 1,030
Jesi li već instalirao nvidia drivere ili bumblebee? Šta kaže `lspci -k`? Možda se pojavljuje kao "Display controller", a ne "VGA Compatible Controller" pa probaj ovo `lspci -nn | grep '\[03'`
cccp je offline   Reply With Quote
Staro 06.07.2015., 14:52   #215
0siris
Lokacija: Stan
Postovi: 122
MS-16G1:~$ lspci -k
00:00.0 Host bridge: Intel Corporation Core Processor DRAM Controller (rev 02)
Subsystem: Micro-Star International Co., Ltd. [MSI] Device 1063
Kernel driver in use: agpgart-intel
00:01.0 PCI bridge: Intel Corporation Core Processor PCI Express x16 Root Port (rev 02)
Kernel driver in use: pcieport
00:02.0 VGA compatible controller: Intel Corporation Core Processor Integrated Graphics Controller (rev 02)
00:16.0 Communication controller: Intel Corporation 5 Series/3400 Series Chipset HECI Controller (rev 06)
Kernel driver in use: mei_me
00:1a.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 05)
Kernel driver in use: ehci-pci
00:1b.0 Audio device: Intel Corporation 5 Series/3400 Series Chipset High Definition Audio (rev 05)
Kernel driver in use: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 1 (rev 05)
00:1c.1 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 2 (rev 05)
00:1c.3 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 4 (rev 05)
00:1c.5 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 6 (rev 05)
00:1d.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 05)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev a5)
00:1f.0 ISA bridge: Intel Corporation Mobile 5 Series Chipset LPC Interface Controller (rev 05)
Kernel driver in use: lpc_ich
00:1f.2 SATA controller: Intel Corporation 5 Series/3400 Series Chipset 4 port SATA AHCI Controller (rev 05)
Kernel driver in use: ahci
00:1f.3 SMBus: Intel Corporation 5 Series/3400 Series Chipset SMBus Controller (rev 05)
00:1f.6 Signal processing controller: Intel Corporation 5 Series/3400 Series Chipset Thermal Subsystem (rev 05)
Kernel driver in use: intel ips
06:00.0 Network controller: Intel Corporation Centrino Wireless-N 1000 [Condor Peak]
Subsystem: Intel Corporation Centrino Wireless-N 1000 BGN
Kernel driver in use: iwlwifi
07:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 06)
Kernel driver in use: r8169
3f:00.0 Host bridge: Intel Corporation Core Processor QuickPath Architecture Generic Non-core Registers (rev 02)
Subsystem: Intel Corporation Device 8086
3f:00.1 Host bridge: Intel Corporation Core Processor QuickPath Architecture System Address Decoder (rev 02)
3f:02.0 Host bridge: Intel Corporation Core Processor QPI Link 0 (rev 02)
3f:02.1 Host bridge: Intel Corporation 1st Generation Core Processor QPI Physical 0 (rev 02)
3f:02.2 Host bridge: Intel Corporation 1st Generation Core Processor Reserved (rev 02)
3f:02.3 Host bridge: Intel Corporation 1st Generation Core Processor Reserved (rev 02)
vnvidia i bumblebee instalirani...
Staro 06.07.2015., 15:46   #216
cccp
cccp's Avatar
Postovi: 1,030
Probaj u potpunosti maknuti bumblebee i nvidiu (apt-get --purge remove ako se ne varam) i restartati pa onda probati vidi li se nvidia gpu sa `lspci -nn | grep '\[03'`. U bios-u nisi ništa dirao?
Ako se vidi instaliraj bumblebee po instrukcijama sa wikija:
Code:
Setup for 14.04 and later
You need to open your terminal and enter the commands below.
    Enable the Universe and Multiverse repositories in order to allow the bumblebee and nvidia packages to be installed:
    sudo apt-get install bumblebee bumblebee-nvidia primus linux-headers-generic
    Reboot.
Nisam dugo koristio Ubuntu pa ne znam kako to tamo točno fukcionira.
Staro 06.07.2015., 19:24   #217
akoj
lijevo smetalo
akoj's Avatar
Datum registracije: Jan 2014
Postovi: 1,120
Kako uključiti headphone jack sense?
U AlsaMixeru toggle za ovu opciju ne funkcionira.
Riječ je o LXLE-u.
Nvisen Y-GX01 // HP ProBook 470 G2 // BMAX Y11
akoj je offline   Reply With Quote
Staro 07.07.2015., 11:32   #218
0siris
Lokacija: Stan
Postovi: 122
Autor cccp Pregled postova
Code:
    Reboot.
nisam dirao ništa po pitanju biosa na ubuntu 14.04 nakon friške instalacije odmah je prepoznao grafičku i pod dodatne driver ponudio mi drivere za nvidia....i kada maknem bumblebee problem je isti grafička jednostavno ne postoji u ovoj novoj verziji ubunte i jako me živcira ovo....
Staro 07.07.2015., 11:51   #219
cccp
cccp's Avatar
Postovi: 1,030
Autor akoj Pregled postova
Riječ je o LXLE-u.
