Staro 03.06.2015., 08:45   #15121
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,141
Autor panoramix Pregled postova
Ha, sve ovisi kak' se voziš. Na tjednoj bazi radim 120 km do vikse i natrag. Motor sa 150tkm 1.6 VVTI benzinac po bord kompu 5 do 5,2 l/100.
Vožnja manje više po ograničenju magistralnom cestom s udjelom 20 km autoceste. Sad kad krene paljenje klime bit' će malo više.
Eto nam novog "moj TDI troši 3 litre" slučaja
Da se 60 voziš nizbrdo u leru u oba smjera, možda bi i došao do tih brojki Board comp laže, i to ne malo, najmanje 2 litre ti skida.
Za 1.6 VVTi fino piše 5.9 za extra urban, 9 urban i 7.9 combined. Pošto to možeš postići samo u dolje navedenim uvjetima...nema ti tu 5 litri potrošnje pa da se na trepavice postaviš.
Urban Cycle
The urban test cycle is carried out in a laboratory at an ambient temperature of 20C to 30C on a rolling road from a cold start, i.e. the engine has not run for several hours. The cycle consists of a series of accelerations, steady speeds, decelerating and idling. Maximum speed is 31mph (50km/h), average speed 12mph (19km/h) and the distance covered is 2.5 miles (4km).
Extra-Urban Cycle
This cycle is conducted immediately following the urban cycle and consists of roughly half steady-speed driving and the remainder accelerations, decelerations, and some idling. Maximum speed is 75mph (120km/h), average speed is 39mph (63 km/h) and the distance covered is 4.3miles (7km).
Combined Fuel Consumption Figure
The combined figure presented is for the urban and extra-urban cycle together. It is therefore an average of the two parts of the test, weighted by the distances covered in each part.
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
OS: Windows 10 Pro x64
Staro 03.06.2015., 09:30   #15122
mislav_os
freak
Postovi: 2,688
Koliko sam skuzio panoramix je i rekao da mu je to potrosnja na otvorenoj cesti do vikse.
Staro 03.06.2015., 09:39   #15123
D1viry
D1viry's Avatar
Lokacija: Slavonija
Postovi: 2,066
Opet dizel/benzin rasprava? Pa pročitajte si par stranica unazad i gotovo. Zašto ponovno u istu raspravu po tko zna koji put?
Pošten trgovac: 1,2,3,4,5,6
Staro 03.06.2015., 10:24   #15124
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,347
Jbg fatal nes pitao i eto kaj se desi
Edit: ivan, za moj 1.4 vvti pise gradska 8.7, toliko mi je trosio jedino kad je bilo jako hladno, inace se potrosnja vrti 7.5-8, mjereno svaki put na cep
žmnpp
Zadnje izmijenjeno od: buljo. 03.06.2015. u 11:00.
Staro 03.06.2015., 12:49   #15125
jed2i
jed2i's Avatar
Datum registracije: Jul 2004
Postovi: 1,771
Dečki jel itko od vas vozio volvo s60 ili v60 d3 geartronic?
Staro 03.06.2015., 13:15   #15126
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Ja D4 V40 Geartronic ako ti išta pomaže
Matth€w je offline   Reply With Quote
Staro 03.06.2015., 14:10   #15127
jed2i
jed2i's Avatar
Postovi: 1,771
181 ks + 8 brzina?
Ovo kaj ja gledam je 163ks i 6 brzina.
Staro 03.06.2015., 15:04   #15128
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Da, taj, odličan je.
Staro 03.06.2015., 16:16   #15129
Roberto
Roberto's Avatar
Postovi: 2,653
Autor 1v@n Pregled postova
A sad ga bome i ti Ivane pretjeruješ
Ne podnosim tu ekipu koja tvrdi da tdi vozila maltene proizvode gorivo u vožnji, ali može se potrošnja autu drastično spustiti, drugo je pitanje koliko je takav način vožnje dugoročno dobar za auto...
