OP
Datum registracije: Feb 2013
Lokacija: Zagreb / Novska
Postovi: 366
win7 update -> Status repair loop
Bok Imam jedan problem... Jučer sam iz dosade išao updatati sve zaostale win updatove (kojih je bilo 142), 137 ih je prošlo uspješno,ostali su bacili neki error Restartao sam komp, počeo se dizati win update, sigurno je prošao 30%, nisam dalje pratio i onda je krenuo status repair loop... Probao sam googleat, izgleda da je problem u jednom win updateu (3033929) Probao sam u cmd kucat stvari koje su dečki prepopručili, ali ništa ne pali Jedino što sam u zadnje vrijeme mijenjao, osim tih win updatova je da sam dodao 20gb harda s D: na C: pomoću EasyUS partition managera Hard je star, ali nema bad sectora Ako netko nešto zna...bio bih zahvalan ![]() Kad status repair odradi svoje, ovo piše pod View diagnostics and repair details Startup Repair diagnosis and repair log Nmb of repair attempts 1 Session details System Disk = /Device/Harddisk0 Windows directory =C:/Windows AutoChk Run =0 Number of root causes = 1 Test performed Name: check for updates Result: completed successfully Error code = 0x0 Time 0 ms Test performed Name: system disk test Result: completed successfully Error code = 0x0 Time 0 ms Test performed Name: Disk failure diagnosis Result: completed successfully Error code = 0x0 Time 187 ms Test performed Name: Disk metadata test Result: completed successfully Error code = 0x0 Time 32 ms Test performed Name: target os test Result: completed successfully Error code = 0x0 Time 62 ms Test performed Name: volume content check Result: completed successfully Error code = 0x0 Time 312 ms Test performed Name: boot manager diagnosis Result: completed successfully Error code = 0x0 Time 0 ms Test performed Name: system boot log diagnosis Result: completed successfully Error code = 0x0 Time 0 ms Root cause found: Boot manager failed to find OS loader Zadnje izmijenjeno od: trebampomoc. 06.04.2015. u 12:11. |
Postovi: 10,805
stavi instalaciju win i repair i vrati sa system restore dan prije instalacije update-a. |
OP
Postovi: 366
OP
Postovi: 366
