Staro 24.02.2015., 14:46   #8371
BladeRy
BladeRy's Avatar
Datum registracije: Aug 2008
Postovi: 2,000
Autor JozicA Pregled postova
Ma nema varanja, sve je princip srece, barem mislim,
Mislis da nema? Ima kolega, ima i te kako.
- smart modified autoaim, that can track a target behind obstacles and highlight its contour. Also, it doesn't aim at the center of the vehicle, but at (preprogrammed) vulnerable spots. Oh, and it also calculates the speed of the target and aims in front of it to compensate (pre-aim)
- automatic fire extinguisher/repair, a script that triggers the repair/extinguish automatically as soon as it happens
- removes any aim circle jerking (contrary to he official version, there is no jerk even when you get rammed)
- counterarty hack that puts a red dot on the spot enemy arty just fired from
- sixth sense mod that replaces the perk (if you don't have it), it shows you not only you are targetted but also who's targetting you
- artymode for tanks and TDs, snipermode for arty (with the artymode you can fire HE shells accross the map with a regular tank)
- tracerhack (visible and color tracers)
- a mod showing on minimap where trees fell or buildings got destroyed ("ideal for field commanders")
- a mod that removes ALL vegetation and "binoculars" in sniper mode
- laser pointer mod - a free camera mod
- enemy reload timer
- white wrecks
- fire burst mode
- extended zoom in sniper mode
Ako se sjecas, veliku problematiku je napravio laser sight. Jer je tocno pokazivao kad te tko nisani i gdje, tako da si uvijek mogao znat jesi u opasnosti ili nisi. A to je bila ogronma prednost u igri.
Slika
A ako nije javno dostupno, i svi nemaju taj pack, onda imaju nepravednu prednost i to je varanje.
Staro 24.02.2015., 15:43   #8372
Thoroughbred B
Thoroughbred B's Avatar
Datum registracije: Apr 2003
Lokacija: RI
Postovi: 4,918
Šta nije to zabranjeno,tj. nemoguće koristit? arty mode s normalnim tenkom...wtf...šta nije instant ban ako to koristiš? nema neki "punkbuster" ili nešto??? nisam se susreo nikad s ničim sumnjivim...
Staro 24.02.2015., 16:02   #8373
BladeRy
BladeRy's Avatar
Postovi: 2,000
Nema nikakve anticheat zastite, koliko god wargaming srao o tome, ekipa igra sa ovim i streama.
Ljudi ga prijavljuju a on jos igra, glavno da su to premium igraci, pa sad da ne otjeraju musterije koje placaju ili nesto drugo, zakljuci sam.
Pricali su oni o nekim detekcijama za laser pointer i ta sranja i digla se opca uzbuna a na kraju imas cijeli cheat pack koji prezivljava i WG nista.
Sta se tice sumnjivog, tesko je primjetit da to ekipa koristi. Kao sta vidis to su mali QoL dodatci, al kad ih se skupi kolicina...
Sjecas se laser pointera koji na tebe nacrta crvenu liniju odakle te netko nisani, samo anglas tenk na 45° (ovisno o tvom oklopu) dok te lik nisani i bouncas sve i svasta, ta tako mala i "bezazlena" stvar je u stvari bila nevjerovatno korisna.
Staro 24.02.2015., 16:09   #8374
Nybelung
Autor Thoroughbred B Pregled postova
Instant ban.
Igra nema nikakvu zaštitu. Sve što je dostupno tvom clientu otvoreno je za cheatnje, pardon, mod-iranje.
Staro 24.02.2015., 18:06   #8375
Thoroughbred B
Lokacija: RI
Postovi: 4,918
Neznam tko bi bio lud riskirat account s tim glupostima? Ajde da je to neznam kakva prednost,ono da vidiš uvijek gdje je tko,da su uvijek spotani...ili neznam,da sam biraš kad i koliko često ćeš ammorackat nekoga...
btw tko streama s warpackom?
Staro 24.02.2015., 18:44   #8376
m4dm4n
Does youer dewg byte?
m4dm4n's Avatar
Postovi: 1,952
http://ftr.wot-news.com/2015/02/23/w...rpack-allowed/
WG EU : "How terrible."
m4dm4n je online   Reply With Quote
Staro 24.02.2015., 19:13   #8377
Nybelung
O kakvom ti to riziku pričaš kad su svi cheatovi, pardon, modovi službeno dopušteni?
