#394 |
Datum registracije: Nov 2014
Postovi: 1,972
Zakljucak izveden iz ovih slajdera sto su kruzili zadnjih mjesec dana. Ne mora bit tocan naravno,ja osobno ocekujem i jos bolje performanse. EDIT: Uzeti sa kamionom soli ali ako je istina: LINK Manuel,bice 20+% ![]() |
#398 |
Postovi: 14,584
Dajte ljudi koji vam je. I prema najoptimističnijim starim neslužbenim najavama (prva stranica) je preko 10% slabija od R9 295x2 . Bit će nešto u rangu titan x-a, u najboljem slučaju mrvicu jača. Već bi samim time postala najjača single gpu ikad |
#400 |
Lynnfield
Datum registracije: Sep 2012
Postovi: 1,023
gigabyte r9 380 G1 leaks,ima 4gb gddr5 |
#405 |
Postovi: 1,972
Malo novih vijesti: http://www.tweaktown.com/news/45602/...ard/index.html World exclusive: Up until this point, most people have presumed that AMD would be launching the Radeon R9 390X as its upcoming flagship video card, but we have just had an anonymous source tell us that this is wrong. nstead, the Radeon R9 Fury X will be the flagship video card, a watercooled part based on the Fiji XT GPU. Under that, we'll have the Radeon R9 Fury, which should be based on the Fiji PRO architecture, with an entire restack of current cards. Under these two new High Bandwidth Memory-powered video cards we'll have the Radeon R9 390X, Radeon R9 390, Radeon R9 390, R9 380, R7 370 and R7 360. EDIT: The Radeon R9 Fury X has a rumored MSRP of $849, making it $200 more than the NVIDIA GeForce GTX 980 Ti, but $150 cheaper than the Titan X Znaci imacemo Fury X i Fury. Zadnje izmijenjeno od: Hawker. 02.06.2015. u 13:18. |
#408 |
PREMIUM
Datum registracije: Dec 2014
Postovi: 2,144
Kruške i jabuke. Tu negdje ne može bit nikako ako ima 8gb manje od titana, a onaj tko kupuje titana valjda i koristi tu memoriju. Prije da će bit konkurent 980ti. A nadam se da će imat i opciju s više memorije jer je i ti već na 6gb. |
#409 |
Postovi: 1,972
#411 | |
Postovi: 1,972
Ako je to istina onda ce Fury X otpuhati sve sto nvidia ima. Realnije je ocekivati 4GB. |
#413 |
Postovi: 753
Ova Gigabajtica 2x mi se bas svida, bas bi mi se dobro uklopila u build, spram ove saphirke koja je bljakic :P Bas krecem sparat neku lovicu, nadam se da ce bit cijenovno prihvatljive, ali me muci, dal opet ic na 390, jer npr. u 290 seriji se vise isplatilo ic na 290, jer na kraju dana kada ju clocknes jaca je od 290x jer se tamo rjetko koja da clockat iznad 1100. P.S. Makar se iskreno nadam da ce bit tak da usparam koju kunu :P EDIT: Jooj sada bolje gledam opet su stavili da svjetli samo plavo windforce, zakaj tu ne stave rgb ledicu ... |
#414 | |
Postovi: 14,584
Također poprilično sam siguran da će trošiti više od titan X (jer je spominjana potrošnja do 300w) Zadnje izmijenjeno od: Manuel Calavera. 02.06.2015. u 14:53. |
#415 | |
Džabe si krečio!
Postovi: 5,190
![]() Samo što ću morat prodat ovu svoju i bubreg da ga zbavim očito ![]() |
#416 |
Datum registracije: Nov 2010
Lokacija: Dubrovnik
Postovi: 509
http://wccftech.com/amd-radeon-r9-fu...er-gtx-980-ti/ The interesting news is however that in its current state – the Radeon R9 Fury X GPU does not beat the GTX 980 Ti in terms of gaming performance. Do note however, that this is a prototype product and AMD is still working on improving the card. |
#418 |
Outer Space
Lokacija: Vinkovci
Postovi: 833
A za cega bi drugo trebalo koristiti ?! Da je tako onda bi tu karticu kupilo 10 ljudi,a gejmeri bi koristili 7970. A iskreno muka mi je vise od AMD-a i njihovih usranih drajvera i podrske. Ova 290x sto imam je zadnja karica od njih.Slijedeca stanica zeleni židovi. |
#420 | |
Postovi: 1,972
A jos kad neko kaze da mu 290x nije dovoljno dobra. ![]() Pitam se za sto to. A izjavu za sto bi se trebale te kartice koristit osim za gejming necu uopce komentirat. ![]() |
