Staro 07.09.2005., 09:40   #1
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,860
leadtek 6600 gt problemčić
konfa
amd 2600+
albatron kx18dpro2
2x256 King Max 433 slot 1i2
cd rom
dvdrw pionir
hdd 80 gb ibm
400 w kodegen
77.72 driver
koji puta znaju se zamrznuti windowsi,recimo zamrznuo se kad sam otvaro podmenije pcchipovog dvd pa sam mora restartati,u igrama se za sada niš ne događa,kartica jučer kupljena,da li je možda napajanje još preslabo,kupljeno isto jučer umjesto legendarnog i neponovljivog jnca???
ovaj erorić je izbacio
EventType: 0xEA - Thread Stuck in Device Driver
// The driver for the display device got stuck in an infinite loop. This
// usually indicates a problem with the device itself or with the device
// driver programming the hardware incorrectly. Please check with your
// display device vendor for any driver updates.
ShutdownCount: 540
Shutdown: 0
EventFlag: 1
EventCount: 1
BreakCount: 1
BugcheckTriggered: 1
DebuggerNotPresent: 1
DriverName: nv4_disp
DeviceClass: Display
DeviceDescription: NVIDIA GeForce 6600 GT
HardwareID: PCI\VEN_10DE&DEV_00F1&SUBSYS_2011107D&REV_A2
Manufacturer: NVIDIA
DriverFixedFileInfo: FEEF04BD 00010000 0006000E 000A1E5C 0006000E 000A1E5C 0000003F 00000008 00040004 00000003 00000004 00000000 00000000
DriverCompanyName: NVIDIA Corporation
DriverFileDescription: NVIDIA Compatible Windows 2000 Display driver, Version 77.72
DriverFileVersion: 6.14.10.7772
DriverInternalName: nv4_disp.dll
DriverLegalCopyright: (C) NVIDIA Corporation. All rights reserved.
DriverOriginalFilename: nv4_disp.dll
DriverProductName: NVIDIA Compatible Windows 2000 Display driver, Version 77.72
DriverProductVersion: 6.14.10.7772
Staro 07.09.2005., 10:24   #2
nicko
Postovi: 4,190
probaj stavit nove drivere
nicko je offline   Reply With Quote
Staro 07.09.2005., 10:32   #3
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,860
misliš zadnje 78.01 su to zadnji.
Staro 07.09.2005., 11:26   #4
Broken Arrow
The Man
Broken Arrow's Avatar
Lokacija: Novi Zagreb
Postovi: 1,252
Imaš par tema niže Forceware v78.03 to su ti najnoviji
"Everybody's at war with different things...I'm at war with my own heart sometimes"
Broken Arrow je offline   Reply With Quote
Staro 07.09.2005., 23:10   #5
srkyno1
srkyno1's Avatar
Lokacija: st
Postovi: 1,084
novi driveri, ti su promašaj.
ASUS K8N & Zalman NB32K @ HTT x3 / A64 3000+ 263x8 / 2x256MB TwinMOS @ 210 / Club3D 5200 & Zalman ZM80C-HP / Maxtor 30GB, 2MB / WD Caviar 80GB, 8MB / Maxtor DM10 250GB, 16MB / Xilence 420W / CoolerMaster Centurion 5
srkyno1 je offline   Reply With Quote
Staro 08.09.2005., 01:01   #6
Cali
H2TB
Cali's Avatar
Postovi: 363
codegen 400w je katastrofa od napajanja, ali mislim da ovdje napajanje nije uzrok problema, nego driveri (kao što su ti već napisali)....
koju grafu si imao prije ove 6600gt? ako je bio ati, da li si pobrisao sa driver cleanerom stare drivere kako treba?
Cali je offline   Reply With Quote
Staro 08.09.2005., 09:14   #7
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,860
to je od frendovog mlađeg brata komp to su mu u ve-milu uvalili za 250 kn (napajanje +škatula),prije je isto imao nvidiu geforcu 2mx 64mb,onda koje drivere da stavim 78.01??je to napajanje dovoljno da povuče te komponente??da možda odspoji cdrom iako on ne troši puno wata??
Staro 08.09.2005., 11:49   #8
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,344
cd rom netrebaš odspojit, napajanje je dovoljno za tu konfu.
probaj izbrisat drivere sa driver cleanerom pa onda stavi nove.