Koja zvučna kartica je u pitanju? Je li loadan dobar modul?
Staro 07.07.2015., 12:04   #220
0siris
Lokacija: Stan
Postovi: 122
vrćam se na 14.04....gotovo nemoguće natjerati da mi glupa nvidia radi na 15.04... pun internet topica vezano uz nvidia i 15.04 ubuntu....
Staro 10.07.2015., 20:37   #221
pjedvaj
pjedvaj's Avatar
Datum registracije: Jul 2015
Lokacija: empty
Postovi: 21
Canonical je uveo ciklus od 2 godine za Ubuntu, bolje se držite 14.04 dok ne izađe 16.04 LTS.
pjedvaj je offline   Reply With Quote
Staro 17.08.2015., 12:21   #222
Michel
Michel's Avatar
Lokacija: Dubrovnik
Postovi: 1,286
Pozdrav,
Inaće sam uvijek bio na win i sada sam dao priliku Linuxu ponovno nakon dugo vremena. Instalirao sam Mint 17.1 . Svidilo mi se što je sličan windowsu po izgledu baš user friendly nekako, ali imam problem. Imam Compaq Nx6310 sa nekom Broadwell wlan karticom. Driver za nju se nije instalirao.
Kada sam se spojio preko Ethernet kabela i pošao u driver manager našao je driver, stavio sam da instalira i navodno se uspješno instalirao, zatim je automatski "otkacio" ethernet konekciju, ali wlanu ni traga. Ne znam gdje da potražim i što mogu sada učiniti ?
Michel je offline   Reply With Quote
Staro 17.08.2015., 20:39   #223
cccp
cccp's Avatar
Postovi: 1,030
Nema neki applet na traci za mrežu? Jesi li rebootao? Treba provjeriti je li pokrenut driver. U terminalu pogledaj što kažu naredbe "ip link" i pojavljuje li se taj instalirani driver kada izlistaš drivere s "lsmod".
Staro 17.08.2015., 21:37   #224
Postovi: 23,498
Staro 18.08.2015., 10:06   #225
Michel
Michel's Avatar
Lokacija: Dubrovnik
Postovi: 1,286
Je je Broadcom , povukli me procesori
Hvala na odgovorima sutra ću pogledat čim stignem odlično
Staro 18.08.2015., 15:39   #226
Mr.Black
Mr.Black's Avatar
Postovi: 1,679
Linux Mint 17 se smrzava
Na laptopu je bio instaliran dual boot, win7 i mint..pošto se mint smrzavao kod podizanja, formatirao sam cijeli disk i stavio samo linux mint 17..i dalje se smrzava kod podizanja, dođe do loga, i tu stoji, disk, memorija, sve ispravno..jel možda ima kakav bug?
Mr.Black je offline   Reply With Quote
Staro 18.08.2015., 15:55   #227
Postovi: 23,498
Jesi li probao drugu pod-varijantu (Xfce ili KDE), starije varijante (17.1, 17) ?
"Laptop" ništa ne znači, navedi ugrađeni hw.
Staro 18.08.2015., 21:17   #228
Mr.Black
Mr.Black's Avatar
Postovi: 1,679
Autor Nikky Pregled postova
Znači model je Lenovo G570..nisam probao ostale varijante..koja bi bila najpraktičnija?
Staro 18.08.2015., 21:37   #229
Postovi: 23,498
Pa pročitaj malo, prvo sam spominjao različiti GUI (Xfce bi trebao biti "lakši") ...
Kako se ponaša ako ga boot - aš direktno sa install medija (Live Linux) ?
Staro 18.08.2015., 21:58   #230
tomek@vz
tomek@vz's Avatar
Lokacija: München/Varaždin
Postovi: 4,694
Autor Mr.Black Pregled postova
Ok...to je šasija...a kaj je ispod haube? Di točno stane? Kaj veli (-verbose opcija kod boota)?
Lenovo LOQ || AMD Ryzen 5 8645HS / 16 GB DDR5 / 1TB Micron M.2 2242 / 1TB Sandisk Extreme nvme M.2 / nVidia Geforce RTX 4050 / Windows 11 Pro
Lenovo Thinkpad T540p || Intel Core i7-4700MQ / 16GB DDR3 / 240GB Sandisk Plus / nVidia Geforce GT 730 / FreeBSD 14.3
Staro 18.08.2015., 22:16   #231
Mr.Black
Mr.Black's Avatar
Postovi: 1,679
Ma sa laptopom je sve ok, vrti windowze i radi ok, temp su ok..znači sa live dvd linux radi ok, al kad se instaliraju onda su problemi..
Staro 19.08.2015., 07:42   #232
tomek@vz
tomek@vz's Avatar
Postovi: 4,694
Mislim da me nisi shvatio. Koje su komponente ispod haube? Kaj logovi pričaju?