Itekako se može do tih brojki koje panoramix spominje. Ovisi naravno do auta, do vozača i do uvjeta vožnje.
Ali evo moj buraz s benzincem pugom 206 već godinama ima potrošnju manju od deklarirane postavio se ti na trepavice ili ne
I to ne mjereno board computerom jer ga to govno ni nema, nego praćenjem i računanjem potrošnje, i tako već godinama.
Jednostavno, buraz vozi 98% kilometara na otvorenoj cesti, uglavnom duže relacije, vozi ko penzić
I ja svog dizelaša od 1.4 tone mogu spustiti ispod 4,5 litre na otvorenoj cesti, štoviše, iz zajebancije sam jednom vozio 70 u petoj na stotinjak km otvorene ceste i dobio potrošnju od 3,7 litri. Naravno da tak ne vozim i ne pada mi na pamet, ali da se može - može se i tak vozit. Jedino je pitanje koliko dugo
A što se tiče kvarova na dizelašu, nije sad da će ti krepat sve, i fap i turbina i dvomaseni i pumpa i injektori i ne znam kaj sve ne. Druga stvar je pak i to da se na dizelašima maltene sve to da reparirat i vozit s tim još ohohoho kilometara.
Ako još dodamo u jednadžbu i veći broj kilometara stvari se još više mijenjaju. Meni dizelaš u odnosu na benzinca iste klase i snage uzme 1000 eura manje na gorivu godišnje. A to pokrije dosta eventualnih dizel kvarova
Staro 03.06.2015., 18:01   #15130
Šole
Šole's Avatar
Datum registracije: Aug 2009
Lokacija: Zürich
Postovi: 710
Dečki što je ovo.
Šole je offline   Reply With Quote
Staro 03.06.2015., 18:04   #15131
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,347
Old skul kabriJo
žmnpp
Staro 03.06.2015., 19:10   #15132
Burko
Osobni opis - pitaj me
Burko's Avatar
Postovi: 2,317
Autor buljo Pregled postova
Old skul kabriJo
ispravak, ako dopustas.....
naopacke ajrodinamicki Old skul kabriJo u obliku mrtvackog kovcega
Staro 03.06.2015., 20:21   #15133
panoramix
driver
panoramix's Avatar
Postovi: 1,083
A kaj si se sad ti dignul na zadnje noge. Pa znam da griješi al' sigurno ne 2 litre ; kojeg bi onda smisla imala ugradnja istoga u vozila ?
Da si pažjivo čital zadnji dio mog posta sve bi ti bilo jasno.
Uostalom, 5,9 extra urban nije podatak o najmanjoj mogućoj već o prosječnoj potrošnji.
Staro 03.06.2015., 23:08   #15134
Fatal
kenova?
Lokacija: Čilipi
Postovi: 573
Autor Roberto Pregled postova
pa u kojoj inace vozis na 70? ja sam kangoom 1.4 benzin vozim u petoj prakticki od 60 nadalje... u biti uvijek gledam vozit na manjim okretajima , normalno pazim da se ne muci niti da se ne vuce auto...sad cete mi rec da se tako ne vozi auto?
Fatal je offline   Reply With Quote
Staro 03.06.2015., 23:56   #15135
Roberto
Roberto's Avatar
Postovi: 2,653
Autor Fatal Pregled postova
70 se najbolje vozi u trecoj
Ne znam za kangoo ali u mom focusu je u petoj pri 70kmph ispod 1500 rpm i motor mi se ne cini previse sretan tak. Pogotovo ne bi bilo dobro tak ga stalno vozit.
Staro 03.06.2015., 23:58   #15136
t3chno b0y
Postovi: 246
Ja 70 vozim u 4.oj jedino nizbrdo u 5. pri toj brzini, 93ks 1000kg auto.
t3chno b0y je offline   Reply With Quote
Staro 04.06.2015., 00:03   #15137
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,141
Pustite board comp, svi lažu, čak i moj koji napiše koliko sam goriva potrošio.