Staro 24.02.2015., 20:07   #8378
tole_
Casual Racist
tole_'s Avatar
Lokacija: Sneed's feed and seed (formerly Chuck's)
Postovi: 422
Urnebes! Ovo sa kupovanjem cheatova me podsjetilo na zlatno doba UTa i Helios hook-a, ajme šta je tu žuči proliveno ccc. Nema tu pomoći, cheateri su uvijek korak ispred i sve da WG nešto poduzme, za tjedan dana vani je novi cheat v1.1 koji to zaobilazi. Naravno, ne kažem da ne bi trebali ništa poduzimati, pogotovo nakon ovako očite prijave, ali u suštini je to borba s vjetrenjačama. Kako kaže SS, Warpack se sramežljivo spominje (evo nisam ni ja čuo za to dok nisam vidio buljin demo) i to vjerojatno nije dobro jer WG ima još manje motiva ulagati pare i raditi neki AC, a opet da je razglašeno sigurno bi bilo i više cheatera. Tak da sve u svemu mene to i ne dira jer davno sam se prestao živcirati u WOTu, a to savjetujem i drugima.
Eh da i sjećam se kako je WG prije govorio kako oni imaju načina na koji detektiraju te illegal modove, sad (a vjerojatno je bilo i prije) je valjda svima jasno da su to prazne priče.
PS Nije li zgodno kako je ovaj uhvaćeni korisnik tog warpacka baš Poljak hehe
Zadnje izmijenjeno od: tole_. 24.02.2015. u 20:14.
tole_ je offline   Reply With Quote
Staro 24.02.2015., 20:11   #8379
BladeRy
BladeRy's Avatar
Postovi: 2,000
A komedije, nekidan igrao WoT i sve ok. Probam danas, i nema nista nakon pokretanja. Opalim launcher, updatea sta treba, hit PLAY i ista stvar, nista se ne pokrene samo launcher nestane. WTF.
Vidim na forumu da ima jos ljudi sa tim sranjem sad...
Staro 25.02.2015., 01:02   #8380
Drift_King
Never Forgetti
Drift_King's Avatar
Lokacija: .
Postovi: 1,640
- white wrecks
- fire burst mode
Slika
Sve je manje vise mod, nego upada mi u opci fire burst? Ali to nije server side konfiguracija? Ili san krivo svatio?
Jedini problem je ovaj laser, a ovo drugo manje vise i nije kriticno (bar meni) jer nisan vidio da me neko stalno ammo racka i sl...
Kako 6th radi ako ga nemas?
BTW koliko san skuzio na ftr za warpack triba premium account, wtf??? Znaci platin premium i cekan da me bana? Ili igraju na kartu premiuma?
Pas mater mene bana zbog team damaga a ove majume ne radi hackova...
Autor BladeRy Pregled postova
Napravi .bat u root folderu od wota
Meni se jucer nije tilo uplait radi Berlin garage moda.
- white wrecks
- fire burst mode
Slika
Zadnje izmijenjeno od: Drift_King. 25.02.2015. u 01:11.
Drift_King je offline   Reply With Quote
Staro 25.02.2015., 01:33   #8381
trouble
našikan pravim haos
Lokacija: u zabrani
Postovi: 2,707
Type 58,sasvim fora mali flanker
Staro 25.02.2015., 01:38   #8382
Nybelung
"Ne možeš dobiti ban za korištenje warpacka. Warpack nije cheat, cheatovi za WoT ne postoje. To je mod, a svi modovi su dozvoljeni na worldoftanks.eu."
^WG logika. Inače, javna je tajna da su ljudi koji su napravili originalni warpack WG zaposlenici.
Kako ne bi radio 6th? Server tvom klijentu javlja kad si odspotan imao ti taj perk ili ne.
Staro 25.02.2015., 02:13   #8383
Drift_King
Never Forgetti
Drift_King's Avatar
Lokacija: .
Postovi: 1,640
Autor Nybelung Pregled postova
Mislio san da javlja samo ako server kuzi da actually imas 6th sense, napravi check prije partije i samo javlja onim koji imaju...
Mozda san po dojmom, ali nije mi dosad "cheat" smeta ka u CODu di je bilo ocigledno. Ode mi jedino arty smeta
Izgleda da je jedina WG logika utrpajte nam para a ko jebe igrivost...
EDIT:
Brat cheater
T37 4/7 1 761 7 581
Zadnje izmijenjeno od: Drift_King. 25.02.2015. u 03:52.
