Lokacija: rijeka
Postovi: 3,849
leadtek 6600 gt problemčić
konfa amd 2600+ albatron kx18dpro2 2x256 King Max 433 slot 1i2 cd rom dvdrw pionir hdd 80 gb ibm 400 w kodegen 77.72 driver koji puta znaju se zamrznuti windowsi,recimo zamrznuo se kad sam otvaro podmenije pcchipovog dvd pa sam mora restartati,u igrama se za sada niš ne događa,kartica jučer kupljena,da li je možda napajanje još preslabo,kupljeno isto jučer umjesto legendarnog i neponovljivog jnca??? ovaj erorić je izbacio EventType: 0xEA - Thread Stuck in Device Driver // // The driver for the display device got stuck in an infinite loop. This // usually indicates a problem with the device itself or with the device // driver programming the hardware incorrectly. Please check with your // display device vendor for any driver updates. // ShutdownCount: 540 Shutdown: 0 EventFlag: 1 EventCount: 1 BreakCount: 1 BugcheckTriggered: 1 DebuggerNotPresent: 1 DriverName: nv4_disp DeviceClass: Display DeviceDescription: NVIDIA GeForce 6600 GT HardwareID: PCI\VEN_10DE&DEV_00F1&SUBSYS_2011107D&REV_A2 Manufacturer: NVIDIA DriverFixedFileInfo: FEEF04BD 00010000 0006000E 000A1E5C 0006000E 000A1E5C 0000003F 00000008 00040004 00000003 00000004 00000000 00000000 DriverCompanyName: NVIDIA Corporation DriverFileDescription: NVIDIA Compatible Windows 2000 Display driver, Version 77.72 DriverFileVersion: 6.14.10.7772 DriverInternalName: nv4_disp.dll DriverLegalCopyright: (C) NVIDIA Corporation. All rights reserved. DriverOriginalFilename: nv4_disp.dll DriverProductName: NVIDIA Compatible Windows 2000 Display driver, Version 77.72 DriverProductVersion: 6.14.10.7772 |
Postovi: 4,190
probaj stavit nove drivere |
Lokacija: st
Postovi: 1,084
novi driveri, ti su promašaj.
ASUS K8N & Zalman NB32K @ HTT x3 / A64 3000+ 263x8 / 2x256MB TwinMOS @ 210 / Club3D 5200 & Zalman ZM80C-HP / Maxtor 30GB, 2MB / WD Caviar 80GB, 8MB / Maxtor DM10 250GB, 16MB / Xilence 420W / CoolerMaster Centurion 5 |
H2TB
Postovi: 363
codegen 400w je katastrofa od napajanja, ali mislim da ovdje napajanje nije uzrok problema, nego driveri (kao što su ti već napisali).... koju grafu si imao prije ove 6600gt? ako je bio ati, da li si pobrisao sa driver cleanerom stare drivere kako treba? |
Lokacija: rijeka
Postovi: 3,849
to je od frendovog mlađeg brata komp to su mu u ve-milu uvalili za 250 kn (napajanje +škatula),prije je isto imao nvidiu geforcu 2mx 64mb,onda koje drivere da stavim 78.01??je to napajanje dovoljno da povuče te komponente??da možda odspoji cdrom iako on ne troši puno wata?? |
#10 | |
Lokacija: Orahovica
Postovi: 7,363
daj molim te, imam to napajanje već par mjeseci i bez problema pogoni: P4 2.8@3.4 2x256 DDR400 kingmax WD40gb, baracuda 120gb cdrw,dvdrw... leadtek 6600GT 5ventova i neonku... i nema nikakvih problema... i da... istu tu konfu je pogonilo codegen 300w 2mj |
#11 | |
Lokacija: Zagreb, Trešnjevka
Postovi: 5,772
Lokacija: Šestanovac
Postovi: 398
bok dem! srkino ima pravo,drajveri su za smeće!! imo sam te drajvere na crashevoj fx 5700,ma kaki u igru neće ući da si ne znam što... zato se kloni tih,smrde mi na betu....:mad:
http://forum.pcekspert.com/faq.php |
Lokacija: rijeka
Postovi: 3,849
onda dobro da nisam krkao 78.03 nego.01,crash vidim da si grafu zamjenio,kolko sad derneš markova???ovo je moja konfa p4 1,8 MB Itel 845 512/266 Fx 5700 500/650 hdd 60 seagate hdd 40 ibm dvd dvdrw DTK 300w,će ovaj pvsić biti dovoljno jak da povuče 6600GT s ovim komponentama??? |
#14 | |
Datum registracije: May 2005
Lokacija: Online
Postovi: 2,404
Nema šanse ! Jedino ako želiš prisilno umirovit računalo ![]() |
Lokacija: rijeka
Postovi: 3,849
hm,kaže frend da mu opet jedan dan radi dobro onda drugi opet mrzne,uz el microsoftov eror u svezi s 6600gt koji sam postao,da diseblam eror report ![]() |
#16 | |
Lokacija: Orahovica
Postovi: 7,363
u 03 oko 8900 6600gt ocana na 570/1170... a sa fx 5700 na 525/690 sam dobivao negdje oko 4000... i ako misliš uzeti 6600gt uzmi si novo napajanje npr chieftec 410w za 300kn u linksu |
