Postovi: 25
Pomoc pri kupnji kompa
1446 kn(links) -->
AMD ATHLON 64 3500+ (2 200GHz) BOX SOCKET S939 VENICE --> 1760kn (raj) ASUS EAX800XL/2DTV, ATI RADEON X800 XL, PCI-Ex16, 256MB DDR 256-bit DDR, VIVO, 2xDVI-I, TV-out, engine clock 392MHz, memory clock 700MHz, RAMDAC 400MHz, max resolution 2048x1536, 2nd DVI and VGA output --> 2165(raj) Caviar 80 GB, WD800JD, SERIAL ATA, 8MB cache, 7200 rpm --> 466 (raj) KINGSTON DDR 1GB DDR400 DUAL CHANNEL ( 2 x 512MB) KVR400X64C3AK2/1G -->950kn(raj) LG DVDRW 16x DoubleLayer +/- Retail crni -->416kn(raj) CREATIVE LABS SB Audigy2 ZS, bilk -->525kn(raj) SM 730BF Matisse, 17" TFT, 1280x1024, 300cd/m2, 600:1, 160°/160°, 4ms (G to G) Worlds record breaking response time, the fastest monitor ever, Silver/Black, MagicTune, MagicBright 2, Analog/Digital, TCO'99, LS17BIDKSV The best monitor for gaming and multimedia -->2440kn(raj) --------------------------------------------- UKUPNO 10168kn Ukljucujuci hdd 40gb i lg cdrw iz starog kompa. Jos 1000 mi ostane za kućište,napajanje i hladenje... Sad mi recite komentare na kofiguraciju,i preporucite ove tri stvari koje mi flae,dali mi je dovoljno 1000kn za to. Imam na raspolaganju 11k kuna...Ovih dana malo po netu citam o svim komponentama,i jos sam zbunjeniji nego prije...koji su vasi savjeti?
Slozio sam jednu konfiguraciju pa mi recite sta mislite o tome... MBO DFI LAN PARTY UT nF4 SLI-D, DDR, zvuk, S-ATA, FW, 2xG-LAN, PCI-E, s. 939 --> 1446 kn(links) AMD ATHLON 64 3500+ (2 200GHz) BOX SOCKET S939 VENICE --> 1760kn (raj) ASUS EAX800XL/2DTV, ATI RADEON X800 XL, PCI-Ex16, 256MB DDR 256-bit DDR, VIVO, 2xDVI-I, TV-out, engine clock 392MHz, memory clock 700MHz, RAMDAC 400MHz, max resolution 2048x1536, 2nd DVI and VGA output --> 2165(raj) Caviar 80 GB, WD800JD, SERIAL ATA, 8MB cache, 7200 rpm --> 466 (raj) KINGSTON DDR 1GB DDR400 DUAL CHANNEL ( 2 x 512MB) KVR400X64C3AK2/1G -->950kn(raj) LG DVDRW 16x DoubleLayer +/- Retail crni -->416kn(raj) CREATIVE LABS SB Audigy2 ZS, bilk -->525kn(raj) SM 730BF Matisse, 17" TFT, 1280x1024, 300cd/m2, 600:1, 160°/160°, 4ms (G to G) Worlds record breaking response time, the fastest monitor ever, Silver/Black, MagicTune, MagicBright 2, Analog/Digital, TCO'99, LS17BIDKSV The best monitor for gaming and multimedia -->2440kn(raj) --------------------------------------------- UKUPNO 10168kn Ukljucujuci hdd 40gb i lg cdrw iz starog kompa. Jos 1000 mi ostane za kućište,napajanje i hladenje... Sad mi recite komentare na kofiguraciju,i preporucite ove tri stvari koje mi flae,dali mi je dovoljno 1000kn za to. Zadnje izmijenjeno od: Shinobi1337. 21.08.2005. u 20:34. |
OMG, thats the funky shit
Lokacija: in The Republic of Peščenica
Postovi: 1,221
Bolje si uzmi u raju od pixelviewa 6800gt za 2165
