Staro 25.08.2014., 15:23   #781
ShanTech
Datum registracije: Apr 2011
Postovi: 3,784
Kome ti to?
Staro 25.08.2014., 15:29   #782
O9g1
Bee-do Bee-do Bee-do, TUP
O9g1's Avatar
Datum registracije: Aug 2009
Postovi: 323
Autor ShanTech Pregled postova
Kome ti to?
A izgleda sebi u brk....
LOL, sad ja ispadoh spamerčina... ahahahahaha
Mod, briši i ovo, molim lijepo!
CPU: Intel i5 2500k (BX80623I52500K) cooled by Scythe Ninja3 (SCNJ-3000)
MBO: Asus P8Z68-V PRO/GEN3
RAM: 2x4GB Kingston 1600MHz, DDR3, XMP (KHX1600C9D3K2/8G)
GPU: GIGABYTE Radeon R9 290 4GB Windforce 3x (GV-R929OC-4GD)
SSD: Samsung 840 EVO 120GB (MZ-7TE120BW) - System
HDD1: WD Caviar Black 500GB (WD5001AALS) - Storage
HDD2: WD 250GB (WD2500JS-22MHB0 ) - Backup
ODD: Samsung 22/8/8/48/32x (SH-S222AB)
PSU: XFX XXX Edition P1-650X-CAG9 650W
CASE: Fractal Design Arc midi
FAN CONTROL: Scythe KAZE MASTER 5.25″ Bay Fan Controller (KM01-BK)
FAN: 2x Fractal Design Dynamic GP-14, 140 mm intake+2X Scythe S-flex 120mm (SFF21E) exhaust
OS: W10 x64
LCD:MASTER: LG 29UM57-P Ultra širok đubar, jooooj što ga volem... , SLAVE: Dell 17"
KEYBOARD: Logitech UltraX keyboard (Y-BL49)
MOUSE: Logitech G400
SOUND: Creative Sound Blaster X-Fi XtremeMusic
HEADSET: Steelseries Siberia v2
RALLYING GEAR: Logitech G25+homemade cokpit+handbrake (modani Genius MaxFighter F-16U)
IF IN DOUBT, FLAT OUT!!!
Don't touch it! It is mine! It's all miiiiineeee!!!
Lenovo Essential B580
CPU: Intel Celeron Dual Core B820 1.70GHz (2MB cache)
LCD: 15.6" HD LED 1366 x 768
GPU: Intel HD Graphics 3000
RAM: 4GB DDR3 1600MHz
HDD: 320GB SATA
ODD: DVDRW DL
PSU: Up to 4hours (Li-Ion 6 cell)
ETHERNET: Yes (Gb LAN)
COMM: Yes (802.11b/g/n)
BLUETOOTH: Yes
AUDIO IN/OUT: Yes
VGA OUT: Yes
HDMI: Yes
CASE: Lenovo
CARD READER: Yes
FINGERPRINT READER: Yes
CAMERA: Yes
OS: Windows 7 Profesional
Lenovo ThinkPad E560
CPU: Intel Core i7-6500U 2.5 GHz
LCD: 15.6 inch 16:9, 1920x1080, IPS-Panel, LED-Backlight, glossy: no
Extern LCD:Lenovo X24a, 24 inch 16:10, 1920x1200, IPS-Panel, LED-Backlight
GPU: AMD Radeon R7 M370 2 GB GDDR5
RAM: 16GB, 2 x 8 GB DDR3L-1600
HDD: 250GB SSD
ODD: DVD+/-RW
PSU: 48 Wh (6 cell)
ETHERNET: Gigabit Ethernet
COMM: 802.11ac, Bluetooth, Intel Dual Band Wireless-AC 8260 - M.2 Card
CONNECTIONS: 3 x USB 3.0, HDMI, VGA, OneLink connector, LAN, Headphone/microphone combo jack
CARD READER: 4 in 1 ( SD Card, MultiMediaCard, SDHC Card, SDXC Card )
CAMERA: Yes
OS: Windows 10 64x
Poštena, dobra i odgovorna trgovina +još jedna...
Straight roads are for fast cars, turns are for fast drivers!
O9g1 je offline   Reply With Quote
Staro 25.08.2014., 17:34   #783
Lewis
Freelancer
Lewis's Avatar
Lokacija: Bilje (Osijek)
Postovi: 5,318
Evo izvrtio sam FutureMark (demo ovaj od 1.4x Gb) i nista od toga, uopce ne kuzi 780ke i sve vrti na single 760ki . Cim sam vidio MSI logo u sceni nesto mi bilo sumnjivo, onda sam skuzio na drugom monitoru da je GPU observer 'ladan ko spricer za sve tri 780ke (32-33C) dok je 760ka isla na nekih 65-66C i 100% opterecenje a ove su bili potpuo idle.
