Staro 19.06.2015., 09:38   #811
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,211
zašto bih onda uopće kupovao winse kad mi ostane RTM sa apdejtima?
Staro 19.06.2015., 11:54   #812
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,031
Zato jer trebaš novi key da ti Winsi budu aktivirani
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Staro 20.06.2015., 14:18   #813
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,031
Op op op:
http://blogs.windows.com/bloggingwin...review-builds/
As long as you are running an Insider Preview build and connected with the MSA you used to register, you will receive the Windows 10 final release build and remain activated. Once you have successfully installed this build and activated, you will also be able to clean install on that PC from final media if you want to start over fresh.
Znači svi Windows Insideri dobivaju Windows 10 for free!
EDIT: Objašnjenje kako to funkcionira:
https://twitter.com/GabeAul/status/611976060863787009
Znači, Insideri trebaju imati Insider build (trenutno je to 10130), spojiti ga sa MSA (Microsoft Accountom), updejtati na RTM i to je to.
EDIT2: Evo i WinBeta piše o tome:
http://www.winbeta.org/news/windows-...medium=twitter
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
Zadnje izmijenjeno od: Mario92. 20.06.2015. u 14:27.
Staro 20.06.2015., 14:20   #814
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,543
Jebeno sad imam 2 originalne licence, odlicnjak
Staro 20.06.2015., 15:41   #815
Neo-ST
Buying Bitcoin
Neo-ST's Avatar
Postovi: 8,251
Koje, home?
Staro 20.06.2015., 16:04   #816
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,031
Da si kliknuo na link vidio bi:
Windows Insiders running the Windows 10 Insider Preview (Home and Pro editions)
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
Staro 20.06.2015., 17:35   #817
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,543
Imam obje pro. Jednu kao upgr sa win 8.1 originalnu i jednu cu dobiti kao insider
Staro 21.06.2015., 19:19   #818
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,211
Microsoft says Windows 10 is only free as an upgrade from Windows 7 or 8.1
http://venturebeat.com/2015/06/20/mi...f-you-test-it/
“It’s important to note that only people running Genuine Windows 7 or Windows 8.1 can upgrade to Windows 10 as part of the free upgrade offer.”
šta sad onda
Staro 21.06.2015., 19:34   #819
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,543
Meni na lenovo l540 na buildu 10130 svaki put updejtovi zapnu na 72%, vec sam popizdio...
Staro 22.06.2015., 09:17   #820
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,235
Autor Mario92 Pregled postova
Op op op:
Citam sada o ovome posvuda...cak i na 24 sata...nista, sljedi insider registracija, preview 10130 se vec skida
Naravno ove winse koje imam cu fino backupirat, da nebi bilo ''nismo znali''
Jel se moze s tim Winsima napravit clean install ili je to iskljucivo nadogradnja vec postojecih (taj build 10130)?
I znaci, kada jednom dobijem kljuc (ili kad se aktivira RTM/ ne kuzim to bas), mogu i reinstalirat Win10 i to ce opet biti legalno?
EDIT: Regao se, sluzbeno sam insider I dalje me zanimaju ova pitanja gore
EDIT 2: OK, moze clean install, sa wintoflash cu napravit USB stick za fresh instalaciju. Dakle, samo me jos zanima, ako mi se skrse prozori hocu li ih moc opet legalno instalirat na komp?
Evo linka gdje je objasnjeno sto i kako : http://www.forbes.com/sites/antonyle...-for-everyone/
Slobodno me dodajte na PSN
Zadnje izmijenjeno od: Disco. 22.06.2015. u 09:33.
Staro 22.06.2015., 11:05   #821
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,543
Dakle ovaj build 10147 je smece nevideno .Ako prilikom instalacije svoj L540 spojim na net kad mi nudi (nebitno lan ili wifi) , instalacija stane na kraju i ostane na "just a moment" i onaj lrug se vrti beskonacno. Ako pak ne spojim na net, uredno udjem u winse pod local accountom i kasnije se ulogiram sa svojim inisder accom, onda mi nonstop izbacuje get insider build builds needs attention sto sam nasao na netu da znaci da mi nije prepoznao microsoft account. Taskbar i dalje steka, prvih 5 mij nemogu otvoriti notification, search ne radi, svako malo se smrzne i jedino ga mogu ubit na tipku. Nazad na 7icu dok ne izadje rtm.
Staro 22.06.2015., 12:28   #822
catroot
catroot's Avatar
Datum registracije: Apr 2009
Lokacija: I live in 43 05'04.11"N 17 57'36.71"E
Postovi: 881
Šta misliš da će bolje radit kad izađe rtm?
catroot je offline   Reply With Quote
Staro 22.06.2015., 12:47   #823
sibica
sibica's Avatar
Lokacija: Croatia/Crikvenica
Postovi: 499
Dečki, što da ja napravim? Imam legalne win 8.1, ali enterprise edition koji se navodno neće moći upgreadati na win 10. Da li bi ipak mogao napraviti update na win10 ako sam u insider programu?..Ili mi je bolja varijanta instalirati piratske win7 pa pomoću insider programa napraviti update na win10?
sibica je offline   Reply With Quote
Staro 22.06.2015., 13:03   #824
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,235
Kako da maknem Login screen? Zelim da kad upalim komp, da mi odmah ode na desktop, a ne da me pita PIN i slicne gluposti?
Staro 22.06.2015., 13:16   #825
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,211
Autor Disco Pregled postova
otvoriš dolje lijevo start i kreni odmah pisat netplwiz, pa stisni enter i za svoj acc gore makni kvačicu ''user must enter username bla bla..''