Fino zapiši broj km kad natočiš, zapiši koliko natočiš i tako najmanje 5 puta. Nakon 2 točenja već možeš dobiti prave podatke.
(Utočene litre x 100) / prijeđeni kilometri.
Meni proizvođač kaže: urban - 4.3, extra urban - 3.2, combined- 3.6
Radi se o 1.5 dci sa 75 ks.
Kako god vozio, najniže sam se spustio na 3.9, ali 99% vremena je to 5.5 - 5.7
Pratim kod svakog točenja. Kad uključim eco mod, potrošnja mi čak i poraste za litru.
Pa nedavno je i bilo istraživanje o tome koliko proizvođači "lažu" i prosjek je negdje oko 2 litre.
LCD: BENQ PD3200Q
Staro 04.06.2015., 00:12   #15138
Mejzlik
tha pilot
Mejzlik's Avatar
Postovi: 649
Toyota Aygo 1.0 vvt-i, automatic (5 brzina), gradska voznja prosjek 6l, ako ga bas lagano vozim, onda 5,5l. Auto ima ispod tone, gume 155, sam se vozim.
Mejzlik je offline   Reply With Quote
Staro 04.06.2015., 00:21   #15139
Dottore
Dottore's Avatar
Postovi: 7,703
Autor syss Pregled postova
pa pregazio je kada ti idu troškovi redom:
- dpf filter po 2k€
- boš pumpa po soma
- turbina po 1-2soma
- injektor komad to 300-400
jako brzo se istopi razlika ako ideš na rabljenog kojeg ne znaš kako je netko vozio...a i da si ti prvi vlasnik nekog euro 6 dizelaša, trebaš se dobrano bojati našeg benzina.
Di to vidiš DPF filter?? Frend u ovlaštenom zamjenio 600 eura. Das is Auto!
Moj krumpirowagen išao 1580km full tanka i ostalo mu još 2 dana. Relacija Zagreb - Mostar - Dubrovnik - Zagreb. Brzina po autoputu 130-150
Koliko općepoznato, svi lažu brojkama potrošnje na papiru.
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 04.06.2015., 00:23   #15140
fanATIk
NITKOV
fanATIk's Avatar
Lokacija: Maksimir / Dugave
Postovi: 4,016
Ne znam u kojem to autu bc laže za dvije litre. Meni ako odstupi koji deci eventualno. Provjeravano na točenju. No nebitno.
Gledam neki dan, gledam ih i danas. Odvojak sa Slavonske - petlja iznad Držićeve prema Folnegovićevom. Murija s laserom, ograničenje 40. Mislim, neki idiot nekad davno tu je stavio to ograničenje i šupci (fakat nemam ništa protiv murije inače, dapače cijenim ljude i posao koji rade al ovo su fakat šupci) stali na vrhu petlje i okidaju laserom. Ne znam ko tamo vozi 40 i zašto bi uopće bilo ograničenje 40, al oni se nasrali gore i pune državni proračun. Pa pizda vam materina, stani se kod škole i mjeri brzinu, kažnjavaj debile kaj voze po pruzi, ima sto stvari koje fakat treba kažnjavat, al ovo je ono, baš dno dna. Igrom slučaja prekjučer je bilo par auta ispred mene, a danas mi vrag nije dao mira pa sam usporio sva sreća. Baš jadno.
some_text
Asrock FM2A78M-DG3+
G.SKILL RipjawsX series 8 GB
Palit GTX 460
Corsair VS550
Thermaltake Core V21
22"LCD LG W2242T
MX Revolution
Logitech X-230
Logitech K740
Canon CanoScan 4400F
Win 10
Unique case by fanATIk
Avatar BIG SIZE
Staro 04.06.2015., 00:26   #15141
Dottore
Dottore's Avatar
Postovi: 7,703
Otkad murija gore??? 3 puta tjedno prolazim gore prema Utrine
Imaš i onih koje voze punu crtu. Tu ima grešaka na mostu.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 04.06.2015., 00:28   #15142
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,141
Autor fanATIk Pregled postova
Pogledaj aute proizvedene 90-ih i s početka 2000-tih gdje čovjek ni sam ne zna na kojem se principu ta potrošnja računa.