Valjda neradi bez SLIa (ili ima neka opcija za upalit ih ?)
Staro 25.08.2014., 23:09   #784
Očito da gamerski benčmarci ne kuže dobro to. Ali dobro je netko rekao, pitanje je kako bi se Crysis 3 na 4K ponašao, možda isto nebi iskoristio sve gpuove...
U svakom slučaju, 2kW nije mala stvar
Staro 30.08.2014., 18:26   #785
New One
New One's Avatar
Datum registracije: Apr 2008
Lokacija: Velika Gorica
Postovi: 471
Da li je i5 2500K @4ghz dovoljan da iskorištava 760Ti ili 780?
New One je offline   Reply With Quote
Staro 30.08.2014., 21:13   #786
tole_
Casual Racist
tole_'s Avatar
Lokacija: Sneed's feed and seed (formerly Chuck's)
Postovi: 422
Dovoljan je. No, preporuka je da se strpis s kupnjom jos cca. mjesec dana jer se suska da bi nvidia mogla za tjedan-dva predstaviti gtx880 (ili 980) koje bi trebale biti dostupne krajem rujna. Vdijeh da je OcUK snizio cijene gtx780/ti uz napomenu da kartica uskoro vise nece biti ili ih bude u ogranicenim kolicinama. Znaci ciste se lageri, stizu nove karice. Valjda nece biti lose.
tole_ je offline   Reply With Quote
Staro 31.08.2014., 00:17   #787
New One
New One's Avatar
Postovi: 471
Odlično. Nemam potrebe da imma nekaj najnovije u kompu, ali ako ovima cjena padne to je već dovoljan razlog pinut rabljeno da malo podigne performanse u odnosu na moju 660.
Staro 31.08.2014., 01:00   #788
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
Rabljena svakako. Puno je to brza grafa od 660, drugi svemir. Nema igre koju nece progutat, samo max postavke i deri. Osim naravno Crysisa 3 i par njih kaj imaju opaki aa..
Staro 31.08.2014., 13:34   #789
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,575
Preporuka je nasvirati taj 2500k jos gore ako govorimo o 780
Staro 11.09.2014., 20:55   #790
esc
Lynnfield
Datum registracije: Sep 2012
Postovi: 1,023
gtx 750 oc s tim da sam ove taktove stavio otprilike,bf4 full stabilno,nevjerojatno koliko ide boost
esc je offline   Reply With Quote
Staro 11.09.2014., 22:51   #791
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
Jos malo pa gtx 970. Ocekivane performanse izmedu 780 i 78Ti.. Cijena je ? iako nebu mala jer je grafa u high end segmentu ali vjerojatno nece bit perverzija. Jos da imamo kaj igrat bilo bi super.
http://www.techpowerup.com/205126/ms...infrozr-v.html
Staro 11.09.2014., 23:02   #792
Brlja
Postovi: 874
Kad su se to odlučili preskočit 800 seriju? Nisam baš u toku.
Brlja je offline   Reply With Quote
Staro 11.09.2014., 23:27   #793
darkydark
N0teb00k n00b
darkydark's Avatar
Lokacija: Zagreb/Koprivnica
Postovi: 2,111
Autor Brlja Pregled postova
Nisu - imas ih u laptopima
1TB A2000, 2TB KC3000
Linđa
Truenas Scale
Staro 11.09.2014., 23:28   #794
arnso
arnso's Avatar
Datum registracije: Aug 2011
Postovi: 79
pred nekih mjesec dana je objavljeno. Razlog je što je 800 serija za laptope vec dugo vani i uskoro ce doci serija 900 za laptope pa da ne bude razlika u nomenklaturi kod desktopa i laptopa tj da ne dolazi do zabuna.
arnso je offline   Reply With Quote
Staro 12.09.2014., 01:04   #795
RaneZ
Vršni visioc
RaneZ's Avatar
Postovi: 2,209
Autor MAGARAC Pregled postova
Mene zivcira sto mi stekaju stvari na 1920x1080 sa klokanom 770 :/
Pa ti reci da se vise isplati pc gaming....pih...
A jos kad pozelim preko 100fps-a zbog monitora, ne gine mi titan black
Bez potpisa.
