Staro 23.01.2015., 22:09   #181
darQ
I'm nightrider
darQ's Avatar
Lokacija: Bjelovar
Postovi: 718
to su linkovi sa ove stranice i živi su već neko vrijeme
plug & pray
Lenovo L440
Intel iCore i7 4702MQ
16GB DDR3
Intel HD 4600 GPU
14-inch LED-backlit fHD IPS (1920 x 1080, 300 nit) matte display
Intel Wireless-N 7260, BlueTooth
Samsung 850PRO 1TB
Logitech M705
6cell baterija
Windows 10 Pro 64bit
Pošteni trgovci: 1, 2, 3, 4
darQ je offline   Reply With Quote
Staro 23.01.2015., 23:12   #182
Facelessone
Facelessone's Avatar
Postovi: 4,204
Autor darQ Pregled postova
Nisu, i jesu....
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 23.01.2015., 23:30   #183
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,471
Pomagajte hitno je )
http://i.imgur.com/mSjHifI.jpg
Ovo mi javlja, a maknuo sam ostale diskove tak da je samo SSD u upotrebi, to je prije palilo, sad nece.
Jel mozda zbog tog sto s usb sticka instaliravam winse? Help, pisem s moba
Staro 23.01.2015., 23:42   #184
dadoremix
dadoremix's Avatar
Postovi: 4,733
eto ja tipkam sa njega...
sad jos maknut onaj watermark dolje lijevo i to je to
izgled ko i win 8.1 ali start mi se sad sviđa
drivere sve sam povukao.. čak i zadnji za ati drivere
Staro 23.01.2015., 23:44   #185
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,471
Edit: rijesio ovo gore tak da sam promijenio usb ulaz -.-
Kak se makne taj watermark?
Staro 24.01.2015., 00:05   #186
dadoremix
dadoremix's Avatar
Postovi: 4,733
z sad na vidiku zanimljiv problem
NAS sistem neče prihvatit user i pass preko samba share
Staro 24.01.2015., 00:13   #187
catroot
catroot's Avatar
Datum registracije: Apr 2009
Lokacija: I live in 43 05'04.11"N 17 57'36.71"E
Postovi: 881
Imam dva diska u kompu, na jednom je win 8.1, drugi slobodan, jel ok ako instaliram taj windows 10 na drugi disk, oče biti kakvih problema za win 8.1.
catroot je offline   Reply With Quote
Staro 24.01.2015., 00:21   #188
dadoremix
dadoremix's Avatar
Postovi: 4,733
nakon 3 reboota radi
pošto je win na SSD-u i to sata 2 sučelju sve leti ko i win 8.1 čak i više
ajd srečom imam backup 8.1 pa ako ovaj nebude sjeo a na prvi dojam je sve ok ... valjda če i ostat .. makar je probna verzija
btw kako provjerit do kada vrijedi?
licenca kaže activated.. ali ne i do kad, sa time da serial code nisam upisivao
Staro 24.01.2015., 00:27   #189
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,471
Instaliro drajvere za grafu i nakon toga mi kod restarta odvrti win10 logo i pojavi se neki plavi ekran samo i tak stoji bez ikakvog texta i iceg. Morat cu opet reinstal izgleda edit: sredio
Zadnje izmijenjeno od: mamutarka. 24.01.2015. u 03:17.
Staro 24.01.2015., 03:17   #190
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,471
kak maknut onaj štit s ikona žuto plavi, UAC je ugašen, znam da sam nekako to bio prije micao al ni gugl mi nije od pomoci ovak nabrzaka
Staro 24.01.2015., 07:57   #191
Postovi: 34,028
Ako će upgrade sa W7 i 8 biti gratis, živo me zanima kako će se ponašati na krakiranim windozama tj. hoće li dozvoliti upgrade.
