Staro 21.09.2005., 03:55   #1
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
modding kucista
evo par slika da vidite unutrasnjost kucista i sta jos da sredim.... kablovi me jaaaaako zivciraju
[img=http://img291.imageshack.us/img291/7319/picture0104lv.th.jpg border=0] [img=http://img291.imageshack.us/img291/2394/picture0113be.th.jpg border=0]
bdw ova na slikama prasina je ociscena...to je bilo ostalo prasine nakon tjedan dana igranja u teskim uvjetima na lanu( citaj 6 kompova u jednoj sobi 4 x 4 m i bez ventilacije) I na slikama vale jedni rami...posuđeno bilo frendu da mu ne steka na lan-ub
AMD Phenom 9850be 2,5ghz@2,9ghz@OCZ Vendetta 2 700rpm
DFI Lan Party JR 790GX-M2RS
OCZ Blade 2x2Gb ddrII@1066mhz@1.8v
Gigabyte HD4850 1GB Multi Core @passive
Auzentech Meridian@Opamp LM4562NA
2xWestern Digital 6400aaks@RAID 1 + Seagate S-ATA 160gb@XXX
Tagan 480W Supersilent
Thermaltake V1000+ black with side window
Logitech MX500
DELL 2007FP
AMD Athlon 3000+(venice e3) stock
Abit AV8
Kingmax Superram 2x256ddr433 FHAS stock
Gainward 7600GT GS 256mb
Seagate Barracuda 80gb P-ata
Denon AVR-3805 black finish @DIY 3.5mm > 2RCA(Neutrik RCA plugs)
Focal Jmlab Chorus S 726s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S CC700s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S SW700 classic finish@Bandridge Profigold Subwoofer Cable
Review Chorus S serije
Review Denon AVR-3805
micek_kc je offline   Reply With Quote
Staro 21.09.2005., 09:50   #2
Darth Vader
Dark side Moderator
Darth Vader's Avatar
Postovi: 1,633
e to se zove prašina u kompu!
Jak ko rakija!
Darth Vader je offline   Reply With Quote
Staro 21.09.2005., 10:22   #3
GoGzS
GoGzS's Avatar
Lokacija: Novi Zagreb
Postovi: 979
Meni je malo to much crvene boje i ventilatora inače, uzmeš si slevning kit (ili kako se već piše) u maxmodusu za 50-ak kn (ima i u crvenoj boji ) i omotaš kablove
GoGzS je online   Reply With Quote
Staro 21.09.2005., 12:58   #4
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,343
uzmi slevning kit kaj je GoGzS napisao i obavezno očisti kučište.
mogo bi zamjenit onu zujalicu na matičnoj sa nekim pasivnjakom.
e da i probaj kablove stavit tako da ti idu sa stražnje stranje kučišta, manje će se vidjet i bit će bolji propuh.
žmnpp
Staro 21.09.2005., 13:01   #5
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
pa nije ventovi previse....vidi ovo pa budes mjenjao misljenje
Proc 30- 44 C
Maticna 17-24 C
Graficka 39-50 C
Hard 23-32 C
odkad sam kupio to kuciste niti jedna komponenta mi se ne pregrijava...sad me jos samo brine pitanje estetike...mislio sam kupiti one rebraste cijevi u koje se stavljaju kablovi za struju inace...pofarbati ih u crno ili crveno i staviti molexe u to... samo neznam di bi to nabavio... :confused:
Logitech MX500
DELL 2007FP
Abit AV8
Staro 21.09.2005., 13:11   #6
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,343
ak mislimo na isto imaš u linksu pod modding oprema.
žmnpp
Staro 21.09.2005., 13:42   #7
Komek
Komek's Avatar
Lokacija: Zagreb-Dubrava
Postovi: 505
Te rebraste cijevi imaš kupit u ducanu sa elekto instalacijama ili u nekom velikom opskrbnom ducanu npr. bauhaus.
Inace kablovi su ti koma a nebi ti skodilo da s vremena na vrijeme malo propuhneš kantu
Komek je offline   Reply With Quote
Staro 21.09.2005., 14:48   #8
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
o maj gad prasine !!!!
nego iz moga kompa se moze jesti
.i.
Razer Blade 15
Staro 21.09.2005., 16:18   #9
ZED
a.k.a. LOPOV
ZED's Avatar
Postovi: 2,022
Upravo to
Covjeku je to neprijtelj No1
Zabranjene reklama u sigu.
Staro 21.09.2005., 20:15   #10
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
ona prasina je pociscena davno.... a ova zujalica na ploci koju spominjes ne radi vec 3 tjedna jer je vent na njoj izgorel....
Logitech MX500
DELL 2007FP
Abit AV8
Staro 21.09.2005., 20:18   #11
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
velis da su kablovi losi? ak mislis na izgled onda dobro al ak mislis na performanse onda te moram demantirat.....ovo napajanje nije niti jedanput srusilo komp....tagan rules
Logitech MX500
DELL 2007FP
Abit AV8
Staro 21.09.2005., 20:29   #12
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,505
Di ste bili na lanu? U Afganistanu?!
Staro 21.09.2005., 20:38   #13
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
ma ne....samo u mojoj sobi al to ti je isto...bdw kolko dodje metar onog rebrastog crijeva ?
Logitech MX500
DELL 2007FP
Abit AV8
Staro 21.09.2005., 20:41   #14
MRKONJA
M.U.P.
MRKONJA's Avatar
Datum registracije: Sep 2004
Postovi: 2,277
Mene bi to bilo sram stavit na net
Kak živiš sa tolkom bukom?
MRKONJA je offline   Reply With Quote
Staro 21.09.2005., 20:56   #15
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
mrkonja kakvom bukom?
tagan se opce ne cuje...zalman nekaj slabo...cooler na northbirdgeu ne radi(valjda zato nemogu ga dici iznad 2.13) a ostali ventovi rade na minimumu(osim ako je jako toplo vrijeme)
I makar su mi stisani proc mi je trenutno na 34 stupnja , ploca 23 , graficka 44 , a hdd na 27.... ja buku ne primjecujem dok je stisano....a i da su pojacani na max onda se cuju al ja ti stalno slusam muziku dost glasno(sam zivim a susjedi svaki 100m udaljen... ) tak da ih ne cujem opce.
Logitech MX500
DELL 2007FP
Abit AV8
Staro 21.09.2005., 20:59   #16
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
e da....planirao sam staviti 120mm ventove. sa cime mogu busiti lim na kucistu?(pitam jer je ovo dosta debeli lim) i recite mi sto mislite o tome dali se isplati opce busiti tak skupo kuciste? mozda mi poslije bude zao... :confused:
Logitech MX500
DELL 2007FP
Abit AV8
Staro 22.09.2005., 08:45   #17
svizac
Postovi: 192
micek...opet se hvališ a??
i da, nemoj si to sam bušit, rađe odnesi nekome koji ima alat da ti to zbuši...jer ak sam kreneš...bit će kaos...a šteta kućišta
svizac je offline   Reply With Quote
