Postovi: 8
dvojba između konfiguracija
#1 DFI nF4 Ultra Infinity, S.939, dualDDR400, 8ch, G-LAN, PCIe, 1394, S-ATA, RAID 827,78 kn AMD Athlon 64 3000PR, Socket 939, 512KB cache, BOX 1.195,22 kn GEIL 2X512MB DDR400 DUAL RETAIL, Ultra X 1.035,49 kn Caviar 120.0 GB, WD1200JB, 9 ms, 8MB, Ultra ATA / 100 582,09 kn HIS X800 256MB PCIe, VGA X800 256MB GDDR3 (256-bit) DVITV PCI-Ex Platinum 1.666,43 kn DVD+RW / -RW NEC ND-3540ABL, Dual Layer 393,38 kn PC Case X-4, ATX, midi tow., no PS 261,32 kn Napajanje Enermax 350W ATX P4, 2x fan, kug.lež., reg.brzine, PFC, EG365AX-VE(G) 422,73 kn Xerox 17" LCD, 1280*1024@75Hz , GLS, DVI, 0.264x0.264, 300cd, 500:1, 8ms 2.048,32 kn Logitech MX518 Gaming-Grade Optical Mouse, USB / PS2 353,42 kn LOGITECH UltraX Flat Keyboard, HR raspored tipki, OEM 180,13 kn #2 mbo dfi nf4-infinity/dagf, nforce 4, ddr, zvuk, s-ata, fw, g-lan, pci-e, s. 939 868,78 KN cpu amd athlon64 3000+ box, socket 939, venice, 1800mhz, 512kb c., fsb 800mhz 1.269,82 KN 2 x ram pc-3200, 512mb, ddr, g.e.i.l., retail, ddr 400 mhz 2 x 437,07 KN hdd 80.0 gb seagate, ncq, 8mb cache, serial ata plus 512,32 KN vga pci-e xfx, geforce pcx 6800, 128mb ddr3, dvi, tv 1.688,44 KN dvd±rw nec nd-3540, 16x, black, dual layer ± recording, bulk 374,16 KN kućište coolermaster centurion 5, silver, cac t05, midi, bez ps 423,09 KN napajanje chieftec delta gps-350bb-101l, 350w, 12cm fan, atx2 309,07 KN Mon. 19" SAMSUNG, SM997MB, 30-96 kHz, 0.20 mm, DynaflatX 1.451,00 kn miš logitech lx7 cordless optical mouse, optički, bežični 284,79 KN Tipkovnica HR 90,00 kn kaj da uzmem #1 ili #2 komp mi treba za školu (AutoCad i Catia) i normalno igrice, filmove i sl. |
the luda ribetna
Postovi: 3,952
1. konfa...nativni pcie doduse neznam dal nv41 ima isto nativni(ta 6800 od xfx-a) al opet ati se pokazao dosta brzim nego nvidija(imam oba i trenutno testiram malo) |
Postovi: 8
uzet ću prvu konfiguraciju al sam malo promjenio; e sad umjesto xeroxa 17" LCD uzimam LG 19" F920B i mijenjam grafičku koju da uzmem: VGA HIS Radeon x800 IceQ II Turbo, 256Mb DDR, 256bit, PCI Express 16, TV-out ili ASUS EXTREME N6800, GeForce 6800, PCI-Ex16, 256MB DDR 256-bit DDR, DVI-I, TV-out, engine clock 350MHz, memory clock 600MHz, RAMDAC 400MHz, max resolution 2048x1536, 15-pin D-sub |
Postovi: 382
Za AutoCad i Catiu ako ćeš printat treba ti dobar printer jer također radim u tim programima a po je asusova 6800 bolji izbor za igre |
