#7952 |
Datum registracije: May 2015
Postovi: 76
evo izvoliš, besplatno slaganje ti je uključeno u cijenu 5091,96 kn |
#7954 |
Postovi: 430
Evo jedna S 960 1 x AMD CPU Desktop FX-Series X8 8300 (3.3GHz,16MB,95W,AM3+) box 1 x Crucial 8GB DDR3 1600 Mhz (PC3-12800) CL11 1 x GIGABYTE GA-970A-DS3P, AM3+ 1 x Grafička Palit GeForce GTX960 2Gb Super JetStream 1 x Toshiba HDD 1TB,7200rpm, 32MB 1 x Zalman Z3, USB3.0 black, 3x120mm 1 x Enermax 500W NAXN Basic ,120mm 1 x CPU Hladnjak LC-CC-95, Intel/AMD, 90mm 4-pin Ukupno: 5254,00 kn sa besplatnim slaganjem i dostavom. |
#7955 |
Shpongle
Datum registracije: Aug 2011
Postovi: 119
Pozdrav Bi bilo ovo ok za gaming ? Ducan mora biti links, treba samo kejs ![]() ASUS STRIX AMD RADEON R9 285 G.SKILL RipjawsX series, F3-14900CL10S-8GBXL, 8 GB DDR3 1866MHz ASUS H81-Plus 1000.0 GB WESTERN DIGITAL Caviar Black Napajanje 650W, LC POWER Silent Giant GREEN POWER 80+ Bronze LC POWER 930B Silent Thunder INTEL Core i3 4330 To na kraju ispada oko 5200 kn EDIT: Limit do 5500 Preporuke ? Savjeti ? LP
#7956 |
Datum registracije: Apr 2013
Postovi: 1,336
Kingston Technology ValueRAM 8GB DDR3 Toshiba 500GB 3.5" 7.2k SATA III 32MB Intel Core i5-4440 LC-Power PRO-923B - Red Captor ASRock H81M-HDS FSP/Fortron Hyper 500 Sapphire Radeon R9 380 Nitro 4GB cca 5300..ne znam di su tražio te komponente ali očito su preskupe, do 5500 si uzmi veći disk ako ti je potreban i to je to ![]() |
#7957 | |
Shpongle
Postovi: 119
#7959 |
Shpongle
Postovi: 119
#7961 |
Datum registracije: Oct 2014
Lokacija: hercegovina
Postovi: 13
Evo kupuje se pc i trebam misljenje o konfi(jeli treba mijenjati ista i to): 2xCrucial RAM 4GB DDR3 1600 MT/s (PC3-12800) 1xGrafička kartica XFX AMD Radeon R9 280A 3GB DDR5, XFX-R9-280A-TDFD 1xFortron napajanje Hexa Plus 500W 80+,active,12 cm 1xZalman mid tower case white, ZAL-Z3 PLUS WHITE 1xAMD CPU Desktop FX-Series X8 8300 (3.3GHz,16MB,95W,AM3+) box 1xMatična ploča Gigabyte GA-970A-DS3P,AM3,A970,D3,S3,U3,A 1xLC Power CPU Hladnjak LC-CC-95 - 1xSEAGATE HDD Desktop Barracuda 7200 ST1000DM003 1xGenius HF2.1 1205 wood ili Genius zvučnici SW-5.1 1020, 26W 1xACER V236HLBd 23" LED Monitor 1xCooler Master Octane tipkovnica + miš, gaming, HR layout ukupno:6,717kn ako se trebaju ikakve izmjene raditi uvezi periferije i kucista slobodno preporucajte. Zadnje izmijenjeno od: coconut. 26.06.2015. u 19:19. |
#7962 |
Postovi: 34,075
Koliko vidim, fali SSD. Ako je konfa za igranje, a čini se da je zbog jake grafe, onda SSD nije obavezan. Za sve ostale namjene, SSD pod 'obavezno'.
#7963 |
Postovi: 13
#7964 |
Terror Absolut!