Staro 19.08.2015., 09:31   #233
Mr.Black
Mr.Black's Avatar
Postovi: 1,679
Cpu: Intel Core i5-2430M
Memory: Samsung 2gb, Transcend 2gb
Hard: Seagate 500gb
Staro 19.08.2015., 12:49   #234
tomek@vz
tomek@vz's Avatar
Postovi: 4,694
Hard: Seagate 500gb
A GPU?
Staro 19.08.2015., 13:57   #235
Mr.Black
Mr.Black's Avatar
Postovi: 1,679
Amd Radeon HD 6370..instalirao sam win7, i radi ok..skinuo sam linuxmint-17.2-xfce-64bit..i isto mi smrzava..
Staro 19.08.2015., 21:09   #236
cccp
cccp's Avatar
Postovi: 1,030
Tomek, pretpostavljam da ciljaš na "display manager"? Mr. Black, možeš li ugasiti jedan od grafičkih čipova u BIOS-u?
Staro 20.08.2015., 11:06   #237
Mr.Black
Mr.Black's Avatar
Postovi: 1,679
Kak misliš ugasiti? Kak? Instalirao sam sad rafaelu 17.2 i kod instalacije se nisam spojio na mrežu, nije potegnuo bilo kakav update..čini mi se da sad radi..barem kaj sam probao nekoliko puta ga upaliti i resetirati..
Zadnje izmijenjeno od: Mr.Black. 20.08.2015. u 11:20.
Staro 20.08.2015., 11:26   #238
snake29o3
snake29o3's Avatar
Lokacija: Croatia - Kutina
Postovi: 211
Ako imas switchable graphics ( Intel i AMD ), ugasi u BIOS-u AMD-a, mislim da ti se to tamo zove Switchable Graphics. Nakon toga instaliraj Mint i radit ce, ali neces imati AMD grafulju vec samo integriranu Intel. Ima mi buraz tu Lenovo G500 seriju i Lenovo je nesto cackao po BIOS-u i nema sanse da Linux radi dobro dok je ukljuceno Switchable Graphics. Steta sto su to tak napravili jer Linux na tome radi ko beba.
CPU: INTEL Xeon E5450 3.0 GHz 12 MB Cache
Cooler: Scythe Grand Kama Cross
Mainboard: Asrock P43DE3
RAM: 4 x 4 GB DDR3 1600MHz
GPU: XFX 8800 GT 512 MB DDR3 Alpha Dog XXX Edition
HDD: Kingston HyperX Fury 120 GB (OS) + ( 4 x Toshiba DT01ACA050 500 GB 32 MB (RAID 10) )
PSU: InterTech SL-500A
Case: Antec P180
OS: Proxmox VE
Cooler: Spire Kepler Rev.2
Mainboard: Gigabyte GA-965P-DS4
RAM: 4 x 2 GB DDR2 Kingmax 1066MHz
GPU: Palit GeForce 8400GS 512MB DDR2
HDD: Hitachi 160 GB (OS) + ( TOSHIBA 3 TB 64 MB DT01ACA300 + Toshiba 3 TB 64 MB HDWD130 (ZFS RAID1)
PSU: Xilence 420W
Case: Generic Midi Tower
OS: CentOS 7
Manufacturer: HP
Model: Z440
CPU: INTEL Xeon E5-1650 v4 3.6GHz ( 4GHz Turbo ) 15 MB Cache
RAM: 4 x 8 GB DDR4 ECC 2400MHz
GPU: nVIDIA Quadro P4000 8 GB
SSD: 2 x 240 GB RAID 1 + 256 GB
HDD: 2 x 3 TB RAID 1
Monitor: HP LA2405wg 24" 1920 x 1200
OS: openSUSE Tumbleweed MATE x64
BRAND: ASUS N705FD
CPU: Intel Core i7 8565U 1.8 GHz ( up to 4.6 GHz with TurboBoost)
RAM: 2 x 8 GB DDR4 2400 MHz
GPU: Intel® UHD Graphics 620 Integrated + nVidia GTX 1050 4GB DDR5
SSD: Crucial Micron 1100 256GB
HDD: Seagate ST1000LM035 1 TB 128 MB Cache
Screen: 17.3" 1920 x 1080
BRAND: HP Notebook 15-ba006nm
CPU: AMD Quad-Core A10-9600P (2.4 GHz, up to 3.3 GHz, 2 MB cache)
RAM: 4 GB DDR4 1866 MHz + 8 GB DDR4 1866 MHz
GPU: AMD Radeon R7 M440 Graphics 4 GB DDR3
HDD: 1 TB 5400 rpm
Screen: 15.6" 1920 x 1080 FullHD
OS: Windows 10 Pro x64
Poštene trgovine:
1, 2, 3, 4, 5, 6, 7
snake29o3 je offline   Reply With Quote
Staro 20.08.2015., 12:01   #239
Mr.Black
Mr.Black's Avatar
Postovi: 1,679
Mogu ugasiti nakon kaj sam instalirao tu rafaelu?
Vidim da imam u biosu graphic device: Switchable graphics
UMA graphic
Staro 20.08.2015., 12:11   #240
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,197
probaj, nista te ne kosta. u najgorem slucaju, ako zapne, ponovo ukljuci