Staro 25.02.2015., 10:40   #8384
BladeRy
BladeRy's Avatar
Postovi: 2,000
@Drift
Ma znam za taj command line, njega sam prvo probao. Odvrti on svoje i kaze da je sve ok, al igra i dalje ne pokrece. Malo kopam po forumima, seru o directx-u i driverima i firewallu, nubine kao i obicno. Opalio clean install preko noci, sad radi. Poslije sam otkrio tko je bio krivac, OMC mod, njega stavio, nije mi se svidio i maknio...usput ubio igru...tako mi i treba kad ne cekam da izadje AIO
Glede LP moda. Stari video al princip je isti, jos je novija verzija pokazivala samo ako tebe netko nisani. Link
Il nesto novija verzija Link, nemogu sad nac stari video gdje je princip rada bio objasnjen. Al pokazuje gdje mu top gleda cak i ako je iza kamena/zida tako da znas gdje je okrenut. I vidis po pointeru jesi mu ispod depresije topa i sve. Korisno? Nadasve. Fair play...nimalo.
Staro 25.02.2015., 11:26   #8385
skoda90
skoda90's Avatar
Datum registracije: Mar 2010
Postovi: 384
Imam problem sa updateovima.
Ujutro mi prvo skine nekih 1.5mb nakon neke provjere pocne skidati 3gb.
I uvijek mi tako bude kao i nedavno izadje neki mali update od 10mb i onda opet poslije toga skida 1.2gb neznam cega.Na drugom kompu sam isto radio update i samo je tih 10mb skinio i to je to.
Isto tako kad je izasao update 9.6 skine ga i poslije toga opet skida nesto preko 1gb zna li netko u cemu je problem?
vec sam kopirao cijelu igru od lege koji nema tih problema ali se meni to uporno dogadja.
skoda90 je offline   Reply With Quote
Staro 25.02.2015., 12:13   #8386
Nybelung
Kad si zadnji put instalirao igru? Mislim na clean install preko launchera, a ne na kopiranje od frenda.
99.99% tih problema se rješava sa novom instalacijom.
Staro 25.02.2015., 12:27   #8387
Drift_King
Never Forgetti
Drift_King's Avatar
Lokacija: .
Postovi: 1,640
Şamo update folder prikopirat da ne skida ponovo.
Staro 25.02.2015., 12:46   #8388
skoda90
skoda90's Avatar
Postovi: 384
Uff prije godinu dana kad sam i poceo igrat.
Inace to i radim samo kopiram update folder al nije mi jasno sta on skida svaki put.
Igra inace najnormalnije radi i nema tih problema.
Budem onda preko noci ponovno stavio skidati pa cemo vidit
Edit:zaboravio pitat da li i vama sta skida danas ili je to samo kod mene?
Staro 25.02.2015., 13:03   #8389
Drift_King
Never Forgetti
Drift_King's Avatar
Lokacija: .
Postovi: 1,640
Autor skoda90 Pregled postova
1.5MB pa onda ~650MB. Ja iman sve update na kompu kao backup, kad se zezne delete all, pokrenem launcher i samo iskopiran update. Sam povuce rezliku ako ima.
Staro 25.02.2015., 13:03   #8390
JozicA
Vozi Miškoooo!!!
JozicA's Avatar
Lokacija: Svuda okolo / EU
Postovi: 1,404
I sam vjerujem da ima toga, mozda, gledao sam video uradke na bugonline forumu gdje pojedinci svoj video stavljaju, i u jedno sam siguran, aimbot postoji, identicnu stvar vidim kao u ovom videu (ako vam se sve negleda obratite paznju na vrijeme oko 28:00).
Jednostavno igrajuci ovu igru i gledajuci kako mi se nisan poklapa s protivnickim tenkom, a kad u video reply vidim da tenk gleda ljevo a nisan gadja weakspot ... ono mislim, pa varajte ako zelite i ako vas to veseli ali onda video stavljati i s time se hvaliti...
Dotle ja povremeno odigram za misiju, i uzivam... koliko mogu...
edit:
evo stavio i ja mod, AIOMOD, nije los, sad sam i ja cheater, konacno dva reda tenkova, lakse listat, i odma prvo pa musko, rijesio zadatak za zauzimanje baze za danas, da nije zadatka isao bih ja nazad,mozda ...ali... video
Zadnje izmijenjeno od: JozicA. 25.02.2015. u 14:13.
JozicA je offline   Reply With Quote
Staro 25.02.2015., 14:32   #8391
BladeRy
BladeRy's Avatar
Postovi: 2,000
AIO nije cheat mod, nema gledanja kroz teren, micanja foliagea, laser pointera i tih sranja. Imas last know enemy spot i par QoL sitnica. Nema automatskog extinguishera i bilo kojih "debelih" prednosti nad vanila verzijom.
U usporedbi sa cheatmodom, AIO je malne vanila WoT.
Staro 25.02.2015., 14:35   #8392
JozicA
Vozi Miškoooo!!!