Staro 24.01.2015., 11:53   #192
rak21
COD2 expert
rak21's Avatar
Postovi: 1,919
Novi preview je dostupan
Staro 24.01.2015., 11:58   #193
Juice
Fresh Juice
Juice's Avatar
Postovi: 4,571
Autor coconut Pregled postova
Rješavanje tako da će tražiti unos koda/ključa prilikom instalacije?
Autor rak21 Pregled postova
Može link?
Staro 24.01.2015., 13:35   #194
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,471
na prošloj stranici je link
Staro 24.01.2015., 13:55   #195
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,087
U doba kad većina laptopa / tablet / gotovih konfiguracija dolazi sa Winsima i dok je moguće imati legalne Winse preko škole/fakulteta/poslodavca i gdje Windows 7/8/10 licenca preko internet košta kao jedna AAA igra - mislim da krekirani Windowsi budu postali stvar prošlosti, tj. Winsi neće biti ni približno toliko piratizirani kao Win7 ili pogotovo WinXP.
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Mario92 je online   Reply With Quote
Staro 24.01.2015., 14:27   #196
Postovi: 34,028
Pozlatile ti se iako zaboravljaš da mnogi još ne kupuju gotove konfe već ih slažu po svojoj želji. Mnogi su uz takve kompove kupili OEM vindoze što baš i nije legalno, ali je prolazilo kod inspekcija.
Znaju li se neke min. specifikacije kompa za W10? Imam jednu stariju konfu - Q6600, 4Gb DDR2, Gigabyte P35-DS3R,... koja mi se na XP ne vrti kako ja mislim da bi trebala pa me zanima hoće li biti dosta jaka za W10 ili da počnem razmišljati o novoj konfi.
Staro 24.01.2015., 15:52   #197
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,087
Ćemo da vidimo, još ima dosta do kraja godine
A system req su isti kao i za Win7 - Giga svega:
- giga RAMa (za 32bit)
- 1GHz proc (sa NX Bit instrukcijom)
- 16GB HDD (čista instalacija Winsa zauzima 15,4GB, bar kod mene)
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
Staro 24.01.2015., 15:54   #198
rak21
COD2 expert
rak21's Avatar
Postovi: 1,919
Da konfiguracija bi po meni trebala raditi bolje na win10 nego na xp..
Staro 24.01.2015., 16:19   #199
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,087
Imam blesav bug - ne mogu staviti desktop background
Solid color radi ali sama slika ne.
Vjerojatno ima veze sa grafičkom i nekompatibilnim driverima. Naime, na Radeonki x1550 sam
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
Staro 24.01.2015., 16:19   #200
darQ
I'm nightrider
darQ's Avatar
Lokacija: Bjelovar
Postovi: 718
i tak, 9926 više nema windows update postavku u control panelu nego se apdejti mogu podešavati samo unutar PC settings-a
ovak na prvu mi ne izgleda da radi fino i glatko kao prethodni 9789 build i čini mi se da će biti više gličeva...npr, ne mogu nikak podesit da se logiram sa fingerprint reader-om, jednostavno se smrzne settings app kad idem to podešavati, a na prethodnom buildu je to radilo bez ikakvih problema
cortana je za naše područje također nedostupna, vjerojatno bi trebalo promjenit regiju u control panel-u, al trenutno sam lijen za to...
plug & pray
Lenovo L440
16GB DDR3
Intel HD 4600 GPU
Samsung 850PRO 1TB
Logitech M705
6cell baterija
Staro 24.01.2015., 16:24   #201
XP se vrti jednako dobro/loše na E4300 + P35 čip i na i7 2500K + Z68 čip. Win 7 i 8 puno bolje rade od XPa na obje kante. Tako da će i desetka vjerojatno na toj tvojoj Q6600 kanti također raditi fino.
Čisto za info, moji starci imaju 2 kompa. E6600 c2d na Q965 čipu i 3 GB RAMa vrti Win7 Home 32bit i drugi je E8400 na P45 čipu sa 6 GB RAMa koji vrti 8.1 PRO X64. Vrlo glatko i dobro to radi. Svakako bolje nego na XPu. Čak su se bez beda naviknuli na win7 i 8.1 nakon godina XPa.