Datum registracije: May 2014
Lokacija: Earth
Postovi: 802
Ja bih to radije ovako: AMD CPU Desktop FX-Series X8 8300 CPU Hladnjak LC-CC-95 GIGABYTE GA-970A-DS3P 1x8GB Kingston DDR3 HyperX Fury, 1866MHz, Black Sapphire Radeon R9 380 Nitro 4GB Tvrdi Disk WD Caviar Blue 1TB SATA 3 Zalman R1 mid tower case XFX 550W Pro, 80+ Bronze ~5600kn Za periferiju: Tipkovnica + miš GAMDIAS Ares Essential bundle - isprobao oboje; zaključak: odličan kombo za ~300kn AOC LED23" I2369Vm monitor - 23'' FHD IPS, dobar panel i integrirani zvučnici (nisu cvijeće ali mogu nekad poslužiti), 3 godine garancija ~ 1250kn Ako ti je sve ovo puno $ onda možeš ići na jeftinije napajanje u klasi Fortron Hypera 600 ili 500W, manji HDD ili Z3+ kućište ako ti je u određenom dućanu jeftinije od R1 pošto su zapravo vrlo slična kučišta, osim estetski. Ostalo ne bih dirao. |
#7965 |
Postovi: 13
Ustao BiH na acer v236hlbd i uzeo BiH zvučnike 2.1(može preporuka). Po čemu je bolja gamdias od octane-a? Kućište mi je malo skupo, isao BiH do 5300kn max. A ta 380 nije dostupna u trgovini gdje BiH uzimao, jeli igdje uopce u ZG dostupna? Zadnje izmijenjeno od: coconut. 27.06.2015. u 18:09. |
#7966 |
Postovi: 76
dobro ti je to šta si složio, bolje nemoraš niti nemožeš složit za te novce, samo bi ja ubacio ove zvučnike Logitech Z313 , ja ih imam doma i mogu ti potvrditi da su odlični, sigurno bolji i kvalitetniji od geniusa Zadnje izmijenjeno od: coconut. 27.06.2015. u 18:09. |
#7967 |
Postovi: 13
Hvala, uzimam te logitech zvuc. Valjda cu biti zadovoljan Zadnje izmijenjeno od: coconut. 27.06.2015. u 18:09. |
#7968 |
Terror Absolut!
Lokacija: Earth
Postovi: 802
Za Gamdias znam iz prve ruke da je odlican bundle za te novce, za Octane nisam siguran. Taj monitor i zvucnici ce isto biti ok, uzmi Z3+ ako ti je R1 preskup, a za R9 380 pricekaj jos koji dan, tek su nedavno predstavljene. I obavezno uzmi verziju s 4GB VRAM-a. |
#7969 |
Datum registracije: Jun 2015
Postovi: 7
Pozdrav, Trebala bi mi konfiguracija do 5k kuna. Monitor - Imam Ostala periferija - imam Hard - imam ssd + 2tb hd Ostalo - nemam Moze pomoc? Hvala |
#7971 | |
Postovi: 13
Z3+ sam i mislio uzeti jer mi je r1 prejednostavan. R9 3xx dolaze slijedeće vikend tako da cu sacekati do tada. Zar mi je bas potrebna ta 4gb verzija igrat cu na jednom monitoru 1080p. Kada stavim r9 380 4gb u konfu onda mi je previše preko budzeta, bili izgubio FPS ako stavim fx 6300? |
#7973 |
Datum registracije: Mar 2015
Postovi: 1,254
Sigmund Malo se protegni, zbog r9 290 koja je dosta jaca od jeftinijih gtx 960 i r9 280. 1 x MSI Radeon R9 290 GAMING 4GB, 512Bit DDR5 1 x AMD CPU Desktop FX-Series X8 8300 (3.3GHz,16MB,95W,AM3+) box 1 x GIGABYTE GA-970A-DS3P, AM3+ 1 x CPU Hladnjak LC-CC-95, Intel/AMD, 90mm 4-pin 1 x Fortron Hyper 600W, 80+ 1 x Zalman Z3, USB3.0 black, 3x120mm Ukupno: 5224,00 kn, besplatna dostava! RAM mora biti DDR3 |
#7974 | |
Postovi: 76
#7975 | |
Postovi: 7
Hvala P.S. Ovo mogu uzeti... gdje? |
#7976 | |
Terror Absolut!
Lokacija: Earth
Postovi: 802
2GB VRAMA na grafičkoj je za FHD rezolucije postalo premalo ukoliko želiš vrtiti nove igre na najvišim postavkama. Topla preporuka je da ostaneš na FX8300, ali ako je hitno onda može i FX6300. Ta matična je okej, AM3 socket je uskoro mrtav pa ne će imati smisle neke nadogradnje u vidu novijih procesora, ali na toj ploči FX8300 možeš i blago clockati pa će biti u redu. |
#7977 | |
Postovi: 13
Ostat cu na z3+ . Još se premisljam oko r9 280 3gb i r9 380 4gb, po benchmarcima 380-ka je 2/5 fpsa bolja i zato pljunuti 250kn neznam bas, a i ovako sam jedva ugurao 280-ku. |
#7978 |
Postovi: 76
ma uzmi onda r9 280, premala je razlika u snazi između te dvije, sad davat 300 kuna više za r9 380 4gb (sigurno ce još malo dignut cijenu kad bude postala dostupna), mislim da se ne isplati |