JozicA's Avatar
Postovi: 1,404
A taman sam se ponadao da sam cheater ...
A evo pao i M s ISU-152, konacno, nakon neznam koliko partija, ti ruski TDovi mi bas nisu sjeli dobro, ali sve u svemu fina partija, na kraju mi se nije dalo ginuti bezveze ... suigraci opet za kupiti lopatom... video
Staro 25.02.2015., 15:15   #8393
Drift_King
Never Forgetti
Drift_King's Avatar
Lokacija: .
Postovi: 1,640
So far so good
upload gambar
EDIT:
Pocelo je srat s artiljerijom. Pa pas ti majku vise, ne mozes se maknit da ne bude -700.
Zadnje izmijenjeno od: Drift_King. 25.02.2015. u 15:32.
Staro 25.02.2015., 16:45   #8394
JozicA
Vozi Miškoooo!!!
JozicA's Avatar
Postovi: 1,404
Ma meni je danas statistika uzasna, uglavnom imam malog japanca Te-Ke, premium, i tek iz 7 pokusjaja ostvarimo pobjedu... do danas ga nisam igrao, nikako mi nije sjeo u ovih par borbi, ali M pao ... video sva sreca pa mi nas arty pomagao ...
joj.. uzeo arty tier III, su-26, i pade M, a stvarno se nisam nadao, video .. mali je kao sumska osica,, bode al ne probija...
Zadnje izmijenjeno od: JozicA. 25.02.2015. u 21:29.
Staro 26.02.2015., 10:51   #8395
skoda90
skoda90's Avatar
Postovi: 384
Nocas ostavio da se ponovno skidaju tenkovi i ujutro me doceka critical error kod raspakiravanja instalacije.
"patch installation. name: "wot_96.5411_client.patch", what: extract file error, msg: name="D:\World_of_Tanks\Updates\wot_96.5411_client.patch" file="res\packages\gui.pkg" to="D:\World_of_Tanks"
Isto se dogodilo prije par dana kad sam htjeo isprobati wowp.
Ima li tko ideju sta radit kako rijesit taj error?
Edit:skinio preko torrenta wot_96.5411_client i probao raspakirati sa winrar u direktorij od igre i opet izbaci error
! D:\World_of_Tanks\Updates\wot_96.5411_client.patch: CRC failed in res\packages\gui.pkg. The file is corrupt
! D:\World_of_Tanks\Updates\wot_96.5411_client.patch: CRC failed in res\packages\misc.pkg. The file is corrupt
Zadnje izmijenjeno od: skoda90. 26.02.2015. u 12:44.
Staro 26.02.2015., 16:14   #8396
JozicA
Vozi Miškoooo!!!
JozicA's Avatar
Postovi: 1,404
probaj iskljuciti torrent download pa skidaj direktno... ali prvo s hdd tune provjeri hdd... da nije poceo otilaziti ... nist mi drugo nepada napamet
a ja malo male tiere vozam jutros .. kad s mini mausom dobijem scout medalju ... a jedan od najsporijih tier II, sto reci ...
video ... samo apcr u upotrebi ... ima se
a kako suigrac moze biti u vodu sam ? nije mi jasno... =?!
Staro 26.02.2015., 18:22   #8397
skoda90
skoda90's Avatar
Postovi: 384
Hdd rikava,bad sectori,navodno je ispravio sa regeneratorom al neda mi se opet sve skidat tak da cu samo kopirat sa laptopa cijelu igru i to je to
Staro 26.02.2015., 21:16   #8398
Hawker
Datum registracije: Nov 2014
Postovi: 1,972
Danas dobar solo day:
Hawker je offline   Reply With Quote
Staro 27.02.2015., 01:49   #8399
JozicA
Vozi Miškoooo!!!
JozicA's Avatar
Postovi: 1,404
Meni je dan onako zavrsio, jutro s malim tierima, vece s arty... uglavnom rijesio misiju kad se nisam ni nadao... tako mi je najljepse, bas za laku noc...
Joj,,, 0/12, pocelo je opet... mislim moj kratki godisnji pa idem malo tenkove provozati, gaze li nas gaze ... samo sam stao i gledam i neznam dal da placem ili se smijem ... video od zadnje ...
Zadnje izmijenjeno od: JozicA. 27.02.2015. u 13:16.
Staro 27.02.2015., 14:56   #8400
Drift_King
Never Forgetti
Drift_King's Avatar
Lokacija: .
Postovi: 1,640
A jesi nasa spg za misije, to uzmes neki high tier i gold...
Ja san malo zapeo na mediumima (zapali 2 tenka ili jednog 2x) ali to bi moga za vikend odradit (ili bar probat)