the luda ribetna
Postovi: 3,952
MBO DFI LAN PARTY UT nF4 SLI-D, DDR, zvuk, S-ATA, FW, 2xG-LAN, PCI-E, s. 939 1446 links CPU AMD Athlon64 3200+, 2.0GHz, 64bit, L2 cache 512kB, socket 939, BUS 800MHz, 0,9®, Venice 1363 info gama RAM PC-3200, 1024MB, DDR, OCZ, KIT, Gold VX, DDR 400 MHz, 2x512MB 1709 links Cooler Arctic-Cooling Freezer 64, socket 754/939/940 157 links Hard disk Hitachi 160 GB Deskstar T7K250, 7200 RPM SATAII, 8 MB 687 autronic Kuciste COOLERMASTER Centurion 5, silver, CAC T05, MIDI, bez PS 396 links DVD-RW NEC ND 3540 386 autronic DVD ROM TOSHIBA 16x 48x, black, SD-M191T, bulk 136 links ASUS EXTREME N6800LE, GeForce 6800LE, PCI-Ex16 1673 diskont24 Monitor 19" Samsung 959NF, 110 kHz, 0.25mm, NaturalFlat 1715 links Labtec Internet Keyboard linsk 100 kuna Logitech mx 510 350 links 10118 kuna ili ako bas os ati MBO DFI LAN PARTY UT nF4 SLI-D, DDR, zvuk, S-ATA, FW, 2xG-LAN, PCI-E, s. 939 1446 links CPU AMD Athlon64 3200+, 2.0GHz, 64bit, L2 cache 512kB, socket 939, BUS 800MHz, 0,9®, Venice 1363 info gama RAM PC-3200, 1024MB, DDR, OCZ, KIT, Gold VX, DDR 400 MHz, 2x512MB 1709 links Cooler Arctic-Cooling Freezer 64, socket 754/939/940 157 links Hard disk Hitachi 160 GB Deskstar T7K250, 7200 RPM SATAII, 8 MB 687 autronic Kuciste COOLERMASTER Centurion 5, silver, CAC T05, MIDI, bez PS 396 links DVD-RW NEC ND 3540 386 autronic DVD ROM TOSHIBA 16x 48x, black, SD-M191T, bulk 136 links ASUS EAX800XL/2DTV, ATI RADEON X800 XL, PCI-Ex16 2165 raj Labtec Internet Keyboard linsk 100 kuna Logitech mx 510 350 links 10568 ![]() |
Postovi: 1,221
Napajanje CHIEFTEC 410W, 12cm vent., ATX2 ver 2.0 364,64 341,37 Kućište AeroCool AERO Engine JR., MIDI, silver, bez PS 540,73 506,21 Ventilator PAPST 80mm, 9dB, N/2GLLE 106,63 99,83 To ti je sve u linksu.
the luda ribetna
Postovi: 3,952
a sad na obrazlozenje: venice corovi su svi isti...tj razlika je samo u max mnozitelju...koji ti uopce ne treba...govorim iz iskustva!!!imao sam winchesterea 3500 i nons top mi je mnozitelj bio 9 a ne 11...3200 ima mnoziltej 10 da ti klok bude okrugao ![]() ploca je svakako dobar izbor tu nemam nikake zamjerke na tome. grafa i hard je tvoja odluka makar ti je sad najbolji izbog hitachi tj bivsi ibm...seagate novi je dosta glasniji makar nimalo slabiji ![]() kingston ima ecc sto ti jako usporava perfomanse...to da je stabilnost veca je...al nije vazno jer imas vx iliti utt zvucna ti netreba a crt 959no je 19" samsung i jedan od najboljih monitora ikada napravljen ![]() ![]() pa sad dali oces poslusat ili ne...tvoja je odluka...ja sam ti slozio 2 konfiguracije jace i brze od tvoje za jeftinije pare ![]() |
Postovi: 25