Staro 22.06.2015., 13:27   #826
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,211
Autor sibica Pregled postova
http://www.bug.hr/vijesti/windows-in...wi/144127.aspx
znači ništa od free windowsa za nas ilegalce insidere na kraju, baš trakavica oko toga jebo ih
Staro 22.06.2015., 13:30   #827
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,543
Autor catroot Pregled postova
Hoce, i 7 i 8.1 je bio drek (al ne toliki) dok nije izazao rtm , tako da vjerujem da ce i s 10kom bit isti slucaj.
Staro 22.06.2015., 13:32   #828
catroot
catroot's Avatar
Postovi: 881
Jel tko dobiva ovaj errorhttps://www.google.co.uk/search?q=ex...ml%3B485%3B197 kad resetira ili gasi win 10.
Staro 22.06.2015., 13:34   #829
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,543
Dap, ja dobijao na 10130,i to je common bug za taj build koji je jos vece smece posto na njemu ne radi windows update i zapne na 72% uz nestabilan start task bar i notificarion bar. To sa explorerom je rjeseno u 10147 al on ima gore navedenih problema.
Staro 22.06.2015., 13:35   #830
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,211
Staro 22.06.2015., 13:35   #831
catroot
catroot's Avatar
Postovi: 881
Da zaboravi reci baš na 10130.
Staro 22.06.2015., 13:38   #832
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,543
Cekamo iduci build...
Staro 22.06.2015., 14:13   #833
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,235
Ja vec vracam win7 koje sam na svu srecu klonirao prije ovoga.
Staro 22.06.2015., 22:09   #834
nathan.fake
Lokacija: n/a
Postovi: 1,258
Upcoming changes to Windows 10 Insider Preview builds [UPDATED 6/22]
Gabe Aul je nadopunio sluzbeni blog post od nekidan, kako bi rascistio nedoumice u vezi Windows Insidera i "besplatnih" Windowsa 10 RTM.
Post je malo duzi, al se svodi na 2 opcije:
1. nakon 29.07. mozes: nastavit bit u Insider programu te ces i dalje dobivat testne buildove (mozes birat fast ili slow ring). Svaki testni build ima rok trajanja, ali prije njegovog isteka ce doc novi build... tako da ces prakticki imat Windowse 10 zauvijek... besplatno.
2. nakon 29.07. mozes: odjavit se iz Insider programa, u tom slucaju vrijede pravila kao i za sve ostale korisnike. Ako imas Genuine Windows 7 or Windows 8.1 dobit ces Windows 10.
Zadnje izmijenjeno od: nathan.fake. 22.06.2015. u 22:19.
nathan.fake je offline   Reply With Quote
Staro 23.06.2015., 11:10   #835
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,235
Dali dobivam Win10 ako imam OEM licencu za Win7 Pro?
Dali se OEM verzija veze za moju trenutnu maticnu plocu (cuo sam tako, ali mi to bas nema smisla)? Tj da budem precizniji, licenca je OEM sa brandiranog racunala (a nije iskoristena na tom racunalu nego na mojem).
I dali je moguce reinstalirat te Win na isti komp ako se skrse s vremenom?
Fala!
Staro 23.06.2015., 15:06   #836
Romano.Cule
Outer Space
Romano.Cule's Avatar
Lokacija: Vinkovci
Postovi: 833
When I upgrade a preinstalled (OEM) or retail version of Windows 7 or Windows 8/8.1 license to Windows 10, does that license remain OEM or become a retail license?
If you upgrade from a OEM or retail version of Windows 7 or Windows 8/8.1 to the free Windows 10 upgrade this summer, the license is consumed into it. Because the free upgrade is derived from the base qualifying license, Windows 10 will carry that licensing too.
If you upgrade from a retail version, it carries the rights of a retail version.
If you upgrade from a OEM version, it carries the rights of a OEM version.
Full version (Retail):
- Includes transfer rights to another computer.
- Doesn't require a previous qualifying version of Windows.
- Expensive
Upgrade version (Retail):
- require a previous qualifying version of Windows.
- Expensive, but cheaper than full version
OEM :
OEM versions of Windows are identical to Full License Retail versions except for the following:
- OEM versions do not offer any free Microsoft direct support from Microsoft support personnel
- OEM licenses are tied to the very first computer you install and activate it on
- OEM versions allow all hardware upgrades except for an upgrade to a different model motherboard
- OEM versions cannot be used to directly upgrade from an older Windows operating system
What happens if I change my motherboard?
As it pertains to the OEM licenses this will invalidate the Windows 10 upgrade license because it will no longer have a previous base qualifying license which is required for the free upgrade. You will then have to purchase a full retail Windows 10 license. If the base qualifying license (Windows 7 or Windows 8.1) was a full retail version, then yes, you can transfer it.
Staro 23.06.2015., 18:25   #837
sibica
sibica's Avatar
Postovi: 499
Instalirao sam win10.Pise mi kako su win aktivirani,ali mi na desktopu pise kako su evaluated copy.Sto je onda tocno?
Staro 23.06.2015., 18:44   #838
nino
nino's Avatar
Postovi: 12,599
Oboje 😂
Staro 23.06.2015., 18:53   #839
sibica
sibica's Avatar
Postovi: 499
U prijevodu...Jesam li sada dobio pravo na win10 kad budu izašli?
Staro 23.06.2015., 19:10   #840
SaleFFS
Varilnik
SaleFFS's Avatar
Postovi: 1,648
Romano.Cule
Ne znam baš za ovo ako matičnu mjenjaš da ne možeš ponovno reaktivirati. Neki dan sam mijenjao u firmi na svom kompu (Win8.1 Pro OEM) ploču, proc i rame. Naravno dekativiralo je, ali sam preko tel službe (automat) ukucavao onih 9 polja od onoga ID keya i sve se ponovno reaktiviralo bez problema.
Možda to neće vrijediti na Win10 ili?