Staro 12.09.2014., 09:19   #796
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,318
Autor RaneZ Pregled postova
Ha, cuj, igranje u visokoj kvaliteti/rezoluciji je uvijek bio skup "sport" .
Staro 12.09.2014., 11:16   #797
virus1
virus1's Avatar
Postovi: 495
Monitor ti je kolega super, vidio sam masu streamera sa 2 ili više takvih, međutim većina ih radi toga ima SLi 2x780 ili 2x770.
virus1 je offline   Reply With Quote
Staro 12.09.2014., 17:15   #798
esc
Lynnfield
Postovi: 1,023
ili sli gtx 780 ili cros 280x pa na više za taj monitor sa 144Hz i ako hoćeš neke high/ultra detalje,gtx 770 je preslaba i ima samo 2gb memorije
Staro 12.09.2014., 19:22   #799
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Šteka?
Staro 13.09.2014., 11:16   #800
RaneZ
Vršni visioc
RaneZ's Avatar
Postovi: 2,209
Autor esc Pregled postova
Je, drage volje bi SLI, ali u malog prodigyja nejde vise od jedne
Bez potpisa.
Staro 13.09.2014., 11:54   #801
esc
Lynnfield
Postovi: 1,023
pa onda ga baci
Staro 16.09.2014., 14:18   #802
scarwin
scarwin's Avatar
Datum registracije: Sep 2014
Lokacija: Zagora
Postovi: 179
Koju nvidiu ove serije do 1200kn za igranje na 1920x1080 na 24"? Jel valja išta gtx750ti?
scarwin je offline   Reply With Quote
Staro 16.09.2014., 14:45   #803
ukiy
ukiy's Avatar
Lokacija: ST
Postovi: 398
@scarwin
Ostatak konfiguracije?
Nemas nekog drugog izbora do te cifre, bar sto se nvidie tice... Mislim da se jos u prodaji moze naci GTX 660, pa eventualno nju...
Ako ides na polovno, na njuskalu je bilo i GTX 760 za tu lovu.
ukiy je offline   Reply With Quote
Staro 16.09.2014., 14:51   #804
ShanTech
Postovi: 3,784
Za te novce od Nvidije ni nema ništa bolje, a iz dućana. Možda bi se u nekim starim zalihama moglo naći 192-bitnu GTX 650 ti Boost ispod 1200 kn, no sumnjam. GTX 660 je već 1300 kn.
Od konkurenta pak možeš dobiti R7 265, koja ima bolje performanse, a za otprilike iste novce ko i GTX 750 Ti.
http://www.nabava.net/search.php?tp=0&q=R7+265
Jače i jeftinije od GTX 660 su R9 270 i R9 270X
http://www.nabava.net/search.php?tp=0&q=R9+270
http://www.nabava.net/search.php?tp=0&q=R9+270X
Staro 16.09.2014., 18:23   #805
scarwin
scarwin's Avatar
Lokacija: Zagora
Postovi: 179
OK, super, hvala vam..ostatak konfiguracije će bit fx6300 (možda 8320), 8gb RAM, i asus a97..dakle R7 265 je bolja?
Staro 16.09.2014., 18:39   #806
Manuel Calavera
Postovi: 14,584
Je. Čak se do nedavno za cijenu gtx 750Ti mogla i R9 270 nabavit u uzishopu 1100kn + nešto sitno
Staro 16.09.2014., 18:41   #807
ukiy
ukiy's Avatar
Lokacija: ST
Postovi: 398
Autor scarwin Pregled postova
Da, imat ces nesto bolje performanse u odnosu na GTX750Ti.
Staro 24.09.2014., 00:39   #808
nino
nino's Avatar
Postovi: 12,613
Kako cujem, u četvrtak bi cijene gtx7xx mogle ici dole od 10 do 30% kako cujem.
Edit: http://forum.pcekspert.com/showpost....&postcount=651
Zadnje izmijenjeno od: nino. 24.09.2014. u 11:42.
Staro 25.09.2014., 00:50   #809
lateralus_eye
lateralus_eye's Avatar
Postovi: 603
Ne vezano za seriju 900... koliki bi bio fail da se uzme ova kartica ASUS ROG STRIKER-GTX760 4GB?
Hvala
lateralus_eye je offline   Reply With Quote
Staro 25.09.2014., 00:58   #810
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
Ovisi o cijeni. 970 se sasvim druga liga ak te ona kopka, neusporedivo a 960 tek treba vidit. Ja nebi.