Win 10 može biti samo još bolji i optimiziraniji kad dođe final verzija.
Staro 24.01.2015., 19:15   #202
darkydark
N0teb00k n00b
darkydark's Avatar
Lokacija: Zagreb/Koprivnica
Postovi: 2,111
Ovo za c2d i win xp mogu i ja potvrditi. Puncu i punici sam nabacio win 7 i nisam im nist ni rekao, samo su prokomentirali kak je sve lepae i brze - e8400, 4gb, radeon 5670.
1TB A2000, 2TB KC3000
Linđa
Truenas Scale
Staro 24.01.2015., 19:24   #203
Juice
Fresh Juice
Juice's Avatar
Postovi: 4,571
Računao sam da misli na neki noviji build jer piše o novoj verziji nakon što se rasrpavilo već o tome
Staro 24.01.2015., 20:10   #204
Guls
Guls's Avatar
Lokacija: Sveta Nedelja
Postovi: 2,938
Tko želi instalirati Win 10 build 9926 na Hyper-V virtualku mora prije instalacije kreirati disk i staviti ga na poziciju 2 (obično je na poziciji 0, a dvd uređaj na poziciji 1).
Intel i7 9700F
32GB Hyper-X DDR4-2666
2TB 970Pro PCIe NVMe M.2
Windows 11 Professional
Periferija
2 x 27" Dell P2723D
Corsair SP2500 2.1
Logitech MK270
17,3 FHD IPS 144Hz
AMD Ryzen 7 5800H
16GB DDR4-3200 RAM
1TB PCIe NVMe SSD
Sony Playstation 5
Staro 24.01.2015., 22:04   #205
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,575
Kako ide upgrade postojece instalacije 8.1 na 10ku?Preko bootabilnog usba samo prilikom instalacije idem na ono upgrade ili?
Staro 24.01.2015., 22:39   #206
Mikeyy
Postovi: 2,078
Ništa ljudovi, sada svi na ebay po Win7 OEM licence po 30€.
Staro 24.01.2015., 23:38   #207
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,471
evo nakon 1 punog dana korištenja ok su mi skroz, mislim da će sedmica konačno u ladicu, e sad nabavit prvi put u životu windowse legalne, jer čini mi se da toliko toga je povezano s netom da neće baš bit ugodno i lako furat krekane
1300kn za sedmicu nedam, tko ima pouzdan link na ebay il neki sedmica ultimate neka podjeli
Staro 24.01.2015., 23:44   #208
denied
denied's Avatar
Postovi: 1,193
Na g2play imaš professional za 30 ojra.......
denied je offline   Reply With Quote
Staro 24.01.2015., 23:59   #209
Sinac
...samo te gledam...
Sinac's Avatar
Postovi: 2,833
Microsoft je dozvoljavao prodaju Windows OEM licenci uz sastavljena računala ali i uz hardverske komponente, prvobitno čak nije ni bilo specificirano što se pod tim podrazumijeva pa si i uz miša ili tipkovnicu mogao kupiti OEM Windowse, kasnije su promijenili da moraju biti CPU i matična ploča (ne drži me za riječ, možda je bio i RAM) u popisu komponenti koje se kupuju. To znam jer sam radio s Microsoftovim proizvodima i išao na prodajne treninge. Tako da nije da se OEM prodavao izvan pravila ili nelegalno i da su takvi Windowsi u bilo kom pogledu "manje" legalni od retail verzije.
Staro 25.01.2015., 00:33   #210
vedran031
vedran031's Avatar
Postovi: 549
Instalirao sam w10 u virtualbox ali nakon instalacije dode do windows logo i ispod njega pise getting ready i tako vrti satima, imao netko ideju sta bi moglo bit problem?
vedran031 je offline   Reply With Quote