Dobro,uzmem slabiji procesor i jacu memoriju na svoju konfiguraciju.... Sto se tice monitora bas zelim lcd,nemam mjesta za crt.Ja mislim da je ovaj poprilicno dobar,pohvalili ga i na pcekspertu. Hvala na prijedlozima,ako se sjetite jos cega... Zasto mi zvucna ne treba?Cesto slusam mjuzu sa kompa,imam surround u sobi,pa mislim da je bolje koristit dobru zvucnu nego integriranu na ploci.Ili grijesim? Sto se tice tipkovnice i misa uzet cu Logitech MX3100. |
the luda ribetna
Postovi: 3,952
integrirani zvuk ti je vise nego dobar ![]() |
#8 | |
Cmdr. Lee Adama
Postovi: 47
#9 | |
a.k.a. LOPOV
Postovi: 2,022
ram pc-4400, 1024mb, ddr, corsair c25, kit, twinx, ddr 550 mhz, 2 x 512mb 1870kn
Zabranjene reklama u sigu. |
#10 | |
Postovi: 1,221
Postovi: 25
Sjetih se jos necega...Uzimam maticnu koja podrzava SLI,pa bi bilo glupo ne uzet graficku koja takodjer podrzava sli,pa da u buducnoxti kupim jos jednu i ugradim...sta vi preporucujete,da bude do 2 i pol milje? |
#12 | |
the luda ribetna
Postovi: 3,952
@ vas 2...kuciste je piranje ukusa...sto se tice mene sam si jako htio uzet ms-techovo lc401...ono zeleno...to je modersko kuciste al ga nema nigdje u hrvatskoj ![]() |
#13 | |
Postovi: 25
the luda ribetna
Postovi: 3,952
na asus stranici pise da podrzava le sli...al za to nisam siher...joj u pet sam imao jednu u rukama i nisam gledao ![]() ![]() |
#15 | |
Postovi: 1,221
#16 | |
Cmdr. Lee Adama
Postovi: 47
#17 | |
M.U.P.
Datum registracije: Sep 2004
Postovi: 2,277
6800le pci-e košta 1620kn
#18 | |
Cmdr. Lee Adama
Postovi: 47
#19 | |
the luda ribetna
Postovi: 3,952
![]() ![]() ![]() ps mrkonja le kolko ja znam nema sli(makar na stranici pise da ima) i stavio sam ju u prvu konfu ![]() |
#20 | |
Cmdr. Lee Adama
Postovi: 47
#21 | |
Postovi: 25
#22 |
Postovi: 25
Decki,jos jedna dilema... U hgspotu je Intel P4 HT 3.0 2Mb cache 1500 kn...popust... izmedju athlona 64 3200+ i njega,bolje athlon,jelda? |
#23 |
the luda ribetna
Postovi: 3,952
par puta ![]() |
#25 | |
the luda ribetna
Postovi: 3,952
![]() govori u svoje ime ![]() ja sam z aono kaj ej bolje ![]() |
#26 | |
Postovi: 1,221
#27 | |
Postovi: 2,458
#28 |
Postovi: 25
Konfiguracija mi se svela na ovo...komentirajte molim vas... MBO DFI LAN PARTY UT nF4 Ultra-D, DDR, zvuk, S-ATA, FW, 2xG-LAN, PCI-E, s. 939 CPU AMD Athlon64 3500+ BOX, socket 939, Venice, 2200MHz, 512kb c., FSB 800MHz Kućište COOLERMASTER Centurion 5, silver, CAC T05, MIDI, bez PS Napajanje CHIEFTEC 410W, 12cm vent., ATX2 ver 2.0 Cooler Arctic-Cooling Freezer 64, socket 754/939/940 VGA PCI-E ATI RADEON X800XT, 256MB DDR3, DVI, VIVO RAM PC-3200, 1024MB, DDR, Corsair, KIT, Value Select, DDR 400 MHz, 2 x 512MB HDD 160.0 GB MAXTOR, 8MB cache, Serial ATA, 7200, DiamondMax Plus 9 DVD±RW LG GSA-4163, 16x, black, Dual layer, DVD RAM |
#30 |
Strichek Moderator
Postovi: 9,343
uzmi rađe uz dvd rw još jednu optiku...
žmnpp |
