Staro 24.09.2005., 01:08   #1
pixel
Postovi: 8
dvojba između konfiguracija
#1
DFI nF4 Ultra Infinity, S.939, dualDDR400, 8ch, G-LAN, PCIe, 1394, S-ATA, RAID
827,78 kn
AMD Athlon 64 3000PR, Socket 939, 512KB cache, BOX
1.195,22 kn
GEIL 2X512MB DDR400 DUAL RETAIL, Ultra X
1.035,49 kn
Caviar 120.0 GB, WD1200JB, 9 ms, 8MB, Ultra ATA / 100
582,09 kn
HIS X800 256MB PCIe, VGA X800 256MB GDDR3 (256-bit) DVITV PCI-Ex Platinum
1.666,43 kn
DVD+RW / -RW NEC ND-3540ABL, Dual Layer
393,38 kn
PC Case X-4, ATX, midi tow., no PS
261,32 kn
Napajanje Enermax 350W ATX P4, 2x fan, kug.lež., reg.brzine, PFC, EG365AX-VE(G)
422,73 kn
Xerox 17" LCD, 1280*1024@75Hz , GLS, DVI, 0.264x0.264, 300cd, 500:1, 8ms
2.048,32 kn
Logitech MX518 Gaming-Grade Optical Mouse, USB / PS2
353,42 kn
LOGITECH UltraX Flat Keyboard, HR raspored tipki, OEM
180,13 kn
#2
mbo dfi nf4-infinity/dagf, nforce 4, ddr, zvuk, s-ata, fw, g-lan, pci-e, s. 939
868,78 KN
cpu amd athlon64 3000+ box, socket 939, venice, 1800mhz, 512kb c., fsb 800mhz
1.269,82 KN
2 x ram pc-3200, 512mb, ddr, g.e.i.l., retail, ddr 400 mhz
2 x 437,07 KN
hdd 80.0 gb seagate, ncq, 8mb cache, serial ata plus
512,32 KN
vga pci-e xfx, geforce pcx 6800, 128mb ddr3, dvi, tv
1.688,44 KN
dvd±rw nec nd-3540, 16x, black, dual layer ± recording, bulk
374,16 KN
kućište coolermaster centurion 5, silver, cac t05, midi, bez ps
423,09 KN
napajanje chieftec delta gps-350bb-101l, 350w, 12cm fan, atx2
309,07 KN
Mon. 19" SAMSUNG, SM997MB, 30-96 kHz, 0.20 mm, DynaflatX
1.451,00 kn
miš logitech lx7 cordless optical mouse, optički, bežični
284,79 KN
Tipkovnica HR
90,00 kn
kaj da uzmem #1 ili #2
komp mi treba za školu (AutoCad i Catia) i normalno igrice, filmove i sl.
pixel je offline   Reply With Quote
Staro 24.09.2005., 04:00   #2
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
1. konfa...nativni pcie
doduse neznam dal nv41 ima isto nativni(ta 6800 od xfx-a)
al opet ati se pokazao dosta brzim nego nvidija(imam oba i trenutno testiram malo)
blup
mc_fish je offline   Reply With Quote
Staro 24.09.2005., 14:08   #3
pixel
Postovi: 8
uzet ću prvu konfiguraciju al sam malo promjenio; e sad
umjesto xeroxa 17" LCD uzimam LG 19" F920B i mijenjam grafičku
koju da uzmem:
VGA HIS Radeon x800 IceQ II Turbo, 256Mb DDR, 256bit, PCI Express 16, TV-out
ili
ASUS EXTREME N6800, GeForce 6800, PCI-Ex16, 256MB DDR 256-bit DDR, DVI-I, TV-out, engine clock 350MHz, memory clock 600MHz, RAMDAC 400MHz, max resolution 2048x1536, 15-pin D-sub
Staro 24.09.2005., 14:16   #4
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,347
ja bi hisovu.
žmnpp
Staro 24.09.2005., 14:50   #5
Komek
Komek's Avatar
Lokacija: Zagreb-Dubrava
Postovi: 505
Hisova ti je dobra + ima ti dobar cooler
Komek je offline   Reply With Quote
Staro 24.09.2005., 20:32   #6
maxtor
maxtor's Avatar
Postovi: 382
Za AutoCad i Catiu ako ćeš printat treba ti dobar printer jer također radim u tim programima a po je asusova 6800 bolji izbor za igre
maxtor je offline   Reply With Quote