žmnpp
Staro 11.09.2005., 19:12   #9
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,860
jesam ali iz remove programs,krknuo 78.01,povećao virtualnu memoriju na mximum,za sad mu radi ali bumo videli,odvrtio 3dmark 03 7700 na deafulat postavkama,ništa nije klokano.
Staro 11.09.2005., 21:15   #10
Crash009
Crash009's Avatar
Lokacija: Orahovica
Postovi: 7,363
daj molim te, imam to napajanje već par mjeseci i bez problema pogoni:
P4 2.8@3.4
2x256 DDR400 kingmax
WD40gb, baracuda 120gb
cdrw,dvdrw...
leadtek 6600GT
5ventova i neonku...
i nema nikakvih problema...
i da... istu tu konfu je pogonilo codegen 300w 2mj
Staro 11.09.2005., 21:25   #11
rendula
Lokacija: Zagreb, Trešnjevka
Postovi: 5,774
...koje je bolje od codegena 400w...
Staro 11.09.2005., 23:15   #12
CRO_VET
CRO_VET's Avatar
Lokacija: Šestanovac
Postovi: 398
bok dem! srkino ima pravo,drajveri su za smeće!!
imo sam te drajvere na crashevoj fx 5700,ma kaki u igru neće ući da si ne znam što...
zato se kloni tih,smrde mi na betu....:mad:
CRO_VET je offline   Reply With Quote
Staro 12.09.2005., 09:04   #13
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,860
onda dobro da nisam krkao 78.03 nego.01,crash vidim da si grafu zamjenio,kolko sad derneš markova???ovo je moja konfa
p4 1,8
MB Itel 845
512/266
Fx 5700 500/650
hdd 60 seagate
hdd 40 ibm
dvd
dvdrw
DTK 300w,će ovaj pvsić biti dovoljno jak da povuče 6600GT s ovim komponentama???
Staro 12.09.2005., 15:04   #14
stuc
stuc's Avatar
Datum registracije: May 2005
Lokacija: Online
Postovi: 2,404
hdd 60 seagate hdd 40 ibm ,dvdrw
i još na to 6600GT !?
Nema šanse ! Jedino ako želiš prisilno umirovit računalo
stuc je offline   Reply With Quote
Staro 12.09.2005., 15:17   #15
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,860
hm,kaže frend da mu opet jedan dan radi dobro onda drugi opet mrzne,uz el microsoftov eror u svezi s 6600gt koji sam postao,da diseblam eror report ??ima ko kakvu ideju što moglo biti uzrok mrznjenja??,da možda disk ne štuca??,morat ću ga odvrtiti na bad lustere.,će meni onda biti dovoljan dtk 400w??
Staro 24.09.2005., 16:49   #16
Crash009
Crash009's Avatar
Lokacija: Orahovica
Postovi: 7,363
p4 1,8
MB Itel 845
512/266
Fx 5700 500/650
hdd 60 seagate
hdd 40 ibm
dvd
dvdrw
u 03 oko 8900 6600gt ocana na 570/1170...
a sa fx 5700 na 525/690 sam dobivao negdje oko 4000...
i ako misliš uzeti 6600gt uzmi si novo napajanje npr chieftec 410w za 300kn u linksu
Staro 24.09.2005., 19:16   #17
maxtor
maxtor's Avatar
Postovi: 382
Mislim da mu ne treba napajanje od 410 W nek samo uzme neko kvalitetnije napajanje Chiftek,Tangan itd. može i od 300 W
maxtor je offline   Reply With Quote
Staro 24.09.2005., 19:54   #18
Crash009
Crash009's Avatar
Lokacija: Orahovica
Postovi: 7,363
taj chief je trenutno best buy, npr chief 360w dualfan dođe 290 ja ga jučer kupio jer nije bilo toga od 410w
Staro 24.09.2005., 22:12   #19
maxtor
maxtor's Avatar
Postovi: 382
Ali je razlika u cijeni između 360 i 410 W velika
Staro 25.09.2005., 09:22   #20
damir1
Ancient
damir1's Avatar
Lokacija: Đakovo
Postovi: 893
ne -cijena je ista,10-tak kuna možda
damir1 je offline   Reply With Quote
Staro 25.09.2005., 14:55   #21
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,344
probaj ovdje
žmnpp