Kod starog na Citroenu iz 2001. pokazuje uredno litru manje od prave prosječne potrošnje.
LCD: BENQ PD3200Q
Staro 04.06.2015., 00:33   #15143
Roberto
Roberto's Avatar
Postovi: 2,653
Ne lazu svi board computeri 2litre, ni izbliza. Ja stalno tankiram puni tank i u zadnjih godinu i pol kolko si to pisem, odstupanja su do max 0,3, rijetko vise. I to board pokazuje 0,3 vise od stvarne potrosnje.
Staro 04.06.2015., 01:04   #15144
X-Plosiv
X-Plosiv's Avatar
Postovi: 1,811
I meni je 2x kada sam mjerio odstupao tako nešto.
Staro 04.06.2015., 01:05   #15145
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Meni BC laže i po litru... Al dobro, vozim toliko random da mi je jasno di fulava.
Ovo za nadvožnjak 40 je malo premalo, ali gore kad krene zavoj u lijevo, malo je jači nego što se prvo čini. A i nekad bude sklisko. Ne bi bilo lijepo izletit u slobodan pad.
Staro 04.06.2015., 01:07   #15146
MAGARAC
MAGARAC's Avatar
Postovi: 5,995
Autor Dottore Pregled postova
Vidim ih s prozora. Ima vec mjesec dana i vise da su skoro svako popodne gore. Ispod ih isto ima kad se penje s Drziceve prema zapadu.
Meni su oba BCa blizu stvarne potrosnje. Mislim da sam najvise izracunal 0.3l manjka.
Staro 04.06.2015., 11:04   #15147
fanATIk
NITKOV
fanATIk's Avatar
Postovi: 4,016
Ja isto 3-4 puta tjedno, furam malog na vaterpolo na bazen u Utrinama.
I čem služi ona lijeva traka po kojoj ne smiješ vozit? Al nek su se oni napenalili na vrhu i ubiru vrhnje. To što se to ladno može proć sa 80 kmh im je nebitno. Baš su mi digli tlak.
Asrock FM2A78M-DG3+
Palit GTX 460
Corsair VS550
22"LCD LG W2242T
MX Revolution
Logitech X-230
Logitech K740
Win 10
Avatar BIG SIZE
Staro 04.06.2015., 11:39   #15148
Apacer ft Bozja
Baja!
Apacer ft Bozja's Avatar
Lokacija: Sisak
Postovi: 761
Kod mene suprotan slučaj. Ja sam negdje godinu dana zapisivao koliko tankam, predjem i board computer je rekao 8,3 a ja sam izracunao 8,6.
Ja sam bio lud, zaljubljen i mlad.
Apacer ft Bozja je offline   Reply With Quote
Staro 04.06.2015., 11:54   #15149
blackened
blackened's Avatar
Lokacija: Beli Manastir
Postovi: 1,281
- dpf filter po 2k€
- boš pumpa po soma
Treba mi malo gradsko vozilo koje ne košta puno i troši naravno malo, poznanik mi prodaje Clio 1.5 dci 2004 godište za 2100 eura, 200 iljadarki okrenuo. Na njemu promijenio turbinu, pumpu, sve dizne, egr ventil. Pošto nikad nisam bio na dizelu kontam da je to u biti i najbitnije što se tiče većih stvari ako se ne varam?
Staro 04.06.2015., 12:08   #15150
murina
murina's Avatar
Postovi: 495
Snimaju i Slavonsku od gore
